После пропадания питания Ericsson Smartedge SE100 не загрузился. Подозреваем, что слетела информация на флешке CompactFlash. При загрузке в логе получаем сообщения, приведены ниже. Кто-то сталкивался, возможно ли восстановить?
Bootstrap 2.0.1.4 PRODUCTION RELEASE
Copyright © 1997-2007 by Redback Networks, Inc.
Compiled 2007-Jan-16 20:37:15 GMT by Release Team
Primary Bootstrap: main is running; startType = 2
PPC0 reboot reason: Power-on reset
NMI reason(s): (none)
PPC1 reboot reason: Power-on reset
[00]: 80 08 07 0d 0b 02 48 00 - 04 60 70 02 82 08 08 01
[10]: 0e 04 0c 01 02 20 c0 75 - 70 00 00 48 30 48 2a 80
[20]: 80 80 45 45 00 00 00 00 - 00 3c 48 30 2d 55 00 00
[30]: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 10 7a
[40]: 00 00 00 00 00 00 00 00 - 01 41 4d 50 33 37 31 44
[50]: 32 38 32 33 58 54 35 4e - 2d 43 42 33 00 11 39 30
[60]: 35 37 32 30 00 00 00 00 - 00 00 00 00 00 00 00 00
[70]: 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00
DRAMINIT: detected 1024 MB
DRAMINIT: DRAM Data line test
DRAMINIT: DRAM Address line test
DRAMINIT: DRAM ECC scrub...verify...
DRAMTEST: Short test
Bootstrap: detected 1024 MB of DRAM
OFWBIN_ldinfo = 0xff8961a0 (48)
._lowest = 0x5000000
._highest = 0x5418fe0
._text = 0x5000000
._etext = 0x50ccec0
._data = 0x50ccec0
._edata = 0x50d6f20
._bss = 0x50d6f20
._end = 0x5418fe0
._entry = 0x5000000
OFWZBIN
cmp_base = 0xff8961d0
cmp_size = 0x5c98a
uncmp_size = 0xd6f20
uncmp_cksum = 0x86c6a053
OFWBIN_ZBIN: being decompressed
OFWBIN_BIN: entire loaded region being flushed
OFWBIN_BIN: entry being jumped to
OpenFirmware 2.0.1.4 PRODUCTION RELEASE
Compiled 2007-Jan-16 20:35:23 GMT by Release Team
Primary OFWBIN: main is running; startType = 2; flags = 0; dramSize = 1024 MB
Starting PPC1...Success!
PPC0 init: sdram size=1024, boot_type=0x2,
PIR=0x00000000, MSR=0x00002000, machine check disabled.
L1 cache enabled.
Initializing L2 Cache...done
Installing package root...done
Installing package failsafe...done
Installing package powerpc_cpu...done
Installing package display...done
Installing package openprom...done
Installing package client-services...done
Extending package /openprom with SE PROM properties...done
Extending package /openprom/client-services with SEOFW methods...done
Installing package memory...done
Installing package flash...done
Initializing /options from nv config var...done
Installing package deblocker...done
Installing package disklabel...done
Installing package ide...done
Installing package eeprom...Management port MAC address = 00:30:88:1c:f9:df
done.
Installing package ethernet ...done
Installing package obptftp...done
Extending package /chosen with SE properties...Done
loading System FPGA from bootrom...Checksum verified.
Verifying shark fpga file: Rev 9
shark FPGA downloaded, verifying...done.
AC power input status OK
Power Supply 12VDC status indicates OK
Initializing CF disks...done
Welcome to SmartFirmware for Redback Networks, PowerPC version 2.0.1.4
SmartFirmware Copyright 1996-2000 by CodeGen, Inc.
All Rights Reserved.
Minikernel Version: 2.6
Executing POST
Sat 10/03/2015 9:57:10
Internal Temp = 25 C
PPC0 Temp = 44 C
IPPA Temp = 28 C
Supply 1.1v reads 1.096v
Supply 1.2v reads 1.196v
Supply 1.5v reads 1.506v
Supply 1.8v reads 1.799v
Supply 2.5v reads 2.502v
Supply 2.6v reads 2.608v
Supply 3.3v reads 3.321v
Supply 12.0v reads 12.031v
Fan 1 tach speed: 4326 RPM
Fan 2 tach speed: 4326 RPM
Fan 3 tach speed: 4326 RPM
Fan 4 tach speed: 4687 RPM
Fan 5 tach speed: 4440 RPM
PASSED Loop 1 of 1, 2015/10/03 09:57:12
POST PASSED
Auto-boot in 1 seconds - press se* to abort, ENTER to boot: inflating image from 0x560001F, 10237015 bytes, to 0x5FC3476, 64031858 bytes
copying inflated image from 0x5FC3476, to 0x5600000, 64031858 bytes
Flushing caches...done
Creating vxWorks bootline...done.
Waiting for PPC1...ready to run.
Checksum verification succeeded.
loading System FPGA from Compact Flash...done
inflating image from 0x5600017, 40101 bytes, to 0x5609CBC, 212424 bytes
copying inflated image from 0x5609CBC, to 0x5600000, 212424 bytes
Not reloading System FPGA, versions match.
launching (entry=0x05a00000)...
MPSC Lives!
SEOFW: bound to kernel printf()
OFW VERSION: PowerPC,rev2.0.1.4
MINIKERNEL VERSION: 2.6
BOOTPATH: /ide@0/disk@1,0:a
BOOTARGS: /p01/netbsd
BOOTDIR: /p01
NetBSD 1.5.3 (CUSTOM_SE100) #1: Thu Apr 16 04:33:45 PDT 2015
sysbuild@eussjlx7008.sj.us.am.ericsson.se:/workspace/sysbuild/RBS/reboot_12119/SE/obj/netbsd-kernels/CUSTOM_SE100
CPU: 7447 (Revision 101)
total memory = 939 MB
avail memory = 769 MB
using 1024 buffers containing 4096 KB of memory
Dumpspace: 0xe90f6000
The controller card is in slot 1
mainbus0 (root)cpu0 at mainbus0
L2CR: 0xC0000000: : unknown size Flow-through synchronous burst SRAM with parity backside cache enabled
vxmem0 at mainbus0gt0 at mainbus0gtpci0 at gt0obio0 at gt0obio1 at gt0wdc1 at obio1
Establishing IRQ 71 of type 3 level 6, func 0x5a070c0 arg 0xe0fe1cb0
Orig CFB Control Status Reg 0
wdc1:0: before reset, st0=0x50, st1=0x0
wd1 at wdc1 channel 0 drive 0: <SMC512BFI6E> lba addressing
<ST0B8365730000067708> <CF060926>
wd1: drive supports 1-sector pio transfers
wd1: 488 MB, 993 cyl, 16 head, 63 sec, 512 bytes/sect x 1000944 sectors
wd1: drive supports PIO mode 4, DMA mode 2
conf[0] = 0x88104821
Orig CFB PIO Timing Reg 9480c82
CFB PIO Timing Reg 88104821
extcf0 at obio1External disk presence status 1cd
wdc2 at obio0ata on obio
Establishing IRQ 66 of type 3 level 6, func 0x5a070c0 arg 0xe0fe18b0
Orig CFX Control Status Reg 0
wdc2:0: before reset, st0=0x50, st1=0x0
wd2 at wdc2 channel 0 drive 0: <SMART CF> lba addressing
<multi_single> <00001011680001986691> <1002092P>
wd2: drive supports 1-sector pio transfers
wd2: 977 MB, 1986 cyl, 16 head, 63 sec, 512 bytes/sect x 2001888 sectors
wd2: drive supports PIO mode 4, DMA mode 2
Orig CFX PIO Timing Reg 89480c82
CFX PIO Timing Reg 88104821
Establishing IRQ 64 of type 3 level 6, func 0x5c006b8 arg 0x1
Establishing IRQ 65 of type 3 level 6, func 0x5c006b8 arg 0x2
Establishing IRQ 67 of type 3 level 6, func 0x5c006b8 arg 0x8
Establishing IRQ 68 of type 3 level 6, func 0x5c006b8 arg 0x10
Establishing IRQ 75 of type 3 level 6, func 0x5c006b8 arg 0x800
SHARK FPGA: Rev 9, base = 0xe48c5000 status = 0, flag = 0x1
obio2 at gt0rtc0 at obio2ds3050 reg attached @ 0xe90f8000
Current date : century : 21, 10/03/15 (Sat)
Current time : 09:57:38
obio3 at gt0obio4 at gt0gfe0 at gt0gfe unit # 0
gfe attach called
: address 00:30:88:1c:f9:df, pcr 0x3c00000, pcxr 0, psc 0x1e20218, psr 0x1c2c , phy 1 (mii)
pcr 0x80, pcxr 0, psc 0x1e0021e
brgphymatch...
OUI = 2072, MODEL = 12brgphy0 at gfe0 phy 1OUI = 2072, MODEL = 12: Media interface
: BCM5461 1000BASE-T media interface, rev. 1
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT-FDX, auto
Establishing IRQ 32 of type 3 level 5, func 0x5bed73c arg 0xe0fe6800
gfe0: interrupting at 32+0
gtmpsc0 at gt0 at 0xe91fb000/0x8afa000Establscc0 at mainbus0 Local SCC @ 0x60000000 Remote SCC @ 0x00000000
Mapping in 0x00200000 bytes starting @ 0x64000000 for PTD driver (pa=0x38000000)
ipc0 at mainbus0Mapped Shared Memory Block @ PA 0x5500000 to VA 0x5500000
Establishing IRQ 60 of type 3 level 5, func 0x5bdbbe0 arg 0x0
flashattach: configuring 1 flash device(s)
PPA Transport Driver v. 2.0
ptd: Initializing SCC SDRAM 0x64001000 size 0x1ff000...Done
## ptdmem_add: npg 480 size 1966080 bmapsz 60 (pg 0xe0fde680) ##
pdtattach: configuring 2 pdt devices
ephemeral range was 49152-65535, new range is 56608-65535
Initializing RTC NVRAM LOG area @ f4001400 succeeded
scc_init: Mapped vxWorks memory console @0xe920d000
Kick_starting vxWorks ....
vxWorks is booting!!!!!
Waiting for Vxworks to boot ...
.VX Redundancy state: ### VX_IS_ACTIVE TRUE ###
Notifying all processes of ACTIVE status
VX Redundancy state: ### VX_ACTSTB_DECIDED TRUE ###
VX Redundancy state: ### VX_BOOT_DONE TRUE ###
start using scc to keep time...
I am active
set max route entry to 190650
booted_partition: 0
boot device: wd1
root on wd1a dumps on wd2b
mountroot: trying msdos...
mountroot: trying nfs...
mountroot: trying ffs...
RTC and System clocks are different. Check and fix the system time afterwards.
root file system type: ffs
init: copying out path `/p01/sbin/init' 15
root_device on / type ffs (local, read-only)
mfs:9 on /dev type mfs (asynchronous, local)
mfs:11 on /tmp type mfs (asynchronous, local)
** /dev/rwd1a
** Last Mounted on /
** Root file system
** Phase 1 - Check Blocks and Sizes
INCORRECT BLOCK COUNT I=53831 (2 should be 0)
CORRECT? yes
** Phase 2 - Check Pathnames
** Phase 3 - Check Connectivity
** Phase 4 - Check Reference Counts
** Phase 5 - Check Cyl groups
FREE BLK COUNT(S) WRONG IN SUPERBLK
SALVAGE? yes
SUMMARY INFORMATION BAD
SALVAGE? yes
BLK(S) MISSING IN BIT MAPS
SALVAGE? yes
1335 files, 389080 used, 94999 free (119 frags, 11860 blocks, 0.0% fragmentation)
MARK FILE SYSTEM CLEAN? yes
***** FILE SYSTEM MARKED CLEAN *****
***** FILE SYSTEM WAS MODIFIED *****
Oct 3 09:58:01 init: Starting in normal mode
Oct 3 09:58:14 Redback /netbsd: Notifying all processes of ACTIVE status
Oct 3 09:58:14 Redback /netbsd: VX Redundancy state: ### VX_ACTSTB_DECIDED TRUE ###
Oct 3 09:58:14 Redback /netbsd: VX Redundancy state: ### VX_BOOT_DONE TRUE ###
Oct 3 09:58:15 Redback /netbsd: Set BSD Redundancy state: ### BSD_COPY_DONE TRUE ###
Oct 3 09:58:15 Redback /netbsd: VX Redundancy state: ### VX_BOOT_DONE TRUE ###
Oct 3 09:58:08 Redback init: bootdev: wd1
Oct 3 09:58:08 Redback init: checking status of vxWorks...
Oct 3 09:58:08 Redback init: Syncing time from RTC...
Oct 3 09:58:08 Redback init: Starting PM...
Oct 3 09:58:09 Redback init: IPNAT: unsupported platform 13
Oct 3 09:58:09 Redback init: Skip loading IPNAT rules
Oct 3 09:58:10 Redback mount_udrv: External disk integrity verified.
Oct 3 09:58:10 Redback mount_udrv: External disk mounted.
/md: write failed, file system is full
Oct 3 09:58:18 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:20 Redback /netbsd: pid 256 (exec_cli), uid 0: exited on signal 4 (core dumped)
Restarting console CLI....
Oct 3 09:58:20 Redback init: A core file of /usr/siara/bin/exec_cli was produced
Oct 3 09:58:21 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:21 Redback /netbsd: pid 258 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Oct 3 09:58:22 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:22 Redback /netbsd: pid 259 (exec_cli), uid 0: exited on signal 4 (core dumped)
Oct 3 09:58:22 Redback init: A core file of /usr/siara/bin/exec_cli was produced
Oct 3 09:58:23 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:23 Redback /netbsd: pid 260 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Oct 3 09:58:23 Redback /netbsd: VX Redundancy state: ### VERSION B3 TRUE ###
Oct 3 09:58:23 Redback /netbsd: VX Redundancy state: ### VX_IS_ACTIVE TRUE ###
Oct 3 09:58:23 Redback /netbsd: Notifying all processes of ACTIVE status
Oct 3 09:58:23 Redback /netbsd: VX Redundancy state: ### VX_ACTSTB_DECIDED TRUE ###
Oct 3 09:58:24 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:24 Redback /netbsd: pid 261 (exec_cli), uid 0: exited on signal 4 (core dumped)
Oct 3 09:58:24 Redback init: A core file of /usr/siara/bin/exec_cli was produced
Oct 3 09:58:25 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:25 Redback /netbsd: pid 262 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Oct 3 09:58:26 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:26 Redback /netbsd: pid 263 (exec_cli), uid 0: exited on signal 4 (core dumped)
Oct 3 09:58:26 Redback init: A core file of /usr/siara/bin/exec_cli was produced
Oct 3 09:58:27 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:27 Redback init: A core file of /usr/siara/bin/exec_cli was produced
Oct 3 09:58:28 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:28 Redback /netbsd: pid 265 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Oct 3 09:58:29 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:29 Redback /netbsd: pid 266 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Oct 3 09:58:30 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:30 Redback /netbsd: pid 267 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Oct 3 09:58:31 Redback /netbsd: VX Redundancy state: ### VX_AL_UP TRUE ###
Oct 3 09:58:31 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:31 Redback /netbsd: pid 268 (exec_cli), uid 0: exited on signal 4 (core dumped)
Oct 3 09:58:31 Redback init: A core file of /usr/siara/bin/exec_cli was produced
Oct 3 09:58:32 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:32 Redback /netbsd: pid 269 (exec_cli), uid 0: exited on signal 4 (core dumped)
Oct 3 09:58:32 Redback init: A core file of /usr/siara/bin/exec_cli was produced
Oct 3 09:58:33 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:33 Redback /netbsd: pid 270 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Oct 3 09:58:34 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:34 Redback /netbsd: pid 271 (exec_cli), uid 0: exited on signal 4 (core dumped)
Oct 3 09:58:34 Redback init: A core file of /usr/siara/bin/exec_cli was produced
Oct 3 09:58:35 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:35 Redback last message repeated 6 times
Oct 3 09:58:36 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:36 Redback /netbsd: pid 273 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Oct 3 09:58:38 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:38 Redback /netbsd: pid 274 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Oct 3 09:58:39 Redback /netbsd: uid 0 on /md: file system full
Oct 3 09:58:39 Redback /netbsd: pid 275 (exec_cli), uid 0: exited on signal 4 (core not dumped, err = 28)
Гляньте содержимое через кардридер на компе.
Могу предположить что не слетела, а забита логами/времянками под завязку.
Через картридер пытались смотреть - не видим файловую систему. Хотя берем обычную флешку КомпактФлеш - все нормально, читаем через картридер. Какая там, кстати, файловая система? Пробовали разные - не видим эту флешку.
Edited by resident_k
Freebsd попробуйте для чтения
Благодаря подсказкам, в т.ч. в личку полезную инструкцию прислали, мы продвинулись. Вроде бы, операционка установилась, но все равно есть ошибки. Похоже, что какая-то внутренняя флешка неисправна. Завтра продолжим разбираться.
Ну вот и конец мучений... проблема решена заменой всех трёх CF карт, и полной переустановкой софта... По порядку если вдруг чё...
Симптомы: Отвалились все интерфейсы (кроме консоли) SEOS не стартует.
Оказалось: Пошли по звезде основная CF карта (в коробке слот J17, карта по умолчанию - 525 МБ, карта в слоте J16 - 256МБ)
Отбросив количество дней, матов и попыток расскажу полный способ решения проблемы ( которая была у меня)
Лечение:
Куплены Все три карты под замену (менять так сразу) 1 Гб в торец, 512 и 256 в коробку
0. Один конец в mngmnt порт, второй к серваку.
1. Поднимаем у tftp и ftp сервер для того что бы с него слить всё что нам надо будет. Можно конечно залить SEOS на карту и вставить её в торец, но поскольку я далеко от сервака ,то через фтп проще)
2. Заливаем на tftp файлики для обновления OpenFirmware и Minikernel ( OFW-se100-2.0.1.4.primary.bin, se100-minikernel.p2.v7.bin)
3. Далее подключаемся через консольку видим приглашение "ok" вдуваем:
setenv ip-addr <свойip:маскаподсети>
setenv gateway-ip-addr <шлюз>
setenv server-ip-addr <ip адрес tftp сервера>
4. Сливаем на redback OFW(обязательно первым) и Minikernel . Если мы этого не сделаем есть вариант что SEOS не станет и будет ругать что мало места в /tmp
ok load net OFW-se100-2.0.1.4.primary.bin
sending tftp request for file 'OFW-se100-2.0.1.4.primary.bin'
ok update-bootrom
Processing bootrom image @0x5600000, 600976 bytes. Dest: Primary:
Format and compatibility verification succeeded.
Erasing bootrom...Programming bootrom...done
Лечение:
[code]setenv ip-addr <свойip:маскаподсети>
Сегодня тоже наступил на эту проблемы, аж 4 SE100, поковырял и нашёл в чём беда... в принципе всё можно удалённо решить, даже без ребута :)
1. Чистим tmp
start shell
cd /tmp/status
ls -l
rm evtmd
Там видим, кто сожрал всё место, у меня это evtmd. Я так же ещё пару файлов удалил, которые выделялись по объёму...
2.Далее рестартуем процессы, которые сожрали больше всего памяти, тут фаворит - rcm, так же ещё и evtmd, dhcp, stats и т.д.
process restart rcm
process restart evtmd
process restart dhcp
process restart stats
Всё беда прошла, можно сохранить конфиг. Пока полечил только один SE100, завтра ещё 2 планирую, отпишу о результатах...
У меня в логах :
%PUBSUB-6-INF: CLI-559 [rbnl_cache_initialize]: initializing PUBSUB, pid(559)
%SYSLOG-3-ERR: /netbsd: uid 0 on /tmp: file system full
%SYSSTAT-3-ERR: [evtmd] Unable to write to system status file(No space left on device): endpoint RBNEVT_00_CLI-559 is up
%SYSSTAT-3-ERR: [evtmd] Unable to write to system status file(No space left on device): endpoint RBNEVT_00_CLI-559 is blocked
%SYSSTAT-3-ERR: [evtmd] Unable to write to system status file(No space left on device): endpoint RBNEVT_00_CLI-559 is down
%SYSSTAT-3-ERR: [evtmd] Unable to write to system status file(No space left on device): de-registering client 00_CLI-555
%SYSSTAT-3-ERR: [evtmd] Unable to write to system status file(No space left on device): de-registering client 00_CLI-559
Судя по логам:
  1. у вас там файловая система UFS
  2. место закончилось на разделе.
Нужно почекать FS на FreeBSD, найти виновника и почистить место на разделе.
По инструкции, размещенной выше, доходим до п.4
ok update-bootrom
какая команда для обновления Minikernel?
пробуем install sys, видимо не правильно
дошли до установки СЕОС но установка долго стоит на одном месте после завершения скачивания:
Would you like to install from external disk (E) or ftp (F): F
Install from FTP
Enter IP address of server : 192.168.1.1
Enter username : anonymous
Enter path to release : /SEOS-se100-12.1.1.10p2.tar.gz
Enter install directory (p01/p02) : p01
ftping release...
Password for anonymous@192.168.1.1:
ftp://anonymous@192.168.1.1//SEOS-se100-12.1.1.10p2.tar.gz (67047K)
- [########################] 67047K | 49.93K/s
68656872 bytes transferred in 1342.94 sec (49.93k/sec)
Подскажите в где грабли?
Кто может помочь? Есть второй SE 100, такой же как и проблемный. Можно ли вынуть флешку внутреннюю из рабочего SE100 и скопировать на нерабочий? Но, при этом надо не завалить рабочий БРАС! Нужны советы.
  • 3 months later...
resident_k Добрый день. Ваша проблема решилась? У нас тоже умерла compact flash. Флешки заменили, все делаю по вышенаписаному мануалу. SEOS заливается без ошибок:
Would you like to erase the external disk(Y/N) : N
Would you like to download a new release(Y/N) : Y
Install from FTP
Enter IP address of server : 93.89.215.4
Enter path to release : SEOS-se100-6.5.1.4p2.tar.gz
ftping release...
Password for anonymous@93.89.215.4:
ftp://anonymous@93.89.215.4/SEOS-se100-6.5.1.4p2.tar.gz (51713K)
- [########################] 51713K | 116.72K/s 34031K | 124.14K/s
52954398 bytes transferred in 443.04 sec (116.72k/sec)
copying releases to appropriate compact flash....
processing dev.tar...done
processing packet.tar...done
processing installedOK.100...done
processing lc...done
processing limfpga...done
processing netop-release.inf...done
processing netsetup...done
processing packet.inf...done
processing ppa...done
processing release.inf...done
processing release2.inf...done
processing vxWorks.gz...done
processing vxinstalledOK...done
processing vxworks.inf...done
running MAKEDEV...done
Setting nvram parameters...done
done
Exiting System Install Script...
До этого пробовал залить SEOS-se100-11.1.2.4p2.tar.gz. Делаю ребут:
Auto-boot in 0 seconds - press se* to abort, ENTER to boot: -
PPC0 Primary OFWBIN Exception: (0x00600) Alignment
Frame = 0x05414F20, 0x00000000
R00 = 0x00000000 R01 = 0x05400540 R02 = 0x050D4EC0 R03 = 0xFFFFF007
R04 = 0x000000FF R05 = 0x0514BB90 R06 = 0x00000470 R07 = 0x00000000
R08 = 0x00000001 R09 = 0xFFFFF790 R10 = 0x050D0000 R11 = 0xFFFFFFFF
R12 = 0x050D4CEC R13 = 0x050DEF10 R14 = 0x054006E8 R15 = 0x050D0000
R16 = 0x00000200 R17 = 0x050D0000 R18 = 0x00000003 R19 = 0x0514B612
R20 = 0x0514A1E8 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
R24 = 0x00000000 R25 = 0x00000000 R26 = 0x00000000 R27 = 0x00000000
R28 = 0x00000000 R29 = 0x00000000 R30 = 0x00000000 R31 = 0x00000000
LR = 0x00000000 CR = 0x44044028 XER = 0x20000000 CTR = 0x00000000
PC = 0x00000000 SRR1 = 0x00002032 DAR = 0x050CAB1E DSISR = 0x00002611
RAM_EVLOG-INFO: Running bootstrap
RAM_EVLOG-INFO: Running Diag test: PPC DRAM ECC
RAM_EVLOG-INFO: Running primary OFW
RAM_EVLOG-SUMMARY:
total shown: 3
total logged: 3
alert total: 0
alert level: DBGERR or more severe
PPC0 enters sys_halt_machine.
Press Ctrl+W within 5 seconds to stop auto-reboot: **^W
И на этом застопорился. В гугле ничего нет по данным ошибкам. Интересно получилось ли у Вас нормально переустановить ОС?
Заранее спасибо.
пардон, не увидел что уже выкладывали прошлый опыт ))
все флэшки пробовали менять?
Да флешки пробовал менять все. Может OpenFirmware и Minikernel не дружат с версией SEOS которые я пробовал ставить? У нас есть еще один SE-100 рабочий. Выше спрашивали можно ли сделать копию флешек с рабочего?
Гугл на тему PPC0 enters sys_halt_machine. вообще ничего не знает (
Edited by cuzen
Ребят может я конечно чего-то не понимаю. Но почему вы не обратитесь в офф саппорт? Железка не из бюджетных, звоните и начинаете трахать саппорт до тех пор пока инженер не попросит удаленный доступ что бы починить все. Еще когда они только анонсировали эту хрень, позвонили к ним, они дали нам 2 фирмы дистрибьютора, созвонились, выклянчили самую вкусную цену на 16к субскрайберов. Оплатили по тем временам 9600$ и ждали месяц. Когда железка пришла, выяснилось что в коробке только брошюрка типа
- Вы стали счастливым обладателем мега железки, теперь ваш бизнес пойдет вверх и бла-бла-бла...
По наговскому мануалу стартанули ее, добрались до шага что бы забить лицензию. А ее нет. Звоним дистрибьютору
- Как нет? А вы хорошо смотрели? Точно нет, а может фломастером на корпусе написано, нет? А бумажки нет? Может на коробке, смотрели?
Звоню я в офф представительство и рассказываю что они шарагина контора, просят за железку туеву кучу денег и даже не рассказывают как запустить, ни примеров конфигурации ***я короче. После того когда я спросил как можно вернуть деньги обратно и куда выслать этот кусок дерьма. Они сразу запели по другому, созвонился менеджер, передал нам ключ в электронном виде и выслал в бумажном по почте, выслал кучу мануалов на русском языке, выслал самые последние прошивки. Когда я ему сказал что сильно много времени было потрачено в пустую и теперь мне некогда читать мануалы. Они начали по телефону рассказывать что и как делать.
Вывод такой, звоните в представительство, пусть выделают технаря и пусть чинят.
кард ридер и линук. при помощи dd сохраняем рабочие флешки на диск и потом заливаем в новые. Получается копия 1 в 1.
Спасибо, попробуем этот вариант. Отпишусь по результатам.
Всем привет. Через картридер с помощью dd залил с рабочих флешек на новые образы. Система грузится, но видимо в каком-то аварийном режиме. Ругается при загрузке на
Lookup for main RCM EP failed, rc -1
% ERROR: Router Configuration Module is not up
Configuration and most of execmode commands will not be available
Please log out and try again...
И консоль router#
Большая половина команд не доступна. Будем дальше пробовать взбодрить ОС.
в закрытом разделе форума поищите информацию, много уже у кого флэшка летела, у нас тоже недавно повредилась, восстанавливаем..
  • 7 months later...
Никто не знает где можно скачать SEOS-6.2.1.tar.gz? Или более ранние версии? Мы сдавали в сервисный центр проблемный SE-100. Нам его починили. Но при обновлении системы, консоль вылетела по таймауту, и снова слетела прошивка. И снова те-же проблемы при установке новой SEOS. Все ставится без ошибок, но при загрузке снова"PPC0 enters sys_halt_machine.
Press Ctrl+W within 5 seconds to stop auto-reboot: *^W
PPC0 Halted by sys_halt_machine. Ctrl+X to reboot control-plane."
И где и как посмотреть закрытый раздел форума. Не хочется линять снова на 200$, причем думаю что теперь придется платить со своего кармана. Как объяснить боссу что он снова сломался не знаю. (
Возможно boot loader не может запустить SEOS который я могу скачать. А это версия 6.5.1.4p2. После ремонта была более старая версия, вот и хочу найти её, попробовать.
Edited by cuzen
У Вас получилось восстановить? И если получилось, то по какой инструкции, которая выше в посте?
huavtor (27 июня 2015 - 18:36) писал:
Лечение:
ok update-bootrom
load net se100-minikernel.p2.v7.bin
ok write-kernel
Erasing minikernel...
Writing minikernel [1411242 bytes]...done
Minikernel Version: 2.7
5. Далее reload
6. Удаляем настройки. Без их удаления vxWorks не стартовал а плотно ругался
!!!controlled REBOOT from vxWorks with reason VX_REBOOT_ON_FATAL_EXCEPTION, requesting coredump!!!
Удаляем...
setenv ip-addr
ip-addr = <null>
gateway-ip-addr = <null>
server-ip-addr = <null>
7. Устанавливаем SEOS предварительно залитый на ftp при помощи команды
installsys
Starting System Install Script...
Вводим свой IP, маску, шлюз ( Странно, но даже если они бы ли бы у вас прописаны в системе, вводить их всё равно бы пришлось
Enter IP address : x.x.x.x
Enter netmask : 255.255.248.0
Enter gateway IP address : x.x.x.y
Configuring ethernet interface...
add net default:gateway x.x.x.y
Далее нас спросят хотим ли мы форматнуть наши карты, мы согласимся. (у меня карты новые там ничего нет, а в задумайтесь)
Checking for presence of hard disk...hard disk detected
Would you like to erase the vxWorks compact flash disk(Y/N) : y
formatting compact flash disk...done
Would you like to erase the BSD compact flash disk(Y/N) : y
formatting compact flash disk...10+0 records in
10+0 records out
655360 bytes transferred in 1 secs (655360 bytes/sec)
/dev/rwd1a: 377856 sectors in 1476 cylinders of 8 tracks, 32 sectors
184.5MB in 93 cyl groups (16 c/g, 2.00MB/g, 512 i/g)
super-block backups (for fsck -b #) at:
32, 4160, 8288, 12416, 16544, 20672, 24800, 28928,
32800, 36928, 41056, 45184, 49312, 53440, 57568, 61696,
65568, 69696, 73824, 77952, 82080, 86208, 90336, 94464,
98336, 102464, 106592, 110720, 114848, 118976, 123104, 127232,
131104, 135232, 139360, 143488, 147616, 151744, 155872, 160000,
163872, 168000, 172128, 176256, 180384, 184512, 188640, 192768,
196640, 200768, 204896, 209024, 213152, 217280, 221408, 225536,
229408, 233536, 237664, 241792, 245920, 250048, 254176, 258304,
262176, 266304, 270432, 274560, 278688, 282816, 286944, 291072,
294944, 299072, 303200, 307328, 311456, 315584, 319712, 323840,
327712, 331840, 335968, 340096, 344224, 348352, 352480, 356608,
360480, 364608, 368736, 372864, 376992,
done
Would you like to erase the hard disk(Y/N) : y
Согласимся загрузить новый релиз, потом вопрос откуда, и затем сетевые настройки
Would you like to download a new release(Y/N) : y
Enter IP address of server : IP фтп серва
Enter username : юзерфтп
Enter password : парольюзерафтп
Enter path to release :путь/к/релизу/SEOS-se100-12.1.1.8.tar.gz
Ждёмс...
Скрипт закончит, появиться приглашение
Затем reload и загрузимся мы уже с SEOS))))
Всем спасибо кто чем помог ))
k104x zstas dmvy _J_
Лечение:
ok update-bootrom
ok write-kernel
5. Далее reload
Удаляем...
setenv ip-addr
ip-addr = <null>
installsys
10+0 records out
done
Ждёмс...
Спасибо, так и делал все. Когда он пришел с ремонта, там был SEOS-6.1.3.3-Release. Найти бы такой-же, что-бы уже удостоверится что проблема не в загрузчике,SEOS-е. По выводу информации тоже нет ничего в интернете. А выводит он следующее:
PPC0 Fallback OFWBIN Exception: (0x00600) Alignment
Frame = 0x054175C0, 0x00000000
R00 = 0x00000000 R01 = 0x05402BE0 R02 = 0x050D7DC0 R03 = 0xFFFFF007
R04 = 0x000000FF R05 = 0x0514E1D0 R06 = 0x00000E30 R07 = 0x00000000
R12 = 0x050D7450 R13 = 0x050E1670 R14 = 0x05402D88 R15 = 0x050D0000
R16 = 0x00000200 R17 = 0x050D0000 R18 = 0x00000003 R19 = 0x0514DC52
R20 = 0x0514C828 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
RAM_EVLOG-INFO: Running fallback OFW
RAM_EVLOG-SUMMARY:
total shown: 3
total logged: 3
alert total: 0
дак похоже OFW и не загружаеться
ЗЫ Поковыряться на железке не могу, второй/резервный SE100 в ремонте все еще :(
