zulu_radist
Активный участник-
Публикации
671 -
Зарегистрирован
Посещение
Все публикации пользователя zulu_radist
accel pptpd
тему ответил в kisa пользователя zulu_radist в Программное обеспечение, биллинг и *unix системы
Пытаюсь спрыгнуть с родного pptpd на акцель, но выдает ошибку 691 [2012-10-15 20:33:46]: info: pptp: new connection from 172.17.13.22 [2012-10-15 20:33:46]: info: : recv [PPTP Start-Ctrl-Conn-Request <Version 1> <Framing 1> <Bearer 1> <Max-Chan 0>] [2012-10-15 20:33:46]: info: : send [PPTP Start-Ctrl-Conn-Reply <Version 1> <Result 1> <Error 0> <Framing 3> <Bearer 3> <Max-Chan 1>] [2012-10-15 20:33:46]: info: : recv [PPTP Outgoing-Call-Request <Call-ID 0> <Call-Serial aae4> <Min-BPS 300> <Max-BPS 100000000> <Bearer 3> <Framing 3> <Window-Size 64> <Delay 0>] [2012-10-15 20:33:46]: info: : send [PPTP Outgoing-Call-Reply <Call-ID 3> <Peer-Call-ID 0> <Result 1> <Error 0> <Cause 0> <Speed 100000000> <Window-Size 64> <Delay 0> <Channel 0>] [2012-10-15 20:33:46]: info: ppp0: connect: ppp0 <--> pptp(172.17.13.22) [2012-10-15 20:33:46]: debug: ppp0: lcp_layer_init [2012-10-15 20:33:46]: debug: ppp0: auth_layer_init [2012-10-15 20:33:46]: debug: ppp0: ccp_layer_init [2012-10-15 20:33:46]: debug: ppp0: ipcp_layer_init [2012-10-15 20:33:46]: debug: ppp0: ipv6cp_layer_init [2012-10-15 20:33:46]: debug: ppp0: ppp established [2012-10-15 20:33:46]: debug: ppp0: lcp_layer_start [2012-10-15 20:33:46]: info: ppp0: send [LCP ConfReq id=1 <auth MSCHAP-v2> <mru 1400> <magic 7c83e458>] [2012-10-15 20:33:46]: info: ppp0: recv [PPTP Set-Link-Info] [2012-10-15 20:33:46]: info: ppp0: recv [LCP ConfReq id=0 <mru 1400> <magic 6bdb4990> <pcomp> <accomp> < d 3 6 >] [2012-10-15 20:33:46]: info: ppp0: send [LCP ConfRej id=0 <pcomp> <accomp> < d 3 6 >] [2012-10-15 20:33:46]: info: ppp0: recv [LCP ConfReq id=1 <mru 1400> <magic 6bdb4990>] [2012-10-15 20:33:46]: info: ppp0: send [LCP ConfAck id=1 ] [2012-10-15 20:33:49]: debug: ppp0: fsm timeout [2012-10-15 20:33:49]: info: ppp0: send [LCP ConfReq id=1 <auth MSCHAP-v2> <mru 1400> <magic 7c83e458>] [2012-10-15 20:33:49]: info: ppp0: recv [LCP ConfAck id=1 <auth MSCHAP-v2> <mru 1400> <magic 7c83e458>] [2012-10-15 20:33:49]: debug: ppp0: lcp_layer_started [2012-10-15 20:33:49]: debug: ppp0: auth_layer_start [2012-10-15 20:33:49]: info: ppp0: send [MSCHAP-v2 Challenge id=1 <fbabc7cfa98bcb118e8fda6f73769251>] [2012-10-15 20:33:49]: info: ppp0: recv [PPTP Set-Link-Info] [2012-10-15 20:33:49]: info: ppp0: recv [LCP Ident id=2 <MSRASV5.10>] [2012-10-15 20:33:49]: info: ppp0: recv [LCP Ident id=3 <MSRAS-0-ZULU_RADIST>] [2012-10-15 20:33:49]: info: ppp0: recv [MSCHAP-v2 Response id=1 <6b50cadd3b86a59e123f5902534ab43>, <12ce3be37d225cfa83f2fbba1929b1dc88fb615421e8d8e>, F=0, name="zulu"] [2012-10-15 20:33:49]: info: ppp0: send [RADIUS(1) Access-Request id=1 <User-Name "zulu"> <NAS-Identifier "astra"> <NAS-IP-Address 172.17.230.11> <NAS-Port 0> <NAS-Port-Type Virtual> <Service-Type Framed-User> <Framed-Protocol PPP> <Calling-Station-Id "172.17.13.22"> <Called-Station-Id "172.17.230.11"><Microsoft MS-CHAP-Challenge ><Microsoft MS-CHAP2-Response >] [2012-10-15 20:33:50]: info: ppp0: recv [RADIUS(1) Access-Reject id=1 <Session-Timeout 1398574> <Session-Octets-Limit 0> <PPPD-Downstream-Speed-Limit 0> <Acct-Interim-Interval 60> <User-Name "zulu"> <PPPD-Upstream-Speed-Limit 0> <Framed-IP-Address 176.100.58.254> <Framed-IP-Netmask 255.255.255.255>] [2012-10-15 20:33:50]: info: ppp0: send [MSCHAP-v2 Failure id=1 "E=691 R=0 V=3 M=Authentication failure"] [2012-10-15 20:33:50]: info: ppp0: zulu: authentication failed [2012-10-15 20:33:50]: info: zulu: authentication failed [2012-10-15 20:33:50]: debug: ppp0: ppp_terminate [2012-10-15 20:33:50]: debug: ppp0: lcp_layer_finish [2012-10-15 20:33:50]: info: ppp0: send [LCP TermReq id=3] [2012-10-15 20:33:50]: debug: ppp0: auth_layer_finish [2012-10-15 20:33:50]: debug: ppp0: auth_layer_finished [2012-10-15 20:33:50]: info: ppp0: recv [PPTP Set-Link-Info] [2012-10-15 20:33:50]: info: ppp0: recv [LCP TermAck id=3] [2012-10-15 20:33:50]: debug: ppp0: lcp_layer_finished [2012-10-15 20:33:50]: debug: ppp0: lcp_layer_free [2012-10-15 20:33:50]: debug: ppp0: auth_layer_free [2012-10-15 20:33:50]: debug: ppp0: ccp_layer_free [2012-10-15 20:33:50]: debug: ppp0: ipcp_layer_free [2012-10-15 20:33:50]: debug: ppp0: ipv6cp_layer_free [2012-10-15 20:33:50]: debug: ppp0: ppp destablished [2012-10-15 20:33:50]: debug: ppp0: pptp: ppp finished [2012-10-15 20:33:50]: info: ppp0: send [PPTP Call-Disconnect-Notify <Call-ID 0> <Result 3> <Error 0> <Cause 0>] [2012-10-15 20:33:50]: info: ppp0: send [PPTP Stop-Ctrl-Conn-Request <Reason 0>] [2012-10-15 20:33:50]: info: ppp0: recv [PPTP Call-Clear-Request <Call-ID 0>] [2012-10-15 20:33:50]: info: ppp0: send [PPTP Call-Disconnect-Notify <Call-ID 0> <Result 4> <Error 0> <Cause 0>] [2012-10-15 20:33:50]: info: ppp0: recv [PPTP Stop-Ctrl-Conn-Reply <Result 1> <Error 0>] [2012-10-15 20:33:50]: debug: ppp0: pptp: disconnect [2012-10-15 20:33:50]: info: ppp0: disconnected куда копнуть? -
accel pptpd
мда, печалька. Я бы попробовал с костылями, только было бы от чего оттолкнуться) или посоветуйте дистр на котором я меньше наступлю на грабли))). Спасибо за ответ. -
accel pptpd
Привет всем. Решился собрать ацель. [ 89%] Building C object accel-pppd/extra/CMakeFiles/shaper_tbf.dir/shaper_tbf.c.o /opt/accel-ppp-1.6.1/accel-pppd/extra/shaper_tbf.c:13:29: fatal error: netlink/netlink.h: No such file or directory compilation terminated. make[2]: *** [accel-pppd/extra/CMakeFiles/shaper_tbf.dir/shaper_tbf.c.o] Error 1 make[1]: *** [accel-pppd/extra/CMakeFiles/shaper_tbf.dir/all] Error 2 make: *** [all] Error 2 Почитал форум, для шейпера требуется libnl, поставил но ситуация не поменялась. Как побороть? kyoukai build # emerge -ptv libnl * Last emerge --sync was 304d 9m 27s ago. These are the packages that would be merged, in reverse order: Calculating dependencies... done! [ebuild R ] dev-libs/libnl-3.2.3 USE="-static-libs -utils" 0 kB Total: 1 package (1 reinstall), Size of downloads: 0 kB * IMPORTANT: 2 news items need reading for repository 'gentoo'. * Use eselect news to read news items. kyoukai build # uname -a Linux kyoukai 3.0.6-gentoo #2 SMP Tue Nov 29 11:34:24 EET 2011 i686 Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz GenuineIntel GNU/Linux -
Заработает ли линк через залив 21 км ?
тему ответил в mrblade пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
работать будет, но я бы начал с 20мгц ставь МТ. -
Выбор длинной ВЧ кабельной сборки для 2.4
тему ответил в xphoenix пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
бери LMR-400 не промахнешься -
dvblast
тему ответил в Alexander пользователя zulu_radist в Телевидение: кабельное (КТВ) эфирное, цифровое (DVB), IPTV и OTT
отвечу сам, мож кому пригодится. на lyngsate написано 11862R, тогда dvblast настраиваем на circ_freq = 5150000 + 10750000 - 11862 -
dvblast
Кто знает как частоту гетеродина 10750 указать? Или надо как-то пересчитать по какой-то формуле? -
Пигтейлы на 5ггц
тему ответил в g7001 пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
надо попросить этих ребят сделать тоже самое но на пятерочку) http://www.imc.org.ua/index3.php?a=pigtail2 -
Кто сталкивался с интермодами от ГСМ операторов на вышках?
тему ответил в Alex_E пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
А покажи плиз как выглядит спектральная маска сего чуда, интересно. Вы же не микротиком уж точно сканили эфир, а чем-то посерьезней;). -
В Ливане холодно
тему ответил в nuclearcat пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
На вышке бардак, и снег со льдом это даже не скрыл))) -
Нагрузка на WLAN NS2
тему ответил в woda пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
мне кажется что это какая-то абонентская точка флудит в беспроводку. судя по тому что "клиенты с Planet WAP 4000A на своих компах поднимают ВПН. " точки подключены по wds, значит срать могут даже клиентские кампы или их паленые карты или кто-то сделал колечко кольцо :) -
RB435G зависает lan
разобрался, тестируем -
RB435G зависает lan
Проблема скорее всего не у Вас, это FW ROS, Вы ведь 5.хх используете? В 4.17 с nv2-wireless такого нет. К сожалению, и прироста скорости тоже... В догонку - мой топик на форуме микротика ТЫЦ, может поддержите? столкнулся с такой же проблемой, виснут порты. Как на 4.17 включить пакет nv2-wireless? В пекеджах его не нашел. -
DHCPD + vlan cisco
тему ответил в zulu_radist пользователя zulu_radist в Программное обеспечение, биллинг и *unix системы
Проблему нашли, забыли прописать маршрут) -
DHCPD + vlan cisco
Ксто подскажет куда рыть? почему не идут DHCPREQUEST и DHCPACK? -
DHCPD + vlan cisco
с консоли если просто запускать - он стартует правильно, если запускать с инит скрипта - шлет нах, мол не знаю где слушать опять, замкнутый круг:) тупо закоментил kyoukai ~ # cat /etc/conf.d/dhcpd DHCPD_CONF="/etc/dhcp/dhcpd.conf" #DHCPD_IFACE="eth1" и все пошло. С authoritative сейчас попробую. -
DHCPD + vlan cisco
запуск победил :) теперь другая беда :) Dec 2 11:33:20 localhost dhcpd: DHCPDISCOVER from 00:18:f3:6a:8b:51 via 172.17.11.1 Dec 2 11:33:20 localhost dhcpd: DHCPOFFER on 172.17.11.199 to 00:18:f3:6a:8b:51 via 172.17.11.1 Dec 2 11:33:27 localhost dhcpd: DHCPDISCOVER from 00:18:f3:6a:8b:51 via 172.17.11.1 Dec 2 11:33:27 localhost dhcpd: DHCPOFFER on 172.17.11.199 to 00:18:f3:6a:8b:51 via 172.17.11.1 -
DHCPD + vlan cisco
Жесть какая-то Никаких сторонникх процессов связанных с dhcp не запущено kyoukai ~ # ps ax | grep dhcpd 3616 pts/0 S+ 0:00 grep --colour=auto dhcpd -
DHCPD + vlan cisco
Дело говорите. Спасибо. Сдвиги пошли, но не до конца. kyoukai ~ # dhcpd Internet Systems Consortium DHCP Server 4.2.2 Gentoo-r2 Copyright 2004-2011 Internet Systems Consortium. All rights reserved. For info, please visit https://www.isc.org/software/dhcp/ WARNING: Host declarations are global. They are not limited to the scope you declared them in. Wrote 0 deleted host decls to leases file. Wrote 0 new dynamic host decls to leases file. Wrote 0 leases to leases file. Listening on LPF/eth1.230/00:0e:0c:4a:73:e7/vlan11 Sending on LPF/eth1.230/00:0e:0c:4a:73:e7/vlan11 Sending on Socket/fallback/fallback-net There's already a DHCP server running. -
DHCPD + vlan cisco
Не понял, вот кусок из конфига: shared-network vlan11 { .... subnet 172.17.11.0 netmask 255.255.255.0 { option routers 172.17.11.1; option ms-classless-static-routes 16, 172,17, 172,17,11,1; option rfc3442-classless-static-routes 16, 172,17, 172,17,11,1; include "/etc/dhcp/list_beta/11.dhcp" ; } .... subnet 10.27.11.0 netmask 255.255.255.0 { option routers 10.27.11.1; include "/etc/dhcp/list_beta/10.11.dhcp" ; } ............ } -
Возникла проблема с dhcp, сначала опишу структуру сети. Изначально все было на одной машине dhcp сервер+кучка виланов. Возникла необходимость разделить функции. cisco 3550 на нем разруливаются сети вланов и в него же воткнут DHCPD сервер. на 3550 настроен ip helper с ip адресом dhcp-сервера. Проблема собственно в чем, когда убираю все виланы с DHCP сервера, прописываю только ip адсрес для "обещения" с cisco, сам dhcp демон не стартует, просит их вернуть))). Ума неприложу что делать... и куда уже копать... кстати ругается на Not configured to listen on any interfaces! но kyoukai ~ # cat /etc/conf.d/dhcpd DHCPD_CONF="/etc/dhcp/dhcpd.conf" DHCPD_IFACE="eth1" kyoukai ~ # emerge -ptv dhcp These are the packages that would be merged, in reverse order: Calculating dependencies... done! [ebuild R ] net-misc/dhcp-4.2.2-r2 USE="client server ssl -ipv6 -ldap (-selinux) -vim-syntax" 0 kB Total: 1 package (1 reinstall), Size of downloads: 0 kB * IMPORTANT: 2 news items need reading for repository 'gentoo'. * Use eselect news to read news items.
Mikrotik 433ah нужна помощь
тему ответил в Dagforce пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
Проблема в наносах. :) Зажми АСК на базе, на 5 скрине видно что плохой клиент "штырит". -
И снова по DWL-2100 BB
тему ответил в aniki пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
Согни на коленке двойной квадрат, припаяй к коннектору от штатной антенки, в разы станет лучше. -
Чем заменить BlueBox (WhiteBox не предлогать!)
тему ответил в sirmax пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
Золотое правило - работает не трогай. Тем более у вас там в Харькове полный кирдык в эфире. -
Линк 2,3 км. на Dlink 2100+Biquad и AirGrid(NanoStation).
тему ответил в Slowesno пользователя zulu_radist в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
M2 тут до одного места. Берите либо локу обычную либо с запасом нанос.
