ASR1006 ESP-20 перезагружается ASR1006 ESP-20 перезагружается
Доброго времени суток. После обновления rommon и IOS, один из ESP все время перезагружается. В чем может быть проблема ?
Зарание спасибо.
ios - asr1000rp2-advipservicesk9.03.16.05.S.155-3.S5-ext.bin
ASR1006#show platform
Chassis type: ASR1006
Slot      Type                State                 Insert time (ago)
0         ASR1000-SIP10       ok                    00:14:23
0/0      SPA-8X1GE-V2        ok                    00:12:45
0/1      SPA-8X1GE-V2        ok                    00:12:37
1         ASR1000-SIP10       ok                    00:14:23
2         ASR1000-SIP10       ok                    00:14:23
R0        ASR1000-RP2         ok, active            00:14:23
R1        ASR1000-RP2         ok, standby           00:14:23
F0        ASR1000-ESP20       booting               00:14:23
F1        ASR1000-ESP20       ok, active            00:14:23
P0        ASR1006-PWR-DC      ok                    00:14:02
P1        ASR1006-PWR-DC      ps, fail              00:14:00
Slot      CPLD Version        Firmware Version
0         07091401            16.3(2r)
1         07091401            16.3(2r)
2         07091401            16.3(2r)
R0        08103002            16.3(2r)
R1        08103002            16.3(2r)
F0        08041102            16.3(2r)
F1        08041102            16.3(2r)
0         ASR1000-SIP10       ok                    00:22:04
0/0      SPA-8X1GE-V2        ok                    00:20:25
0/1      SPA-8X1GE-V2        ok                    00:20:17
1         ASR1000-SIP10       ok                    00:22:04
2         ASR1000-SIP10       ok                    00:22:04
R0        ASR1000-RP2         ok, active            00:22:04
R1        ASR1000-RP2         ok, standby           00:22:04
F0        ASR1000-ESP20       init, standby         00:22:04
F1        ASR1000-ESP20       ok, active            00:22:04
P0        ASR1006-PWR-DC      ok                    00:21:42
P1        ASR1006-PWR-DC      ps, fail              00:21:40
0         07091401            16.3(2r)
1         07091401            16.3(2r)
2         07091401            16.3(2r)
*Mar 17 15:17:28.603: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Mar 17 15:18:06.621: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_driver-0:  cpp_driver-0 encountered an error -Traceback= 1#5e20de18455afb2c35bfb97d39d067cb   errmsg:EE17000+2230 cpp_common_os:F55D000+C550 cpp_common_os:F55D000+C350 cpp_drv_cmn:FC78000+29A20 cpp_drv_dev_cpp10:FA91000+71D80 cpp_drv_dev_cpp10:FA91000+8A388 cpp_drv_dev_cpp10:FA91000+8DB88 cpp_drv_dev_cpp10:FA91000+6C7C0 cpp_drv_dev_cpp10:FA91000+6CAE0 :10000000+78A0 :10000000+858C cpp_drv_cmn:FC78000+217AC binos:F0BF000+F20C cpp_drv_cmn:FC78000+218B8 :10
*Mar 17 15:18:06.626: %CPPDRV-3-FATAL_MEM_CLEAR: F0: cpp_driver-0:  CPP0: (0x6e) Failed to clear memory 'cpp/driver' detected the 'warning' condition 'CPP driver error in devobj layer': Connection timed out -Traceback= 1#5e20de18455afb2c35bfb97d39d067cb   errmsg:EE17000+2230 cpp_drv_cmn:FC78000+22D60 cpp_drv_dev_cpp10:FA91000+6C82C cpp_drv_dev_cpp10:FA91000+6CAE0 :10000000+78A0 :10000000+858C cpp_drv_cmn:FC78000+217AC binos:F0BF000+F20C cpp_drv_cmn:FC78000+218B8 :10000000+7CE4 :10000000+ED48 cpp_client_ha:F67
*Mar 17 15:18:06.628: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0.0 desc:DPE6_CPE_CPE_DPE_INT_SET_0_LEAF_INT_INT_PHY_ERROR det:DRVR(interrupt) class:OTHER sev:FATAL id:1862 cppstate:STOPPED res:UNKNOWN flags:0x3 cdmflags:0x5
*Mar 17 15:18:06.631: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_ha:  cpp_ha encountered an error -Traceback= 1#c12dfd71ead09772120b306b06b22af7   errmsg:F2CB000+2230 cpp_common_os:FF59000+C550 cpp_common_os:FF59000+C350 cpp_common_os:FF59000+19CDC cpp_drv_cmn:FB64000+21AD0 cpp_dmap:FEEC000+384C0 :10000000+22E5C :10000000+24C70 :10000000+D238 :10000000+E09C :10000000+BB98 cpp_common_os:FF59000+114C4 cpp_common_os:FF59000+11AFC evlib:EFA2000+E1FC evlib:EFA2000+105E4 cpp_common_os:FF59000+1326C :10000000+F8C8 c:DB2F000+
*Mar 17 15:18:06.634: %CPPDRV-3-LOCKDOWN_INITIATED: F0: cpp_ha:  QFP0.0 CPP Driver LOCKDOWN being triggered due to fatal error.
*Mar 17 15:18:06.685: %CPPHA-3-FAULTCRASH: F0: cpp_ha:  CPP 0.0 unresolved fault detected, initiating crash dump.
*Mar 17 15:18:06.693: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0.0 desc:DPE6_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_MBE det:DRVR(interrupt) class:MBE sev:FATAL id:1891 cppstate:STOPPED res:SUCCESS flags:0x3 cdmflags:0x5
*Mar 17 15:18:06.696: %CPPHA-3-FAULTCRASH: F0: cpp_ha:  CPP 0.0 unresolved fault detected, initiating crash dump.
*Mar 17 15:18:06.716: %CPPDRV-3-FATAL_INIT_ID: F0: cpp_driver-0:  CPP0: (0x1) Failed to initialize init device drivers(s) - Operation not permitted -Traceback= 1#5e20de18455afb2c35bfb97d39d067cb   errmsg:EE17000+2230 cpp_drv_cmn:FC78000+23008 :10000000+78C4 :10000000+858C cpp_drv_cmn:FC78000+217AC binos:F0BF000+F20C cpp_drv_cmn:FC78000+218B8 :10000000+7CE4 :10000000+ED48 cpp_client_ha:F67A000+2E18 cpp_common_os:F55D000+114C4 cpp_common_os:F55D000+11AFC evlib:F1A8000+E1FC evlib:F1A8000+105E4 :10000000+71E4 c:E
*Mar 17 15:18:06.717: %CPPHA-3-INITFAIL: F0: cpp_ha:  CPP 0 initialization failed - startup init (0x1)
*Mar 17 15:18:06.717: %CPPHA-3-INITFAIL: F0: cpp_ha:  CPP 0 initialization failed - start CPP (0x1)
*Mar 17 15:18:06.718: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0.0 desc:Platform Collection Error: Message STARTUP_INIT to client cpp_driver0 failed with error [Operation not permitted] det:HA class:CLIENT_SW sev:FATAL id:2 cppstate:RUNNING res:UNKNOWN flags:0x0 cdmflags:0x0
*Mar 17 15:18:06.747: %IOSXE-3-PLATFORM: F0: cpp_cdm: CPP crashed, core file /tmp/corelink/ASR1006_ESP_0_cpp-mcplo-ucode_031717151806.core.gz
*Mar 17 15:18:28.925: %CPPHA-3-CDMDONE: F0: cpp_ha:  CPP 0 microcode crashdump creation completed.
*Mar 17 15:18:28.926: %IOSXE-6-PLATFORM: F0: cpp_cdm: Shutting down CPP MDM while client(s) still connected
*Mar 17 15:18:28.931: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while client(s) still connected
*Mar 17 15:18:28.931: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP CDM while client(s) still connected
*Mar 17 15:18:29.063: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_ha_top_level_server has been helddown (rc 69)
*Mar 17 15:18:29.091: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_cdm_svr has been helddown (rc 69)
*Mar 17 15:18:34.272: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
*Mar 17 15:19:45.225: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Mar 17 15:20:23.641: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_driver-0:  cpp_driver-0 encountered an error -Traceback= 1#5e20de18455afb2c35bfb97d39d067cb   errmsg:EE17000+2230 cpp_common_os:F55D000+C550 cpp_common_os:F55D000+C350 cpp_drv_cmn:FC78000+29A20 cpp_drv_dev_cpp10:FA91000+71D80 cpp_drv_dev_cpp10:FA91000+8A388 cpp_drv_dev_cpp10:FA91000+8DB88 cpp_drv_dev_cpp10:FA91000+6C7C0 cpp_drv_dev_cpp10:FA91000+6CAE0 :10000000+78A0 :10000000+858C cpp_drv_cmn:FC78000+217AC binos:F0BF000+F20C cpp_drv_cmn:FC78000+218B8 :10
*Mar 17 15:20:23.646: %CPPDRV-3-FATAL_MEM_CLEAR: F0: cpp_driver-0:  CPP0: (0x6e) Failed to clear memory 'cpp/driver' detected the 'warning' condition 'CPP driver error in devobj layer': Connection timed out -Traceback= 1#5e20de18455afb2c35bfb97d39d067cb   errmsg:EE17000+2230 cpp_drv_cmn:FC78000+22D60 cpp_drv_dev_cpp10:FA91000+6C82C cpp_drv_dev_cpp10:FA91000+6CAE0 :10000000+78A0 :10000000+858C cpp_drv_cmn:FC78000+217AC binos:F0BF000+F20C cpp_drv_cmn:FC78000+218B8 :10000000+7CE4 :10000000+ED48 cpp_client_ha:F67
*Mar 17 15:20:23.648: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0.0 desc:DPE6_CPE_CPE_DPE_INT_SET_0_LEAF_INT_INT_PHY_ERROR det:DRVR(interrupt) class:OTHER sev:FATAL id:1862 cppstate:STOPPED res:UNKNOWN flags:0x3 cdmflags:0x5
*Mar 17 15:20:23.651: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_ha:  cpp_ha encountered an error -Traceback= 1#c12dfd71ead09772120b306b06b22af7   errmsg:F2CB000+2230 cpp_common_os:FF59000+C550 cpp_common_os:FF59000+C350 cpp_common_os:FF59000+19CDC cpp_drv_cmn:FB64000+21AD0 cpp_dmap:FEEC000+384C0 :10000000+22E5C :10000000+24C70 :10000000+D238 :10000000+E09C :10000000+BB98 cpp_common_os:FF59000+114C4 cpp_common_os:FF59000+11AFC evlib:EFA2000+E1FC evlib:EFA2000+105E4 cpp_common_os:FF59000+1326C :10000000+F8C8 c:DB2F000+
*Mar 17 15:20:23.653: %CPPDRV-3-LOCKDOWN_INITIATED: F0: cpp_ha:  QFP0.0 CPP Driver LOCKDOWN being triggered due to fatal error.
*Mar 17 15:20:23.705: %CPPHA-3-FAULTCRASH: F0: cpp_ha:  CPP 0.0 unresolved fault detected, initiating crash dump.
*Mar 17 15:20:23.712: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0.0 desc:DPE6_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_MBE det:DRVR(interrupt) class:MBE sev:FATAL id:1891 cppstate:STOPPED res:SUCCESS flags:0x3 cdmflags:0x5
*Mar 17 15:20:23.716: %CPPHA-3-FAULTCRASH: F0: cpp_ha:  CPP 0.0 unresolved fault detected, initiating crash dump.
*Mar 17 15:20:23.735: %CPPDRV-3-FATAL_INIT_ID: F0: cpp_driver-0:  CPP0: (0x1) Failed to initialize init device drivers(s) - Operation not permitted -Traceback= 1#5e20de18455afb2c35bfb97d39d067cb   errmsg:EE17000+2230 cpp_drv_cmn:FC78000+23008 :10000000+78C4 :10000000+858C cpp_drv_cmn:FC78000+217AC binos:F0BF000+F20C cpp_drv_cmn:FC78000+218B8 :10000000+7CE4 :10000000+ED48 cpp_client_ha:F67A000+2E18 cpp_common_os:F55D000+114C4 cpp_common_os:F55D000+11AFC evlib:F1A8000+E1FC evlib:F1A8000+105E4 :10000000+71E4 c:E
*Mar 17 15:20:23.737: %CPPHA-3-INITFAIL: F0: cpp_ha:  CPP 0 initialization failed - startup init (0x1)
*Mar 17 15:20:23.739: %CPPHA-3-INITFAIL: F0: cpp_ha:  CPP 0 initialization failed - start CPP (0x1)
*Mar 17 15:20:23.739: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0.0 desc:Platform Collection Error: Message STARTUP_INIT to client cpp_driver0 failed with error [Operation not permitted] det:HA class:CLIENT_SW sev:FATAL id:2 cppstate:RUNNING res:UNKNOWN flags:0x0 cdmflags:0x0
*Mar 17 15:20:23.748: %IOSXE-3-PLATFORM: F0: cpp_cdm: CPP crashed, core file /tmp/corelink/ASR1006_ESP_0_cpp-mcplo-ucode_031717152023.core.gz
*Mar 17 15:20:45.893: %IOSXE-6-PLATFORM: F0: cpp_cdm: Shutting down CPP MDM while client(s) still connected
*Mar 17 15:20:45.893: %CPPHA-3-CDMDONE: F0: cpp_ha:  CPP 0 microcode crashdump creation completed.
*Mar 17 15:20:45.898: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while client(s) still connected
*Mar 17 15:20:45.900: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP CDM while client(s) still connected
*Mar 17 15:20:46.031: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_cdm_svr has been helddown (rc 69)
*Mar 17 15:20:46.054: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_ha_top_level_server has been helddown (rc 69)
*Mar 17 15:20:50.849: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
*Mar 17 15:22:01.581: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
Share this post
Link to post
Share on other sites
Проблема аналогичная, только прошивка не свежая. 2 года uptime, без проблем. За последнюю неделю три раза перезагружался ESP.
прошивка asr1000rp2-advipservicesk9.03.08.02.S.153-1.S2.bin
Chassis type: ASR1004
0         ASR1000-SIP40       ok                    1y49w
0/0      SPA-1X10GE-L-V2     ok                    1y49w
0/1      SPA-1X10GE-L-V2     ok                    1y49w
R0        ASR1000-RP2         ok, active            1y49w
F0        ASR1000-ESP20       ok, active            1y49w
P0        ASR1004-PWR-AC      ok                    1y49w
P1        ASR1004-PWR-AC      ok                    1y49w
0         00200800            15.3(3r)S
R0        13092401            15.3(3r)S
F0        08041102            15.3(3r)S
Mar 23 16:57:16.036: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_driver-0:  cpp_driver-0 encountered an error -Traceback= 1#d1f96301963189ea83fad3aa768b5903
errmsg:F329000+2230 cpp_common_os:F9B6000+BBB0 cpp_common_os:F9B6000+B9C0 cpp_drv_cmn:FB03000+1B2CB0 cpp_drv_cmn:FB03000+1BA220 cpp_drv_cmn:FB03000+D26F8
cpp_drv_cmn:FB03000+D2E3C cpp_drv_cmn:FB03000+99CB8 cpp_drv_cmn:FB03000+92964 cpp_drv_cmn:FB03000+1B9EC4 cpp_drv_cmn:FB03000+1B2480 time:EF27000+5754 evlib:F68C000+E318 evlib:F68C000+104C4 :10000000+6AD0 c:E7D10
Mar 23 16:57:16.041: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0.0 desc:DPE4_CPE_CPE_DPE_INT_SET_0_LEAF_INT_INT_PHY_ERROR det:DRVR(interrupt) class:OTHER sev:FATAL id:1606 cppstate:STOPPED res:UNKNOWN flags:0x7 cdmflags:0x1
Mar 23 16:57:16.041: %CPPHA-3-FAULTCRASH: F0: cpp_ha:  CPP 0.0 unresolved fault detected, initiating crash dump.
Mar 23 16:57:16.044: %CPPHA-3-FAULTCRASH: F0: cpp_ha:  CPP 0.0 unresolved fault detected, initiating crash dump.
Mar 23 16:57:16.047: %CPPHA-3-FAULT: F0: cpp_ha:  CPP:0.0 desc:DPE4_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_MBE det:DRVR(interrupt) class:MBE sev:FATAL id:1635 cppstate:STOPPED res:SUCCESS flags:0x7 cdmflags:0x1
Mar 23 16:57:16.047: %CPPHA-3-FAULTCRASH: F0: cpp_ha:  CPP 0.0 unresolved fault detected, initiating crash dump.
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0:  CPP10(0) Interrupt : Last 16 Interrupts Since Boot
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0:  CPP10(0) Interrupt : 17-Mar-21 16:04:48.491044 UTC+0300:HOT:GAL_GAL_CSR_IPM_IF_GAL_IPM_IF_LEAF_INT_INT_IPM_ERR
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0:  CPP10(0) Interrupt : 17-Mar-22 21:11:52.813127 UTC+0300:DPE4_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_SBE
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0:  CPP10(0) Interrupt : 17-Mar-22 21:11:52.820137 UTC+0300:DPE4_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_SBE
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0:  CPP10(0) Interrupt : 17-Mar-23 19:57:16.041003 UTC+0300:HALT:DPE4_CPE_CPE_DPE_INT_SET_0_LEAF_INT_INT_PHY_ERROR
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0:  CPP10(0) Interrupt : 17-Mar-23 19:57:16.041003 UTC+0300:HALT:DPE4_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_MBE
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0:  CPP10(0) Interrupt : 17-Mar-23 19:57:16.041003 UTC+0300:HEDP_HED_HALTED_IN_63_0_LEAF_INT_INT_HALTED9
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0:  CPP10(0) Interrupt : 17-Mar-23 19:57:16.041003 UTC+0300:HOT:INFP_INF_IDMU_LEAF_INT_INT_TRANSACTION_TIMEOUT
Mar 23 16:57:16.099: %IOSXE-3-PLATFORM: F0: cpp_cdm: CPP crashed, core file /tmp/corelink/sssgw_ESP_0_cpp-mcplo-ucode_032317195716.core.gz
Mar 23 16:57:16.283: %CPPDRV-3-LOCKDOWN: F0: cpp_cp:  CPP10(0) CPP Driver LOCKDOWN due to fatal error.
Mar 23 16:57:16.327: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_cp:  cpp_cp encountered an error -Traceback= 1#8aa6f4f1aa1c5cc9343ddb5d1ccf589e   errmsg:CB06000+2230
cpp_common_os:D193000+BBB0 cpp_common_os:D193000+B9C0 cpp_common_os:D193000+18FDC
cpp_uidb_mgr_lib:E941000+FD90 cpp_uidb_mgr_lib:E941000+15098 cpp_uidb_mgr_lib:E941000+8400
cpp_uidb_mgr_local:E9B0000+3874 cpp_gic_ea_lib:F679000+111E8
cpp_gic_ea_lib:F679000+DB44 cpp_gic_ea_lib:F679000+E5BC cpp_gic_intl_local:F6EA000+2474 cpp_ess_svr_lib:FB48000+79E54 cpp_
Mar 23 16:57:16.353: %CPPDRV-3-LOCKDOWN: F0: fman_fp_image:  CPP10(0) CPP Driver LOCKDOWN due to fatal error.
Mar 23 16:57:16.592: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
Mar 23 16:58:28.686: %CPPHA-3-CDMDONE: F0: cpp_ha:  CPP 0 microcode crashdump creation completed.
Mar 23 16:58:28.687: %IOSXE-6-PLATFORM: F0: cpp_cdm: Shutting down CPP MDM while client(s) still connected
Mar 23 16:58:28.695: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while client(s) still connected
Mar 23 16:58:28.698: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP CDM while client(s) still connected
Mar 23 16:58:29.366: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_cdm_svr has been helddown (rc 69)
Mar 23 16:58:29.369: %PMAN-3-PROCHOLDDOWN: F0: pman.sh:  The process cpp_ha_top_level_server has been helddown (rc 69)
Mar 23 17:01:14.896: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
Mar 23 17:01:44.034: %CPPHA-7-READY: F0: cpp_ha:  CPP 0 loading and initialization complete
Mar 23 17:01:44.386: %IOSXE-6-PLATFORM: F0: cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
Share this post
Link to post
почти аналогичная ситуация, с той лишь разницей, что после обновления(до такой же версии что и у ТС) грузится один из RP.
Share this post
Link to post
Мораль сей басни такова - если работает и нет медицинских показаний к апгрейду (что-то конкретно глючит и это заявлено как исправленное в новой версии) - не трогай!
Share this post
Link to post
Вам только одна дорога - в Cisco TAC :)
Берите это и прикладывайте к кейсу.
А что там - проблема с роммоном и поддержкой hot/standby, или с конфигурацией, или баг IOS - только они Вам и скажут. А здесь, к сожалению, не околачиваются Cisco TAC спецы :)
Странно, что никто этого Вам еще не сказал)
Share this post
Link to post
Да просто судя по всему нету смартнет, вот сюда и пишут :)
Share this post
Link to post
Может известный баг памяти? Ребутнули и здрасьте.
Есть у меня в шкафчике 7201
uptime is 3 years, 3 weeks, 1 day, 5 hours, 46 minutes
боюсь что не заведется если выключить.
Share this post
Link to post
откатился на старую IOS - все норм, это может быть связана с памятью ?
Share this post
Link to post
Если помогает откат софта - вам в cisco tac
Share this post
Link to post
С недавних времён опять в провайдинге.
Не радует вообще такая ситуация с оборудованием cisco.
Такое ощущение, что их место не в провайдинге, а в крупных сетях предприятия, где не так сожрут за отсутствие сервисов.
ASR9001 asr9k-os-mbi-5.3.3.sp4-1.0.0 - BGP роутер, перезагружался ещё до меня, я уже выключил netflow, стоит, молотит десятки.
на всякий случай заказал Mikrotik CCR-1072, так сказать для резервирования. поставил, опробовал, FV конечно не держит, начинает отпадывать OSPF :) по загрузке на 100% одного из ядер, но отфильтровав префиксы > /16 встал на боевое дежурство.
ASR1004 RP2 - NAT & netflow начались проблемы после поднятия трафика в два раза, до этого аптайм был приличный.
asr1000rp2-adventerprisek9.03.13.01.S.154-3.S1-ext.bin - пару раз перезагрузился ESP, наша техподдержка на пот изошла, заменил софт.
asr1000rp2-advipservicesk9.03.16.02.S.155-3.S2-ext.bin - 4 дня аптайма и:
%CMCC-5-SERDES_BLOCK_EVENT: SIP0: cmcc: A SerDes link informational error ESIB0 - rxLoShortPacket, block 1b count 5
%CMCC-3-PLIM_STATUS: SIP0: cmcc: A PLIM driver informational error txnpEOPErrorRcvd, block 1e count 7
одна из SIP карт не в работоспособном состоянии, какие-то мегабиты приходят-уходят, но ничего не работает
ставлю сейчас asr1000rp2-advipservices.03.16.05.S.155-3.S5-ext.bin, посмотрим.
всё время даунтайма ASR1004, её успешно заменял CCR-1072 (кстати там conntrack увеличили до 1М состояний)
на счет трансляций, может коллеги не вкурсе, наткнулся на грабли: браузер при просмотре youtube открывает очень много udp/443 коннектов на гугловские хосты.
пришлось сильно закручивать гайки тайм-аутов.
скорее всего после рассмотрения цены на саппорт, который собсно ничего не гарантирует, будет закупаться оборудования для децентрализации центрального узла.
Share this post
Link to post
замена cisco asr9k и asr1k на микротик - это вы сильно :)
Share this post
Link to post
К сожалению это мировой тренд - продавать не железо а услуги. По отношению к циске это значит что нужно иметь к железке сервисный контракт, хотябы первые несколько лет.
Share this post
Link to post
Есть мнение, и кажется на форуме его уже озвучивали, что циска уже не так сильна в isp, как раньше (за энтерпрайз не скажу).
На бордер берите, например, джун.
А вообще имхо все сетевые вендоры 1го эшелона делают барахло, - и циска, и джун, и хуавэй, и алкатель и прочие, не говоря уже про пародии на операторские роутеры типа шлакотика или длинка во 2-3 эшелоне. Получается, что добиться нормального качества можно только строя сети с _горячим_ резервированием n+1 каждой элемента.
Edited by furai
Share this post
Link to post
Щас вообще везде все стали делать барахло, потому что если сделать что-то хорошее, то его продашь только один раз, а кушать всем хочется каждый день. Это касается вообще любой техники, от роутеров до автомобилей и зубных щеток. Настала эпоха говна и лучше не стенет никогда уже, пока не полетим колонизировать другие звездные системы, когда вновь появится необходимость делать качественное.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Sign in to follow this
