Cisco 2821 1gb Ram 256m на флехе.
1 Uplinker 40Mb\s
1 BGP FullView
Ната нет.
Шайп через CBWFQ
Ниже стоящему аплинкеру через rate-limmit
sh processes cpu s
CPU utilization for five seconds: 91%/79%; one minute: 83%; five minutes: 83%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
222 48001540 363761 131959 10.00% 1.62% 1.51% 0 BGP Scanner
223 34828 6145 5667 0.81% 1.18% 0.41% 322 SSH Process
77 64720 215038049 0 0.22% 0.43% 0.50% 0 traffic_shape
78 1461632 4751975 307 0.14% 0.06% 0.07% 0 IP Input
17 1127160 8121963 138 0.07% 0.07% 0.08% 0 ARP Input
2 20168 586278 34 0.07% 0.02% 0.00% 0 Load Meter
3 49392 249220 198 0.00% 0.00% 0.00% 0 IP SNMP
4 0 1 0 0.00% 0.00% 0.00% 0 EDDRI_MAIN
5 39404132 2010520 19599 0.00% 0.77% 1.04% 0 Check heaps
6 1080 984 1097 0.00% 0.00% 0.00% 0 Pool Manager
7 0 2 0 0.00% 0.00% 0.00% 0 Timers
8 168 48836 3 0.00% 0.00% 0.00% 0 IPC Dynamic Cach
9 0 1 0 0.00% 0.00% 0.00% 0 IPC Zone Manager
10 2008 2921714 0 0.00% 0.00% 0.00% 0 IPC Periodic Tim
11 1476 2921715 0 0.00% 0.00% 0.00% 0 IPC Deferred Por
12 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
13 0 1 0 0.00% 0.00% 0.00% 0 IPC BackPressure
14 0 1 0 0.00% 0.00% 0.00% 0 OIR Handler
15 0 1 0 0.00% 0.00% 0.00% 0 Crash writer
16 49968 97402 513 0.00% 0.00% 0.00% 0 Environmental mo
18 0 2 0 0.00% 0.00% 0.00% 0 ATM Idle Timer
#sh memory
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 450F1960 976283296 268536240 707747056 707331380 707537316
I/O 3F400000 12582912 5959288 6623624 6243568 6623356
sh processes
CPU utilization for five seconds: 87%/79%; one minute: 83%; five minutes: 83%
PID QTy PC Runtime (ms) Invoked uSecs Stacks TTY Process
1 Cwe 400AB11C 96 929 103 5468/6000 0 Chunk Manager
2 Csp 4008F038 20224 586292 34 1128/3000 0 Load Meter
3 Mwe 41800184 49392 249220 19810820/12000 0 IP SNMP
4 Mwe 424A785C 0 1 023384/24000 0 EDDRI_MAIN
5 Lst 400A800C 39408284 2010724 19599 5388/6000 0 Check heaps
6 Cwe 400AF1C4 1080 984 1097 5356/6000 0 Pool Manager
7 Mst 412A3E9C 0 2 0 5504/6000 0 Timers
8 Mwe 401125E4 168 48837 3 5700/6000 0 IPC Dynamic Cach
9 Mwe 40103628 0 1 0 5700/6000 0 IPC Zone Manager
10 Mwe 401027D4 2008 2921780 0 5612/6000 0 IPC Periodic Tim
11 Mwe 40102624 1476 2921781 0 5636/6000 0 IPC Deferred Por
12 Mwe 40103304 0 1 0 5576/6000 0 IPC Seat Manager
13 Mwe 401088B4 0 1 0 5672/6000 0 IPC BackPressure
14 Mwe 40258878 0 1 011672/12000 0 OIR Handler
15 Mwe 402F6F38 0 1 023608/24000 0 Crash writer
16 Msi 403F7958 49972 97404 513 5500/6000 0 Environmental mo
17 Mwe 40D150D4 1127384 8122275 138 4752/6000 0 ARP Input
18 Mwe 40DCA7C4 0 2 0 5452/6000 0 ATM Idle Timer
19 Mwe 4125E104 0 2 0 5492/6000 0 AAA high-capacit
20 Lwe 41261FEC 0 1 0 5688/6000 0 AAA_SERVER_DEADT
21 Mwe 412CA900 0 1 011652/12000 0 Policy Manager
sh ip traffic
IP statistics:
Rcvd: 1129869117 total, 2973929 local destination
165 format errors, 126 checksum errors, 505183 bad hop count
0 unknown protocol, 0 not a gateway
0 security failures, 0 bad options, 676 with options
Opts: 0 end, 664 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 664 record route
0 stream ID, 0 strict source route, 12 alert, 0 cipso, 0 ump
0 other
Frags: 0 reassembled, 273 timeouts, 0 couldn't reassemble
0 fragmented, 0 fragments, 0 couldn't fragment
Bcast: 1634711 received, 0 sent
Mcast: 0 received, 0 sent
Sent: 2963312 generated, 1121962392 forwarded
Drop: 292093 encapsulation failed, 0 unresolved, 0 no adjacency
2028650 no route, 0 unicast RPF, 83 forced drop
0 options denied
Drop: 0 packets with source IP address zero
Drop: 0 packets with internal loop back IP address
58763 physical broadcast
ICMP statistics:
Rcvd: 927 format errors, 42039 checksum errors, 0 redirects, 1104 unreachable
215780 echo, 1145 echo reply, 0 mask requests, 0 mask replies, 0 quench
0 parameter, 332 timestamp, 0 info request, 15 other
0 irdp solicitations, 0 irdp advertisements
Sent: 0 redirects, 1255050 unreachable, 1280 echo, 215780 echo reply
0 mask requests, 0 mask replies, 0 quench, 332 timestamp
0 info reply, 505033 time exceeded, 0 parameter problem
TCP statistics:
Rcvd: 1036915 total, 9388 checksum errors, 934 no port
Sent: 846151 total
BGP statistics:
Rcvd: 4676826 total, 8 opens, 0 notifications, 4632426 updates
44392 keepalives, 0 route-refresh, 0 unrecognized
Sent: 4143903 total, 8 opens, 6 notifications, 4053550 updates
90339 keepalives, 0 route-refresh
IP-EIGRP statistics:
Rcvd: 0 total
Sent: 0 total
PIMv2 statistics: Sent/Received
Total: 0/0, 0 checksum errors, 0 format errors
Registers: 0/0 (0 non-rp, 0 non-sm-group), Register Stops: 0/0, Hellos: 0/0
Join/Prunes: 0/0, Asserts: 0/0, grafts: 0/0
Bootstraps: 0/0, Candidate_RP_Advertisements: 0/0
Queue drops: 0
State-Refresh: 0/0
IGMP statistics: Sent/Received
Total: 0/0, Format errors: 0/0, Checksum errors: 0/0
Host Queries: 0/0, Host Reports: 0/0, Host Leaves: 0/0
DVMRP: 0/0, PIM: 0/0
Queue drops: 0
UDP statistics:
Rcvd: 1665834 total, 2 checksum errors, 1529820 no port
Sent: 139752 total, 0 forwarded broadcasts
OSPF statistics:
Rcvd: 0 total, 0 checksum errors
0 hello, 0 database desc, 0 link state req
0 link state updates, 0 link state acks
Sent: 0 total
ARP statistics:
Rcvd: 537366 requests, 1369 replies, 0 reverse, 0 other
Sent: 262236 requests, 522847 replies (15 proxy), 0 reverse
Edited by baronzzz
зачем при 1 uplinke FullView?
"CPU utilization for five seconds: 91%/79%; one minute: 83%; five minutes: 83%"
Хотя 79% уже говорят что коробку нужно уже другую.
ПРимерно такой, вырезал сабинтерфейсы, ессенсо заменил ипы
Building configuration...
Current configuration : 20535 bytes
! Last configuration change at 11:56:36 YEKST Fri Nov 19 2010 by rico
! NVRAM config last updated at 10:17:04 YEKST Fri Nov 19 2010 by rico
version 12.4
service nagle
no service pad
service telnet-zeroidle
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
service sequence-numbers
no service dhcp
hostname outpost-c2821
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-25c.bin
boot-end-marker
logging buffered 4096 debugging
enable secret 5
aaa new-model
aaa authentication login vty local
aaa authorization console
aaa authorization exec vty local if-authenticated
aaa session-id common
clock timezone YEKST 5
clock summer-time MSD recurring last Sun Mar 2:00 last Sun Oct 3:00
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name *****.net
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
voice-card 0
no dspfarm
username ******
archive
log config
logging enable
hidekeys
ip tcp path-mtu-discovery
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh logging events
ip ssh version 2
class-map match-all client1-out
match access-group name client1-out
policy-map CBWFQ-OUT
class client1-out
shape average 524288 16384 32768
bandwidth 8
random-detect dscp-based
.policy-map CBWFQ-IN
class client1-in
bandwidth 8
interface GigabitEthernet0/0
description 2UpLinker
no ip address
ip virtual-reassembly max-fragments 64 max-reassemblies 1024
load-interval 30
duplex auto
speed auto
no mop enabled
service-policy output CBWFQ-IN
interface GigabitEthernet0/1
description #########Clients##########
no ip address
load-interval 30
duplex auto
speed auto
no cdp enable
service-policy output CBWFQ-OUT
interface GigabitEthernet0/1.726
description ######### cLIENT1 #########
encapsulation dot1Q 726
ip address ***,***,***,**** 255.255.255.252
ip access-group 4 in
ip access-group 4 out
no ip redirects
no ip unreachables
no ip proxy-arp
no cdp enable
router bgp xxxxx
no synchronization
bgp log-neighbor-changes
network xxx.xxxx.xxx.xxx mask 255.255.252.0
network xxx.xxx.xxx.0 mask 255.255.255.0
network xxx.xxx.xxx.255 mask 255.255.255.255
aggregate-address xxx.Xxx.xxx.0 255.255.252.0 summary-only
neighbor yyy.yyy.1.2 remote-as Xxx2324
neighbor yy.yyy.1.2 description UPlinker
neighbor yy.yyy.1.2 update-source GigabitEthernet0/0.500
neighbor yyy.yyy.1.2 version 4
neighbor yyy.yyy.1.2 send-community both
neighbor yyy.yyy.1.2 route-map Foratec-OUT out
neighbor qqq.qqq.56.250 remote-as 44bbb
neighbor qqq.qqq.56.250 description LinKey
neighbor qqq.qqq.56.250 update-source GigabitEthernet0/0.501
neighbor qqq.qqq.56.250 version 4
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 yyy.yyy.1.2 254
ip route xxx.xxx.56.0 255.255.252.0 Null0
ip as-path access-list 5 permit ^$
ip as-path access-list 5 permit _44bbb$
ip as-path access-list 5 deny .*
no ip http server
no ip http secure-server
scheduler allocate 20000 1000
process cpu threshold type total rising 70 interval 10
process cpu threshold type interrupt rising 60 interval 10
process cpu threshold type process rising 60 interval 10
process cpu statistics limit entry-percentage 5 size 300
ntp clock-period 17180088
ip virtual-reassembly Надо выкинуть отовсюду.
А еще поглядеть, не летит ли какой лишний трафик к вам.
Edited by sol
mschedrin все же ты оказался прав, глянув более пристоольно в Cacti, обнаружил исходящий траф в 8 мегобит от клиента к себе. Отрубил, все сразу успакоилось. дальше анализ.
ВереШарк показал, что эта сцу**а засаряет весь свой канал и соотвественно поганет жизгь мне ARP запросами типа:
Who has xxx.xxx.xxx.xxx tell 127.0.0.1
Who has xxx.xxx.xxx.xxx tell 127.0.0.20
Who has xxx.xxx.xxx.xxx tell 127.0.0.39
Who has xxx.xxx.xxx.xxx tell 127.0.0.134
И так далее.....
Может кто подсказать как бороться с этими паразитами, п.с. так сказать для будущего ?
И так далее.....
RFC1918
LiuPing пытался, а дабы не искать даже делал так sh proc cpu s, один черт все не более чем 0.8%, был один процесс 3 %, но это временно..как и говорили все жрало прерывания а не сам проц.
Вот меня тоже всегда печалило: циска чем-то занята, и реально это заметно, и мониторинг показывает, что процессор занят, например, на 80%, а никак не посмотреть чем именно!
Любые команды показывают, что никто ничего не делает, но реально то 80% занято процессора... Неужели нельзя понятно сообщить пользователю об узком месте. Какой из сервисов перегружен, что надо разгрузить.
Сплошное гадание :(
sh processes cpu s
Из прочитанного ранее:
Статистика загрузки CPU за 5сек выдается 2-мя числами: <общий процент от используемой мощности(загрузки) CPU за 5 сек - total percent CPU busy>/<общий процент от используемой мощности(загрузки) CPU за 5 сек затрачиваемой на обработку прерываний>. "one minute" и "five minutes" - общий процент от используемой мощности(загрузки) CPU как экспоненциальное среднее за 1 и 5 мин соответственно.
Т.е. 91% - 79% = 12% мощности(загрузки) CPU используется запланированными процессами "by scheduled processes" (либо шедулером на обработку контекстов каждого процесса). Получается, что на interrupt затрачивается основное кол-во процессорного времени.
Cisco реализует 2 типа коммутации пакетов: process switching и interrupt context switching. К реализациям последенего (точнее к реализациям построения route cache) относятся: Fast switching, CEF, dCEF. Как посмотреть что и как коммутируется - http://www.cisco.com/en/US/products/sw/ios...0801e1e46.shtml
#sh int stats
GigabitEthernet0/0
Switching path Pkts In Chars In Pkts Out Chars Out
Processor 1093198315 187390289 407550666 362360226
Route cache 3464076371 3929606470 3380562605 3468534950
Total 4557274686 4116996759 3788113271 3830895176
Proccessor - это process switching
Route cache - это interrupt context switching
Troubleshooting High CPU Utilization on Cisco Routers
http://www.cisco.com/en/US/products/hw/rou...0800a70f2.shtml
Troubleshooting High CPU Utilization Due to Interrupts
http://www.cisco.com/en/US/products/hw/rou...0801c2af0.shtml
  • 2 months later...
У меня такой вопрос - есть Cisco 7606, используется в качестве узла ядра сети, периодами CPU подскакивает до 90 процентов, удалочь выяснить, что грузит ее процесс SNMP ENGINE.
Как вычислить какой из серверов грузит ее по snmp?
Debug snmp не хочу включать, боюсь может совсем в себя уйти.
vanishox у Вас так много серверов получают по снмп данные?
Порезать их по очереди по одному ацлкой:
snmp-server community <> view <> RO/RW <acl>
а дальше на сервере tcpdump`ом снять что он там запрашивает.
  • 3 years later...
