Кто-нить использует getstream для вещания транспондера в сеть ?
поделитесь плиз конфигом ?
У меня
root@tv1:~# ./12303-36e-getstream
2009-01-08 21:49:02.551 fe: Adapter 0 Setting up frontend tuner
2009-01-08 21:49:02.556 fe: DVB-S tone = 0
2009-01-08 21:49:02.556 fe: DVB-S voltage = 1
2009-01-08 21:49:02.556 fe: DVB-S diseqc = 0
2009-01-08 21:49:02.556 fe: DVB-S freq = 12303000
2009-01-08 21:49:02.556 fe: DVB-S lof1 = 9750000
2009-01-08 21:49:02.556 fe: DVB-S lof2 = 10600000
2009-01-08 21:49:02.556 fe: DVB-S slof = 11700000
2009-01-08 21:49:02.556 fe: DVB-S feparams.frequency = 1703000
2009-01-08 21:49:02.556 fe: DVB-S feparams.inversion = 2
2009-01-08 21:49:02.556 fe: DVB-S feparams.u.qpsk.symbol_rate = 27500000
2009-01-08 21:49:02.556 dmx: Setting filter for pid 8192 pestype 20
2009-01-08 21:49:02.657 fe: Adapter 0 Status: 0x1f (HAS_SIGNAL HAS_CARRIER HAS_VITERBI HAS_SYNC HAS_LOCK)
2009-01-08 21:49:11.731 stream_http: connection from 10.7.52.52 for /aone
2009-01-08 21:49:54.824 stream_http: dropping connection to 10.7.52.52 for /aone
2009-01-08 21:51:02.558 dvr: inputstats: 88 pids 24703 pkt/s 4644333 byte/s
2009-01-08 21:53:02.559 dvr: inputstats: 88 pids 24698 pkt/s 4643410 byte/s
2009-01-08 21:54:48.246 stream_http: connection from 10.7.52.52 for /aone
2009-01-08 21:55:02.559 dvr: inputstats: 88 pids 24699 pkt/s 4643554 byte/s
2009-01-08 21:57:02.561 dvr: inputstats: 88 pids 24700 pkt/s 4643620 byte/s
2009-01-08 21:57:14.705 stream_http: dropping connection to 10.7.52.52 for /aone
2009-01-08 21:58:24.382 stream_http: connection from 10.7.52.52 for /aone
2009-01-08 21:59:02.562 dvr: inputstats: 88 pids 24699 pkt/s 4643562 byte/s
2009-01-08 22:01:02.562 dvr: inputstats: 88 pids 24699 pkt/s 4643429 byte/s
2009-01-08 22:03:02.563 dvr: inputstats: 88 pids 24699 pkt/s 4643571 byte/s
2009-01-08 22:05:02.563 dvr: inputstats: 88 pids 24699 pkt/s 4643593 byte/s
2009-01-08 22:07:02.563 dvr: inputstats: 88 pids 24699 pkt/s 4643565 byte/s
[code]
видимо процесс вещания происходит, но в клиенте vlc -пусто.
  • Replies 2.5k
  • Created
  • Last Reply
Top Posters In This Topic
например так:
config-eutelsat36-11727-full:
http {
        port 8001;
adapter 0 {
        packet-buffer 50;
        stat-interval 120;
        dvb-s {
                #lnb-sharing yes;
                lnb {
                        lof1 10750000;
                        lof2 10750000;
                        slof 11700000;
                transponder {
                        frequency 11727000;
                        polarisation h;
                        symbol-rate 27500000;
        stream {
                name "Full";
                input {
                        full;
                output-udp {
                        remote-address 225.1.1.1;
                        remote-port 1234;
                        sap {
                                scope global;
                                ttl 5;
                                playgroup "Free";
заодно вопрос: для чего нужен вывод в pipe? например:
        stream {
                name "eutelsat36-11727-management";
                input {
                        pid 0x0;
                        pid 0x10;
                        pid 0x11;
                        pid 0x12;
                        pid 0x13;
                        pid 0x14;
                output-pipe {
                        filename "/tmp/eutelsat36-11727";
кстати, Mechanic, судя по всему у вас неверно частоты гетеродина выставлены:
На 36E - круговая поляризация и обе частоты должны быть установлены в 10750000
пока одна (SkyStar2) - тестируем. нагрузки практически нет. getstream из под скрина запущен пока что. потом, конечно, обвязку сделаем, чтобы при старте системы запускался.
а про pipe ничего не скажете?
привет всем
                output-pipe {
я так понимаю что это "запись в файл" перечисленных выше пидов (скорее всего это пиды епг)
нет, это я и сам понимаю :) а для чего это надо и как (чем) это обрабатывать?
Alexander - а где ты конфиги такие нашел??
к исходникам getstream'а прилагались
у меня с этим конфигом почемуто вылавливает нтв+ :)
а какие именно каналы вылавливает?
косяк какой то - и 12226 -вместо триколора - нтв - тот же транспондер...
тут скорее всего дело в поляризации. НТВ+ - круговая, а триколор - ээ.. некруговая :)
и еще один баг - почему то срывается вещание :
2009-01-16 14:23:26.616 stream_http: connection from 192.168.10.94 for /tv1
2009-01-16 14:28:24.878 stream_http: dropping connection to 192.168.10.94 for /tv1
я не отключал..
у меня такое бывает, когда в сети пакеты теряются. тогда клиент коннекцию отрубает. посмотри tcpdump'ом, кто сессию прерывает.
а меня с исходниками конфиги на астру..
Естественно, я слегка подредактировал под 36E..
транспондер везде у меня один и тотже - судя по программам 12456 L, не смотря на указываемую частоту в конфиге - не влияет на ситуацию даже изменение промежуточных частот в конфиге (хоть 10600 - хоть 9750).
Попробуй обе частоты в 10750 выставить.
попробовал поляризацию сменить - говори:
Попробуй создать файлик test:
S 12456000 L 27500000 AUTO
и натравить на него scandvb:
scandvb -l 10750,10750 test
что выдает?
и т.д. и заканчует таблицей каналов - но каналы одни и теже - но частоты разные
про разные частоты - не понял. у меня так:
using '/dev/dvb/adapter0/frontend0' and '/dev/dvb/adapter0/demux0'
initial transponder 12456000 L 27500000 9
>>> tune to: 12456:h:0:27500
Network Name 'NTV+'
0x0000 0x5015: pmt_pid 0x008c HTB+ -- Discovery (running, scrambled)
0x0000 0x5016: pmt_pid 0x008d HTB+ -- Hallmark (running, scrambled)
0x0000 0x5017: pmt_pid 0x008e HTB+ -- Jetix (running, scrambled)
0x0000 0x5018: pmt_pid 0x008f HTB+ -- Animal Planet (running, scrambled)
0x0000 0x5019: pmt_pid 0x0090 HTB+ -- Discovery Travel&Living (running, scrambled)
0x0000 0x501a: pmt_pid 0x0091 HTB+ -- Eurosport (running, scrambled)
0x0000 0x501b: pmt_pid 0x0095 HTB+ -- Music Box (running, scrambled)
0x0000 0x501c: pmt_pid 0x0097 HTB+ -- Mezzo (Muzzik) (running, scrambled)
0x0000 0x501f: pmt_pid 0x0092 HTB+ -- Zone Romantica (running, scrambled)
0x0000 0x5020: pmt_pid 0x0093 HTB+ -- ТДК (running, scrambled)
0x0000 0x5021: pmt_pid 0x0094 HTB+ -- Jetix Play (running, scrambled)
0x0000 0x5022: pmt_pid 0x0096 HTB+ -- National Geographic (running, scrambled)
>>> tune to: 12322:h:0:27500
WARNING: >>> tuning failed!!!
>>> tune to: 12322:h:0:27500 (tuning failed)
>>> tune to: 12379:h:0:27500
0x0002 0x27d9: pmt_pid 0x0000 HTB+ -- 365 дней ТВ (running, scrambled)
0x0002 0x27da: pmt_pid 0x0000 HTB+ -- ТВ Бульвар (running, scrambled)
0x0002 0x27db: pmt_pid 0x0000 HTB+ -- Комедия ТВ (running, scrambled)
0x0002 0x27dc: pmt_pid 0x0000 HTB+ -- Индия ТВ (running, scrambled)
0x0002 0x27dd: pmt_pid 0x0000 HTB+ -- Русская ночь (running, scrambled)
0x0002 0x27de: pmt_pid 0x0000 HTB+ -- Ля-минор ТВ (running, scrambled)
0x0002 0x27df: pmt_pid 0x0000 HTB+ -- МНОГОсерийное ТВ (running, scrambled)
0x0002 0x27e0: pmt_pid 0x0000 HTB+ -- Интересное ТВ (running, scrambled)
0x0002 0x27e1: pmt_pid 0x0000 HTB+ -- Кухня ТВ (running, scrambled)
0x0002 0x27e3: pmt_pid 0x0000 HTB+ -- Боец ТВ (running, scrambled)
0x0002 0x27e4: pmt_pid 0x0000 HTB+ -- Авто Плюс (running, scrambled)
0x0002 0x27e5: pmt_pid 0x0000 HTB+ -- Закон-ТВ (running, scrambled)
Network Name 'NTV+'
>>> tune to: 12398:h:0:27500
>>> tune to: 12398:h:0:27500 (tuning failed)
ERROR: interrupted by SIGINT, dumping partial result... (тут я ctrl-C нажал)
dumping lists (24 services)
Discovery:12456:h:0:27500:320:400:20501
Hallmark:12456:h:0:27500:321:402:20502
Jetix:12456:h:0:27500:328:404:20503
Animal Planet:12456:h:0:27500:323:406:20504
Discovery Travel&Living:12456:h:0:27500:324:408:20505
Eurosport:12456:h:0:27500:325:410:20506
Music Box:12456:h:0:27500:326:412:20507
Mezzo (Muzzik):12456:h:0:27500:341:431:20508
Zone Romantica:12456:h:0:27500:330:414:20511
ТДК:12456:h:0:27500:331:416:20512
Jetix Play:12456:h:0:27500:332:418:20513
National Geographic:12456:h:0:27500:329:420:20514
365 дней ТВ:12379:h:0:27500:320:400:10201
ТВ Бульвар:12379:h:0:27500:321:402:10202
Комедия ТВ:12379:h:0:27500:322:404:10203
Индия ТВ:12379:h:0:27500:323:406:10204
Русская ночь:12379:h:0:27500:324:408:10205
Ля-минор ТВ:12379:h:0:27500:325:410:10206
МНОГОсерийное ТВ:12379:h:0:27500:326:412:10207
Интересное ТВ:12379:h:0:27500:330:414:10208
Кухня ТВ:12379:h:0:27500:328:416:10209
Боец ТВ:12379:h:0:27500:331:420:10211
Авто Плюс:12379:h:0:27500:332:422:10212
Закон-ТВ:12379:h:0:27500:333:424:10213
Done.
вот тут показует частоты.
мне говорит что меняет частоты а фактически не реагирует карта...
с чего ты взял-то что карта не реагирует? в завершающем списке каналов каналы с этими частотами есть?
как я и говорил вся проблема была в дровах - в ubuntu 8.10 ss2 rev 2.8 из коробки не идет (практически) я использовал драйвер gpl http://forum.ubuntu.ru/index.php?topic=43300.0
все сразу заработало!
Как getstream'у прикрутить sasc-ng?
open-sasc-ng и sasc-ng - в чем отличия? у меня откомпилился open-sasc-ng, а просто sasc не захотел, не смотря на все мои ухищрения - говорит что не известен тип кернела
должен ли запускаться ./sasc-ng -j 0:1 без конфигов (cardclient,softcam и т.д.)?
правда при компиляции open-sasc выдается сообщение
echo 'const char *source_version =' '"'`(svnversion /win1/open-sasc-ng/open-sasc-ng 2>/dev/null) || echo Unknown`/`(svnversion /win1/open-sasc-ng/open-sasc-ng/dvbloopback 2>/dev/null) || echo Unknown`'";' > .vers.new ; diff .vers.new objs/version.cpp > .vers.diff 2>&1 ; if test -s .vers.diff ; then mv -f .vers.new objs/version.cpp ; fi ; rm -f .vers.new .vers.diff
make -C ./sc/PLUGINS/src/sc-src CXX=g++ CXXFLAGS="-O2 -fPIC -Wall -Woverloaded-virtual -g" SASC=1 STATIC=1 all
sed: can't read ../../../ci.c: No such file or directory - вот это сообщение мне не нравится
дальше все нормально, ошибок не выдает, sasc создается
$insmod dvbloopback.ko
$dmesg
[ 2635.146970] /win1/open-sasc-ng/open-sasc-ng/dvbloopback/module/dvb_loopback.c: frontend loopback driver v0.0.1
[ 2635.146981] dvbloopback: registering 1 adapters
[ 2635.150273] DVB: registering new adapter (DVB-LOOPBACK)
$./sasc-ng -j 0:1
Jan 18 15:31:40.157 : Version: 0.0.2-58M/58
Jan 18 15:31:40.157 CAM: initializing plugin: SoftCam (0.9.0-Unknown): A software emulated CAM
Jan 18 15:31:40 [general.info] SC version 0.9.0-Unknown initializing
Jan 18 15:31:40.158 CAM: starting plugin:
Jan 18 15:31:40 [general.info] SC version 0.9.0-Unknown starting
Jan 18 15:31:40 [core.load] ** Plugin config:
Jan 18 15:31:40 [core.load] ** Key updates (AU) are enabled (active CAIDs) (no prestart)
Jan 18 15:31:40 [core.load] ** Local systems DON'T take priority over cached remote
Jan 18 15:31:40 [core.load] ** Concurrent FF recordings are NOT allowed
Jan 18 15:31:40 [core.load] ** Force transfermode with digital audio
Jan 18 15:31:40 [core.load] ** ScCaps are 1 2 0 0 0 0 0 0 0 0
Jan 18 15:31:40 [core.load] ** Ignored CAIDs 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
Jan 18 15:31:40 [general.info] loading cardclient config from ./sc_files/cardclient.conf
Jan 18 15:31:40 [general.info] loading Viaccess cards from ./sc_files/Viaccess.KID
Jan 18 15:31:40 [core.load] loaded 1 Viaccess cards from ./sc_files/Viaccess.KID
Jan 18 15:31:40 [general.info] loading keys from ./sc_files/SoftCam.Key
Jan 18 15:31:40 [core.load] loaded 2 keys from ./sc_files/SoftCam.Key
Jan 18 15:31:40 [general.info] loading smartcard data from ./sc_files/smartcard.conf
Jan 18 15:31:40 [core.load] loaded 0 smartcard data from ./sc_files/smartcard.conf
Jan 18 15:31:40 [core.load] ** registered systems:
Jan 18 15:31:40 [core.load] ** Cardclient (pri -15)
Jan 18 15:31:40 [core.load] ** Conax (pri -10)
Jan 18 15:31:40 [core.load] ** ConstCW (pri -20)
Jan 18 15:31:40 [core.load] ** Cryptoworks (pri -10)
Jan 18 15:31:40 [core.load] ** Irdeto (pri -10)
Jan 18 15:31:40 [core.load] ** Nagra (pri -10)
Jan 18 15:31:40 [core.load] ** Nagra2 (pri -10)
Jan 18 15:31:40 [core.load] ** SC-Conax (pri -5)
Jan 18 15:31:40 [core.load] ** SC-Cryptoworks (pri -5)
Jan 18 15:31:40 [core.load] ** SC-Irdeto (pri -5)
Jan 18 15:31:40 [core.load] ** SC-Nagra (pri -5)
Jan 18 15:31:40 [core.load] ** SC-Seca (pri -5)
Jan 18 15:31:40 [core.load] ** SC-Viaccess (pri -5)
Jan 18 15:31:40 [core.load] ** SC-VideoGuard2 (pri -5)
Jan 18 15:31:40 [core.load] ** Seca (pri -10)
Jan 18 15:31:40 [core.load] ** @SHL (pri -10)
Jan 18 15:31:40 [core.load] ** Viaccess (pri -10)
Jan 18 15:31:40 [general.warn] no smartcard interface defined!
Jan 18 15:31:40.165 frontend: Could not open /dev/dvb/adapter1/frontend1. Error was: 16
Open failed
: Device or resource busy
в чем может быть причина?
виртуальный адаптер 1 создается:
$ ls /dev/dvb/*
/dev/dvb/adapter0:
demux0 dvr0 frontend0 net0
/dev/dvb/adapter1:
audio0 demux0 dvr0 frontend0 osd0 video0
audio1 demux1 dvr1 frontend1 osd1 video1
а на счет output-pipe - попробуй $cat /tmp/eutelsat36-11727
тока я не очень заморачивался, надо кодировку подбирать
Edited by nast2003
СПАСИБО Alexander
как все таки хорошо когда всехоть и со скрипом, но получается!
фикс нашел : http://dolot.kipdola.com/index.php?title=Install_SASC-NG
нужно было сделать :
cp /usr/local/src/s2-liplianin/linux/drivers/media/dvb/dvb-core/dvbdev.h /usr/local/src/opensasc/dvbloopback/module/dvbdev.h
cp /usr/local/src/s2-liplianin/linux/drivers/media/dvb/dvb-core/dvbdev.h /usr/local/src/opensasc/dvbloopback/module/config-dvb/dvbdev.h
с этим все скомпилилось (правда нужно установить g++-4.2
теперь буду тестить
еще факерут на будующе сделать надо бы...deb-пакеты dvbloopback и sasc-ng под ядро 2.6.26-9 amd64 с дровами на ss2 rev 2.8 от v4l
Edited by nast2003
Чет не могу собрать...
giver getstream2-20081204 # make
gcc -O0 -g -Wall  -I. -I/usr/include/glib-2.0/ -I/usr/lib/glib-2.0/include/   -c -o getstream.o getstream.c
getstream.c:21:19: error: event.h: Нет такого файла или каталога
In file included from output.h:5,
                 from sap.h:5,
                 from getstream.h:15,
                 from getstream.c:23:
libhttp.h:82: error: field ‘ev’ has incomplete type
In file included from sap.h:5,
output.h:116: error: field ‘rtcpevent’ has incomplete type
output.h:128: error: field ‘event’ has incomplete type
In file included from getstream.h:15,
sap.h:33: error: field ‘event’ has incomplete type
In file included from getstream.c:23:
getstream.h:227: error: field ‘patevent’ has incomplete type
getstream.h:240: error: field ‘timer’ has incomplete type
getstream.h:241: error: field ‘event’ has incomplete type
getstream.h:280: error: field ‘dvrevent’ has incomplete type
getstream.h:282: error: field ‘stucktimer’ has incomplete type
getstream.h:307: error: field ‘event’ has incomplete type
getstream.h:312: error: field ‘dmxevent’ has incomplete type
getstream.c: In function ‘init_guard_evtimer’:
getstream.c:57: error: storage size of ‘gevent’ isn’t known
getstream.c:63: warning: implicit declaration of function ‘evtimer_set’
getstream.c:64: warning: implicit declaration of function ‘evtimer_add’
getstream.c:57: warning: unused variable ‘gevent’
getstream.c: In function ‘terminate_init’:
getstream.c:88: error: storage size of ‘event’ isn’t known
getstream.c:88: warning: unused variable ‘event’
getstream.c: In function ‘main’:
getstream.c:136: warning: implicit declaration of function ‘event_init’
getstream.c:177: warning: implicit declaration of function ‘event_dispatch’
make: *** [getstream.o] Ошибка 1
У кого есть здравые мысли?
Libevent нужен
http://www.monkey.org/~provos/libevent-1.4.9-stable.tar.gz
Libevent нужен
Спасибо, собралось ;) Будем теперь ковырять.
Для примера взял конфиг от Alexander.
giver ~ # /opt/getstream2-20081204/getstream -c /opt/getstream2-20081204/configs/config-abs1-12670 -d
2009-01-20 21:39:05.667 fe: Adapter 2 Setting up frontend tuner
2009-01-20 21:39:05.667 fe: DVB-S tone = 0
2009-01-20 21:39:05.667 fe: DVB-S voltage = 1
2009-01-20 21:39:05.667 fe: DVB-S diseqc = 0
2009-01-20 21:39:05.667 fe: DVB-S freq = 11727000
2009-01-20 21:39:05.667 fe: DVB-S lof1 = 10750000
2009-01-20 21:39:05.667 fe: DVB-S lof2 = 10750000
2009-01-20 21:39:05.667 fe: DVB-S slof = 11700000
2009-01-20 21:39:05.667 fe: DVB-S feparams.frequency = 977000
2009-01-20 21:39:05.667 fe: DVB-S feparams.inversion = 2
2009-01-20 21:39:05.667 fe: DVB-S feparams.u.qpsk.symbol_rate = 27500000
2009-01-20 21:39:05.668 dmx: Setting filter for pid 8192 pestype 20
2009-01-20 21:39:05.799 fe: Adapter 2 Status: 0x1f (HAS_SIGNAL HAS_CARRIER HAS_VITERBI HAS_SYNC HAS_LOCK)
Судя по netstat сервер слушает:
udp        0      0 10.2.1.3:32838          10.2.1.3:1234           ESTABLISHED
Чем теперь смотреть то? VLC не видит потоков(
Есть пример не для udp а для http?
Edited by zulu_radist
Разобрался, для одного канала с 36 градуса работает пока что так:
http {
        port 8001;
adapter 2 {
        packet-buffer 50;
        stat-interval 120;
        dvb-s {
                #lnb-sharing yes;
                lnb {
                        lof1 10750000;
                        lof2 10750000;
                        slof 11700000;
                transponder {
                        frequency 11727000;
                        polarisation h;
  stream {
                name "test";
                input {
                        pnr 3;
                output-http {
                        url /tv/test;
VLC открывает поток по http, ip-сервера:8001/tv/test
Если надо добавить еще один канал с этого транспондера, добавляем еще один блок stream, меняем pnr (смортим в lyngsat число VPID) и адрес url например /tv/test2
Запустил сервер в тестовое вещание, память не жрет, радует, до этого вещал vlc + 6 dvb карт ss3. Посмотрим пару деньков.
кстати какие карты ss2 или ss3 более чувствительны к приему сигнала и при каких значения уровня сигнала начинают сыпать картинку ?
кто нибудь в курсе, как изменить следующие параметры:
если конкретнее мне нужно поставить на одной плате DVB-S voltage = 1, а на другой 0
заметил странность, когда выдается сообщение
dvr: inputstats: 52 pids 24364 pkt/s 4580502 byte/s
картинка начинает сыпаться... переключение каналов помагает но не надолго... Edited by nast2003
