Alexanse Posted April 27, 2021 Posted April 27, 2021 Доброго времени суток всем! Поделитесь пожалуйста софтом на N3K-3064PQ-10GE с 7 по 9 версию. Может также кто-то подскажет, после обновления с версии 6.0.2.U6.7 на 7.0.3.I4.6 отвалились 24 порта, это связано с не последовательным обновлением ? Вставить ник Quote
pukoid Posted April 27, 2021 Posted April 27, 2021 Превратил в баклажан 3048. Обновлял 6.0(2)U2(2) на 6.0(2)U6(8), чтобы появилась команда install all nxos, а оказалось, нельзя так. Spoiler switch# install all system bootflash:n3000-uk9.6.0.2.U6.8.bin kickstart bootflash:n3000-uk9-kickstart.6.0.2.U6.8.bin Installer is forced disruptive Verifying image bootflash:/n3000-uk9-kickstart.6.0.2.U6.8.bin for boot variable "kickstart". [####################] 100% -- SUCCESS Verifying image bootflash:/n3000-uk9.6.0.2.U6.8.bin for boot variable "system". [####################] 100% -- SUCCESS Verifying image type. [####################] 100% -- SUCCESS Extracting "system" version from image bootflash:/n3000-uk9.6.0.2.U6.8.bin. [####################] 100% -- SUCCESS Extracting "kickstart" version from image bootflash:/n3000-uk9-kickstart.6.0.2.U6.8.bin. [####################] 100% -- SUCCESS Extracting "bios" version from image bootflash:/n3000-uk9.6.0.2.U6.8.bin. [####################] 100% -- SUCCESS Performing module support checks. [####################] 100% -- SUCCESS Notifying services about system upgrade. [####################] 100% -- SUCCESS Compatibility check is done: Module bootable Impact Install-type Reason ------ -------- -------------- ------------ ------ 1 yes disruptive reset Forced by the user Images will be upgraded according to following table: Module Image Running-Version New-Version Upg-Required ------ ---------------- ---------------------- ---------------------- ------------ 1 system 6.0(2)U2(2) 6.0(2)U6(8) yes 1 kickstart 6.0(2)U2(2) 6.0(2)U6(8) yes 1 bios v1.2.0(08/25/2011) v1.4.0(12/09/2013) yes 1 power-seq v4.4 v4.4 no Switch will be reloaded for disruptive upgrade. Do you want to continue with the installation (y/n)? [n] y Time Stamp: Tue Apr 27 08:03:12 2021 Install is in progress, please wait. Performing runtime checks. [####################] 100% -- SUCCESS Setting boot variables. [####################] 100% -- SUCCESS Performing configuration copy. [####################] 100% -- SUCCESS Module 1: Refreshing compact flash and upgrading bios/loader/bootrom/power-seq. Warning: please do not remove or power off the module at this time. Note: Power-seq upgrade needs a power-cycle to take into effect. On success of power-seq upgrade, SWITCH OFF THE POWER to the system and then, power it up. [####################] 100% -- SUCCESS Time Stamp: Tue Apr 27 08:05:05 2021 Finishing the upgrade, switch will reboot in 10 seconds. switch# [ 4273.417321] writing reset reason 49, И всё. Горит ID и ноль-повдоль. Потом нашёл на форуме циски - https://community.cisco.com/t5/other-data-center-subjects/nexus-3048tp-1ge-no-console-after-upgrade/td-p/3000371 Quote We are hitting following bug: Nexus doesn't boot after upgrade to 6.0.2.U6.7 CSCva97678 Nexus doesn't boot after upgrade to 6.0.2.U6.7 from release older than 6.0.2.U6.2 Оказывается, надо было на 6.0.2.U6.2 сначала обновиться, потом 6.0.2.U6.7... В закромах вижу 6.0.2.U6.2a, интересно подойдёт? У меня второй такой есть, чтобы окончательно похоронить. Вставить ник Quote
neperpbl3 Posted June 1, 2021 Posted June 1, 2021 (edited) Здравствуйте. Хочу поделится опытом обновления устройства Cisco Nexus N3K-C3064PQ. Возможно это кому-то будет полезно. Не стал создавать новую тему, здесь вроде как разбирается тема обновлений. Согласно www.cisco.com Cisco сейчас рекомендует релиз 9 ветки 9.3(7). Подробности здесь. Отличие 7 и 9 версии: Цитата v9 is initially an alignment train to allow the convergence of the whole of the N9k and N3k series switches. There is not currently a long-lived v9 release, so it is unlikely that there would be any recommendation to go there except for functionality reasons. I have experienced some issues with 9.2.1, so would suggest that if you want to go for a v9, you use 9.2.2. You might be best served by talking to your Cisco Account SE to get a view of the relevant software road maps. https://community.cisco.com/ В официальном руководстве Cisco Nexus 3000 Series NX-OS Software Upgrade and Downgrade Guide, Release 7.x сказано, что обновление осуществляется через версию 6.0.2.U6(3) Согласно инструкции по обновлению Upgrade Nexus 3000 and 3100 NX-OS Software обновление с 6 до 7 версии осуществляется через промежуточную версию 6.0(2)U6(10) Цитата Note: An NX-OS software upgrade to a target release in the NX-OS 7.x major release from a source release in the NX-OS 6.x major release requires a mandatory intermediate upgrade to 6.0(2)U6(10) before upgrading to the desired target release. А обновление с 6 до 9 версии осуществляется через две промежуточные версии 6.0(2)U6(10) и 7.0(3)I7(9) Другие официальные инструкции: Инструкции Cisco Nexus 3000 Series NX-OS Software Upgrade and Downgrade Guides Cisco Nexus 3000 Series NX-OS Software Upgrade and Downgrade Guide, Release 9.3(x) Cisco Nexus 3000 Series NX-OS Software Upgrade and Downgrade Guide, Release 9.2(x) Cisco Nexus 3000 Series NX-OS Software Upgrade and Downgrade Guide, Release 6.x Практический опыт обновления Обновлять нужно строго последовательно по схеме и никаких проблем не возникнет. Основная сложность - это перейти с 6 ветки на 7. Если скокануть со старой 6 сразу на 7 или 9 без промежуточных обновлений, то может получится кирпич. Кирпичи получаются, когда люди по незнанию начинают обновляться со старых 6 сразу на последние версии, подобно как на привычных системах IOS. Промежуточные версии нужны для того, что в них последовательно обновляется BIOS и микрокод в других платах (не проверенная инфа). Устройство может стать кирпичем, если возникнет сбой при обновлении BIOS. Коммутатор просто не выполнит первичный загрузчик и не загрузится. Начиная с 7 ветки обновление практически безопасное. В процессе обновления флешка может не определяться. Это нормально. Чтобы была видна USB флешка в некоторых случаях нужно ее вынимать при перезагрузке устройства, а в других случаях надо оставлять вставленной при перезагрузке. Если не появляется, то перезагружать нужно без флешки, затем ждать минут пять, потом вставить на минуту, затем вынуть на минуту и опять вставить. Когда загрузится, то нужно вставить, потом вынуть и опять вставить. Cisco позволяет сжимать образы (команда compact). Файл заметно уменьшается, но однако устройство будет дольше грузиться, т.к. файл будет распаковывается при загрузке. Внимание!!! Файл «compact» нужно генерировать каждый раз заного. Сгенерированный под одной версией он может быть несовместимым с другой. Проверка файла на читаемость во время установки отсутствует. Во время операций копирования следите за свободным местом с помощью команды dir. Инструкция по обновлению Алгоритм обновлений 6.0(2)U3(9) 6.0(2)U5(2) 6.0(2)U6(2a) 6.0(2)U6(10) (!!!) 7.0(3)I7(1) 7.0(3)I7(9) (!!!) 9.2(1) 9.2(4) 9.3(7) Подключаемся к коммутатору с помощью стандартного консольного кабеля. По-умолчанию скорость порта 9600. Рекомендуется её повысить до 11500 Цитата switch# conf t switch(config)# line console switch(config-console)#speed 115200 switch# copy running-config startup-config Проверяем версию Цитата switch# show version | i version BIOS: version 2.6.0 loader: version N/A kickstart: version 6.0(2)U3(7) system: version 6.0(2)U3(7) Module 1: version v1.0 SFP uC: version 2.12 System version: 6.0(2)U3(7) Проверяем активированные лицензии Цитата switch# show license usage Feature Ins Lic Status Expiry Date Comments Count -------------------------------------------------------------------------------- LAN_BASE_SERVICES_PKG Yes - Unused Never - ALGO_BOOST_SERVICES_PKG No - Unused - LAN_ENTERPRISE_SERVICES_PKG Yes - Unused Never - -------------------------------------------------------------------------------- Вставляем флешку размером 8-16 ГБ. Если не определяется, то нужно перевключить. Цитата switch# dir usb1: 32507392 Jun 17 07:33:06 2019 n3000-uk9-kickstart.6.0.2.U3.9.bin 37738496 Oct 16 11:35:06 2019 n3000-uk9-kickstart.6.0.2.U5.2.bin 37881856 Jun 17 08:01:24 2019 n3000-uk9-kickstart.6.0.2.U6.10.bin 37853184 Jun 17 10:01:26 2019 n3000-uk9-kickstart.6.0.2.U6.2a.bin 188984752 Jun 17 07:36:18 2019 n3000-uk9.6.0.2.U3.9.bin 190169216 Oct 16 11:35:10 2019 n3000-uk9.6.0.2.U5.2.bin 206130057 Jun 17 08:04:54 2019 n3000-uk9.6.0.2.U6.10.bin 206765681 Jun 18 09:21:12 2019 n3000-uk9.6.0.2.U6.2a.bin 443319296 Mar 10 07:48:00 2021 nxos.7.0.3.I1.3.bin 882475008 Jun 17 15:29:36 2019 nxos.7.0.3.I7.1.bin 982694912 Sep 07 01:35:16 2020 nxos.7.0.3.I7.9.bin 1308795904 Jun 17 16:53:28 2019 nxos.9.2.1.bin Usage for usb1://sup-local 4555374592 bytes used 10929872896 bytes free 15485247488 bytes total switch# dir 0 Jun 03 19:36:10 2016 20160603_193610_poap_3843_init.log 168 Feb 03 21:46:19 2020 20200203_213215_poap_4187_init.log 84 May 31 05:48:29 2021 20210531_054818_poap_3843_init.log 84 May 31 05:58:42 2021 20210531_055831_poap_3843_init.log 168 May 31 06:11:33 2021 20210531_060835_poap_3843_init.log 640 Jun 03 19:20:10 2016 license_FOC2013R00S_10_1.lic 4096 Jun 03 19:30:46 2016 lost+found/ 32519680 Jun 03 19:14:02 2016 n3000-uk9-kickstart.6.0.2.U3.7.bin 216049041 Jun 03 19:14:27 2016 n3000-uk9.6.0.2.U3.7.bin 4096 Jan 29 19:16:52 2010 vdc_2/ 4096 Jan 29 19:16:52 2010 vdc_3/ 4096 Jan 29 19:16:52 2010 vdc_4/ Usage for bootflash:// 376639488 bytes used 1 476 476 928 bytes free 1853116416 bytes total Свободно 1,4 ГБайт Копируем все версии 6 ветки на внутреннюю память «bootflash». Эти версии занимают немного и памяти хватит. Цитата switch# copy usb1:n3000-uk9-kickstart.6.0.2.U3.9.bin bootflash: switch# copy usb1:n3000-uk9-kickstart.6.0.2.U5.2.bin bootflash: switch# copy usb1:n3000-uk9-kickstart.6.0.2.U6.10.bin bootflash: switch# copy usb1:n3000-uk9-kickstart.6.0.2.U6.2a.bin bootflash: switch# copy usb1:n3000-uk9.6.0.2.U3.9.bin bootflash: switch# copy usb1:n3000-uk9.6.0.2.U5.2.bin bootflash: switch# copy usb1:n3000-uk9.6.0.2.U6.10.bin bootflash: switch# copy usb1:n3000-uk9.6.0.2.U6.2a.bin bootflash: В дальнейшем в инструкции не будет приводится вывод команды «dir». При каждой операции проверяйте наличие свободного места на внутренней памяти. На внутренней памяти bootflash должны появится все скопированные версии 6-й ветки. Устанавливаем 6.0(2)U3(9) Цитата switch# install all system bootflash:n3000-uk9.6.0.2.U3.9.bin kickstart bootflash:n3000-uk9-kickstart.6.0.2.U3.9.bin Images will be upgraded according to following table: Module Image Running-Version New-Version Upg-Required ------ ---------------- ---------------------- ---------------------- ------------ 1 system 6.0(2)U3(7) 6.0(2)U3(9) yes 1 kickstart 6.0(2)U3(7) 6.0(2)U3(9) yes 1 bios v2.6.0(08/06/2014) v1.7.0(10/14/2013) no 1 power-seq v1.0 v1.0 no 1 SFP-uC v2.12 v2.12 no После перезагрузки Цитата switch# show version | i version BIOS: version 2.6.0 loader: version N/A kickstart: version 6.0(2)U3(9) system: version 6.0(2)U3(9) Module 1: version v1.0 SFP uC: version 2.12 System version: 6.0(2)U3(7) Устанавливаем 6.0(2)U5(2) Цитата switch# install all system bootflash:n3000-uk9.6.0.2.U5.2.bin kickstart bootflash:n3000-uk9-kickstart.6.0.2.U5.2.bin Images will be upgraded according to following table: Module Image Running-Version New-Version Upg-Required ------ ---------------- ---------------------- ---------------------- ------------ 1 system 6.0(2)U3(9) 6.0(2)U5(2) yes 1 kickstart 6.0(2)U3(9) 6.0(2)U5(2) yes 1 bios v2.6.0(08/06/2014) v2.6.0(08/06/2014) no 1 power-seq v1.0 v1.0 no 1 SFP-uC v2.12 v2.12 no После перезагрузки Цитата switch# show version | i version BIOS: version 2.6.0 loader: version N/A kickstart: version 6.0(2)U5(2) system: version 6.0(2)U5(2) Module 1: version v1.0 SFP uC: version 2.12 System version: 6.0(2)U3(9) Устанавливаем 6.0(2)U6(2a) Цитата switch# install all system bootflash:n3000-uk9.6.0.2.U6.2a.bin kickstart bootflash:n3000-uk9-kickstart.6.0.2.U6.2a.bin Images will be upgraded according to following table: Module Image Running-Version New-Version Upg-Required ------ ---------------- ---------------------- ---------------------- ------------ 1 system 6.0(2)U5(2) 6.0(2)U6(2a) yes 1 kickstart 6.0(2)U5(2) 6.0(2)U6(2a) yes 1 bios v2.6.0(08/06/2014) v2.6.0(08/06/2014) no 1 SFP-uC v2.12 v2.12 no После перезагрузки Цитата switch# show version | i version BIOS: version 2.6.0 loader: version N/A kickstart: version 6.0(2)U6(2a) system: version 6.0(2)U6(2a) Module 1: version v1.0 SFP uC: version 2.12 System version: 6.0(2)U5(2) Устанавливаем 6.0(2)U6(10) (!!!) Цитата switch# install all system bootflash:n3000-uk9.6.0.2.U6.10.bin kickstart bootflash:n3000-uk9-kickstart.6.0.2.U6.10.bin Images will be upgraded according to following table: Module Image Running-Version New-Version Upg-Required ------ ---------------- ---------------------- ---------------------- ------------ 1 system 6.0(2)U6(2a) 6.0(2)U6(10) yes 1 kickstart 6.0(2)U6(2a) 6.0(2)U6(10) yes 1 bios v2.6.0(08/06/2014) v2.8.0(12/22/2015) yes 1 SFP-uC v2.12 v2.12 no После перезагрузки Цитата switch# show version | i version BIOS: version 2.8.0 loader: version N/A kickstart: version 6.0(2)U6(10) system: version 6.0(2)U6(10) Module 1: version v1.0 SFP uC: version 2.12 System version: 6.0(2)U6(2a) Удаляем старые образы и копируем новые образы на внутреннюю память Цитата switch# delete bootflash:n3000-uk9-kickstart.6.0.2.U3.9.bin switch# delete bootflash:n3000-uk9-kickstart.6.0.2.U5.2.bin switch# delete bootflash:n3000-uk9-kickstart.6.0.2.U6.2a.bin switch# delete bootflash:n3000-uk9.6.0.2.U3.9.bin switch# delete bootflash:n3000-uk9.6.0.2.U5.2.bin switch# delete bootflash:n3000-uk9.6.0.2.U6.2a.bin switch# copy usb1:nxos.7.0.3.I7.1.bin bootflash: Устанавливаем 7.0(3)I7(1) Цитата switch# install all nxos bootflash:nxos.7.0.3.I7.1.bin Images will be upgraded according to following table: Module Image Running-Version New-Version Upg-Required ------ ---------------- ---------------------- ---------------------- ------------ 1 kickstart 6.0(2)U6(10) 7.0(3)I7(1) yes 1 bios v2.8.0(12/22/2015) v4.4.0(07/12/2017) yes 1 SFP-uC v2.12 v0.0 no После перезагрузки Цитата switch# show version | i version the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU BIOS: version 4.4.0 NXOS: version 7.0(3)I7(1) System version: 6.0(2)U6(10) Удаляем старые образы и копируем новые образы на внутреннюю память Цитата switch# delete bootflash:n3000-uk9-kickstart.6.0.2.U3.7.bin switch# delete bootflash:n3000-uk9-kickstart.6.0.2.U6.10.bin switch# delete bootflash:n3000-uk9.6.0.2.U3.7.bin switch# delete bootflash:n3000-uk9.6.0.2.U6.10.bin Сжимаем следующий образ, чтобы он влез на внутреннюю память. Команда «install all nxos usb1:файл compact» только сжимает файл и больше ничего не делает. Цитата switch# install all nxos usb1:nxos.7.0.3.I7.9.bin compact switch# copy usb1:nxos.7.0.3.I7.9.bin bootflash:nxos.7.0.3.I7.9_compact.bin Устанавливаем 7.0(3)I7(9) (!!!) Цитата switch# install all nxos bootflash:nxos.7.0.3.I7.9_compact.bin Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------ ---------- ---------------------------------------- -------------------- ------------ 1 nxos 7.0(3)I7(1) 7.0(3)I7(9) yes 1 bios v4.4.0(07/12/2017) v4.5.0(11/09/2017) yes После перезагрузки Цитата switch# show version | i version the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU BIOS: version 4.5.0 NXOS: version 7.0(3)I7(9) System version: 7.0(3)I7(1) Удаляем старые файлы и сжимаем следующий образ, чтобы он влез на внутреннюю память. Цитата switch# delete bootflash:nxos.7.0.3.I7.1.bin switch# install all nxos usb1:nxos.9.2.1.bin compact switch# copy usb1:nxos.9.2.1.bin bootflash:nxos.9.2.1_compact.bin Устанавливаем 9.2(1) Цитата switch# conf t Enter configuration commands, one per line. End with CNTL/Z. switch(config)# no system dme enable Warning: DME successfully disabled Warning: Please copy running-config to startup-config and reload the switch to apply changes. switch(config)# copy running-config startup-config [########################################] 100% reloadCopy complete, now saving to disk (please wait)... Copy complete. switch(config)# reload This command will reboot the system. (y/n)? [n] y switch# install all nxos bootflash:nxos.9.2.1_compact.bin Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------ ---------- ---------------------------------------- -------------------- ------------ 1 nxos 7.0(3)I7(9) 9.2(1) yes 1 bios v4.5.0(11/09/2017) v5.0.0(06/05/2018) yes После перезагрузки Цитата switch# show version | i version 2021 May 31 10:40:57 switch %$ VDC-1 %$ %ASCII-CFG-2-CONF_CONTROL: System ready the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU BIOS: version 5.0.0 NXOS: version 9.2(1) System version: 7.0(3)I7(9) NXOS версии 9.2.1 не умеет сжимать образы подветки 9.3.х. Они почему-то получаются меньшего размера. Если их установить такие сжатые версии, то коммутатор не загрузится и нужно будет восстанавливать старую версию. Как видно ниже глючные сжатые версии nxos.9.3.5.bin и nxos.9.3.6.bin имеют меньший размер, чем текущая nxos.9.2.1_compact.bin Цитата switch # dir usb1: 526038807 May 12 10:30:54 2021 nxos.9.2.1_compact.bin 506664569 May 14 11:04:39 2021 nxos.9.3.5.bin 507440790 May 14 10:23:24 2021 nxos.9.3.6.bin Для перехода на версию 9.3.х нужно обновится на версию 9.2.4. Врсия 9.2.4 правильно сжимает файлы подветки 9.3.х Удаляем старые файлы и сжимаем следующий образ, чтобы он влез на внутреннюю память. Цитата switch# delete bootflash:nxos.7.0.3.I7.9_compact.bin switch# install all nxos usb1:nxos.9.2.4.bin compact switch# copy usb1:nxos.9.2.4.bin bootflash:nxos.9.2.4_compact.bin Устанавливаем 9.2(4) Цитата switch# install all nxos bootflash:nxos.9.2.4_compact.bin Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------ ---------- ---------------------------------------- -------------------- ------------ 1 nxos 9.2(1) 9.2(4) yes 1 bios v5.0.0(06/05/2018) v5.0.0(06/05/2018) no После перезагрузки Цитата switch# show version | i version the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU BIOS: version 5.0.0 NXOS: version 9.2(4) System version: 9.2(1) Удаляем старые файлы и сжимаем следующий образ, чтобы он влез на внутреннюю память. Цитата switch# delete bootflash:nxos.9.2.1_compact.bin switch# install all nxos usb1:nxos.9.3.7.bin compact switch# copy usb1:nxos.9.3.7.bin bootflash:nxos.9.3.7_compact.bin Устанавливаем 9.3(7) (последняя) но сперва удостоверяемся, что файл новой версии занимает больше прежней. Цитата switch# dir 544 195 757 Jun 01 03:05:18 2021 nxos.9.2.4_compact.bin 673 224 466 Jun 01 03:38:28 2021 nxos.9.3.7_compact.bin switch# install all nxos bootflash:nxos.9.3.7_compact.bin Images will be upgraded according to following table: Module Image Running-Version(pri:alt) New-Version Upg-Required ------ ---------- ---------------------------------------- -------------------- ------------ 1 nxos 9.2(4) 9.3(7) yes 1 bios v5.0.0(06/05/2018) v5.0.0(06/05/2018) no После перезагрузки Цитата switch# show version Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Copyright (C) 2002-2021, Cisco and/or its affiliates. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under their own licenses, such as open source. This software is provided "as is," and unless otherwise stated, there is no warranty, express or implied, including but not limited to warranties of merchantability and fitness for a particular purpose. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or GNU General Public License (GPL) version 3.0 or the GNU Lesser General Public License (LGPL) Version 2.1 or Lesser General Public License (LGPL) Version 2.0. A copy of each such license is available athttp://www.opensource.org/licenses/gpl-2.0.php andhttp://opensource.org/licenses/gpl-3.0.html andhttp://www.opensource.org/licenses/lgpl-2.1.php andhttp://www.gnu.org/licenses/old-licenses/library.txt. Software BIOS: version 5.0.0 NXOS: version 9.3(7) BIOS compile time: 06/05/2018 NXOS image file is: bootflash:///nxos.9.3.7_compact.bin NXOS compile time: 3/10/2021 3:00:00 [03/10/2021 13:39:29] Hardware cisco Nexus3000 C3064PQ Chassis Intel(R) Celeron(R) CPU P4505 @ 1.87GHz with 3901500 kB of memory. Processor Board ID FOC201ЯЯЯЯЯЯ Device name: switch bootflash: 1838592 kB usb1: 15137280 kB (expansion flash) Kernel uptime is 0 day(s), 2 hour(s), 33 minute(s), 21 second(s) Last reset at 882545 usecs after Tue Jun 1 05:54:50 2021 Reason: Reset Requested by CLI command reload System version: 9.3(7) Service: plugin Core Plugin, Ethernet Plugin Active Package(s): Цитата switch# show license usage Feature Ins Lic Status Expiry Date Comments Count -------------------------------------------------------------------------------- VPN_FABRIC No - Unused - NXOS_OE_PKG No - Unused - TP_SERVICES_PKG No - Unused - NXOS_ADVANTAGE_XF No - Unused - NXOS_ESSENTIALS_XF No - Unused - LAN_BASE_SERVICES_PKG Yes - Unused never - LAN_ENTERPRISE_SERVICES_PKG Yes - Unused never - -------------------------------------------------------------------------------- Цитата switch# delete bootflash:nxos.9.2.4_compact.bin Задача выполнена. Как загрузиться при неудачном обновлении? Удерживаем ctrl+L при появлении сообщения и входим в загрузчик Цитата ^LPress ctrl L to go to loader prompt in 2 secs User break into bootloader loader> dir bootflash: sprom_cstruct_2_0_0 vdc_2 vdc_3 vdc_4 virtual-instance sprom_cstruct_3_0_0 nxos.9.2.1_compact.bin lost+found patch_debug.log sprom_3_0_0 nxos.9.3.6_compact.bin bios_daemon.dbg patch_control.log bootflash_sync_list home eem_snapshots sprom_2_0_1 sysmgrLcore_0x101_ifmgr_log.13235.tar.gz platform-sdk.cmd logflash sysmgrLcore_0x101_ifmgr_log.13572.tar.gz usb1: System Volume Information n3000-uk9-kickstart.6.0.2.U6.10.bin n3000-uk9.6.0.2.U6.10.bin poap_script.6.0.2.U6.10.py n3000-uk9-kickstart.6.0.2.U6.2a.bin n3000-uk9.6.0.2.U6.2a.bin n3000-uk9-kickstart.6.0.2.U5.2.bin n3000-uk9.6.0.2.U5.2.bin n3000-uk9-kickstart.6.0.2.U3.9.bin n3000-uk9.6.0.2.U3.9.bin nxos.7.0.3.I7.1.bin nxos.7.0.3.I7.9.bin nxos.9.3.6_compact.bin nxos.7.0.3.I7.1_compact.bin nxos.7.0.3.I7.9_compact.bin nxos.9.2.1_compact.bin Загружаем нужную версию командой loader> boot bootflash:nxos.9.2.1_compact.bin После перезагрузки install all nxos bootflash:nxos.XXX Edited June 1, 2021 by neperpbl3 Вставить ник Quote
kayot Posted June 2, 2021 Posted June 2, 2021 В 01.06.2021 в 11:44, neperpbl3 сказал: Алгоритм обновлений 6.0(2)U3(9) 6.0(2)U5(2) 6.0(2)U6(2a) 6.0(2)U6(10) (!!!) 7.0(3)I7(1) 7.0(3)I7(9) (!!!) 9.2(1) 9.2(4) 9.3(7) Очень странный метод. 9 промежуточных ненужных обновлений. С 6.0 можно ставить 6.0(2)U6(10), она обновитт биос и добавит команду установки nxos. При и какой-то совсем древней 4.хх или 5.хх возможно придется залить промежуточную 6.0 старую, но у меня на все что пробовал становилась 6.0(2)U6 включая 5.х Дальше заливается 7.0(3).I7(9).bin, я заливал 7.0(3).I7(7).bin. Опять будет обновление биос. Ну и поверх неё любая 9.хх, собственно сразу 9.3.(7) Вставить ник Quote
spwest Posted June 3, 2021 Posted June 3, 2021 (edited) Коллеги можете выложить где то файлы прошивок до 9.3.7 для Cisco Nexus 3048. И еще подскажите есть смысл обновляться с 7.0(3)I7(9) выше, у всех ли корректно работает 9.3(7) 7.0(3)I7(9) (!!!) 9.2(1) 9.2(4) 9.3(7) Edited June 3, 2021 by spwest Вставить ник Quote
Павел Кротов Posted June 8, 2021 Posted June 8, 2021 (edited) Здравствуйте, поделитесь пожалуйста, ссылкой на сжатый nxos.9.3.7.bin (n3000-compact.9.3.7.bin) и сжатый nxos.7.0.3.I7.9.bin (n3000-compact.7.0.3.I7.9.bin) для N3K-C3064PQ-10GX. Чтоб 9.3.7 правильно сжался, говорят надо на 9.2.4 сперва обновить, а 7.0.3.I7.9 якобы неправильно сжимает 9.3.7. Ну и вообще, размышляю надо ли с 7.0.3.I7.9 до 9.3.7 обновлять? Если ли какие то важные улучшения или объективные доводы или в новых новые глюки и тормоза? Изменение прошивки с 200мб (v6) до 1,8Гб (v9) настораживает. Грузиться будет наверное долго, да еще из сжатого. В этом чате читал про проблемы IGMP, где то их решили (не уверен что он нужен нам). уязвимостей по безопасности на 7.0.3.I7.9 не вижу. Нам важна надежность, но хотелось бы сразу обновить на лучшую версию, пока он не в работе. Планирую сделать на двух N3K-C3064PQ-10GX VPC для серверов, роутинг интервлан, вероятно Eigrp, ACL к вланам. SFP купил такие SFP-H10GB-CU и SFP-10G-SR. Edited June 8, 2021 by Павел Кротов Вставить ник Quote
avko Posted June 23, 2021 Posted June 23, 2021 В 08.06.2021 в 19:37, Павел Кротов сказал: SFP купил такие SFP-H10GB-CU и SFP-10G-SR А почему не SNR? Задача схожая с Вашей, тоже думаю, может и не надо до 9.3 обновляться Вставить ник Quote
AN111 Posted June 24, 2021 Posted June 24, 2021 On 6/8/2021 at 7:37 PM, Павел Кротов said: Чтоб 9.3.7 правильно сжался, говорят надо на 9.2.4 сперва обновить, а 7.0.3.I7.9 якобы неправильно сжимает 9.3.7. Изменение прошивки с 200мб (v6) до 1,8Гб (v9) настораживает. Грузиться будет наверное долго, да еще из сжатого. C 9.2.3 в 9.3.7 скомпактился нормально. Полный перегруз коробки с 9.3.7 около 5 мин. Вставить ник Quote
geelros Posted September 1, 2021 Posted September 1, 2021 Кто может подсказать правильный алгоритм с версии 5.0(3)U5(1a)? А то найдены разные варианты. Вставить ник Quote
agilium Posted September 15, 2021 Posted September 15, 2021 В 03.12.2020 в 13:53, AAS сказал: В личке :) Поделитесь пожалуйста софтом У меня данная версия прошивки стоит в данный момент n3000-uk9.6.0.2.U2.9Z.bin Как я понял из гайдов, мне нужны следующие версии, чтобы обновить до девятки: NX-OS 6.0(2)U6(10) NX-OS 7.0(3)I2(2d) NX-OS 7.0(3)I7(7) NX-OS 9.3(1) Спасибо! В 03.12.2020 в 13:53, AAS сказал: В личке :) Возможно сможете подсказать. Лицензии не слетают при обновлении ОС на данной модели нексуса? Вставить ник Quote
AAS Posted September 15, 2021 Posted September 15, 2021 18 минут назад, agilium сказал: Возможно сможете подсказать. Лицензии не слетают при обновлении ОС на данной модели нексуса? С таким не сталкивался. Как правило "лицензии" это файлик в корне коммутатора с расширением *.lic его можно на флешку скинуть до начала процедуры а потом в случае чего выполнить install licence bootflash://*.lic Иногда лицензия без файла на диске сразу в память сохранена (уже инсталл сделан) - я не помню, чтобы у кого-то когда-то это слетело (а я этих коммутаторов не один десяток перешивал и даже из "кирпича" оживляли) Вставить ник Quote
geelros Posted October 5, 2021 Posted October 5, 2021 On 6/8/2021 at 5:37 PM, Павел Кротов said: Здравствуйте, поделитесь пожалуйста, ссылкой на сжатый nxos.9.3.7.bin (n3000-compact.9.3.7.bin) и сжатый nxos.7.0.3.I7.9.bin (n3000-compact.7.0.3.I7.9.bin) для N3K-C3064PQ-10GX. Чтоб 9.3.7 правильно сжался, говорят надо на 9.2.4 сперва обновить, а 7.0.3.I7.9 якобы неправильно сжимает 9.3.7. Ну и вообще, размышляю надо ли с 7.0.3.I7.9 до 9.3.7 обновлять? Если ли какие то важные улучшения или объективные доводы или в новых новые глюки и тормоза? Изменение прошивки с 200мб (v6) до 1,8Гб (v9) настораживает. Грузиться будет наверное долго, да еще из сжатого. В этом чате читал про проблемы IGMP, где то их решили (не уверен что он нужен нам). уязвимостей по безопасности на 7.0.3.I7.9 не вижу. Нам важна надежность, но хотелось бы сразу обновить на лучшую версию, пока он не в работе. Планирую сделать на двух N3K-C3064PQ-10GX VPC для серверов, роутинг интервлан, вероятно Eigrp, ACL к вланам. SFP купил такие SFP-H10GB-CU и SFP-10G-SR. Что в итоге решили? Стою перед тем же вопросом, напрягает время перезагрузки. Вставить ник Quote
CraztRoot Posted October 6, 2021 Posted October 6, 2021 День добрый. Не нашел информации, селектив QinQ в 9.3.8 поддерживается? Вставить ник Quote
geelros Posted October 6, 2021 Posted October 6, 2021 А сколько у кого compact 9.3 выполнялся? У меня уже часа 3 Вставить ник Quote
neperpbl3 Posted October 7, 2021 Posted October 7, 2021 (edited) 21 час назад, CraztRoot сказал: День добрый. Не нашел информации, селектив QinQ в 9.3.8 поддерживается? Здравствуйте. Не интересовался. В data_sheet что-нибудь сказано? Здесь спрашивали? Есть свободный тестовый коммутатор. Если нужно проверить скажите как проверить. я проверю. 12 часов назад, geelros сказал: А сколько у кого compact 9.3 выполнялся? У меня уже часа 3 Здравствуйте. Файл сжимается минут 5-7 В 06.10.2021 в 00:14, geelros сказал: Что в итоге решили? Стою перед тем же вопросом, напрягает время перезагрузки. Здравствуйте. Коммутатор загружается около 5 минут. По секундомеру не замерял. Могу замерить, если для вас это важно. Edited October 7, 2021 by neperpbl3 Вставить ник Quote
geelros Posted October 7, 2021 Posted October 7, 2021 13 hours ago, geelros said: А сколько у кого compact 9.3 выполнялся? У меня уже часа 3 Это я обновлялся с 7.0(3)I7(9) на 9.3 сразу. Через промежуточные 9ки все получилось. На 7.0(3)I7(9) без сжатого образа загружался коммутатор 4 минуты. На 9.3(7) сжатым образом загружается 3. Вдруг кому пригодится) Вставить ник Quote
Kroys Posted October 12, 2021 Posted October 12, 2021 Доброго времени суток. Хотелось бы попросить Вас, пожалуйста скинуть промежуточные обновление для 3064. У меня текущая версия: kickstart: version 6.0(2)U6(7) system: version 6.0(2)U6(7) Хотелось бы обновиться до последней 9.3(8). Будут премногом благодарен Вам. Очень сильно выручите =) Вставить ник Quote
ichthyandr Posted October 13, 2021 Posted October 13, 2021 В 03.12.2020 в 13:53, AAS сказал: В личке :) И мне тоже будьте любезны ) Вставить ник Quote
d1m0n Posted October 20, 2021 Posted October 20, 2021 BIOS: version 4.5.0 NXOS: version 7.0(3)I7(4) и мне будьте добры, большое спасибо заранее! Вставить ник Quote
ffrds Posted December 15, 2021 Posted December 15, 2021 Коллеги, поделитесь, пож, софтом n3000-compact.9.3.8.bin. Заранее благодарю! Вставить ник Quote
zlobar Posted December 15, 2021 Posted December 15, 2021 On 12/15/2021 at 7:53 PM, ffrds said: Коллеги, поделитесь, пож, софтом n3000-compact.9.3.8.bin. Заранее благодарю! Скинув в приватні повідомлення. Вставить ник Quote
mag106 Posted December 19, 2021 Posted December 19, 2021 Поделитесь пожалуйста compact 9.3.8 для N3K-C3064PQ-10GX, поставил на сжатие на флешке, за 6 часов так и не сжалось, точки бегут только(пробую сжать из под nxos.7.0.3.I7.10) Вставить ник Quote
zlobar Posted December 19, 2021 Posted December 19, 2021 On 12/19/2021 at 7:17 PM, mag106 said: Поделитесь пожалуйста compact 9.3.8 для N3K-C3064PQ-10GX, поставил на сжатие на флешке, за 6 часов так и не сжалось, точки бегут только(пробую сжать из под nxos.7.0.3.I7.10) Скинув) Вставить ник Quote
kayot Posted December 19, 2021 Posted December 19, 2021 В 19.12.2021 в 19:17, mag106 сказал: пробую сжать из под nxos.7.0.3.I7.10 А надо из 9ой, некорректный образ получится. Вставить ник Quote
mag106 Posted December 24, 2021 Posted December 24, 2021 (edited) !удалено Edited December 24, 2021 by mag106 Вставить ник Quote
