terrible Posted June 11, 2010 Posted June 11, 2010 Настраиваю новый mpd5 сервер: FreeBSD 7.3-RELEASE-p1 FreeBSD 7.3-RELEASE-p1 #5: Fri Jun 11 17:28:57 MSD 2010 root@:/usr/obj/usr/src/sys/MYCONF amd64 на нём пока никого нет, mpd5 является radius клиентом. Конфиг mpd: startup: set user login parol admin set console self 127.0.0.1 5005 set console open radius: set auth max-logins 2 CI set auth disable internal set auth enable radius-auth set auth enable radius-acct set auth timeout 60 set radius identifier mpd set radius retries 3 set radius timeout 5 set radius server 192.168.3.122 123456789qwerty 1812 1813 set radius me 192.168.3.220 set radius enable message-authentic default: set ippool add natpool 172.16.153.1 172.16.154.254 set ippool add defpool 81.91.189.129 81.91.189.191 create bundle template B set ipcp no vjcomp set ipcp no req-pri-dns set ipcp no req-sec-dns set ipcp no req-pri-nbns set ipcp no req-sec-nbns load pptp pptp: create bundle template P set ipcp ranges 81.91.189.3/32 ippool defpool set ipcp dns 81.91.189.7 81.91.189.14 set ipcp no vjcomp set ipcp no req-pri-dns set ipcp no req-sec-dns set ipcp no req-pri-nbns set ipcp no req-sec-nbns create link template P pptp set link action bundle P set link enable multilink set link no pap eap set link enable chap set link enable chap-msv1 set link enable chap-msv2 set link keep-alive 10 60 set link mtu 1492 set link enable peer-as-calling set pptp self 10.10.10.235 1723 set link enable incoming load radius опции ядра: options NETGRAPH options NETGRAPH_PPPOE #options NETGRAPH_IPFW options LIBALIAS options NETGRAPH_NAT options NETGRAPH_NETFLOW options NETGRAPH_SPLIT options NETGRAPH_ECHO options NETGRAPH_ETHER options NETGRAPH_TEE options NETGRAPH_BPF options NETGRAPH_IFACE options NETGRAPH_KSOCKET options NETGRAPH_MPPC_ENCRYPTION options NETGRAPH_PPP options NETGRAPH_PPTPGRE options NETGRAPH_SOCKET options NETGRAPH_TCPMSS options NETGRAPH_VJC Подключаюсь к серверу: # mpd5 Multi-link PPP daemon for FreeBSD process 25125 started, version 5.5 (root@ 14:06 10-Jun-2010) CONSOLE: listening on 127.0.0.1 5005 PPTP: waiting for connection on 10.10.10.235 1723 [P] [P-1] Accepting PPTP connection [P-1] Link: OPEN event [P-1] LCP: Open event [P-1] LCP: state change Initial --> Starting [P-1] LCP: LayerStart [P-1] PPTP: attaching to peer's outgoing call [P-1] Link: UP event [P-1] LCP: Up event [P-1] LCP: state change Starting --> Req-Sent [P-1] LCP: SendConfigReq #1 [P-1] ACFCOMP [P-1] PROTOCOMP [P-1] MRU 1500 [P-1] MAGICNUM feaeca26 [P-1] AUTHPROTO CHAP MSOFTv2 [P-1] MP MRRU 2048 [P-1] MP SHORTSEQ [P-1] ENDPOINTDISC [802.1] 00 15 17 da f8 05 [P-1] LCP: rec'd Configure Request #0 (Req-Sent) [P-1] MRU 1400 [P-1] MAGICNUM 3f617153 [P-1] PROTOCOMP [P-1] ACFCOMP [P-1] CALLBACK 6 [P-1] LCP: SendConfigRej #0 [P-1] CALLBACK 6 [P-1] LCP: rec'd Configure Request #1 (Req-Sent) [P-1] MRU 1400 [P-1] MAGICNUM 3f617153 [P-1] PROTOCOMP [P-1] ACFCOMP [P-1] LCP: SendConfigAck #1 [P-1] MRU 1400 [P-1] MAGICNUM 3f617153 [P-1] PROTOCOMP [P-1] ACFCOMP [P-1] LCP: state change Req-Sent --> Ack-Sent [P-1] LCP: SendConfigReq #2 [P-1] ACFCOMP [P-1] PROTOCOMP [P-1] MRU 1500 [P-1] MAGICNUM feaeca26 [P-1] AUTHPROTO CHAP MSOFTv2 [P-1] MP MRRU 2048 [P-1] MP SHORTSEQ [P-1] ENDPOINTDISC [802.1] 00 15 17 da f8 05 [P-1] LCP: rec'd Configure Reject #2 (Ack-Sent) [P-1] MP MRRU 2048 [P-1] MP SHORTSEQ [P-1] ENDPOINTDISC [802.1] 00 15 17 da f8 05 [P-1] LCP: SendConfigReq #3 [P-1] ACFCOMP [P-1] PROTOCOMP [P-1] MRU 1500 [P-1] MAGICNUM feaeca26 [P-1] AUTHPROTO CHAP MSOFTv2 [P-1] LCP: rec'd Configure Ack #3 (Ack-Sent) [P-1] ACFCOMP [P-1] PROTOCOMP [P-1] MRU 1500 [P-1] MAGICNUM feaeca26 [P-1] AUTHPROTO CHAP MSOFTv2 [P-1] LCP: state change Ack-Sent --> Opened [P-1] LCP: auth: peer wants nothing, I want CHAP [P-1] CHAP: sending CHALLENGE #1 len: 21 [P-1] LCP: LayerUp [P-1] LCP: rec'd Ident #2 (Opened) [P-1] MESG: MSRASV5.10 [P-1] LCP: rec'd Ident #3 (Opened) [P-1] MESG: MSRAS-0-BROOD [P-1] CHAP: rec'd RESPONSE #1 len: 59 [P-1] Name: "brood" [P-1] AUTH: Trying RADIUS [P-1] RADIUS: Authenticating user 'brood' [P-1] RADIUS: Rec'd RAD_ACCESS_ACCEPT for user 'brood' [P-1] AUTH: RADIUS returned: authenticated [P-1] CHAP: Auth return status: authenticated [P-1] CHAP: Reply message: S=6445E4BA4D46000761081AF785ADB5F289379578 [P-1] CHAP: sending SUCCESS #1 len: 46 [P-1] LCP: authorization successful [P-1] Link: Matched action 'bundle "P" ""' [P-1] Creating new bundle using template "P". [P-2] Bundle: Interface ng0 created [P-1] Link: Join bundle "P-2" [P-2] Bundle: Status update: up 1 link, total bandwidth 64000 bps [P-2] IPCP: Open event [P-2] IPCP: state change Initial --> Starting [P-2] IPCP: LayerStart [P-2] IPCP: Up event [P-2] IPCP: Got IP 81.91.189.129 from pool "defpool" for peer [P-2] IPCP: state change Starting --> Req-Sent [P-2] IPCP: SendConfigReq #1 [P-2] IPADDR 81.91.189.3 [P-1] RADIUS: Accounting user 'brood' (Type: 1) [P-1] RADIUS: Rec'd RAD_ACCOUNTING_RESPONSE for user 'brood' [P-1] rec'd unexpected protocol CCP, rejecting [P-2] IPCP: rec'd Configure Request #5 (Req-Sent) [P-2] IPADDR 0.0.0.0 [P-2] NAKing with 81.91.189.129 [P-2] PRIDNS 0.0.0.0 [P-2] NAKing with 81.91.189.7 [P-2] PRINBNS 0.0.0.0 [P-2] SECDNS 0.0.0.0 [P-2] NAKing with 81.91.189.14 [P-2] SECNBNS 0.0.0.0 [P-2] IPCP: SendConfigRej #5 [P-2] PRINBNS 0.0.0.0 [P-2] SECNBNS 0.0.0.0 [P-2] IPCP: rec'd Configure Ack #1 (Req-Sent) [P-2] IPADDR 81.91.189.3 [P-2] IPCP: state change Req-Sent --> Ack-Rcvd [P-2] IPCP: rec'd Configure Request #6 (Ack-Rcvd) [P-2] IPADDR 0.0.0.0 [P-2] NAKing with 81.91.189.129 [P-2] PRIDNS 0.0.0.0 [P-2] NAKing with 81.91.189.7 [P-2] SECDNS 0.0.0.0 [P-2] NAKing with 81.91.189.14 [P-2] IPCP: SendConfigNak #6 [P-2] IPADDR 81.91.189.129 [P-2] PRIDNS 81.91.189.7 [P-2] SECDNS 81.91.189.14 [P-2] IPCP: rec'd Configure Request #7 (Ack-Rcvd) [P-2] IPADDR 81.91.189.129 [P-2] 81.91.189.129 is OK [P-2] PRIDNS 81.91.189.7 [P-2] SECDNS 81.91.189.14 [P-2] IPCP: SendConfigAck #7 [P-2] IPADDR 81.91.189.129 [P-2] PRIDNS 81.91.189.7 [P-2] SECDNS 81.91.189.14 [P-2] IPCP: state change Ack-Rcvd --> Opened [P-2] IPCP: LayerUp [P-2] 81.91.189.3 -> 81.91.189.129 [P-2] IFACE: Up event И получаю очень низкую входящую скорость. Куда смотреть, что бы найти причину этой проблемы? Вставить ник Quote
jab Posted June 11, 2010 Posted June 11, 2010 я же говорил, их нужно отстреливать пока маленькие... Вставить ник Quote
Ivan_83 Posted June 11, 2010 Posted June 11, 2010 [P-2] Bundle: Status update: up 1 link, total bandwidth 64000 bps нетграф в ядре вовсе не обязателен, мпд5 сам подгружает модулями всё что ему нужно. Вставить ник Quote
polmax Posted June 11, 2010 Posted June 11, 2010 И получаю очень низкую входящую скорость. Что значит очень низкую? Это сколько? Вставить ник Quote
AntonS Posted June 11, 2010 Posted June 11, 2010 смотреть какую скорость ты радиусом передаешь PS: внимательно посмотри что в биллинге привзал к тарифу либо еще что Вставить ник Quote
polmax Posted June 11, 2010 Posted June 11, 2010 смотреть какую скорость ты радиусом передаешьСудя по логам он её вообще не передаёт.От автора хотелось бы узнать как вообще скорость шейпиться, на каком уровне? В общем нужно более подробную информацию. Вставить ник Quote
terrible Posted June 12, 2010 Author Posted June 12, 2010 Что значит очень низкую? Это сколько?Это около 300 кбит/ссмотреть какую скорость ты радиусом передаешьПроверяю логин, пароль и IP звонящего, передаю только это:Reply Framed-Protocol:=PPP Reply Session-Timeout:=86400 как вообще скорость шейпиться, на каком уровне?Шейпится/полисится RADIUS-атрибутами, примерно такими, но тестирую без них: Reply Cisco-AVPair+=ip:sub-policy-Out=client1024k_outs Reply Cisco-AVPair+=ip:sub-policy-In=client1024k_in Reply mpd-limit:=out#1=all shape 1024000 192000 pass Reply mpd-limit:=in#1=all shape 1024000 192000 pass Вставить ник Quote
terrible Posted June 14, 2010 Author Posted June 14, 2010 (edited) Конфиг mpd взял с рабочего сервера. Пересобрал в GENERIC: FreeBSD 7.3-RELEASE-p1 FreeBSD 7.3-RELEASE-p1 #0: Sat Jun 12 16:05:10 MSD 2010 root@:/usr/obj/usr/src/sys/GENERIC amd64 # kldstat Id Refs Address Size Name 1 10 0xffffffff80100000 c06710 kernel 2 1 0xffffffff80e22000 19ba ng_socket.ko 3 7 0xffffffff80e24000 8f74 netgraph.ko 4 1 0xffffffff80e2d000 1852 ng_mppc.ko 5 1 0xffffffff80e2f000 247 rc4.ko 6 1 0xffffffff80e30000 a9e ng_tee.ko 7 1 0xffffffff80e31000 1a22 ng_pptpgre.ko 8 1 0xffffffff80e33000 202a ng_ksocket.ko 9 1 0xffffffff80e36000 1446 ng_iface.ko 10 1 0xffffffff80e38000 45fe ng_ppp.ko # Поднял для тестов на нём-же FTP сервер, через тоннель прокачиваю трафик на этот FTP - получаю пиковую физическую скорость (и download и upload). Если качать с другой машины через тоннель - опять медленно :( Ради интереса решил сменить встроенные IGB на доп. em, и о чудо, скорость нормализовалась. Установил драйвера igb.1.8.4, результата не дало. Причина - сетевухи, что с ними можно сделать? Edited June 14, 2010 by terrible Вставить ник Quote
terrible Posted June 14, 2010 Author Posted June 14, 2010 igb это как-бы интел, em тоже Вставить ник Quote
Hawk128 Posted June 15, 2010 Posted June 15, 2010 А что за железо? У меня SR1600URHS - тоже на igb - молотят просто супер... Вставить ник Quote
_longhorn_ Posted June 15, 2010 Posted June 15, 2010 terrible Попробуйте отключить LRO. Вставить ник Quote
terrible Posted June 16, 2010 Author Posted June 16, 2010 А что за железо?SR1600UR Попробуйте отключить LRO.Выключил, помогло. Спасибо вам большое!!! Вставить ник Quote
