Что то не работает ip unnumbered? Может я что то делаю не так?
Есть
Switch#show ver
Cisco IOS Software, C3560 Software (C3560-IPSERVICESK9-M), Version 12.2(50)SE3, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 22-Jul-09 06:41 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
Switch uptime is 3 hours, 51 minutes
System returned to ROM by power-on
System image file is "flash:c3560-ipservicesk9-mz.122-50.SE3/c3560-ipservicesk9-mz.122-50.SE3.bin"
Конфиг
Switch#show run
Building configuration...
Current configuration : 3501 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
no service password-encryption
hostname Switch
boot-start-marker
boot-end-marker
no aaa new-model
vtp mode transparent
ip subnet-zero
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
spanning-tree extend system-id
vlan internal allocation policy ascending
vlan 100
interface Loopback50
ip address 192.168.100.1 255.255.255.0
no ip redirects
interface GigabitEthernet0/1
switchport access vlan 100
switchport mode access
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
ip address 192.168.50.1 255.255.255.0
interface Vlan100
description testing_abonent
ip unnumbered Loopback50
no ip proxy-arp
ip default-gateway 192.168.50.254
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.50.254
ip route 192.168.100.35 255.255.255.255 Vlan100
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
Подключаюсь к первомму порту
пробую пингануть с компьютера 192.168.100.1
не пингуется
Настройки у компьютера
ip 192.168.100.35
netmask 255.255.255.0
interface Vlan100
no ip proxy-arp
Уберите.
Убрал
Switch#show run int Vlan 100
Current configuration : 80 bytes
interface Vlan100
end
Switch#
Все равно не пингуется((
Ты имеешь ввиду 900 SVI? Мне кажется нереально, ну 400 максимум. Хотя с удовольствием выслушаю версию об использовании 900 SVI.
ip routing?
Это помогло спасибо.
Попробуйте пингануть другой ip из этой подсети... ничего не выйдет, маска на компе должна быть /32
как показала практика все работает /24, и даже без указания шлюза
А 900 человек так можно окучить, выдержит ли 3560???
Можете привети цифры если кто использует??
у нас на 200 уже тяжело ей было
а можно с этого места поподробнее?... и в первую очередь про архитектуру сети... можно в ПС
а то я чего то не понимаю... это может работать только при условии что все адреса из этой /24 подключены к одному коммутатору, а если нет?
а без указания шлюза - это винда?
ip routing?
А 3750 скока выжмет???
Без разницы винда или нет.
Прочитай мат.часть по ip unnumbered, все станет понятно. Шлюз в любом случае будет виден, а другие компы в зависимости от настроек proxy-arp. Кошка в любом случае всегда отвечает своим маком.
Edited by SokolovS
Cisco 3550, поднято 850 SVI, активных клиентов в среднем 300.
Используется дхцп снупинг. Загрузка проца до 40%.
На всей циске суммарно бегает около 1-1,2 ГБ трафа.
п.с. Жалоб/тормозов нет.
Edited by Elisium
<br />
<br /><br />Cisco 3550, поднято 850 SVI, активных клиентов в среднем 300.<br />Используется дхцп снупинг. Загрузка проца до 40%.<br />На всей циске суммарно бегает около 1-1,2 ГБ трафа.<br /><br />п.с. Жалоб/тормозов нет.<br />
а как полосу нарезаете?
Edited by MiB
<br />
Поставить перед каталистом роутер от cisco и резать rate-limit'Ом
А зачем тогда каталист? Так и заводить все интерфейсы на роутере...
А как вы тогда считаете, как правильнее организовать данную схему???
такие схемы я использую повсеметсно. только не rate-limit, а servise-policy но сути не меняет и городить unnumbered на каталистах не нужно.
вопрос и стоял именно для того чтобы избавиться от раутеров в некоторых точках. есть послеки там 1-10 юриков и для них приходится держать 28xx + комутатор.
svi в данной схеме не очень много - 1 на loopback и еще несколько для связи с другими коммутаторами.
Вот VLAN можно привязать к loopback до тысячи. Компьютеров может быть и больше тысячи(несколько в одном влан)
опробовано 3750G-12TS, C3560E-24TD. C3750G-16TD и других.
Например сейчас онлайн
>sh ip dhcp snooping binding
Total number of bindings: 903
Но при такой нагрузке уже проявляется проблема
http://forum.nag.ru/forum/index.php?showto...=0&p=408457
Решение так и не нашли - перешли на 65.
PS: Скорости режутся в другом месте(на выход в интернет).
Edited by doubtpoint
А вторым уровнем (виланами/EoMPLS) доставить до точки терминации (общей для всех клиентов) не судьба?
<br />
<br />такие схемы я использую повсеметсно. только не rate-limit, а servise-policy но сути не меняет и городить unnumbered на каталистах не нужно.<br />вопрос и стоял именно для того чтобы избавиться от раутеров в некоторых точках. есть послеки там 1-10 юриков и для них приходится держать 28xx + комутатор.<br />
<br />А вторым уровнем (виланами/EoMPLS) доставить до точки терминации (общей для всех клиентов) не судьба?<br />
нет. дешевле в каждом городе купить интернет и поставить узел, чем купить канал между городами и все тащить в одно место.
А нафига Вам в таком случае ip unnumbered и прочий "вилан на юзера"?
Это для подключения десятков тысяч хомяков надо, где IP-адреса - ресурс конечный, да и защита требуется от снифинга, спуфинга и подмены IP. В корпоративе-то всё это нафиг???
<br />А нафига Вам в таком случае ip unnumbered и прочий "вилан на юзера"?<br />Это для подключения десятков тысяч хомяков надо, где IP-адреса - ресурс конечный, да и защита требуется от снифинга, спуфинга и подмены IP. В корпоративе-то всё это нафиг???<br />
удешевление первоначальной стройки.
на первом этапе поставилои только комутаттор, подняли BGP default only.
набралось клиентов с десяток поставили 2851 перенсли тот десяток что был на него, перенесли BGP....
ну и т.д.
Используется дхцп снупинг. Загрузка проца до 40%. На всей циске суммарно бегает около 1-1,2 ГБ трафа.
У нас стоит каждая такая циска на некоторый район города.
Соединены между собой по Л3. Локальный траф не считаем и не ограничиваем.
Для раздачи инета стоит несколько мощных серваков - нарезка полос дамминет на фре.
Чистый провайдинг или много локальных ресурсов? Если второе то как по мне 3550 не гигабитная (я думаю, что она?) маловато как на район. Состояние аплинка и даунлинков должно быть постоянно забитым под завязку. Если есть локальные ресурсы и p2p внутри.
Расскажите как у вас. Буду рад послушать.
