megahertz0 Posted February 2, 2015 Posted February 2, 2015 (edited) Есть одна 3750. На ней поднят DHCP-сервер с вот таким пулом: ! ip dhcp pool ONT-Pool network 10.22.4.0 255.255.252.0 default-router 10.22.7.254 dns-server 91.197.107.200 91.197.104.182 ! Используем для доступа на ONT с целью отладки конфигов. Проблема в том, что при рестарте ONT он получает не тот же адрес, а следующий. Даже при штатном рестарте ONT со всеми release адресов. Вот так выглядит на циске: 3750.U63#sh ip dhcp binding | inc a8f9.4bc0.06d2 10.22.4.12 a8f9.4bc0.06d2 Feb 03 2015 04:01 PM Automatic 3750.U63#sh ip dhcp binding | inc a8f9.4bc0.06d2 10.22.4.13 a8f9.4bc0.06d2 Feb 03 2015 04:19 PM Automatic 3750.U63#[/size] [size="2"] Вот дебаг с циски: [/size] [size=2]000261: Feb 2 16:23:25.703: DHCPD: Sending notification of TERMINATION:[/size] [size=2]000262: Feb 2 16:23:25.703: DHCPD: address 10.22.4.13 mask 255.255.252.0[/size] [size=2]000263: Feb 2 16:23:25.703: DHCPD: reason flags: RELEASE 2[/size] [size=2]000264: Feb 2 16:23:25.703: DHCPD: htype 1 chaddr a8f9.4bc0.06d2[/size] [size=2]000265: Feb 2 16:23:25.703: DHCPD: lease time remaining (secs) = 86163[/size] [size=2]000266: Feb 2 16:23:25.703: DHCPD: interface = Vlan396[/size] [size=2]000267: Feb 2 16:23:25.703: DHCPD: out_vlan_id 0[/size] [size=2]000268: Feb 2 16:23:25.703: DHCPD: dhcpd_deactivate_binding binding removed from mac hash 5CC056C[/size] [size=2]000269: Feb 2 16:23:25.703: DHCPD: returned 10.22.4.13 to address pool ONT-Pool.[/size] [size=2]000270: Feb 2 16:24:36.295: DHCPD: checking for expired leases.[/size] [size=2]000271: Feb 2 16:25:08.843: DHCPD: Sending notification of DISCOVER:[/size] [size=2]000272: Feb 2 16:25:08.843: DHCPD: htype 1 chaddr a8f9.4bc0.06d2[/size] [size=2]000273: Feb 2 16:25:08.843: DHCPD: remote id 6d61343030302d706c35[/size] [size=2]000274: Feb 2 16:25:08.843: DHCPD: circuit id 454c54583546303030324143[/size] [size=2]000275: Feb 2 16:25:08.843: DHCPD: interface = Vlan396[/size] [size=2]000276: Feb 2 16:25:08.843: DHCPD: out_vlan_id 0[/size] [size=2]000277: Feb 2 16:25:08.843: DHCPD: Sending notification of DISCOVER:[/size] [size=2]000278: Feb 2 16:25:08.843: DHCPD: htype 1 chaddr a8f9.4bc0.06d2[/size] [size=2]000279: Feb 2 16:25:08.843: DHCPD: remote id 6d61343030302d706c35[/size] [size=2]000280: Feb 2 16:25:08.843: DHCPD: circuit id 454c54583546303030324143[/size] [size=2]000281: Feb 2 16:25:08.843: DHCPD: interface = Vlan396[/size] [size=2]000282: Feb 2 16:25:08.843: DHCPD: out_vlan_id 0[/size] [size=2]000283: Feb 2 16:25:10.857: DHCPD: Allocated binding 5CC056C[/size] [size=2]000284: Feb 2 16:25:10.857: DHCPD: Adding binding to radix tree (10.22.4.14)[/size] [size=2]000285: Feb 2 16:25:10.857: DHCPD: Adding binding to hash tree 5CC056C[/size] [size=2]000286: Feb 2 16:25:10.857: DHCPD:dhcpd_binding_add_to_mac_hash: index- 146 add binding 5CC056C[/size] [size=2]000287: Feb 2 16:25:10.857: DHCPD: assigned IP address 10.22.4.14 to client a8f9.4bc0.06d2. (2464 0)[/size] [size=2]000288: Feb 2 16:25:10.857: DHCPD: DHCPOFFER notify setup address 10.22.4.14 mask 255.255.252.0[/size] [size=2]000289: Feb 2 16:25:10.865: DHCPD: Sending notification of ASSIGNMENT:[/size] [size=2]000290: Feb 2 16:25:10.865: DHCPD: address 10.22.4.14 mask 255.255.252.0[/size] [size=2]000291: Feb 2 16:25:10.865: DHCPD: htype 1 chaddr a8f9.4bc0.06d2[/size] [size=2]000292: Feb 2 16:25:10.865: DHCPD: lease time remaining (secs) = 86400[/size] [size=2]000293: Feb 2 16:25:10.865: DHCPD: interface = Vlan396[/size] [size=2]000294: Feb 2 16:25:10.873: DHCPD: out_vlan_id 0[/size][size=2][size=2] [/size] Вроде никакого криминала нет.. Может есть какая-нибудь опция по повторному использованию адресов? Edited February 2, 2015 by megahertz0 Вставить ник Quote
s.lobanov Posted February 2, 2015 Posted February 2, 2015 сделайте жёсткую привязку к макам (раз вам это для отладки, а не для продакшн) Вставить ник Quote
megahertz0 Posted February 2, 2015 Author Posted February 2, 2015 сделайте жёсткую привязку к макам (раз вам это для отладки, а не для продакшн) Ну как бы в продакшен тоже пойдет. Можно, конечно, сделать релей на dhcpd и выдавать адреса оттуда. Но хотелось бы оставить на циске. Не будем же делать статик биндинг под каждую ONT. Вставить ник Quote
vlad11 Posted February 2, 2015 Posted February 2, 2015 DHCP-сервер на Cisco только для офисной сети для раздачи серых ip из пула. Для провайдинга желательно отдельный DHCP-сервер соединенный с радиусом-биллингом. Вставить ник Quote
megahertz0 Posted February 2, 2015 Author Posted February 2, 2015 DHCP-сервер на Cisco только для офисной сети для раздачи серых ip из пула. Для провайдинга желательно отдельный DHCP-сервер соединенный с радиусом-биллингом. Этот DHCP-сервер нужен для доступа на менеджмент-интерфейс ONT. Для абонентов там отдельный влан с нормальным DHCP. Я не задаю же вопрос "зачем", а задаю вопрос "почему так происходит". Вставить ник Quote
GrandPr1de Posted February 2, 2015 Posted February 2, 2015 Ну биндите каждую ОНТ, великая проблема? :) Вставить ник Quote
megahertz0 Posted February 2, 2015 Author Posted February 2, 2015 Ну биндите каждую ОНТ, великая проблема? :) 300 штук? Вставить ник Quote
vurd Posted February 2, 2015 Posted February 2, 2015 Может быть это? By default, the DHCP server pings a pool address twice before assigning a particular address to a requesting client. If the ping is unanswered, the DHCP server assumes (with a high probability) that the address is not in use and assigns the address to the requesting client. Что-то вроде, ип на устройстве активен несмотря на release. Если заменить ont на ноутбук, ситуация такая же? Вставить ник Quote
GrandPr1de Posted February 2, 2015 Posted February 2, 2015 300 штук? А в чём проблема? Хоть 10 тысяч, был бы смысл. Вставить ник Quote
sol Posted February 2, 2015 Posted February 2, 2015 ip dhcp database tftp://<куда нибудь>/<где можно записывать>/<Файлы> В принципе, можно и на флешь ip dhcp database flash:/leases Или как-то так. Ему у вас лизы хранить негде. Вот и выдаёт каждый раз как в первый раз. Вставить ник Quote
snark Posted February 3, 2015 Posted February 3, 2015 ip dhcp database flash:/leases ip dhcp database nvram:dhcp.txt Дабы флешко не насиловать. Вставить ник Quote
sol Posted February 3, 2015 Posted February 3, 2015 Не могу сказать, как на Л3 свичках, а вот на роутерах NVRAM тоже флешко. EEPROM точнее. Так-же подвергается износу. Так что лучше на внешний TFTP Вставить ник Quote
vurd Posted February 3, 2015 Posted February 3, 2015 А в памяти ему лизы хранить сил не хватает что-ли? А что тогда показывает sh ip dhcp binding? Случайно не лизы ли как раз? :) Всё это сохранение нужно только на случа ребута железки, на рантайм работу влиять не должно совершенно. Вставить ник Quote
snark Posted February 3, 2015 Posted February 3, 2015 NVRAM тоже флешко Заточенная под частое юзание ;) Всё это сохранение нужно только на случа ребута железки, на рантайм работу влиять не должно совершенно. Не помню точно (в доку лень лезть) но вроде бы там by default лизы нигде не хранятся, поэтому на 100500 устройств можно честно выдавать один и тот же адрес, т.к. состояние адреса не известно. Вставить ник Quote
sol Posted February 3, 2015 Posted February 3, 2015 А в памяти ему лизы хранить сил не хватает что-ли?А что тогда показывает sh ip dhcp binding? Случайно не лизы ли как раз? :) Памяти, может и хватает. Но, надо указать, ГДЕ ИМЕННО сетевой админ РЕШИЛ хранить лизы. Железко не готов решать это за вас. А sh ip dhcp binding показывает не лизы а привязки. Адрес зарелизился - биндинг исчез. Смысл базы данных лизов в том, чтобы хранить привязки МЕЖДУ периодами аренды адреса. Пруфлинк http://www.cisco.com/c/en/us/td/docs/ios/12_2/ip/configuration/guide/fipr_c/1cfdhcp.html#wp1018925 Даже буквами написано, что если вы не конфигурируете базу данных - то отключите логгирование конфликтов IP. Ибо, они будут. Заточенная под частое юзание ;) Как правило, это простая 28F256 А у неё - от 1000 до 10000 циклов гарантируется. Смотря по поколению. Вставить ник Quote
ilili Posted February 5, 2015 Posted February 5, 2015 В продакшн, деньги освоить - CNR внедрить. Ну или ISC DHCP крутить. Не надо железку мучить :) Вставить ник Quote
