  • 2 months later...
  • Replies 110
  • Created
  • Last Reply
Top Posters In This Topic
Solution to enable Ovislink wl-5460ap upgrade:
Login via serial console
Command "flash" can be used to change builtin parameters. Change network interface mac addreses to original (written on ap case)
So:
; Ethernet LAN address
flash set HW_NIC0_ADDR 00e098940215
flash set HW_NIC1_ADDR 00e098940216
; WLAN0 interface. Note: "WLAN0" means 8186 embedded wlan controller
flash set HW_WLAN0_WLAN_ADDR 00e098940215
There is also many other parameters that can be listed by "flash all" command and changed via "flash set".
P.S. Very big thanks to dgreen - i had same problems and this thread solved them! Sucessfully built jtag interface and now i know how to solder two wires in 1mm :)
To others - if jtag only sometimes detects cpu and flash, is "No processor access" errors - you have problems with cable - try unbuffered, simpler interface (only limited to 15cm).
  • 2 weeks later...
When you say login via serial console, that means by max232, right? When i do that and press ESC on boot, i get terminal, but flash command is not working, says unknown command. Only ipconfig works, and by typing ? it lists some commands but not flash command. So, where i type that flash command?
EDIT: stupid me, just had to hit ENTER, sorry
I see you use same mac address for etho0 and wlan0, shouldnt wlan0 be in your case xxxxx:17? Because i do rtl8186 full dump it has all 3 mac addresses different. Thanx.
Cool stuff in there, i saw txpower can be set, wuold it work?
One more think, how can i make a backup of full flash, so i have this one with my mac address in it? Thanx
Edited by Imlek
  • 2 weeks later...
Исче один, пока непронятный, глюк.....
Проверяю с прошивкой 5460APv2_e5 в режиме Universal Repeater, пока взял от тестовой базы с прошивкой v3.2.1.3.9eu, вобчем пашет, но в логах базы наблюдаю постоянный реконнект. Broadcast SSID естессно включен. Впереди перепрошивка базы и проверка на реальной.
Эксперемент продолжается, клиент(репитер) перешит на 5460APv2_e8, изменений не замечено, окромя одного момента (жаль на старой прошивке не попробовал), в режиме клиента никаких проблемм не наблюдается, только в режиме универсального репитера - база показывает что клиент отпадает четко каждые 6сек. Выходит что бок в реализации именно репитера......
З.Ы. Периодически, после реконнекта, база пишет в лог следующие строчки
0day 00:59:27 wlan0: A wireless client is associated - CLIENT MAC
0day 00:59:27 wlan0: A expired STA is resumed - CLIENT MAC
Что бы это значило?
Edited by Gadzila
  • 1 month later...
  • 3 months later...
  • 3 months later...
Не знаю как не работает, но два компа соединенные через AP 5460 великолепно видятся между собой даже в мелкософтовской сети.
Подскажите, другая проблема. Иногда по второму порту сеть подвисает, спасает только сбос, причем только через ВЕБ, просто выключить-включить питание помогает очень редко. И какая из прошивок сейчас актуальная, у меня стоит v3.2.1.3.9e_b[2], иногда теряет сеть, особенно когда солнце ((((
Спасибо
  • 1 year later...
Народ помогите из wl-5460ap V2 прошил ital8186-modificado потом сделал upfirmware файлом Intermediate-firmware.bin и окончательно зашил WL-5460APv2e11_EU_httpupgrade всё роботаёт.
Меняю настройки в Client mode всё харашо сохраняет но как поменяю ip у lan interface setup тоже работает пока не выключу модем, я после включения на настроений ip 10.3.253.78 зайти не могу.
В свойствах сетевой плати прописываю вроде всё верно.
