Несколько раз отправлял коммутатор в FATAL ERROR. Софт еще сырой. А платформа Marvel. Такая же как у Eltex MES1124. Ошибки в софте тянутся еще из SDK Marvel. Только Eltex их быстрее выявляет и правит. Не рекомендую.
01-Oct-2006 11:47:38 %Fiber-I-SFP-PRESENT-CHNG: gi1/1/4 SFP status is present.
01-Oct-2006 11:48:23 %SNMP-F-FTLERR: SNMP Package: SnmpCen Routine: 24 Location: 10 Error: Bad value returned by application: Size error: variabl8
***** FATAL ERROR ******
(warning: SYSLOGG_log_fatal should be used to log fatal errors, not SYSLOGG_log)
Reporting Task: SNMP.
Software Version: 3.0.10.1 (date  24-Feb-2014 time  11:12:39)
***** DEBUG *****
DEBUG LOG IS EMPTY
0x16ac20
0x167714
0x6fede0
0x4ac8a4
0x4b16cc
0x4b2060
0x4b1b1c
0x46cf98
0x46d90c
0x450040
0x454cb4
0x45582c
0x43ae10
0x42286c
0x42d8ec
0x4369b4
0x436a2c
0x4387f4
0x4388b8
0x46a1b0
0x645fe4
0x121f18
*****************  SYSTEM RESET  *****************
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.2.1 Built  06-Sep-2013  16:39:03
console(config)#no ip dhcp snooping vlan 22
console(config)#no ip dhcp snooping vlan 21
01-Oct-2006 13:22:05 %3SWCOS-F-PCLSERVDELBEDARP: Delete not existed VLAN 21
Reporting Task: POLI.
Software Version: 3.0.11.7 (date  04-Jun-2014 time  13:10:43)
***** DEBUG *****
DEBUG LOG IS EMPTY
0x16ac20
0x167714
0x703fe4
0x4b1aa8
0x4b68d0
0x4b7264
0x8e27d4
0x8e30f4
0x5fdbd4
0x64b1e8
0x121f18
Networking device with CPU based on arm926ejs core. 256 MByte SDRAM.
I-Cache 16 KB. D-Cache 16 KB. L2 Cache 256 KB. Cache Enabled.
MAC Address   :  68:eb:c5:11:39:c0.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%
Decompressing SW from image-2
100%
OK
Running from RAM...
Board ID:0x0C
Copper ports:24, Combo ports:4
Device Type: 0xE77B11AB
*** Running  SW  Ver. 3.0.11.7  Date  04-Jun-2014  Time  13:10:43 ***
HW version is 00.01.10
Base Mac address is: 68:eb:c5:11:39:c0
Dram size is  : 256M bytes
Dram first block size is  : 208896K bytes
Dram first PTR is  : 0x3000000
Dram second block size is  : 4096K bytes
Dram second PTR is  : 0xFC00000
Flash size is: 32M
01-Oct-2006 13:11:10 %CDB-I-LOADCONFIG: Loading running configuration.
01-Oct-2006 13:11:10 %CDB-I-LOADCONFIG: Loading startup configuration.
The monitor is activated with Trace Enabled.
It will be automatic enabled after system reset also.
Device configuration:
Slot 1 - Angtel Topaz FE
-- Unit Standalone                --
  • 1 month later...
В апреле-мае этого года проведены многочисленные тесты коммутаторов Топаз на сетях операторов в различных сервисных моделях.
Имевшиеся ранее проблемы устранены.
Берите версии софта 2015 года.
Ангстрем-Телеком, вам бы сайт более информативный сделать с реальными фотографиями коммутаторов, как у длинка или как элтекса. Софт и ченджлоги сразу бы выкладывали на сайте.
  • 2 weeks later...
  • 3 weeks later...
Версии софта высылаются только по личному обращению.
Как я уже сообщал, софт досконально отшлифован в соответствии с наработанным опытом применения на различных сервисных моделях.
А теперь по конструкции.
Конструкция коммутаторов доработана под самые изысканные запросы.
Изменения:
- съемно-поворотные уголки - можно крепить на стену,
- крайне малые габариты (глубина всего 153), можно легко устанавливать в любую стойку,
- готовность к установке PoE, причем РоЕ по всем портам устанавливается без изменения габаритных размеров.
post-129559-000436000 1443536916_thumb.jpg.
Вот это и убивает всю веру в производителя.
Что мешает выложить софт на FTP, как это делают все вменяемые люди?
Конкуренты заберут?
Да. Абсурд.
Конкуренты заберут?
А как ты думал... Все охотятся на тайные прошивки...
Только лохи на сайте выкладывают новые прошивки с описанием изменений...
А вообще это показывает что софт не допилен, если каждый пшик выкладывать изменения- то сразу видно что сырое... А так клиент позвонил- ему сбросили... Возможно даже и не самый свежий, а только с его нужными исправлениями...
Спрятаный софт (если конечно, вы не компания уровня циски), говорит о том, что девайс ваш полнейший референс, и ничего такого, что бы не стыдно в этом софте было показать публике, у вас нет.
А смысл смотреть софт если коммутаторов нет? Вот пусть dmvy обновит и напишет как оно сейчас по сравнению с прошивками 2014 года.
Циска кстати тоже очень медленно баги исправляет, а некоторые так и не исправляет даже до EOL. Сколько они NAT "лечили" для 1000-ой?
Ну так если коммутатор полный референс, только корпус другой, то софт можно "посмотреть" и на любом совместимом. Этого и боятся скорее всего.
Зависит от того, насколько вы толстый клиент, как и везде.
Самое смешное, что где-то так и есть. У мну самая безбажная прошивка на зюкселевый коммутатор получена методом легкого шантажа. :-)
А что за коммутатор?
3500-24
Но память все равно течет. При наличии снупинга перегрузка раз в 200 дней желательна.
  • 2 weeks later...
Получили на тест коммутаторы ТОПАЗ. Интересные с точки зрения монтажа: один коммутатор в сборе в ящике с ИБП, второй для частников на 8 портов в герметичном боксе. Но если бы внутри была бы циска или хотя бы Qtech(SNR), то взяли не задумываясь.
Сиськовед, 8 портовый (Топаз-1О-8Е) в герметичном у меня уже полтора года лежит, так никуда и не поставили. Из мелкого что не понравилось: размещение COM порта, DSL разъем мешал воткнуть шнурок. А ip по умолчанию у коммутатора не было.
На до бы его куда-то поставить на боевой режим, да вот перешли на оптику до дома в частном секторе + монтажникам не понравилось что надо забивать витую пару в плинты.
