npokypop Опубликовано 5 декабря, 2010 (изменено) · Жалоба Sorry! Может и была проблема но не нашел. root@ubuntutv:/etc/sc# sasc-ng -j 4:5 --cam-budget --sid-nocache -d 0xf0a --cam-dir /etc/sc Dec 6 01:24:45.806 : Version: 0.0.2-61975953edd0+ Dec 6 01:24:45.807 CAM: initializing plugin: SoftCam (1.0.0pre-HG-61975953edd0+): A software emulated CAM Dec 6 01:24:45.807 CAM(general.info): SC version 1.0.0pre-HG-61975953edd0+ initializing (VDR 1.6.0) Dec 6 01:24:45.807 CAM: starting plugin: Dec 6 01:24:45.807 CAM(general.info): SC version 1.0.0pre-HG-61975953edd0+ starting (VDR 1.6.0) Dec 6 01:24:45.807 CAM(core.load): ** Plugin config: Dec 6 01:24:45.807 CAM(core.load): ** Key updates (AU) are enabled (active CAIDs) (no prestart) Dec 6 01:24:45.807 CAM(core.load): ** Local systems DON'T take priority over cached remote Dec 6 01:24:45.807 CAM(core.load): ** Concurrent FF recordings are NOT allowed Dec 6 01:24:45.807 CAM(core.load): ** Force transfermode with digital audio Dec 6 01:24:45.807 CAM(core.load): ** ECM cache is set to enabled Dec 6 01:24:45.807 CAM(core.load): ** ScCaps are 1 2 0 0 0 0 0 0 0 0 Dec 6 01:24:45.807 CAM(general.info): loading cardclient config from /etc/sc/cardclient.conf Dec 6 01:24:45.807 CAM(cardclient.newcamd): now using protocol version 525 (cdLen=8) Dec 6 01:24:45.807 CAM(cardclient.core): hostname=cserv16.net port=20250 emm=0 emmCaids 0500/ffff Dec 6 01:24:45.807 CAM(cardclient.core): Newcamd: username=ххххх password=ххххх key=ххххххххххххххххххххххххххххххх Dec 6 01:24:45.807 CAM(cardclient.core): client 'Newcamd' ready Dec 6 01:24:45.810 CAM(core.net): connecting to cserv16.net:20250/tcp (89.149.223.124) Dec 6 01:24:46.264 CAM(cardclient.login): Newcamd: CaID=0500 admin=0 srvUA=0000000000000000 provider 042700/0000000000000000 Dec 6 01:24:46.264 CAM(general.error): failed open /etc/sc/SoftCam.Key: No such file or directory Dec 6 01:24:46.264 CAM(general.error): failed open /etc/sc/smartcard.conf: No such file or directory Dec 6 01:24:46.264 CAM(general.error): failed open /etc/sc/cardslot.conf: No such file or directory Dec 6 01:24:46.264 CAM(general.error): failed open /etc/sc/override.conf: No such file or directory Dec 6 01:24:46.264 CAM(general.error): no keys loaded for softcam! Dec 6 01:24:46.264 CAM(core.load): ** registered systems: Dec 6 01:24:46.264 CAM(core.load): ** Cardclient (pri -15) Dec 6 01:24:46.264 CAM(core.load): ** Conax (pri -10) Dec 6 01:24:46.264 CAM(core.load): ** ConstCW (pri -20) Dec 6 01:24:46.264 CAM(core.load): ** Cryptoworks (pri -10) Dec 6 01:24:46.264 CAM(core.load): ** Irdeto (pri -10) Dec 6 01:24:46.264 CAM(core.load): ** Irdeto2 (pri -8) Dec 6 01:24:46.264 CAM(core.load): ** Nagra (pri -10) Dec 6 01:24:46.264 CAM(core.load): ** Nagra2 (pri -10) Dec 6 01:24:46.264 CAM(core.load): ** Fake-NDS (pri -12) Dec 6 01:24:46.264 CAM(core.load): ** SC-Conax (pri -5) Dec 6 01:24:46.264 CAM(core.load): ** SC-Cryptoworks (pri -5) Dec 6 01:24:46.264 CAM(core.load): ** SC-Irdeto (pri -5) Dec 6 01:24:46.264 CAM(core.load): ** SC-Nagra (pri -5) Dec 6 01:24:46.264 CAM(core.load): ** SC-Seca (pri -5) Dec 6 01:24:46.264 CAM(core.load): ** SC-Viaccess (pri -5) Dec 6 01:24:46.264 CAM(core.load): ** SC-VideoGuard2 (pri -5) Dec 6 01:24:46.264 CAM(core.load): ** Seca (pri -10) Dec 6 01:24:46.264 CAM(core.load): ** @SHL (pri -10) Dec 6 01:24:46.264 CAM(core.load): ** Viaccess (pri -10) Dec 6 01:24:47.274 demux: Starting thread on /dev/dvb/adapter5/demux1 The thread scheduling parameters indicate: policy = 0 priority = 0 Dec 6 01:24:47.274 dvr: Starting thread on /dev/dvb/adapter5/dvr1 The thread scheduling parameters indicate: policy = 1 priority = 99 Dec 6 01:24:47.274 frontend: Starting thread on /dev/dvb/adapter5/frontend1 The thread scheduling parameters indicate: policy = 0 priority = 0 Dec 6 01:24:47.274 : Listening on port 5456 На сколько понял то САСЦ принял ключ ? Потом я запускаю Гетс И получаю ответ от САСЦ Dec 6 01:26:34.632 frontend: Opened fd: 0=10 mode: 4002 Dec 6 01:26:34.632 frontend: Got command 61 (size: 176) Dec 6 01:26:34.636 frontend: ioctl on (10) returned: 0 Dec 6 01:26:34.636 : FE_GET_INFO(10): 'ST STV0299 DVB-S' min:950000 max:2150000 step:125 tol:0 minsr:1000000 maxsr:45000000 tolsr:500 Dec 6 01:26:34.636 frontend: Got command 67 (size: 12) Dec 6 01:26:34.636 frontend: ioctl on (10) returned: 0 Dec 6 01:26:34.636 : FE_SET_VOLTAGE(10): 13 Dec 6 01:26:34.636 CHANNEL: Clearing tuning cache due to switch cmd Dec 6 01:26:34.636 frontend: Got command 66 (size: 12) Dec 6 01:26:34.637 frontend: ioctl on (10) returned: 0 Dec 6 01:26:34.637 : FE_SET_TONE(10): ON Dec 6 01:26:34.637 CHANNEL: Clearing tuning cache due to switch cmd Dec 6 01:26:34.637 frontend: Got command 76 (size: 44) Dec 6 01:26:34.637 frontend: ioctl on (10) returned: 0 Dec 6 01:26:34.637 : FE_SET_FRONTEND(10): freq: 1127000 inv: AUTO QPSK: sr: 27500000 fec: 9 Dec 6 01:26:34.637 CHANNEL: Tuning frontend Dec 6 01:26:34.637 CSA: Got command(5): I idx: 0 pid: 0 Dec 6 01:26:34.638 demux: Opened fd: 0=12 mode: 2 Dec 6 01:26:34.638 demux: Got command 44 (size: 28) Dec 6 01:26:34.638 demux: ioctl on (12) returned: 0 Dec 6 01:26:34.638 : DMX_SET_PES_FILTER(12): pid:8192 in:FRONTEND out:TS_TAP type:OTHER flags: IMMEDIATE_START Dec 6 01:26:34.638 CHANNEL: Sending PID: 8192 Dec 6 01:26:34.638 CHANNEL: Got Start! Dec 6 01:26:34.639 frontend: Got command 78 (size: 48) Dec 6 01:26:34.639 frontend: ioctl on (10) returned: 0 Dec 6 01:26:34.639 : FE_GET_EVENT(10) returned 0 Dec 6 01:26:34.737 frontend: Got command 78 (size: 48) Dec 6 01:26:34.738 frontend: ioctl on (10) returned: 0 Dec 6 01:26:34.738 : FE_GET_EVENT(10) returned 0 SIGNAL CARRIER Dec 6 01:26:35.138 frontend: Got command 78 (size: 48) Dec 6 01:26:35.138 frontend: ioctl on (10) returned: 0 Dec 6 01:26:35.138 : FE_GET_EVENT(10) returned 0 SIGNAL CARRIER VITERBI SYNC LOCK Dec 6 01:26:35.183 CHANNEL: found NIT at PID: 16Dec 6 01:26:35.183 CHANNEL: found PID: 306 for sid: 1 Dec 6 01:26:35.183 CHANNEL: found PID: 33 for sid: 2 Dec 6 01:26:35.183 CHANNEL: found PID: 37 for sid: 3 Dec 6 01:26:35.183 CHANNEL: found PID: 44 for sid: 4 Dec 6 01:26:35.183 CHANNEL: found PID: 1024 for sid: 5 Dec 6 01:26:35.183 CHANNEL: found PID: 1536 for sid: 6 Dec 6 01:26:35.183 CHANNEL: found PID: 1792 for sid: 7 Dec 6 01:26:35.183 CHANNEL: found PID: 2096 for sid: 8 Dec 6 01:26:35.183 CHANNEL: found PID: 2560 for sid: 10 Dec 6 01:26:35.183 CHANNEL: found PID: 2816 for sid: 11 Dec 6 01:26:35.183 CHANNEL: found PID: 2832 for sid: 12 Dec 6 01:26:35.183 CHANNEL: found PID: 2848 for sid: 14 Dec 6 01:26:35.183 CHANNEL: found PID: 2880 for sid: 15 Dec 6 01:26:35.183 CHANNEL: found PID: 2880 for sid: 16 Dec 6 01:26:35.183 CHANNEL: found PID: 2112 for sid: 129 Dec 6 01:26:35.183 CHANNEL: found PID: 2896 for sid: 177 Dec 6 01:26:35.183 CHANNEL: found PID: 2912 for sid: 178 Dec 6 01:26:35.183 CHANNEL: found PID: 2864 for sid: 179 Dec 6 01:26:35.183 CHANNEL: found PID: 3840 for sid: 241 Dec 6 01:26:35.183 CHANNEL: found PID: 1793 for sid: 257 Orbit: 00000130E Dec 6 01:26:35.582 CHANNEL: Reading 2 of 2 filters Dec 6 01:26:35.582 CHANNEL: polling 2 fds Dec 6 01:26:35.682 CHANNEL: Read 32 bytes Dec 6 01:26:35.682 CHANNEL: read_pmt: sid: 241 pcrpid: 3841 skip: 0 count: 28 Dec 6 01:26:35.682 CHANNEL: read_pmt: epid 3841 (type 2) mapped to sid 241 Dec 6 01:26:35.682 CHANNEL: read_pmt: epid 3842 (type 4) mapped to sid 241 Dec 6 01:26:35.682 CHANNEL: polling 2 fds Dec 6 01:26:35.883 CHANNEL: Read 40 bytes Dec 6 01:26:35.883 CHANNEL: read_pmt: sid: 257 pcrpid: 8191 skip: 0 count: 36 Dec 6 01:26:35.883 CHANNEL: read_pmt: epid 1074 (type 13) mapped to sid 257 Dec 6 01:26:35.883 CHANNEL: Reading 2 of 2 filters Dec 6 01:26:35.883 CHANNEL: polling 2 fds Dec 6 01:26:36.083 CHANNEL: polling 2 fds Dec 6 01:26:36.184 CHANNEL: Read 21 bytes Dec 6 01:26:36.184 CHANNEL: read_pmt: sid: 178 pcrpid: 2836 skip: 0 count: 17 Dec 6 01:26:36.184 CHANNEL: read_pmt: epid 2897 (type 4) mapped to sid 178 Dec 6 01:26:36.184 CHANNEL: polling 2 fds Dec 6 01:26:36.284 CHANNEL: Read 21 bytes Dec 6 01:26:36.284 CHANNEL: read_pmt: sid: 179 pcrpid: 2836 skip: 0 count: 17 Dec 6 01:26:36.284 CHANNEL: read_pmt: epid 2865 (type 4) mapped to sid 179 Dec 6 01:26:36.284 CHANNEL: Reading 2 of 2 filters Dec 6 01:26:36.284 CHANNEL: polling 2 fds Dec 6 01:26:36.382 CHANNEL: Read 21 bytes Dec 6 01:26:36.382 CHANNEL: read_pmt: sid: 177 pcrpid: 2836 skip: 0 count: 17 Dec 6 01:26:36.382 CHANNEL: read_pmt: epid 2898 (type 4) mapped to sid 177 Dec 6 01:26:36.382 CHANNEL: Read 44 bytes Dec 6 01:26:36.382 CHANNEL: read_pmt: sid: 129 pcrpid: 2052 skip: 17 count: 40 Dec 6 01:26:36.382 CHANNEL: read_pmt: epid 2052 (type 4) mapped to sid 129 Dec 6 01:26:36.382 CHANNEL: Reading 2 of 2 filters Dec 6 01:26:36.382 CHANNEL: polling 2 fds Dec 6 01:26:36.482 CHANNEL: Read 21 bytes Dec 6 01:26:36.482 CHANNEL: read_pmt: sid: 16 pcrpid: 2881 skip: 0 count: 17 Dec 6 01:26:36.482 CHANNEL: read_pmt: epid 2866 (type 4) mapped to sid 16 Dec 6 01:26:36.482 CHANNEL: polling 2 fds Dec 6 01:26:36.683 CHANNEL: polling 2 fds Dec 6 01:26:36.683 CHANNEL: Read 21 bytes Dec 6 01:26:36.683 CHANNEL: read_pmt: sid: 14 pcrpid: 2881 skip: 0 count: 17 Dec 6 01:26:36.683 CHANNEL: read_pmt: epid 2833 (type 4) mapped to sid 14 Dec 6 01:26:36.683 CHANNEL: polling 2 fds Dec 6 01:26:36.783 CHANNEL: Read 21 bytes Dec 6 01:26:36.783 CHANNEL: read_pmt: sid: 15 pcrpid: 2881 skip: 0 count: 17 Dec 6 01:26:36.783 CHANNEL: read_pmt: epid 2850 (type 4) mapped to sid 15 Dec 6 01:26:36.783 CHANNEL: Reading 2 of 2 filters Dec 6 01:26:36.783 CHANNEL: polling 2 fds Dec 6 01:26:36.883 CHANNEL: Read 21 bytes Dec 6 01:26:36.883 CHANNEL: read_pmt: sid: 11 pcrpid: 2881 skip: 0 count: 17 Dec 6 01:26:36.883 CHANNEL: read_pmt: epid 2817 (type 4) mapped to sid 11 Dec 6 01:26:36.883 CHANNEL: polling 2 fds Dec 6 01:26:36.983 CHANNEL: Read 21 bytes Dec 6 01:26:36.983 CHANNEL: read_pmt: sid: 12 pcrpid: 2836 skip: 0 count: 17 Dec 6 01:26:36.983 CHANNEL: read_pmt: epid 2882 (type 4) mapped to sid 12 Dec 6 01:26:36.984 CHANNEL: Reading 2 of 2 filters Dec 6 01:26:36.984 CHANNEL: polling 2 fds Dec 6 01:26:37.082 CHANNEL: Read 52 bytes Dec 6 01:26:37.082 CHANNEL: read_pmt: sid: 8 pcrpid: 2050 skip: 17 count: 48 Dec 6 01:26:37.082 CHANNEL: read_pmt: epid 2050 (type 2) mapped to sid 8 Dec 6 01:26:37.082 CHANNEL: read_pmt: epid 2051 (type 4) mapped to sid 8 Dec 6 01:26:37.082 CHANNEL: polling 2 fds Dec 6 01:26:37.182 CHANNEL: Read 52 bytes Dec 6 01:26:37.182 CHANNEL: read_pmt: sid: 10 pcrpid: 2561 skip: 17 count: 48 Dec 6 01:26:37.182 CHANNEL: read_pmt: epid 2562 (type 2) mapped to sid 10 Dec 6 01:26:37.182 CHANNEL: read_pmt: epid 2563 (type 4) mapped to sid 10 Dec 6 01:26:37.182 CHANNEL: Reading 2 of 2 filters Dec 6 01:26:37.182 CHANNEL: polling 2 fds Dec 6 01:26:37.282 CHANNEL: Read 52 bytes Dec 6 01:26:37.282 CHANNEL: read_pmt: sid: 6 pcrpid: 1537 skip: 17 count: 48 Dec 6 01:26:37.282 CHANNEL: read_pmt: epid 1537 (type 2) mapped to sid 6 Dec 6 01:26:37.282 CHANNEL: read_pmt: epid 1538 (type 4) mapped to sid 6 Dec 6 01:26:37.282 CHANNEL: polling 2 fds Dec 6 01:26:37.382 CHANNEL: Read 61 bytes Dec 6 01:26:37.382 CHANNEL: read_pmt: sid: 7 pcrpid: 8191 skip: 6 count: 57 Dec 6 01:26:37.382 CHANNEL: read_pmt: epid 1073 (type 13) mapped to sid 7 Dec 6 01:26:37.383 CHANNEL: Reading 2 of 2 filters Dec 6 01:26:37.383 CHANNEL: polling 2 fds Dec 6 01:26:37.583 CHANNEL: Read 32 bytes Dec 6 01:26:37.583 CHANNEL: read_pmt: sid: 4 pcrpid: 46 skip: 0 count: 28 Dec 6 01:26:37.583 CHANNEL: read_pmt: epid 46 (type 2) mapped to sid 4 Dec 6 01:26:37.583 CHANNEL: read_pmt: epid 47 (type 4) mapped to sid 4 Dec 6 01:26:37.583 CHANNEL: polling 2 fds Dec 6 01:26:37.783 CHANNEL: Read 32 bytes Dec 6 01:26:37.783 CHANNEL: read_pmt: sid: 5 pcrpid: 1026 skip: 0 count: 28 Dec 6 01:26:37.783 CHANNEL: read_pmt: epid 1026 (type 2) mapped to sid 5 Dec 6 01:26:37.783 CHANNEL: read_pmt: epid 1027 (type 3) mapped to sid 5 Dec 6 01:26:37.784 CHANNEL: Reading 2 of 2 filters Dec 6 01:26:37.784 CHANNEL: polling 2 fds Dec 6 01:26:37.884 CHANNEL: Read 77 bytes Dec 6 01:26:37.884 CHANNEL: read_pmt: sid: 3 pcrpid: 40 skip: 23 count: 73 Dec 6 01:26:37.884 CHANNEL: read_pmt: epid 40 (type 2) mapped to sid 3 Dec 6 01:26:37.884 CHANNEL: read_pmt: epid 42 (type 4) mapped to sid 3 Dec 6 01:26:37.884 CHANNEL: read_pmt: epid 43 (type 4) mapped to sid 3 Dec 6 01:26:37.884 CHANNEL: polling 2 fds Dec 6 01:26:38.082 CHANNEL: Read 44 bytes Dec 6 01:26:38.082 CHANNEL: read_pmt: sid: 2 pcrpid: 35 skip: 9 count: 40 Dec 6 01:26:38.082 CHANNEL: read_pmt: epid 35 (type 2) mapped to sid 2 Dec 6 01:26:38.082 CHANNEL: read_pmt: epid 36 (type 4) mapped to sid 2 Dec 6 01:26:38.082 CHANNEL: Reading 1 of 2 filters Dec 6 01:26:38.082 CHANNEL: polling 1 fds Dec 6 01:26:38.283 CHANNEL: Read 63 bytes Dec 6 01:26:38.283 CHANNEL: read_pmt: sid: 1 pcrpid: 307 skip: 17 count: 59 Dec 6 01:26:38.283 CHANNEL: read_pmt: epid 308 (type 2) mapped to sid 1 Dec 6 01:26:38.283 CHANNEL: read_pmt: epid 309 (type 4) mapped to sid 1 Dec 6 01:26:38.283 CHANNEL: read_pmt: epid 310 (type 4) mapped to sid 1 Dec 6 01:26:38.283 CHANNEL: returned: 0 Dec 6 01:26:38.283 CHANNEL: Got Pid: 8192 Dec 6 01:26:39.639 frontend: Got command 69 (size: 12) Dec 6 01:26:39.639 frontend: ioctl on (10) returned: 0 Dec 6 01:26:39.639 : FE_READ_STATUS(10): SIGNAL CARRIER VITERBI SYNC LOCK Dec 6 01:26:44.640 frontend: Got command 69 (size: 12) Dec 6 01:26:44.640 frontend: ioctl on (10) returned: 0 Dec 6 01:26:44.640 : FE_READ_STATUS(10): SIGNAL CARRIER VITERBI SYNC LOCK Dec 6 01:26:46.931 CAM(core.net): idle timeout, disconnected cserv16.net:20250 Dec 6 01:26:49.641 frontend: Got command 69 (size: 12) Dec 6 01:26:49.641 frontend: ioctl on (10) returned: 0 Dec 6 01:26:49.641 : FE_READ_STATUS(10): SIGNAL CARRIER VITERBI SYNC LOCK ^CDec 6 01:26:51.636 CAM(general.debug): SC cleanup done Но при этом ГЕТС поток не отдает. Изменено 6 декабря, 2010 пользователем npokypop Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
MasterHome Опубликовано 6 декабря, 2010 · Жалоба Сасц принял не ключ, а настройки подключения к серверу. Запросов на ключ не было. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
npokypop Опубликовано 6 декабря, 2010 · Жалоба Не могу запустить гетстрим после сасц в rc.local modprobe dvbloopback & sasc-ng -j 2:5 --cam-budget --sid-nocache -d 0xf0a --cam-dir /etc/sc & /iptv/getstream -c ./iptv/config1 -dd & после перезапуска нету в процессах гетстрима, а при прописывании вручную то запускается. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
MasterHome Опубликовано 6 декабря, 2010 · Жалоба Адаптер один? Судя по номеру - нет, а почему тогда dvbloopback запускается без указания количества адаптеров? Прописываешь вручную точно такую-же строку? При этом находишься в корневой директории или в директории с гетстримом? Пути в строке правильные? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
npokypop Опубликовано 6 декабря, 2010 · Жалоба Прописываешь вручную точно такую-же строку?ДаПри этом находишься в корневой директории или в директории с гетстримом?Разницы нету где находиться, ведь путь указан верный.Пути в строке правильные?Да SASC умеет работать как демон ? может нужна задержка после запуска SASC и перед запуском GETs & Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
MasterHome Опубликовано 6 декабря, 2010 · Жалоба Задержка нужна. У тебя конфиг гетстрима указан по относительному пути. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
npokypop Опубликовано 6 декабря, 2010 · Жалоба каким образом сделать задержку ? Чтобы гетстрим грузился после загрузки САСЦ ? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Roma_n Опубликовано 6 декабря, 2010 · Жалоба Получилось ли у кого-то выдать в сеть getstream-ом раскодированный крадшарингом при помощи sasc-ng HD-DVB-S2-канал? У меня такое впечатление, что sasc не может корректно собрать ХД канал. Getstream честно вещает открытые HD каналы. А при попытке вещать HD-канал, раскодированный sasc-ом на экран попадает либо серая, либо зелёная, либо разноцветная каша. Пробовал каналы с НТВ+ и с Платформы - результат одинаковый. Если у кого есть опыт решения такой задачи, отзовитесь, пжлст. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
maximas Опубликовано 7 декабря, 2010 (изменено) · Жалоба Roma_n что значит кардшарингом? Собственным? Внешним/покупным? Вообще это только впечатление. Все работает, открывается и вещается. Причем не один канал, а сразу пару трансов, при желании. Изменено 7 декабря, 2010 пользователем maximas Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Roma_n Опубликовано 7 декабря, 2010 · Жалоба Roma_n что значит кардшарингом?Кардшаринг внешний, покупной. По Виндой в ProgDVB плагином ACamd эти же ключи нормально раскодируют эти же самые ХД каналы. А саск их почему-то не берёт. Я уже пробовал на двух разных компах, выдвал каналы на сеттопбокс - результат одинаковый - вместо изображения на экране мешанина. Спутниковая карта - SkyStar S2. Она же под Виндой ХД принимает, как я написал выше. Дрова от Липлианина. Ubuntu 10.10. Может, у меня версия плагина устаревшая? Саск мне пишет о себе следующее: sasc-ng [options] -j <real>:<virtual> ... Version: 0.0.2-61975953edd0+ SD каналы при этом совершенно нормально раскодируются и подаются в сеть без проблем. Помогите, пожалуйста, разобраться. Уже сил нет с этим бороться. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Roma_n Опубликовано 7 декабря, 2010 · Жалоба При попытке открыть ХД канал кафеином, используя тот же саск, результат в точности такой же: серая каша. SD каналы и в этом варианте открываются без проблем. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
server801 Опубликовано 8 декабря, 2010 (изменено) · Жалоба Кто знает , как побороть? [ 6.692870] saa7146: register extension 'budget dvb'. [ 6.692940] budget dvb 0000:01:07.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 852.655342] dvbloopback: disagrees about version of symbol dvb_register_adapter [ 852.655349] dvbloopback: Unknown symbol dvb_register_adapter [ 852.655500] dvbloopback: disagrees about version of symbol dvb_generic_open [ 852.655503] dvbloopback: Unknown symbol dvb_generic_open [ 852.655652] dvbloopback: disagrees about version of symbol dvb_unregister_device [ 852.655655] dvbloopback: Unknown symbol dvb_unregister_device [ 852.655869] dvbloopback: disagrees about version of symbol dvb_generic_release [ 852.655872] dvbloopback: Unknown symbol dvb_generic_release [ 852.656485] dvbloopback: disagrees about version of symbol dvb_register_device [ 852.656489] dvbloopback: Unknown symbol dvb_register_device [ 852.656651] dvbloopback: disagrees about version of symbol dvb_unregister_adapter [ 852.656658] dvbloopback: Unknown symbol dvb_unregister_adapter Ubuntu server 10.04 Omicom DVB - S2 SS4 rev.3 Изменено 8 декабря, 2010 пользователем server801 Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
server801 Опубликовано 9 декабря, 2010 · Жалоба Ребята, подкиньте для 36 градуса рабочий конфиг открытого канала для тренировки . Вот радио поет, а каналы не хочет.. Заранее спасибо Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Roma_n Опубликовано 9 декабря, 2010 · Жалоба Ребята, подкиньте для 36 градуса рабочий конфиг открытого канала для тренировки . Вот радио поет, а каналы не хочет.. Заранее спасибо [/quote Лови: http { port 8000; }; adapter 0 { budget-mode 1; packet-buffer 50; stat-interval 120; dvb-s { #lnb-sharing yes; lnb { lof1 10750000; lof2 10750000; slof 11700000; }; transponder { frequency 12303000; polarisation h; symbol-rate 27500000; }; }; stream { name "Soyuz"; input { pnr 3; }; output-http { url "/Soyuz"; }; }; stream { name "Bridge TV"; input { pnr 59; }; output-http { url "/m1"; }; }; stream { name "A-One"; input { pnr 400; }; output-http { url "/A-One"; }; }; Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
server801 Опубликовано 9 декабря, 2010 (изменено) · Жалоба Спасибо огромное! Это все работает, двигаемся далее, буду стараться открыть шареные каналы.... Очень много читаю по настройке шаренных, но не могу выбрать правильное решение. Вот список транспондеров scan c 36 градуса, но через putty выглядет плохо. dumping lists (180 services) Ѕ▒ :11727:h:0:27500:51:52:901 ▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒ :11727:h:0:27500:101:102:902 Top Shop :11727:h:0:27500:151:152:903 RUSONG TV :11727:h:0:27500:201:202:904 Comedy TV :11727:h:0:27500:251:252:905 ▒І ▒▒▒▒ ▒▒▒▒ ▒▒▒▒ :11727:h:0:27500:301:302:906 ▒▒▒▒▒▒▒▒І :12072:h:0:27500:271:272:27000 ▒▒▒▒▒▒ :12072:h:0:27500:51:52:27005 ▒▒▒▒▒▒ 1 :12072:h:0:27500:101:102:27010 ▒І :12072:h:0:27500:151:152:27015 ▒▒▒▒▒▒ ▒ :12072:h:0:27500:201:202:27020 Ѕ▒ :12072:h:0:27500:251:252:27025 ▒▒▒▒▒▒ 2 :12072:h:0:27500:301:302:27030 ▒▒▒▒▒▒ 24 :12072:h:0:27500:401:402:27040 ▒▒▒▒▒▒▒▒▒ 5 ▒▒▒▒▒ :12072:h:0:27500:501:502:27050 ▒І :12072:h:0:27500:601:602:27060 ▒▒▒▒▒▒▒▒▒ ▒▒ :12072:h:0:27500:701:702:27070 ▒▒▒▒▒▒▒ :12072:h:0:27500:901:902:27090 І▒ :12072:h:0:27500:1001:1002:27100 ▒▒ І :12072:h:0:27500:1101:1102:27110 ▒▒▒ ▒▒▒▒▒▒ :12072:h:0:27500:1201:1202:27120 DRE:12072:h:0:27500:0:0:27150 ▒▒▒▒▒ ▒▒▒▒▒ ▒▒▒▒▒▒▒:12111:h:0:27500:0:0:2 EPG TECT:12111:h:0:27500:0:0:3 010D011320:12111:h:0:27500:0:0:50 010E01120F:12111:h:0:27500:0:0:60 ▒▒▒▒▒▒▒▒:12111:h:0:27500:322:402:31002 ▒▒▒ ▒▒▒▒:12111:h:0:27500:324:404:31004 ▒▒▒▒▒▒ ▒▒▒▒▒▒▒:12111:h:0:27500:325:405:31005 ▒▒▒▒▒ ▒▒▒▒▒:12111:h:0:27500:326:406:31006 ▒▒▒:12111:h:0:27500:328:408:31008 ▒▒▒▒▒▒ ▒▒µ▒:12111:h:0:27500:329:409:31009 3 ▒▒▒▒▒:12111:h:0:27500:330:410:31010 І▒:12111:h:0:27500:331:411:31011 RT (▒▒▒▒▒▒▒▒):12111:h:0:27500:332:412:31012 ▒▒▒▒▒▒▒:12111:h:0:27500:333:413:31013 ▒▒-І:12111:h:0:27500:334:414:31014 TV SALE:12111:h:0:27500:335:415:31015 ▒▒▒▒▒▒ ▒▒µ▒:12111:h:0:27500:329:409:31050 3 ▒▒▒▒▒:12111:h:0:27500:330:410:31051 ▒▒▒:12111:h:0:27500:328:408:31052 ▒▒▒▒▒ ▒▒▒▒▒ µ▒▒:12111:h:0:27500:352:422:31102 365 ▒▒▒▒ І:12226:h:0:27500:320:400:10201 І ▒▒▒▒▒▒▒:12226:h:0:27500:321:402:10202 ▒▒▒▒▒▒▒ І:12226:h:0:27500:322:404:10203 ▒▒▒▒▒ І:12226:h:0:27500:323:406:10204 ▒▒▒▒▒▒▒ ▒▒▒▒:12226:h:0:27500:324:408:10205 ▒▒-▒▒▒▒▒ І:12226:h:0:27500:325:410:10206 ▒▒▒▒▒▒▒▒▒▒▒▒▒ І:12226:h:0:27500:326:412:10207 ▒▒▒▒▒▒▒▒▒▒ І:12226:h:0:27500:330:414:10208 ▒▒▒▒▒ І:12226:h:0:27500:328:416:10209 ▒▒▒▒ І:12226:h:0:27500:331:420:10211 ▒▒▒▒ ▒▒▒▒:12226:h:0:27500:332:422:10212 ▒▒▒▒▒-І:12226:h:0:27500:333:424:10213 Discovery:12303:h:0:27500:320:400:20501 DIVA Universal:12303:h:0:27500:321:402:20502 Disney Channel:12303:h:0:27500:328:404:20503 Animal Planet:12303:h:0:27500:323:406:20504 Discovery Travel&Living:12303:h:0:27500:324:408:20505 Eurosport:12303:h:0:27500:325:410:20506 VH1:12303:h:0:27500:326:412:20507 Mezzo (Muzzik):12303:h:0:27500:341:431:20508 Zone Romantica:12303:h:0:27500:330:414:20511 ґ▒:12303:h:0:27500:331:416:20512 Investigation Discovery:12303:h:0:27500:332:418:20513 National Geographic:12303:h:0:27500:329:420:20514 ▒▒η▒▒ ▒▒▒▒ ▒▒:12303:h:0:27500:333:422:20515 Discovery:12303:h:0:27500:320:400:20550 Disney Channel:12303:h:0:27500:328:404:20551 Eurosport:12303:h:0:27500:325:410:20552 ▒▒η▒▒ ▒▒▒▒ ▒▒:12303:h:0:27500:333:422:20553 Animal Planet:12303:h:0:27500:323:406:20554 Zone Romantica:12303:h:0:27500:330:414:20555 Ѕ▒ :11727:h:0:27500:51:52:901 ▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒ :11727:h:0:27500:101:102:902 Top Shop :11727:h:0:27500:151:152:903 RUSONG TV :11727:h:0:27500:201:202:904 Comedy TV :11727:h:0:27500:251:252:905 ▒І ▒▒▒▒ ▒▒▒▒ ▒▒▒▒ :11727:h:0:27500:301:302:906 ▒▒▒▒▒▒▒▒І :12073:h:0:27500:271:272:27000 ▒▒▒▒▒▒ :12073:h:0:27500:51:52:27005 ▒▒▒▒▒▒ 1 :12073:h:0:27500:101:102:27010 ▒І :12073:h:0:27500:151:152:27015 ▒▒▒▒▒▒ ▒ :12073:h:0:27500:201:202:27020 Ѕ▒ :12073:h:0:27500:251:252:27025 ▒▒▒▒▒▒ 2 :12073:h:0:27500:301:302:27030 ▒▒▒▒▒▒ 24 :12073:h:0:27500:401:402:27040 ▒▒▒▒▒▒▒▒▒ 5 ▒▒▒▒▒ :12073:h:0:27500:501:502:27050 ▒І :12073:h:0:27500:601:602:27060 ▒▒▒▒▒▒▒▒▒ ▒▒ :12073:h:0:27500:701:702:27070 ▒▒▒▒▒▒▒ :12073:h:0:27500:901:902:27090 І▒ :12073:h:0:27500:1001:1002:27100 ▒▒ І :12073:h:0:27500:1101:1102:27110 ▒▒▒ ▒▒▒▒▒▒ :12073:h:0:27500:1201:1202:27120 DRE:12073:h:0:27500:0:0:27150 ▒▒▒▒▒ ▒▒▒▒▒ ▒▒▒▒▒▒▒:12111:h:0:27500:0:0:2 EPG TECT:12111:h:0:27500:0:0:3 010D011320:12111:h:0:27500:0:0:50 010E01120F:12111:h:0:27500:0:0:60 ▒▒▒▒▒▒▒▒:12111:h:0:27500:322:402:31002 ▒▒▒ ▒▒▒▒:12111:h:0:27500:324:404:31004 ▒▒▒▒▒▒ ▒▒▒▒▒▒▒:12111:h:0:27500:325:405:31005 ▒▒▒▒▒ ▒▒▒▒▒:12111:h:0:27500:326:406:31006 ▒▒▒:12111:h:0:27500:328:408:31008 ▒▒▒▒▒▒ ▒▒µ▒:12111:h:0:27500:329:409:31009 3 ▒▒▒▒▒:12111:h:0:27500:330:410:31010 І▒:12111:h:0:27500:331:411:31011 RT (▒▒▒▒▒▒▒▒):12111:h:0:27500:332:412:31012 ▒▒▒▒▒▒▒:12111:h:0:27500:333:413:31013 ▒▒-І:12111:h:0:27500:334:414:31014 TV SALE:12111:h:0:27500:335:415:31015 ▒▒▒▒▒▒ ▒▒µ▒:12111:h:0:27500:329:409:31050 3 ▒▒▒▒▒:12111:h:0:27500:330:410:31051 ▒▒▒:12111:h:0:27500:328:408:31052 ▒▒▒▒▒ ▒▒▒▒▒ µ▒▒:12111:h:0:27500:352:422:31102 365 ▒▒▒▒ І:12226:h:0:27500:320:400:10201 І ▒▒▒▒▒▒▒:12226:h:0:27500:321:402:10202 ▒▒▒▒▒▒▒ І:12226:h:0:27500:322:404:10203 ▒▒▒▒▒ І:12226:h:0:27500:323:406:10204 ▒▒▒▒▒▒▒ ▒▒▒▒:12226:h:0:27500:324:408:10205 ▒▒-▒▒▒▒▒ І:12226:h:0:27500:325:410:10206 ▒▒▒▒▒▒▒▒▒▒▒▒▒ І:12226:h:0:27500:326:412:10207 ▒▒▒▒▒▒▒▒▒▒ І:12226:h:0:27500:330:414:10208 ▒▒▒▒▒ І:12226:h:0:27500:328:416:10209 ▒▒▒▒ І:12226:h:0:27500:331:420:10211 ▒▒▒▒ ▒▒▒▒:12226:h:0:27500:332:422:10212 ▒▒▒▒▒-І:12226:h:0:27500:333:424:10213 ▒І:12245:v:0:27500:320:400:10301 Ѕ▒:12245:v:0:27500:321:402:10302 MTV Russia:12245:v:0:27500:322:404:10303 ▒▒▒▒▒▒ 1:12245:v:0:27500:323:406:10304 ▒▒▒▒▒▒ ▒:12245:v:0:27500:324:408:10305 ▒▒▒-▒▒▒▒▒▒:12245:v:0:27500:325:410:10306 ▒▒▒▒▒▒ 24:12245:v:0:27500:326:412:10307 ▒▒▒▒:12245:v:0:27500:328:418:10308 ▒▒▒▒▒▒:12245:v:0:27500:329:419:10309 ▒▒▒▒▒▒▒▒:12245:v:0:27500:332:422:10314 24▒▒▒:12245:v:0:27500:333:423:10315 ▒▒▒▒▒ on-line:12245:v:0:27500:334:424:10316 Fashion TV Network:12245:v:0:27500:335:425:10317 Relax FM:12245:v:0:27500:0:427:10327 ▒▒▒ ▒▒▒▒▒▒:12245:v:0:27500:0:428:10328 ▒▒▒▒▒ ▒▒▒▒ FM ▒▒▒▒▒▒▒:12245:v:0:27500:0:429:10329 ▒▒▒▒▒▒:12245:v:0:27500:329:419:10350 Discovery:12303:h:0:27500:320:400:20501 DIVA Universal:12303:h:0:27500:321:402:20502 Disney Channel:12303:h:0:27500:328:404:20503 Animal Planet:12303:h:0:27500:323:406:20504 Discovery Travel&Living:12303:h:0:27500:324:408:20505 Eurosport:12303:h:0:27500:325:410:20506 VH1:12303:h:0:27500:326:412:20507 Mezzo (Muzzik):12303:h:0:27500:341:431:20508 Zone Romantica:12303:h:0:27500:330:414:20511 ґ▒:12303:h:0:27500:331:416:20512 Investigation Discovery:12303:h:0:27500:332:418:20513 National Geographic:12303:h:0:27500:329:420:20514 ▒▒η▒▒ ▒▒▒▒ ▒▒:12303:h:0:27500:333:422:20515 Discovery:12303:h:0:27500:320:400:20550 Disney Channel:12303:h:0:27500:328:404:20551 Eurosport:12303:h:0:27500:325:410:20552 ▒▒η▒▒ ▒▒▒▒ ▒▒:12303:h:0:27500:333:422:20553 Animal Planet:12303:h:0:27500:323:406:20554 Zone Romantica:12303:h:0:27500:330:414:20555 Euronews:12322:v:0:27500:330:412:20611 VH1 Classic:12322:v:0:27500:331:416:20612 CNN International:12322:v:0:27500:332:418:20613 Cartoon Network/TCM:12322:v:0:27500:333:420:20614 Discovery World:12322:v:0:27500:334:422:20615 Discovery Science:12322:v:0:27500:335:423:20616 MGM int.:12322:v:0:27500:336:424:20617 MTV Dance:12322:v:0:27500:337:426:20618 Zone Reality:12322:v:0:27500:338:428:20619 MCM:12322:v:0:27500:339:430:20620 Extreme Sports:12322:v:0:27500:340:432:20621 Nat Geo Wild:12322:v:0:27500:341:434:20622 Jim Jam:12322:v:0:27500:342:436:20623 Euronews:12322:v:0:27500:330:412:20650 Zone Reality:12322:v:0:27500:338:428:20651 MCM:12322:v:0:27500:339:430:20652 Cartoon Network/TCM:12322:v:0:27500:333:420:20653 а через scan-s2 больше каналов dumping lists (107 services) Ѕ▒;TricolorTV:11727:hS0:S0.0W:27500:51:52=rus:0:0:901:65535:9:0 ▒▒▒▒▒▒▒▒ ▒▒▒▒▒▒▒;TricolorTV:11727:hS0:S0.0W:27500:101:102=rus:0:0:902:65535:9:0 Top Shop;TricolorTV:11727:hS0:S0.0W:27500:151:152=rus:0:0:903:65535:9:0 RUSONG TV;TricolorTV:11727:hS0:S0.0W:27500:201:202=rus:0:0:904:65535:9:0 Comedy TV;TricolorTV:11727:hS0:S0.0W:27500:251:252=rus:0:0:905:65535:9:0 ▒І ▒▒▒▒ ▒▒▒▒ ▒▒▒▒;TricolorTV:11727:hS0:S0.0W:27500:301:302=rus:0:0:906:65535:9:0 ▒▒▒▒▒▒▒▒І;TricolorTV:12073:hS0:S0.0W:27500:271:272=rus,273=AUD:0:0:27000:65535:27:0 ▒▒▒▒▒▒;TricolorTV:12073:hS0:S0.0W:27500:51:52=rus:53:0:27005:65535:27:0 ▒▒▒▒▒▒ 1;TricolorTV:12073:hS0:S0.0W:27500:101:102=rus:103:0:27010:65535:27:0 ▒І;TricolorTV:12073:hS0:S0.0W:27500:151:152=rus:0:0:27015:65535:27:0 ▒▒▒▒▒▒ ▒;TricolorTV:12073:hS0:S0.0W:27500:201:202=rus:199:0:27020:65535:27:0 Ѕ▒;TricolorTV:12073:hS0:S0.0W:27500:251:252=rus:0:0:27025:65535:27:0 ▒▒▒▒▒▒ 2;TricolorTV:12073:hS0:S0.0W:27500:301:302=rus:0:0:27030:65535:27:0 ▒▒▒▒▒▒ 24;TricolorTV:12073:hS0:S0.0W:27500:401:402=rus:0:0:27040:65535:27:0 ▒▒▒▒▒▒▒▒▒ 5 ▒▒▒▒▒;TricolorTV:12073:hS0:S0.0W:27500:501:502=rus:0:0:27050:65535:27:0 ▒І;TricolorTV:12073:hS0:S0.0W:27500:601:602=rus:0:0:27060:65535:27:0 ▒▒▒▒▒▒▒▒▒ ▒▒;TricolorTV:12073:hS0:S0.0W:27500:701:702=rus:0:0:27070:65535:27:0 ▒▒▒▒▒▒▒;TricolorTV:12073:hS0:S0.0W:27500:901:902=rus:0:0:27090:65535:27:0 І▒;TricolorTV:12073:hS0:S0.0W:27500:1001:1002=rus:1003:0:27100:65535:27:0 ▒▒ І;TricolorTV:12073:hS0:S0.0W:27500:1101:1102=rus:0:0:27110:65535:27:0 ▒▒▒ ▒▒▒▒▒▒;TricolorTV:12073:hS0:S0.0W:27500:1201:1202=rus:0:0:27120:65535:27:0 ▒▒▒▒▒▒▒▒;HTB+:12111:hS0:S0.0W:27500:322:402=rus:0:0:31002:112:10:0 ▒▒▒ ▒▒▒▒;HTB+:12111:hS0:S0.0W:27500:324:404=rus:0:0:31004:112:10:0 ▒▒▒▒▒▒ ▒▒▒▒▒▒▒;HTB+:12111:hS0:S0.0W:27500:325:405=rus:0:0:31005:112:10:0 ▒▒▒▒▒ ▒▒▒▒▒;HTB+:12111:hS0:S0.0W:27500:326:406=rus:0:0:31006:112:10:0 ▒▒▒;HTB+:12111:hS0:S0.0W:27500:328:408=rus:0:0:31008:112:10:0 ▒▒▒▒▒▒ ▒▒µ▒;HTB+:12111:hS0:S0.0W:27500:329:409=rus:0:0:31009:112:10:0 3 ▒▒▒▒▒;HTB+:12111:hS0:S0.0W:27500:330:410=rus:0:0:31010:112:10:0 І▒;HTB+:12111:hS0:S0.0W:27500:331:411=rus:511:0:31011:112:10:0 RT (▒▒▒▒▒▒▒▒);HTB+:12111:hS0:S0.0W:27500:332:412=ara:0:0:31012:112:10:0 ▒▒▒▒▒▒▒;HTB+:12111:hS0:S0.0W:27500:333:413=rus:0:0:31013:112:10:0 ▒▒-І;HTB+:12111:hS0:S0.0W:27500:334:414=rus:0:0:31014:112:10:0 TV SALE;HTB+:12111:hS0:S0.0W:27500:335:415=rus:0:0:31015:112:10:0 ▒▒▒▒▒▒ ▒▒µ▒;HTB+:12111:hS0:S0.0W:27500:329:409=rus:0:0:31050:112:10:0 3 ▒▒▒▒▒;HTB+:12111:hS0:S0.0W:27500:330:410=rus:0:0:31051:112:10:0 ▒▒▒;HTB+:12111:hS0:S0.0W:27500:328:408=rus:0:0:31052:112:10:0 ▒▒▒▒▒ ▒▒▒▒▒ µ▒▒;HTB+:12111:hS0:S0.0W:27500:352+422:422:0:0:31102:112:10:0 365 ▒▒▒▒ І;HTB+:12226:hS0:S0.0W:27500:320:400=rus:0:0:10201:112:2:0 І ▒▒▒▒▒▒▒;HTB+:12226:hS0:S0.0W:27500:321:402=rus:0:0:10202:112:2:0 ▒▒▒▒▒▒▒ І;HTB+:12226:hS0:S0.0W:27500:322:404=rus:0:0:10203:112:2:0 ▒▒▒▒▒ І;HTB+:12226:hS0:S0.0W:27500:323:406=rus:0:0:10204:112:2:0 ▒▒▒▒▒▒▒ ▒▒▒▒;HTB+:12226:hS0:S0.0W:27500:324:408=rus:0:0:10205:112:2:0 ▒▒-▒▒▒▒▒ І;HTB+:12226:hS0:S0.0W:27500:325:410=rus:0:0:10206:112:2:0 ▒▒▒▒▒▒▒▒▒▒▒▒▒ І;HTB+:12226:hS0:S0.0W:27500:326:412=rus:0:0:10207:112:2:0 ▒▒▒▒▒▒▒▒▒▒ І;HTB+:12226:hS0:S0.0W:27500:330:414=rus:0:0:10208:112:2:0 ▒▒▒▒▒ І;HTB+:12226:hS0:S0.0W:27500:328:416=rus:0:0:10209:112:2:0 ▒▒▒▒ І;HTB+:12226:hS0:S0.0W:27500:331:420=rus:0:0:10211:112:2:0 ▒▒▒▒ ▒▒▒▒;HTB+:12226:hS0:S0.0W:27500:332:422=rus:0:0:10212:112:2:0 ▒▒▒▒▒-І;HTB+:12226:hS0:S0.0W:27500:333:424=rus:0:0:10213:112:2:0 ▒І;HTB+:12245:vS0:S0.0W:27500:320:400=rus,401=und:0:0:10301:112:3:0 Ѕ▒;HTB+:12245:vS0:S0.0W:27500:321:402=rus,403:0:0:10302:112:3:0 MTV Russia;HTB+:12245:vS0:S0.0W:27500:322:404=rus:0:0:10303:112:3:0 ▒▒▒▒▒▒ 1;HTB+:12245:vS0:S0.0W:27500:323:406=rus:0:0:10304:112:3:0 ▒▒▒▒▒▒ ▒;HTB+:12245:vS0:S0.0W:27500:324:408=rus:0:0:10305:112:3:0 ▒▒▒-▒▒▒▒▒▒;HTB+:12245:vS0:S0.0W:27500:325:410=rus:0:0:10306:112:3:0 ▒▒▒▒▒▒ 24;HTB+:12245:vS0:S0.0W:27500:326:412=rus:0:0:10307:112:3:0 ▒▒▒▒;HTB+:12245:vS0:S0.0W:27500:328:418=rus:0:0:10308:112:3:0 ▒▒▒▒▒▒;HTB+:12245:vS0:S0.0W:27500:329:419=rus:0:0:10309:112:3:0 ▒▒▒▒▒▒▒▒;HTB+:12245:vS0:S0.0W:27500:332:422=rus:0:0:10314:112:3:0 24▒▒▒;HTB+:12245:vS0:S0.0W:27500:333:423=rus:0:0:10315:112:3:0 ▒▒▒▒▒ on-line;HTB+:12245:vS0:S0.0W:27500:334:424=rus:0:0:10316:112:3:0 Fashion TV Network;HTB+:12245:vS0:S0.0W:27500:335:425=rus:0:0:10317:112:3:0 Relax FM;HTB+:12245:vS0:S0.0W:27500:0:427=rus:0:0:10327:112:3:0 ▒▒▒ ▒▒▒▒▒▒;HTB+:12245:vS0:S0.0W:27500:0:428=rus:0:0:10328:112:3:0 ▒▒▒▒▒ ▒▒▒▒ FM ▒▒▒▒▒▒▒;HTB+:12245:vS0:S0.0W:27500:0:429:0:0:10329:112:3:0 ▒▒▒▒▒▒;HTB+:12245:vS0:S0.0W:27500:329:419=rus:0:0:10350:112:3:0 Discovery;HTB+:12303:hS0:S0.0W:27500:320:400=rus,401=eng:0:0:20501:112:5:0 DIVA Universal;HTB+:12303:hS0:S0.0W:27500:321:402=rus,403=eng:0:0:20502:112:5:0 Disney Channel;HTB+:12303:hS0:S0.0W:27500:328:404=rus,405=eng:0:0:20503:112:5:0 Animal Planet;HTB+:12303:hS0:S0.0W:27500:323:406=rus,407=eng:0:0:20504:112:5:0 Discovery Travel&Living;HTB+:12303:hS0:S0.0W:27500:324:408=rus,409=eng:0:0:20505:112:5:0 Eurosport;HTB+:12303:hS0:S0.0W:27500:325:410=rus:0:0:20506:112:5:0 VH1;HTB+:12303:hS0:S0.0W:27500:326:412=eng:0:0:20507:112:5:0 Mezzo (Muzzik);HTB+:12303:hS0:S0.0W:27500:341:431=fra:0:0:20508:112:5:0 Zone Romantica;HTB+:12303:hS0:S0.0W:27500:330:414=rus:0:0:20511:112:5:0 ґ▒;HTB+:12303:hS0:S0.0W:27500:331:416=rus:0:0:20512:112:5:0 Investigation Discovery;HTB+:12303:hS0:S0.0W:27500:332:418=rus,419=eng:0:0:20513:112:5:0 National Geographic;HTB+:12303:hS0:S0.0W:27500:329:420=rus,421=eng:0:0:20514:112:5:0 ▒▒η▒▒ ▒▒▒▒ ▒▒;HTB+:12303:hS0:S0.0W:27500:333:422=rus:0:0:20515:112:5:0 Discovery;HTB+:12303:hS0:S0.0W:27500:320:400=rus,401=eng:0:0:20550:112:5:0 Disney Channel;HTB+:12303:hS0:S0.0W:27500:328:404=rus,405=eng:0:0:20551:112:5:0 Eurosport;HTB+:12303:hS0:S0.0W:27500:325:410=rus:0:0:20552:112:5:0 ▒▒η▒▒ ▒▒▒▒ ▒▒;HTB+:12303:hS0:S0.0W:27500:333:422=rus:0:0:20553:112:5:0 Animal Planet;HTB+:12303:hS0:S0.0W:27500:323:406=rus,407=eng:0:0:20554:112:5:0 Zone Romantica;HTB+:12303:hS0:S0.0W:27500:330:414=rus:0:0:20555:112:5:0 Euronews;HTB+:12322:vS0:S0.0W:27500:330:412=rus,413=deu,414=eng,415=fra,465=ita,466=spa:0:0:20611:112:6:0 VH1 Classic;HTB+:12322:vS0:S0.0W:27500:331:416=eng:0:0:20612:112:6:0 CNN International;HTB+:12322:vS0:S0.0W:27500:332:418=eng:0:0:20613:112:6:0 Cartoon Network/TCM;HTB+:12322:vS0:S0.0W:27500:333:420=eng,421=rus:0:0:20614:112:6:0 Discovery World;HTB+:12322:vS0:S0.0W:27500:334:422=rus,442=eng:0:0:20615:112:6:0 Discovery Science;HTB+:12322:vS0:S0.0W:27500:335:423=rus,443=eng:0:0:20616:112:6:0 MGM int.;HTB+:12322:vS0:S0.0W:27500:336:424=rus,425=eng:0:0:20617:112:6:0 MTV Dance;HTB+:12322:vS0:S0.0W:27500:337:426=eng:0:0:20618:112:6:0 Zone Reality;HTB+:12322:vS0:S0.0W:27500:338:428=rus,429=eng:0:0:20619:112:6:0 MCM;HTB+:12322:vS0:S0.0W:27500:339:430=eng:0:0:20620:112:6:0 Extreme Sports;HTB+:12322:vS0:S0.0W:27500:340:432=rus,433=eng:0:0:20621:112:6:0 Nat Geo Wild;HTB+:12322:vS0:S0.0W:27500:341:434=rus,435=eng:0:0:20622:112:6:0 Jim Jam;HTB+:12322:vS0:S0.0W:27500:342:436=rus,437=eng:0:0:20623:112:6:0 Euronews;HTB+:12322:vS0:S0.0W:27500:330:412=rus,413=deu,414=eng,415=fra,465=ita,466=spa:0:0:20650:112:6:0 Zone Reality;HTB+:12322:vS0:S0.0W:27500:338:428=rus,429=eng:0:0:20651:112:6:0 MCM;HTB+:12322:vS0:S0.0W:27500:339:430=eng:0:0:20652:112:6:0 Cartoon Network/TCM;HTB+:12322:vS0:S0.0W:27500:333:420=eng,421=rus:0:0:20653:112:6:0 вопрос : почему такая разница? далее продолжу мысль, к примеру возьмем для кодированного канала к примеру MTV Russia:12245:v:0:27500:322:404:10303 конфиг получится такой http { port 8000; }; adapter 1 { budget-mode 1; packet-buffer 50; stat-interval 120; dvb-s { #lnb-sharing yes; lnb { lof1 10750000; lof2 10750000; slof 11700000; }; transponder { frequency 12245000; polarisation v; symbol-rate 27500000; }; }; stream { name "Soyuz"; input { pnr 10303; }; Это правильно? Адаптер 1 - это виртуальный dvbloopback собствено dmesg dmesg | grep DVB [ 9.474338] DVB: registering new adapter (OMICOM S2 PCI (rev.3)) [ 9.991441] DVB: registering adapter 0 frontend 0 (STV090x Multistandard)... [ 391.069293] DVB: adapter 0 frontend 0 frequency 9750000 out of range (950000..2150000) [ 391.277302] DVB: adapter 0 frontend 0 frequency 9750000 out of range (950000..2150000) [ 1358.493536] DVB: registering new adapter (DVB-LOOPBACK) меня еще смущает вот эта строчка DVB: adapter 0 frontend 0 frequency 9750000 out of range (950000..2150000) Заранее спасибо! Изменено 9 декабря, 2010 пользователем server801 Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Roma_n Опубликовано 9 декабря, 2010 · Жалоба далее продолжу мысль, к примеру возьмем для кодированного канала к примеру MTV Russia:12245:v:0:27500:322:404:10303 конфиг получится такой http { port 8000; }; adapter 1 { budget-mode 1; packet-buffer 50; stat-interval 120; dvb-s { #lnb-sharing yes; lnb { lof1 10750000; lof2 10750000; slof 11700000; }; transponder { frequency 12245000; polarisation v; symbol-rate 27500000; }; }; stream { name "Soyuz"; input { pnr 10303; }; Это правильно? Адаптер 1 - это виртуальный dvbloopback собствено dmesg dmesg | grep DVB [ 9.474338] DVB: registering new adapter (OMICOM S2 PCI (rev.3)) [ 9.991441] DVB: registering adapter 0 frontend 0 (STV090x Multistandard)... [ 391.069293] DVB: adapter 0 frontend 0 frequency 9750000 out of range (950000..2150000) [ 391.277302] DVB: adapter 0 frontend 0 frequency 9750000 out of range (950000..2150000) [ 1358.493536] DVB: registering new adapter (DVB-LOOPBACK) меня еще смущает вот эта строчка DVB: adapter 0 frontend 0 frequency 9750000 out of range (950000..2150000) Заранее спасибо! Насчёт первой половины вопроса - не понял, о чём речь. По второй половине: всё правильно за исключением того, что MTV Russia идёт на 12399 R (в нашем случае - это действительно V). И название канала надо менять в конфиге, чтоб самому потом не запутаться. А pnr действительно 10303. Только на 12245 Вы его не найдёте. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
MasterHome Опубликовано 9 декабря, 2010 (изменено) · Жалоба server801 Рекомендую http://www.lyngsat.com Дабы избежать излишнего копи-паста каши набора каналов с 36Е. Настройки конвертера под круговую поляризацию lnb { lof1 10750000; lof2 10750000; slof 10750000; }; Иначе будет смещение частоты транспондеров, именно поэтому частота с 12399 съехала на 12245, при этом часть каналов пропала, а часть из тех, которые видятся, показывать не будут. Изменено 9 декабря, 2010 пользователем MasterHome Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
server801 Опубликовано 9 декабря, 2010 (изменено) · Жалоба Молчание... запускаю виртуальный адаптер /usr/bin/sasc-ng -j 0:1 --cam-budget --cam-dir /etc/camfiles Dec 9 15:35:55.642 CAM(core.net): connecting to cserv14.net:10000/tcp (77.221.136.146) Dec 9 15:35:55.790 CAM(cardclient.login): Newcamd: CaID=0500 admin=0 srvUA=0000000000000000 provider 040600/0000000000000000 030600/0000000000000000 023700/0000000000000000 Dec 9 15:35:55.790 CAM(general.error): failed open /etc/camfiles/SoftCam.Key: No such file or directory Dec 9 15:35:55.790 CAM(general.error): failed open /etc/camfiles/smartcard.conf: No such file or directory Dec 9 15:35:55.790 CAM(general.error): failed open /etc/camfiles/cardslot.conf: No such file or directory Dec 9 15:35:55.790 CAM(general.error): failed open /etc/camfiles/override.conf: No such file or directory Dec 9 15:35:55.790 CAM(general.error): no keys loaded for softcam! Dec 9 15:35:55.790 CAM(core.load): ** registered systems: Dec 9 15:35:55.790 CAM(core.load): ** Cardclient (pri -15) Dec 9 15:35:55.790 CAM(core.load): ** Conax (pri -10) Dec 9 15:35:55.790 CAM(core.load): ** ConstCW (pri -20) Dec 9 15:35:55.790 CAM(core.load): ** Cryptoworks (pri -10) Dec 9 15:35:55.790 CAM(core.load): ** Irdeto (pri -10) Dec 9 15:35:55.790 CAM(core.load): ** Irdeto2 (pri -8) Dec 9 15:35:55.790 CAM(core.load): ** Nagra (pri -10) Dec 9 15:35:55.790 CAM(core.load): ** Nagra2 (pri -10) Dec 9 15:35:55.790 CAM(core.load): ** Fake-NDS (pri -12) Dec 9 15:35:55.790 CAM(core.load): ** SC-Conax (pri -5) Dec 9 15:35:55.790 CAM(core.load): ** SC-Cryptoworks (pri -5) Dec 9 15:35:55.790 CAM(core.load): ** SC-Irdeto (pri -5) Dec 9 15:35:55.790 CAM(core.load): ** SC-Nagra (pri -5) Dec 9 15:35:55.790 CAM(core.load): ** SC-Seca (pri -5) Dec 9 15:35:55.790 CAM(core.load): ** SC-Viaccess (pri -5) Dec 9 15:35:55.790 CAM(core.load): ** SC-VideoGuard2 (pri -5) Dec 9 15:35:55.790 CAM(core.load): ** Seca (pri -10) Dec 9 15:35:55.790 CAM(core.load): ** @SHL (pri -10) Dec 9 15:35:55.790 CAM(core.load): ** Viaccess (pri -10) Dec 9 15:35:56.799 demux: Starting thread on /dev/dvb/adapter1/demux1 The thread scheduling parameters indicate: policy = 0 priority = 0 Dec 9 15:35:56.799 dvr: Starting thread on /dev/dvb/adapter1/dvr1 The thread scheduling parameters indicate: policy = 1 priority = 99 Dec 9 15:35:56.799 frontend: Starting thread on /dev/dvb/adapter1/frontend1 The thread scheduling parameters indicate: policy = 0 priority = 0 Dec 9 15:35:56.799 : Listening on port 5456 Dec 9 15:37:56.687 CAM(core.net): idle timeout, disconnected cserv14.net:10000 конфиг http { port 8000; }; adapter 1 { budget-mode 0; packet-buffer 50; stat-interval 120; dvb-s { #lnb-sharing yes; lnb { lof1 10750000; lof2 10750000; slof 10750000; }; transponder { frequency 12245000; polarisation v; symbol-rate 27500000; }; }; stream { name "MTV Russia"; input { pnr 10303; }; output-http { url "/MTV_Russia"; }; }; }; далее /usr/local/bin/getstream -c кофиг -ddd и ничего не происходит... Ткните носом, где ошибка . Изменено 9 декабря, 2010 пользователем server801 Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
MasterHome Опубликовано 9 декабря, 2010 · Жалоба server801 Еще раз ВНИМАТЕЛЬНО прочитать предыдущий пост и пред-предыдущий про частоту транспондера. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
server801 Опубликовано 9 декабря, 2010 · Жалоба Прочитал... Исправил http { port 8000; }; adapter 1 { #budget-mode 0; packet-buffer 50; stat-interval 120; dvb-s { #lnb-sharing on; lnb { lof1 10750000; lof2 10750000; slof 10750000; }; transponder { frequency 12399000; polarisation v; symbol-rate 27500000; }; }; stream { name "MTV Russia"; input { pnr 10303; }; output-http { url "/MTV_Russia"; }; }; }; Ситауция не меняется... Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
MasterHome Опубликовано 9 декабря, 2010 (изменено) · Жалоба output-http {url "/MTV_Russia"; }; Кавычки в URL ненужны. Изменено 9 декабря, 2010 пользователем MasterHome Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
server801 Опубликовано 9 декабря, 2010 · Жалоба Разницы никакой.... Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Roma_n Опубликовано 9 декабря, 2010 · Жалоба Ситауция не меняется... Dec 9 15:37:56.687 CAM(core.net): idle timeout, disconnected cserv14.net:10000 - sasc теряет соединение с сервером по таймауту. Что при этом пишет getstream? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
server801 Опубликовано 9 декабря, 2010 (изменено) · Жалоба Ситауция не меняется...Dec 9 15:37:56.687 CAM(core.net): idle timeout, disconnected cserv14.net:10000 - sasc теряет соединение с сервером по таймауту. Что при этом пишет getstream? Абсолютно ничего root@tv:/usr/share/dvb/dvb-s# /usr/local/bin/getstream -c 4 -ddd далее никакой инфы Такое впечатление, что он вообще не цепляет каналы ... Вот если открытые каналы - адаптер реальный (adapter0) , то лог /usr/local/bin/getstream -c 3 -ddd 2010-12-09 18:34:24.393 fe: Adapter 0 Setting up frontend tuner 2010-12-09 18:34:24.405 fe: DVB-S tone = 0 2010-12-09 18:34:24.405 fe: DVB-S voltage = 1 2010-12-09 18:34:24.405 fe: DVB-S diseqc = 0 2010-12-09 18:34:24.405 fe: DVB-S freq = 12303000 2010-12-09 18:34:24.405 fe: DVB-S lof1 = 10750000 2010-12-09 18:34:24.405 fe: DVB-S lof2 = 10750000 2010-12-09 18:34:24.405 fe: DVB-S slof = 10750000 2010-12-09 18:34:24.405 fe: DVB-S feparams.frequency = 1553000 2010-12-09 18:34:24.405 fe: DVB-S feparams.inversion = 2 2010-12-09 18:34:24.405 fe: DVB-S feparams.u.qpsk.symbol_rate = 27500000 2010-12-09 18:34:24.406 dmx: Setting filter for pid 8192 pestype 20 2010-12-09 18:34:24.406 dvr: Add Section callback for PID 0 (0x0000) type 1 (PAT) 2010-12-09 18:34:24.406 dvr: Add TS callback for PID 0 (0x0000) type 9 (Reassemble) 2010-12-09 18:34:24.597 fe: Adapter 0 Status: 0x1f (HAS_SIGNAL HAS_CARRIER HAS_VITERBI HAS_SYNC HAS_LOCK) 2010-12-09 18:34:24.735 pat: found program 0190(400) pmt pid 0122 2010-12-09 18:34:24.735 pat: found program 001e(30) pmt pid 0c04 2010-12-09 18:34:24.735 pat: found program 0020(32) pmt pid 0c08 2010-12-09 18:34:24.735 pat: found program 002d(45) pmt pid 0c05 2010-12-09 18:34:24.735 pat: found program 0039(57) pmt pid 0be0 2010-12-09 18:34:24.735 pat: found program 0003(3) pmt pid 0086 2010-12-09 18:34:24.735 pat: found program 0004(4) pmt pid 007c 2010-12-09 18:34:24.735 pat: found program 003b(59) pmt pid 03b0 2010-12-09 18:34:24.735 pat: found program 019a(410) pmt pid 0123 2010-12-09 18:34:24.735 pat: found program 7922(31010) pmt pid 044c 2010-12-09 18:34:24.735 pat: found program 792c(31020) pmt pid 04b0 2010-12-09 18:34:24.735 pat: found program 7936(31030) pmt pid 0514 2010-12-09 18:34:24.735 pat: found program 7940(31040) pmt pid 05df 2010-12-09 18:34:24.735 pat: found program 794a(31050) pmt pid 0643 2010-12-09 18:34:24.735 pat: found program 7954(31060) pmt pid 0258 2010-12-09 18:34:24.735 pat: found program 795e(31070) pmt pid 06a4 2010-12-09 18:34:24.735 pat: found program 7968(31080) pmt pid 0708 2010-12-09 18:34:24.735 pat: found program 7972(31090) pmt pid 0771 2010-12-09 18:34:24.735 pat: pat parse found 18 programs 2010-12-09 18:34:24.735 dvr: Add Section callback for PID 290 (0x0122) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 290 (0x0122) type 9 (Reassemble) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 290 (0x0122) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add Section callback for PID 3076 (0x0c04) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 3076 (0x0c04) type 9 (Reassemble) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 3076 (0x0c04) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 3076 (0x0c04) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add Section callback for PID 3080 (0x0c08) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 3080 (0x0c08) type 9 (Reassemble) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 3080 (0x0c08) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add Section callback for PID 134 (0x0086) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 134 (0x0086) type 9 (Reassemble) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 134 (0x0086) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add Section callback for PID 124 (0x007c) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 124 (0x007c) type 9 (Reassemble) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 124 (0x007c) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add Section callback for PID 944 (0x03b0) type 2 (PMT) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 944 (0x03b0) type 9 (Reassemble) 2010-12-09 18:34:24.735 dvr: Add TS callback for PID 944 (0x03b0) type 2 (PMT) 2010-12-09 18:34:24.748 pmt: parse_pmt found 3 elementary streams for pnr 0190 2010-12-09 18:34:24.748 pmt: pmt_update running for program 0190 2010-12-09 18:34:24.748 dvr: Add TS callback for PID 401 (0x0191) type 4 (Video) 2010-12-09 18:34:24.748 dvr: Add TS callback for PID 402 (0x0192) type 5 (Audio) 2010-12-09 18:34:24.749 dvr: Add TS callback for PID 404 (0x0194) type 6 (Privat) 2010-12-09 18:34:24.749 pmt: parse_pmt found 1 elementary streams for pnr 001e 2010-12-09 18:34:24.749 pmt: pmt_update running for program 001e 2010-12-09 18:34:24.749 dvr: Add TS callback for PID 4143 (0x102f) type 5 (Audio) 2010-12-09 18:34:24.749 dvr: Add TS callback for PID 4143 (0x102f) type 5 (Audio) 2010-12-09 18:34:24.762 pmt: parse_pmt found 1 elementary streams for pnr 0020 2010-12-09 18:34:24.762 pmt: pmt_update running for program 0020 2010-12-09 18:34:24.762 dvr: Add TS callback for PID 4200 (0x1068) type 5 (Audio) 2010-12-09 18:34:24.803 pmt: parse_pmt found 2 elementary streams for pnr 0003 2010-12-09 18:34:24.803 pmt: pmt_update running for program 0003 2010-12-09 18:34:24.803 dvr: Add TS callback for PID 303 (0x012f) type 4 (Video) 2010-12-09 18:34:24.803 dvr: Add TS callback for PID 405 (0x0195) type 5 (Audio) 2010-12-09 18:34:24.816 pmt: parse_pmt found 1 elementary streams for pnr 0004 2010-12-09 18:34:24.816 pmt: pmt_update running for program 0004 2010-12-09 18:34:24.816 dvr: Add TS callback for PID 126 (0x007e) type 5 (Audio) 2010-12-09 18:34:24.816 pmt: parse_pmt found 2 elementary streams for pnr 003b 2010-12-09 18:34:24.816 pmt: pmt_update running for program 003b 2010-12-09 18:34:24.816 dvr: Add TS callback for PID 308 (0x0134) type 4 (Video) 2010-12-09 18:34:24.816 dvr: Add TS callback for PID 256 (0x0100) type 5 (Audio) А если закрытые каналы - то виртуальный adapter1 (dvbloopback) то тишина... логи вверху Изменено 9 декабря, 2010 пользователем server801 Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Roma_n Опубликовано 9 декабря, 2010 · Жалоба root@tv:/usr/share/dvb/dvb-s# /usr/local/bin/getstream -c 4 -dddдалее никакой инфы Такое впечатление, что он вообще не цепляет каналы ... Так у тебя getstream не запускается. Ставь ему опцию -d вместо -ddd (хотя скорее всего это без разницы). А самое главное - внимательно проверь путь к файлу конфигурации. Почти 100%, что getstream не находит свой конфиг и поэтому не запускается. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
