Проблема аналогичная, только прошивка не свежая. 2 года uptime, без проблем. За последнюю неделю три раза перезагружался ESP.
прошивка asr1000rp2-advipservicesk9.03.08.02.S.153-1.S2.bin
Chassis type: ASR1004
Slot Type State Insert time (ago)
0 ASR1000-SIP40 ok 1y49w
0/0 SPA-1X10GE-L-V2 ok 1y49w
0/1 SPA-1X10GE-L-V2 ok 1y49w
R0 ASR1000-RP2 ok, active 1y49w
F0 ASR1000-ESP20 ok, active 1y49w
P0 ASR1004-PWR-AC ok 1y49w
P1 ASR1004-PWR-AC ok 1y49w
Slot CPLD Version Firmware Version
0 00200800 15.3(3r)S
R0 13092401 15.3(3r)S
F0 08041102 15.3(3r)S
Mar 23 16:57:16.036: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_driver-0: cpp_driver-0 encountered an error -Traceback= 1#d1f96301963189ea83fad3aa768b5903
errmsg:F329000+2230 cpp_common_os:F9B6000+BBB0 cpp_common_os:F9B6000+B9C0 cpp_drv_cmn:FB03000+1B2CB0 cpp_drv_cmn:FB03000+1BA220 cpp_drv_cmn:FB03000+D26F8
cpp_drv_cmn:FB03000+D2E3C cpp_drv_cmn:FB03000+99CB8 cpp_drv_cmn:FB03000+92964 cpp_drv_cmn:FB03000+1B9EC4 cpp_drv_cmn:FB03000+1B2480 time:EF27000+5754 evlib:F68C000+E318 evlib:F68C000+104C4 :10000000+6AD0 c:E7D10
Mar 23 16:57:16.041: %CPPHA-3-FAULT: F0: cpp_ha: CPP:0.0 desc:DPE4_CPE_CPE_DPE_INT_SET_0_LEAF_INT_INT_PHY_ERROR det:DRVR(interrupt) class:OTHER sev:FATAL id:1606 cppstate:STOPPED res:UNKNOWN flags:0x7 cdmflags:0x1
Mar 23 16:57:16.041: %CPPHA-3-FAULTCRASH: F0: cpp_ha: CPP 0.0 unresolved fault detected, initiating crash dump.
Mar 23 16:57:16.044: %CPPHA-3-FAULTCRASH: F0: cpp_ha: CPP 0.0 unresolved fault detected, initiating crash dump.
Mar 23 16:57:16.047: %CPPHA-3-FAULT: F0: cpp_ha: CPP:0.0 desc:DPE4_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_MBE det:DRVR(interrupt) class:MBE sev:FATAL id:1635 cppstate:STOPPED res:SUCCESS flags:0x7 cdmflags:0x1
Mar 23 16:57:16.047: %CPPHA-3-FAULTCRASH: F0: cpp_ha: CPP 0.0 unresolved fault detected, initiating crash dump.
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0: CPP10(0) Interrupt : Last 16 Interrupts Since Boot
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0: CPP10(0) Interrupt : 17-Mar-21 16:04:48.491044 UTC+0300:HOT:GAL_GAL_CSR_IPM_IF_GAL_IPM_IF_LEAF_INT_INT_IPM_ERR
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0: CPP10(0) Interrupt : 17-Mar-22 21:11:52.813127 UTC+0300:DPE4_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_SBE
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0: CPP10(0) Interrupt : 17-Mar-22 21:11:52.820137 UTC+0300:DPE4_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_SBE
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0: CPP10(0) Interrupt : 17-Mar-23 19:57:16.041003 UTC+0300:HALT:DPE4_CPE_CPE_DPE_INT_SET_0_LEAF_INT_INT_PHY_ERROR
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0: CPP10(0) Interrupt : 17-Mar-23 19:57:16.041003 UTC+0300:HALT:DPE4_CPE_CPE_DPE_DUI_LEAF_INT_INT_DUI_CHN0_DRAM_MBE
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0: CPP10(0) Interrupt : 17-Mar-23 19:57:16.041003 UTC+0300:HEDP_HED_HALTED_IN_63_0_LEAF_INT_INT_HALTED9
Mar 23 16:57:16.058: %CPPDRV-6-INTR: F0: cpp_driver-0: CPP10(0) Interrupt : 17-Mar-23 19:57:16.041003 UTC+0300:HOT:INFP_INF_IDMU_LEAF_INT_INT_TRANSACTION_TIMEOUT
Mar 23 16:57:16.099: %IOSXE-3-PLATFORM: F0: cpp_cdm: CPP crashed, core file /tmp/corelink/sssgw_ESP_0_cpp-mcplo-ucode_032317195716.core.gz
Mar 23 16:57:16.283: %CPPDRV-3-LOCKDOWN: F0: cpp_cp: CPP10(0) CPP Driver LOCKDOWN due to fatal error.
Mar 23 16:57:16.327: %CPPOSLIB-3-ERROR_NOTIFY: F0: cpp_cp: cpp_cp encountered an error -Traceback= 1#8aa6f4f1aa1c5cc9343ddb5d1ccf589e errmsg:CB06000+2230
cpp_common_os:D193000+BBB0 cpp_common_os:D193000+B9C0 cpp_common_os:D193000+18FDC
cpp_uidb_mgr_lib:E941000+FD90 cpp_uidb_mgr_lib:E941000+15098 cpp_uidb_mgr_lib:E941000+8400
cpp_uidb_mgr_local:E9B0000+3874 cpp_gic_ea_lib:F679000+111E8
cpp_gic_ea_lib:F679000+DB44 cpp_gic_ea_lib:F679000+E5BC cpp_gic_intl_local:F6EA000+2474 cpp_ess_svr_lib:FB48000+79E54 cpp_
Mar 23 16:57:16.353: %CPPDRV-3-LOCKDOWN: F0: fman_fp_image: CPP10(0) CPP Driver LOCKDOWN due to fatal error.
Mar 23 16:57:16.592: %IOSXE_OIR-6-OFFLINECARD: Card (fp) offline in slot F0
Mar 23 16:58:28.686: %CPPHA-3-CDMDONE: F0: cpp_ha: CPP 0 microcode crashdump creation completed.
Mar 23 16:58:28.687: %IOSXE-6-PLATFORM: F0: cpp_cdm: Shutting down CPP MDM while client(s) still connected
Mar 23 16:58:28.695: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP MDM while client(s) still connected
Mar 23 16:58:28.698: %IOSXE-6-PLATFORM: F0: cpp_ha: Shutting down CPP CDM while client(s) still connected
Mar 23 16:58:29.366: %PMAN-3-PROCHOLDDOWN: F0: pman.sh: The process cpp_cdm_svr has been helddown (rc 69)
Mar 23 16:58:29.369: %PMAN-3-PROCHOLDDOWN: F0: pman.sh: The process cpp_ha_top_level_server has been helddown (rc 69)
Mar 23 17:01:14.896: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
Mar 23 17:01:44.034: %CPPHA-7-READY: F0: cpp_ha: CPP 0 loading and initialization complete
Mar 23 17:01:44.386: %IOSXE-6-PLATFORM: F0: cpp_cp: Process CPP_PFILTER_EA_EVENT__API_CALL__REGISTER
