Судя по упавшему с 60 гигабит до 25 трафику на М9 проблема с такой вот ошибкой массовая
 Assertion `len < str_size' failed in file bgp_aspath.c, line 619, function aspath_make_str_count
http://groups.google.ru/group/fido7.ru.uni...d7a4f3ce0?hl=ru
запредельная по безответственности ошибка
патчится вот так
собственно значимую часть патча я выдели болдом:
aurora:/usr/home/wawa# cat /usr/ports/net/quagga/files/patch-WAWA-AS4fix*
--- bgpd/bgp_aspath.h.orig 2008-09-05 18:27:26.000000000 +0400
+++ bgpd/bgp_aspath.h 2009-04-30 13:54:00.000000000 +0400
@@ -60,7 +60,7 @@ struct aspath
char *str;
-#define ASPATH_STR_DEFAULT_LEN 32
+#define ASPATH_STR_DEFAULT_LEN 512
/* Prototypes. */
extern void aspath_init (void);
--- bgpd/bgp_aspath.c.orig 2008-09-05 18:27:26.000000000 +0400
+++ bgpd/bgp_aspath.c 2009-04-30 13:50:17.000000000 +0400
@@ -540,16 +540,14 @@ aspath_make_str_count (struct aspath *as
seg = as->segments;
- /* ASN takes 5 chars at least, plus seperator, see below.
+ /* ASN takes 10 chars at least, plus seperator, see below.
* If there is one differing segment type, we need an additional
* 2 chars for segment delimiters, and the final '\0'.
* Hopefully this is large enough to avoid hitting the realloc
* code below for most common sequences.
- * With 32bit ASNs, this range will increase, but only worth changing
- * once there are significant numbers of ASN >= 100000
-#define ASN_STR_LEN (5 + 1)
+#define ASN_STR_LEN (10 + 1)
str_size = MAX (assegment_count_asns (seg, 0) * ASN_STR_LEN + 2 + 1,
ASPATH_STR_DEFAULT_LEN);
str_buf = XMALLOC (MTYPE_AS_STR, str_size);
@@ -574,16 +572,6 @@ aspath_make_str_count (struct aspath *as
XFREE (MTYPE_AS_STR, str_buf);
return NULL;
- /* We might need to increase str_buf, particularly if path has
- * differing segments types, our initial guesstimate above will
- * have been wrong. need 5 chars for ASN, a seperator each and
- * potentially two segment delimiters, plus a space between each
- * segment and trailing zero.
- * This may need to revised if/when significant numbers of
- * ASNs >= 100000 are assigned and in-use on the internet...
#define SEGMENT_STR_LEN(X) (((X)->length * ASN_STR_LEN) + 2 + 1 + 1)
if ( (len + SEGMENT_STR_LEN(seg)) > str_size)
ээээ объясните плиз что это за проблема и зачем надо патчить квагу
дело в том что пару дней дней назад поднял квагу в виртуалке - для теста - и наблюдал падение демона bgpd
с записью в логе аналогичной ошибки
Патчить надо: 32bit ASN это больше, чем 5 цифр. Так что при появлении номеров более 99999 происходит "наезд" на другие данные со всеми вытекающими последствиями.
А собственно, если я full view не беру, оно мне срочно надо ? или подождать обновления в портах ?
ну тем неменее, давеча на Msk-Ix в те 6 тысяч префиксов, что там есть, закралась такая весчь.... поэтому если от апстрима отдается не только дефолт, а и что-то еще, то надо бы. причем сами такие префиксы отфильтрвать вы не сможете, оно развалится сразу по приходу.
если фильтрует аплинк и сливает тебе исключительно дефолт - то тебе будет по барабану эта проблема, можно дождаться апдейта в портах.
Подобная проблема возникает естественно при принятии fullview с апстримов. Причем штатными средствами куаги, например отрезать префикс-листами все кроме default, не дало результата, bgpd все также уходит в ступор.
4 варианта выхода из данной ситуации:
1. Купить cisco/juniper в место тазика с куагой ($$$$$$$$).
2. Даунгрейд до версии quagga-0.98.6. (тут все понятно)
3. Попросить апстримы отдавать Вам не fullview, а только default. (Соответственно при нескольких апстримах про балансировку забудьте. Разве что если есть сессия в IX, но не факт что и рано или поздно оттуда придут префиксы, которые завалят Вашу куагу)
4. Пропатчить куагу патчем.
Edited by Keyptor
хотелось бы спросить многоуважаемого и всепросвещённого товарища wawa, к тому что они когда то давно там в Яндексе приняли концепцию использовать только OpenSource решения,
в том числе чтобы не тратить много денег и не зависеть от злобных вендоров и их проприетарщины,
как вы кушаете такие ошибки?(*материтесь пятиэтажно в слух при всех?*) :)
проводите ли анализ кода который скачиваете бесплатно?
Уважаемые коллеги,
в прошедшие выходные была обнаружена проблема с программным обеспечением Route Server (работающем под управлением Quagga daemon), связанная с некорректной обработкой новых ASN32.
Был выпущен патч, который был наложен на Route Serverа MSK-IX и проблема была устранена. Обращаем внимание участников MSK-IX, кто столкнулся с подобной ошибкой, на необходимость обновления ПО quagga с целью ее устранения.
Для дополнительной информации вы можете ознакомиться со списком рассылки
Quagga:
http://lists.quagga.net/pipermail/quagga-d...ril/006537.html
После обновления система ведет себя стабильно и проблем более не наблюдается.
Приносим извинения за доставленные неудобства, связанными с перебоями в работе услуги Route Server на MSK-IX.
С уважением.
Технический директор MSK-IX
Ильин Александр.
Я давно заметил, что неинформированные люди почему-то более склонны к агрессии.
Поэтому информирую (долой агрессию !):
Словили проблему 30 апреля утром.
Отлов и диагностика проблемы заняла минут пять
Выпуск горячего патча примерно столько же (чтоб не падало).
Еще через полчаса был выпущен более осмысленный (разобрались почему падало и исправили нетопорно).
Основую проблему составила переналивка большого парка маршрутизаторов. Как легко дагадаться задним умом тут полезно было соблюдать очередность
Так или иначе, к ночи 30 апреля почти все было готово (что-то по мелочи конечно недоглядели).
Вот планово перепуститься не успели. Факт. И закоммитить патчи по-нормальному тоже не успели. Чтобы меньше народу пострадало.
Тем не менее, когда бабахнуло по полной программе (в выходной день) неперепущенные Квагги попадали, но отжались уже пропатченным кодом.
А про Жунипер Вы у японцев спросите. Про Циску тут тоже многим есть что рассказать.
Впрочем, кто сказал что в Яндексе этих зверьков не водится ?
Edited by wawa
