WS-C2960-24TT-L прошивка C2960-LANBASE-M 12.2(25)SEE2
Хочется получить:
1) ssh
2) возможность подключиться к провайдеру с циски через PPPoE (int Dialer0, pppoe enable)
Есть обновить до 12.2(85) или 15.0, то появятся ли у 2960 эти функции?
  • 2 years later...
Коллеги, подскажите плс софтец для
WS-C2960-24TT-L
сейчас стоит 12.2(35)SE5 C2960-LANBASE-M.
нужна поддержка MVR, Option82
и как бы хотелось 4к вланов, а то:
TEST#sh sdm prefer
The current template is "default" template.
The selected template optimizes the resources in
the switch to support this level of features for
0 routed interfaces and 255 VLANs.
number of unicast mac addresses: 8K
number of IPv4 IGMP groups: 0.25K
number of IPv4/MAC qos aces: 0
number of IPv4/MAC security aces: 0.25K
TEST#
Заранее выражаю благодарность.
У меня на 48tt-l при 12.2(55)SE9
Switch#sh sdm prefer
number of IPv4/MAC qos aces: 0.125k
number of IPv4/MAC security aces: 0.375k
Мечты инженеришки разбились о политику CISCO SYSTEMS :(
The switch supports VLANs in VTP client, server, and transparent modes. VLANs are identified by a number from 1 to 4094. VLAN IDs 1002 through 1005 are reserved for Token Ring and FDDI VLANs.
VTP version 1 and version 2 support only normal-range VLANs (VLAN IDs 1 to 1005). In these versions, the switch must be in VTP transparent mode when you create VLAN IDs from 1006 to 4094. Cisco IOS Release 12.2(52)SE and later support VTP version 3. VTP version 3 supports the entire VLAN range (VLANs 1 to 4094). Extended range VLANs (VLANs 1006 to 4094) are supported only in VTP version 3. You cannot convert from VTP version 3 to VTP version 2 if extended VLANs are configured in the domain.
Although the switch stack supports a total of 1,000 (normal range and extended range) VLANs, the number of configured features affects the use of the switch hardware.
Switch Ports Model SW Version SW Image
* 1 48 WS-C2960G-48TC-L 15.0(1)SE C2960-LANBASEK9-M
The current template is "lanbase-routing" template.
8 routed interfaces and 255 VLANs.
number of unicast mac addresses: 4K
number of IPv4 IGMP groups + multicast routes: 0.25K
number of IPv4 unicast routes: 4.25K
number of directly-connected IPv4 hosts: 4K
number of indirect IPv4 routes: 0.25K
number of IPv4 policy based routing aces: 0
включена маршрутизация
ОК, с вланами понятно что кроме как конечного доступа в транзит его не ставить.
А что скажете про MVR и Option82?
на моей что-то контекста даже не нашел...
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swigmp.html
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swdhcp82.html#wp1069615
как ты искал-то?
как ты искал-то?
каюсь, ориентировался на эту статью http://habrahabr.ru/post/192136/
а конкретно на
И так, на С2950 конфигурируем следующее:
В режиме глобальной конфигурации указываем необходимость добавления опций в dhcp-relay сообщение:
ip dhcp relay information option
В настройках management-интерфейса указать, что DHCP-запросы нужно пересылать на 2960-й коммутатор по адресу 10.0.254.2
interface Vlan254
ip address 10.0.254.10 255.255.255.0
ip helper-address 10.0.254.2
В режиме глобальной конфигурации активировать DHCP-snooping для всех наших vlan-ов
ip dhcp snooping vlan 10
ip dhcp snooping vlan 20
ip dhcp snooping vlan 254
ip dhcp snooping
Определить, что DHCP-offer разрешены только с порта 24, к которому подключен вышестоящий 2960 с DHCP-сервером.
interface FastEthernet0/24
ip dhcp snooping trust
Конфигурация С2960 чуть более сложная:
Для каждого пользователя необходимо создать запись ip dhcp class
ip dhcp class user01
remark SW2950-1 port 01
relay agent information
relay-information hex 01060004000a0001020800060011921b3a00
  • 4 months later...
Доброго дня \ ночи..
подскажите, может кто поделиться свежими прошивками на WS-C2960-24TT-L, с k9 ?
Подскажите, может ли работать с qinq данный коммутатор (а также есть ли у него supervlan, цель обьеденить n вланов в 1 влан)
Еще один вопросик, WS-C2960-24TС-L.
1. 255 vlans это максимально возможное кол-во вланов, одновременно работающих ?
2. Если да, то при пропуске qinq влана, будет тратиться влан из счетчика (255) ?
Проще гвооря, присматриваю ее (на старте) в ядро, тип подключения будет IPoe vlan-per-user. До нее (2960) стоит s3750 (наговский) который будет собирать вланы и через 2960 будет пропускать в сторону se100...
3560 возьмите лучше уж тогда. Бу не сильно дороже
Это понятно, но интересует сам вопрос, тратятся ли локальные вланы, если через коммутатор проходит QinQ тунель ?
