Добрый день ..
Cisco IOS Software, C890 Software (C890-UNIVERSALK9_NPE-M), Version 15.2(4)M5, RELEASE SOFTWARE (fc2)
 c890-universalk9_npe-mz.152-4.M5.bin
Напрямую проверяю закачку с yandex.disk ~100 мбит/с , после циски ~20 мбит/с
r1#sh run
Building configuration...
Current configuration : 7529 bytes
! Last configuration change at 11:35:13 UTC Fri Jul 3 2020 by admin
version 15.2
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
hostname r1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 F
aaa new-model
aaa authentication login default local
aaa authorization network default local
aaa session-id common
no ip source-route
ip dhcp excluded-address 192.168.99.1
ip dhcp excluded-address 192.168.99.11 192.168.99.100
ip dhcp pool test
 import all
 network 192.168.99.0 255.255.255.0
 default-router 192.168.1.1
no ip bootp server
no ip domain lookup
ip domain name xxxx.ru
ip cef
no ipv6 cef
multilink bundle-name authenticated
vpdn enable
vpdn-group 1
 ! Default PPTP VPDN group
 accept-dialin
  protocol pptp
  virtual-template 1
crypto pki trustpoint TP-self-signed-3951281973
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3951281973
 revocation-check none
 rsakeypair TP-self-signed-3951281973
crypto pki certificate chain TP-self-signed-3951281973
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
        quit
license udi pid CISCO892-K9 sn FCZ17539076
license accept end user agreement
redundancy
interface Tunnel1
 ip address 10.10.149.2 255.255.255.252
 ip mtu 1500
 tunnel source GigabitEthernet0
 tunnel mode ipip
 tunnel destination XXXXXXXXX
interface Tunnel3
 ip address 192.168.198.1 255.255.255.252
 tunnel mode ipip
 tunnel destination XXXXXXXXXXX
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 no ip address
interface FastEthernet5
 no ip address
interface FastEthernet6
 no ip address
interface FastEthernet7
 no ip address
interface FastEthernet8
 no ip address
 shutdown
 duplex auto
 speed auto
interface Virtual-Template1
 ip unnumbered GigabitEthernet0
 peer default ip address pool vpn
 no keepalive
 ppp authentication ms-chap ms-chap-v2 chap
interface GigabitEthernet0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 description LAN_IN
 ip address 192.168.99.1 255.255.255.0
 ip nat inside
ip local pool vpn 192.168.99.230 192.168.99.235
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip forward-protocol nd
ip nat source list 1 interface Vlan1 overload
ip nat inside source list 1 interface GigabitEthernet0 overload
ip nat inside source static tcp 192.168.99.15 80 XXXXXXXXX 80 extendable
ip route 10.10.13.0 255.255.255.0 Tunnel1
ip route 192.168.16.4 255.255.255.255 Tunnel3
access-list 1 permit 192.168.99.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
no cdp run
control-plane
mgcp profile default
banner exec ^C
% Password expiration warning.
^C
banner login ^C
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
line aux 0
line vty 0 4
 access-class 23 in
 privilege level 15
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
end
  • Replies 52
  • Created
  • Last Reply
Top Posters In This Topic
скачать честно моей модели я не нашел конкретики, кроме каких то абстрактных графиков ..
но при этом sh processes cpu sorted ... CPU utilization for five seconds: 23%/20%; one minute: 4%; five minutes: 3%
по памяти вроде тоже порядок .. я бы не сказал, что она сильно устала ..
4 minutes ago, zhenya` said:
ip nat source list 1 interface Vlan1 overload лишнее
Согласен, это я разные варианты пробовал ..
r1#show proc cpu sort 5sec
CPU utilization for five seconds: 23%/19%; one minute: 9%; five minutes: 4%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 106       69272       28902       2396  1.51%  1.25%  1.24%   0 COLLECT STAT COU
   6        7300         879       8304  0.87%  0.15%  0.12%   0 Check heaps
 116           4      741233          0  0.31%  0.23%  0.18%   0 Ethernet Msec Ti
  31         976         223       4376  0.15%  0.28%  0.21%   0 Exec
 143           0      180244          0  0.07%  0.03%  0.02%   0 IPAM Manager
 290           0      180390          0  0.07%  0.01%  0.00%   0 MMON MENG
 371           4       11281          0  0.07%  0.00%  0.00%   0 IP NAT Ager
 366           0      180327          0  0.07%  0.04%  0.05%   0 PPP Events
  77           4        1157          3  0.07%  0.00%  0.00%   0 Compute load avg
 365           8      180327          0  0.07%  0.08%  0.07%   0 PPP manager
  11           0           1          0  0.00%  0.00%  0.00%   0 License Client N
Посмотрел таблицу производительности и  расстроился ..  WAN 15 очков :((
По итогу вообще все интересно стало ..
1. Замер Яндекс.Интернетометр (через Cisco), скорость ~24 мбит/с
2. Закачка с Disk.Yandex (через Cisco), скорость ~2.9 МБ/с
3. Замер через Speedtest (через Cisco) ~95 мбит/с
4. Загрузка с Google Disk (через Cisco) ~10 МБ/с
А теперь самое интересно:
5. Замер Яндекс.Интернетометр (напрямую в ПК), скорость ~95 мбит/с
6. Закачка с Disk.Yandex (напрямую в ПК) скорость ~10 МБ/с
7. Замер через Speedtest (напрямую в ПК) ~95 мбит/с
8. Загрузка с Google Disk (напрямую в ПК) ~10 МБ/с
И еще, пробовал "no ip cef"  .. нагрузка на ЦПУ 80% .. и сразу падает скорость до ~20 мбит/с на всех тестилках и загрузках ..
Не могу понять в чем может быть проблема ?
Edited by serg999
10 часов назад, serg999 сказал:
Npe это non payload encryption, Вы строите туннели какие то?
No ip cef не надо делать.
Пробовали торрент файлик качнуть? Или взять iperf и протестировать до публичных серверов, 75 мбит она точно должна качать
Ps, часто облачные сервисы использую для обмена, они прям плохо в последнее время работают
Туннели есть, но во первых они чистыq GRE без шифрования ... во вторых я их отключил ... результата это не дало ..
ip cef отключал для проверки что пойдет нагрузка на проц ..
торрент попробовал выше 3 МБ/с не поднимается :(
Насчет облачного сервиса ... подключаю ПК напрямую ... и пров выдает заявленную скорость, а через циску нет ...
17 hours ago, serg999 said:
Добрый день ..
Настоятельно рекомендую обновить IOS: https://mfd.sk/fneQSs-7u3beQaA2MHz_xCeX
Не знаю как в 15.2.4M5, а в предыдущем M4a есть баг с таблицей маков.
Я не кошковод, но:
1. убедитесь что киска выше IP не лезет и просто перекладывает пакеты, без всяких проверок валидности их содержимого
2. что нет ошибок на портах со всех сторон: и на киске, и на коммутаторе и на сетевухе компа
3. убедитесь что у кошки не переполняются никакие буффера
4. посмотрите на flow control на кошке и поиграйте с ним, на обоих линках
PS: кошку на помойку, какойнить тплинк + опенврт зарулят лучше.
Делал когда-то мелкий тест. Некоторые данные остались.
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.2(4)M8, RELEASE SOFTWARE (fc1)
iperf3 -c iperf.volia.net
Connecting to host iperf.volia.net, port 5201
[  4] local 192.168.100.27 port 49176 connected to 77.120.3.236 port 5201
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.01   sec  4.25 MBytes  35.2 Mbits/sec
[  4]   1.01-2.01   sec  4.88 MBytes  41.0 Mbits/sec
[  4]   2.01-3.01   sec  5.50 MBytes  46.2 Mbits/sec
[  4]   3.01-4.01   sec  5.75 MBytes  48.3 Mbits/sec
[  4]   4.01-5.01   sec  5.75 MBytes  48.3 Mbits/sec
[  4]   5.01-6.01   sec  5.75 MBytes  48.3 Mbits/sec
[  4]   6.01-7.00   sec  5.75 MBytes  48.3 Mbits/sec
[  4]   7.00-8.00   sec  5.75 MBytes  48.3 Mbits/sec
[  4]   8.00-9.00   sec  5.50 MBytes  46.2 Mbits/sec
[  4]   9.00-10.02  sec  5.75 MBytes  47.6 Mbits/sec
[  4]   0.00-10.02  sec  54.6 MBytes  45.8 Mbits/sec                  sender
[  4]   0.00-10.02  sec  54.6 MBytes  45.8 Mbits/sec                  receiver
iperf Done.
                     4444444444
      222222222288888999991111111111222222222222222222221111122222
  100
   90
   80
   70
   60
   50                *****
   40                **********
   30                **********
   20                **********
   10           ***************
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
Скорость по тарифу была 50 Мбит. Интерфейс использовался Fa8. А подключение pppoe.
Спидтест, насколько помню, показывал несколько выше результаты, чем тарифная скорость.
Такие косяки с любым оборудованием могут быть, а то что пока не могу понять где "горлышко бутылки" это не повод для замены ..
да и 890 железяка с учетом того что она БУ на наге  ~14 тыр как то косвенно подталкивает разобраться :)
Может еще можно, что то выключить ?
GigabitEthernet0 is up, line protocol is up
  Internet address is XX.XX.XX.XX/23
  Broadcast address is 255.255.255.255
  Address determined by DHCP
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is enabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
  Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
  Output features: Post-routing NAT Outside, Common Flow Table, Stateful Inspection, NAT ALG proxy
  IPv4 WCCP Redirect outbound is disabled
  IPv4 WCCP Redirect inbound is disabled
  IPv4 WCCP Redirect exclude is disabled
Vlan1 is up, line protocol is up
  Internet address is 192.168.99.1/24
  Address determined by non-volatile memory
  MTU is 1500 bytes
  IP Null turbo vector
  Network address translation is enabled, interface in domain inside
  Input features: Common Flow Table, Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
  Output features: NAT Inside, Common Flow Table, Stateful Inspection, NAT ALG proxy
Протестил на:
Cisco 892 (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.9(3)M1, RELEASE SOFTWARE (fc1)
1. https://www.speedtest.net/ru/result/9714310428
2.
.\iperf3.exe -c ping.online.net -P 4
Connecting to host ping.online.net, port 5201
[  4] local 10.10.0.115 port 64873 connected to 62.210.18.40 port 5201
[  6] local 10.10.0.115 port 64874 connected to 62.210.18.40 port 5201
[  8] local 10.10.0.115 port 64875 connected to 62.210.18.40 port 5201
[ 10] local 10.10.0.115 port 64876 connected to 62.210.18.40 port 5201
[  4]   0.00-60.01  sec   104 MBytes  14.5 Mbits/sec                  sender
[  4]   0.00-60.01  sec   104 MBytes  14.5 Mbits/sec                  receiver
[  6]   0.00-60.01  sec   190 MBytes  26.6 Mbits/sec                  sender
[  6]   0.00-60.01  sec   190 MBytes  26.6 Mbits/sec                  receiver
[  8]   0.00-60.01  sec   190 MBytes  26.5 Mbits/sec                  sender
[  8]   0.00-60.01  sec   190 MBytes  26.5 Mbits/sec                  receiver
[ 10]   0.00-60.01  sec   191 MBytes  26.7 Mbits/sec                  sender
[ 10]   0.00-60.01  sec   191 MBytes  26.7 Mbits/sec                  receiver
[SUM]   0.00-60.01  sec   675 MBytes  94.4 Mbits/sec                  sender
[SUM]   0.00-60.01  sec   675 MBytes  94.4 Mbits/sec                  receiver
Что-то у вас с железкой совсем не так. Надо обнулять. Но совет @SOFTOLAB - одобряю, железкам оным на пенсию пора было еще лет пять назад.
Мда ... время будет вечерком попробую сброс сделать ..
#sh processes cpu
CPU utilization for five seconds: 10%/8%; one minute: 3%; five minutes: 2%
   1          16          83        192  0.00%  0.00%  0.00%   0 Chunk Manager
   2          44       33625          1  0.00%  0.01%  0.00%   0 Load Meter
   3           0           1          0  0.00%  0.00%  0.00%   0 LICENSE AGENT
   4           0           1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
   6      219244       25608       8561  0.00%  0.09%  0.10%   0 Check heaps
   7          56        2820         19  0.00%  0.00%  0.00%   0 Pool Manager
   8           0           2          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
   9           0           2          0  0.00%  0.00%  0.00%   0 Timers
  10           0         122          0  0.00%  0.00%  0.00%   0 WATCH_AFS
 --More--
