BobroCoder Posted December 16, 2018 Posted December 16, 2018 Доброго времени суток. Имеется сервер FreeBSD 11.2 с биллингов NoDeny Plus (ipfw+mpd5 pppoe) Перезагружается с паникой ядра в произвольные моменты времени. Зависимости найти на данный момент не удалось... Оперативку меняли, Жесткий диск проверен - без бедов и подкидывали другой. Помогите пожалуйста! Уже не знаю на что думать, не могу найти проблему # kgdb /boot/kernel.min/kernel /var/crash/vmcore.last Spoiler GNU gdb 6.1.1 [FreeBSD] Copyright 2004 Free Software Foundation, Inc. GDB is free software, covered by the GNU General Public License, and you are welcome to change it and/or distribute copies of it under certain conditions. Type "show copying" to see the conditions. There is absolutely no warranty for GDB. Type "show warranty" for details. This GDB was configured as "amd64-marcel-freebsd"... Unread portion of the kernel message buffer: Fatal trap 12: page fault while in kernel mode cpuid = 0; apic id = 00 fault virtual address = 0x0 fault code = supervisor read instruction, page not present instruction pointer = 0x20:0x0 stack pointer = 0x28:0xfffffe011a338638 frame pointer = 0x28:0xfffffe011a338780 code segment = base 0x0, limit 0xfffff, type 0x1b = DPL 0, pres 1, long 1, def32 0, gran 1 processor eflags = interrupt enabled, resume, IOPL = 0 current process = 0 (dummynet) trap number = 12 panic: page fault cpuid = 0 KDB: stack backtrace: #0 0xffffffff805b98c7 at kdb_backtrace+0x67 #1 0xffffffff80572fc7 at vpanic+0x177 #2 0xffffffff80572e43 at panic+0x43 #3 0xffffffff807f0fdf at trap_fatal+0x35f #4 0xffffffff807f1039 at trap_pfault+0x49 #5 0xffffffff807f0807 at trap+0x2c7 #6 0xffffffff807d044c at calltrap+0x8 #7 0xffffffff8067ee63 at pfil_run_hooks+0xb3 #8 0xffffffff8069fde3 at ip_output+0xb33 #9 0xffffffff81523232 at dummynet_send+0xf2 #10 0xffffffff81522cb5 at dummynet_task+0x2c5 #11 0xffffffff805cb0d4 at taskqueue_run_locked+0x154 #12 0xffffffff805cc238 at taskqueue_thread_loop+0x98 #13 0xffffffff8053d963 at fork_exit+0x83 #14 0xffffffff807d136e at fork_trampoline+0xe Uptime: 5d14h28m4s Dumping 535 out of 3979 MB:..3%..12%..21%..33%..42%..51%..63%..72%..81%..93% Reading symbols from /boot/kernel.min/zfs.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/zfs.ko.debug...done. done. Loaded symbols for /boot/kernel.min/zfs.ko Reading symbols from /boot/kernel.min/krpc.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/krpc.ko.debug...done. done. Loaded symbols for /boot/kernel.min/krpc.ko Reading symbols from /boot/kernel.min/opensolaris.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/opensolaris.ko.debug...done. done. Loaded symbols for /boot/kernel.min/opensolaris.ko Reading symbols from /boot/kernel.min/ipfw.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ipfw.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ipfw.ko Reading symbols from /boot/kernel.min/ipdivert.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ipdivert.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ipdivert.ko Reading symbols from /boot/kernel.min/dummynet.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/dummynet.ko.debug...done. done. Loaded symbols for /boot/kernel.min/dummynet.ko Reading symbols from /boot/kernel.min/netgraph.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/netgraph.ko.debug...done. done. Loaded symbols for /boot/kernel.min/netgraph.ko Reading symbols from /boot/kernel.min/ng_tee.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_tee.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_tee.ko Reading symbols from /boot/kernel.min/ng_ether.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_ether.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_ether.ko Reading symbols from /boot/kernel.min/ng_socket.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_socket.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_socket.ko Reading symbols from /boot/kernel.min/ng_mppc.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_mppc.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_mppc.ko Reading symbols from /boot/kernel.min/rc4.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/rc4.ko.debug...done. done. Loaded symbols for /boot/kernel.min/rc4.ko Reading symbols from /boot/kernel.min/ng_iface.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_iface.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_iface.ko Reading symbols from /boot/kernel.min/ng_pppoe.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_pppoe.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_pppoe.ko Reading symbols from /boot/kernel.min/ng_ppp.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_ppp.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_ppp.ko Reading symbols from /boot/kernel.min/pf.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/pf.ko.debug...done. done. Loaded symbols for /boot/kernel.min/pf.ko Reading symbols from /boot/kernel.min/accf_http.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/accf_http.ko.debug...done. done. Loaded symbols for /boot/kernel.min/accf_http.ko Reading symbols from /boot/kernel.min/uhid.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/uhid.ko.debug...done. done. Loaded symbols for /boot/kernel.min/uhid.ko #0 doadump (textdump=<value optimized out>) at pcpu.h:229 229 pcpu.h: No such file or directory. in pcpu.h (kgdb) bt #0 doadump (textdump=<value optimized out>) at pcpu.h:229 #1 0xffffffff80572bdb in kern_reboot (howto=260) at /usr/src/sys/kern/kern_shutdown.c:383 #2 0xffffffff80573001 in vpanic (fmt=<value optimized out>, ap=<value optimized out>) at /usr/src/sys/kern/kern_shutdown.c:776 #3 0xffffffff80572e43 in panic (fmt=<value optimized out>) at /usr/src/sys/kern/kern_shutdown.c:707 #4 0xffffffff807f0fdf in trap_fatal (frame=0xfffffe011a338570, eva=0) at /usr/src/sys/amd64/amd64/trap.c:875 #5 0xffffffff807f1039 in trap_pfault (frame=0xfffffe011a338570, usermode=0) at pcpu.h:229 #6 0xffffffff807f0807 in trap (frame=0xfffffe011a338570) at /usr/src/sys/amd64/amd64/trap.c:415 #7 0xffffffff807d044c in calltrap () at /usr/src/sys/amd64/amd64/exception.S:231 #8 0x0000000000000000 in ?? () Current language: auto; currently minimal (kgdb) # cat /boot/loader.conf Spoiler kern.geom.label.disk_ident.enable="0" kern.geom.label.gptid.enable="0" vfs.zfs.min_auto_ashift=12 zfs_load="YES" kernel="kernel.min" kern.hz=5000 vm.pmap.pti=0 ipfw_load="YES" ipdivert_load="YES" dummynet_load="YES" netgraph_load="YES" ng_tee_load="YES" ng_ether_load="YES" ng_socket_load="YES" ng_mppc_load="YES" ng_iface_load="YES" ng_pppoe_load="YES" ng_ppp_load="YES" # cat /etc/sysctl.conf Spoiler vfs.zfs.min_auto_ashift=12 kern.ipc.somaxconn=1024 kern.ipc.maxsockbuf=83886080 net.link.ether.inet.max_age=600 net.link.ether.inet.log_arp_wrong_iface=0 net.inet.icmp.icmplim=5000 net.inet.ip.fw.one_pass=1 net.inet.ip.maxfragsperpacket=43 net.inet.ip.intr_queue_maxlen=10240 net.inet.ip.dummynet.io_fast=1 net.inet.ip.dummynet.hash_size=1024 net.inet.ip.dummynet.pipe_slot_limit=2048 Конфиг ядра: Spoiler # $FreeBSD: releng/11.2/sys/amd64/conf/BSDGW 341405 2018-12-01 $ cpu HAMMER ident MIN makeoptions DEBUG=-g # Build kernel with gdb(1) debug symbols makeoptions WITH_CTF=1 # Run ctfconvert(1) for DTrace support options SCHED_ULE # ULE scheduler options PREEMPTION # Enable kernel thread preemption options INET # InterNETworking options TCP_OFFLOAD # TCP offload options SCTP # Stream Control Transmission Protocol options FFS # Berkeley Fast Filesystem options SOFTUPDATES # Enable FFS soft updates support options UFS_ACL # Support for access control lists options UFS_DIRHASH # Improve performance on big directories options UFS_GJOURNAL # Enable gjournal-based UFS journaling options QUOTA # Enable disk quotas for UFS options MD_ROOT # MD is a potential root device options MSDOSFS # MSDOS Filesystem options CD9660 # ISO 9660 Filesystem options PROCFS # Process filesystem (requires PSEUDOFS) options PSEUDOFS # Pseudo-filesystem framework options GEOM_PART_GPT # GUID Partition Tables. options GEOM_RAID # Soft RAID functionality. options GEOM_LABEL # Provides labelization options COMPAT_FREEBSD32 # Compatible with i386 binaries options COMPAT_FREEBSD4 # Compatible with FreeBSD4 options COMPAT_FREEBSD5 # Compatible with FreeBSD5 options COMPAT_FREEBSD6 # Compatible with FreeBSD6 options COMPAT_FREEBSD7 # Compatible with FreeBSD7 options COMPAT_FREEBSD9 # Compatible with FreeBSD9 options COMPAT_FREEBSD10 # Compatible with FreeBSD10 options SCSI_DELAY=5000 # Delay (in ms) before probing SCSI options KTRACE # ktrace(1) support options STACK # stack(9) support options SYSVSHM # SYSV-style shared memory options SYSVMSG # SYSV-style message queues options SYSVSEM # SYSV-style semaphores options _KPOSIX_PRIORITY_SCHEDULING # POSIX P1003_1B real-time extensions options PRINTF_BUFR_SIZE=128 # Prevent printf output being interspersed. options KBD_INSTALL_CDEV # install a CDEV entry in /dev options HWPMC_HOOKS # Necessary kernel hooks for hwpmc(4) options AUDIT # Security event auditing options CAPABILITY_MODE # Capsicum capability mode options CAPABILITIES # Capsicum capabilities options MAC # TrustedBSD MAC Framework options KDTRACE_FRAME # Ensure frames are compiled in options KDTRACE_HOOKS # Kernel DTrace hooks options DDB_CTF # Kernel ELF linker loads CTF data options INCLUDE_CONFIG_FILE # Include this file in kernel # Debugging support. Always need this: options KDB # Enable kernel debugger support. options KDB_TRACE # Print a stack trace for a panic. # Make an SMP-capable kernel by default options SMP # Symmetric MultiProcessor Kernel options DEVICE_NUMA # I/O Device Affinity # CPU frequency control device cpufreq # Bus support. device acpi options ACPI_DMAR device pci options PCI_HP # PCI-Express native HotPlug options PCI_IOV # PCI SR-IOV support # ATA controllers device ahci # AHCI-compatible SATA controllers device ata # Legacy ATA/SATA controllers # ATA/SCSI peripherals device scbus # SCSI bus (required for ATA/SCSI) device da # Direct Access (disks) device cd # CD device pass # Passthrough device (direct ATA/SCSI access) # atkbdc0 controls both the keyboard and the PS/2 mouse device atkbdc # AT keyboard controller device atkbd # AT keyboard device psm # PS/2 mouse device kbdmux # keyboard multiplexer device vga # VGA video card driver options VESA # Add support for VESA BIOS Extensions (VBE) device splash # Splash screen and screen saver support # syscons is the default console driver, resembling an SCO console device sc options SC_PIXEL_MODE # add support for the raster text mode # vt is the new video console driver device vt device vt_vga device vt_efifb device agp # support several AGP chipsets # Serial (COM) ports device uart # Generic UART driver device puc # Multi I/O cards and multi-channel UARTs # PCI Ethernet NICs. device em # Intel PRO/1000 Gigabit Ethernet Family device igb # Intel PRO/1000 PCIE Server Gigabit Family device ix # Intel PRO/10GbE PCIE PF Ethernet device ixv # Intel PRO/10GbE PCIE VF Ethernet # PCI Ethernet NICs that use the common MII bus controller code. # NOTE: Be sure to keep the 'device miibus' line in order to use these NICs! device miibus # MII bus support device re # RealTek 8139C+/8169/8169S/8110S device rl # RealTek 8129/8139 # Pseudo devices. device loop # Network loopback device random # Entropy device device padlock_rng # VIA Padlock RNG device rdrand_rng # Intel Bull Mountain RNG device ether # Ethernet support device vlan # 802.1Q VLAN support device tun # Packet tunnel. device md # Memory "disks" device gif # IPv6 and IPv4 tunneling device firmware # firmware assist module # The `bpf' device enables the Berkeley Packet Filter. # Be aware of the administrative consequences of enabling this! # Note that 'bpf' is required for DHCP. device bpf # Berkeley packet filter # USB support options USB_DEBUG # enable debug msgs device uhci # UHCI PCI->USB interface device ohci # OHCI PCI->USB interface device ehci # EHCI PCI->USB interface (USB 2.0) device xhci # XHCI PCI->USB interface (USB 3.0) device usb # USB Bus (required) device ukbd # Keyboard device umass # Disks/Mass storage - Requires scbus and da # VirtIO support device virtio # Generic VirtIO bus (required) device virtio_pci # VirtIO PCI device device vtnet # VirtIO Ethernet device device virtio_blk # VirtIO Block device device virtio_scsi # VirtIO SCSI device device virtio_balloon # VirtIO Memory Balloon device # Xen HVM Guest Optimizations # NOTE: XENHVM depends on xenpci. They must be added or removed together. options XENHVM # Xen HVM kernel infrastructure device xenpci # Xen HVM Hypervisor services driver # VMware support device vmx # VMware VMXNET3 Ethernet # Netmap provides direct access to TX/RX rings on supported NICs device netmap # netmap(4) support Вставить ник Quote
paradox_ Posted December 16, 2018 Posted December 16, 2018 (edited) нужен стектрейс паника он бывает в dmesg все остальное не нужно хотя при наличии mpd+ipfw это не удивительно довольно частая проблема обновляйте систему в стеибл Edited December 16, 2018 by paradox_ Вставить ник Quote
default_vlan Posted December 16, 2018 Posted December 16, 2018 1 час назад, paradox_ сказал: обновляйте систему в стеибл Не в стейбл мяс. Стэйбл, так сказать, не поддерживается более и баги в багтреке не принимаются. Я бы рекомендовал перейти на нетграф. Сам юзаю mpd + netgraph + pf. Была проблема на 10.3, решилась патчем. Вставить ник Quote
paradox_ Posted December 16, 2018 Posted December 16, 2018 обновляются до стеибл что бы не ловить новые баги а в карренте они баг на баге и не поймешь где поймаешь новые но если роутер для хомяков то конечно и так сойдет Вставить ник Quote
GrandPr1de Posted December 16, 2018 Posted December 16, 2018 7 часов назад, BobroCoder сказал: Доброго времени суток. Имеется сервер FreeBSD 11.2 с биллингов NoDeny Plus (ipfw+mpd5 pppoe) Перезагружается с паникой ядра в произвольные моменты времени. Зависимости найти на данный момент не удалось... Оперативку меняли, Жесткий диск проверен - без бедов и подкидывали другой. Помогите пожалуйста! Уже не знаю на что думать, не могу найти проблему # kgdb /boot/kernel.min/kernel /var/crash/vmcore.last Показать содержимое GNU gdb 6.1.1 [FreeBSD] Copyright 2004 Free Software Foundation, Inc. GDB is free software, covered by the GNU General Public License, and you are welcome to change it and/or distribute copies of it under certain conditions. Type "show copying" to see the conditions. There is absolutely no warranty for GDB. Type "show warranty" for details. This GDB was configured as "amd64-marcel-freebsd"... Unread portion of the kernel message buffer: Fatal trap 12: page fault while in kernel mode cpuid = 0; apic id = 00 fault virtual address = 0x0 fault code = supervisor read instruction, page not present instruction pointer = 0x20:0x0 stack pointer = 0x28:0xfffffe011a338638 frame pointer = 0x28:0xfffffe011a338780 code segment = base 0x0, limit 0xfffff, type 0x1b = DPL 0, pres 1, long 1, def32 0, gran 1 processor eflags = interrupt enabled, resume, IOPL = 0 current process = 0 (dummynet) trap number = 12 panic: page fault cpuid = 0 KDB: stack backtrace: #0 0xffffffff805b98c7 at kdb_backtrace+0x67 #1 0xffffffff80572fc7 at vpanic+0x177 #2 0xffffffff80572e43 at panic+0x43 #3 0xffffffff807f0fdf at trap_fatal+0x35f #4 0xffffffff807f1039 at trap_pfault+0x49 #5 0xffffffff807f0807 at trap+0x2c7 #6 0xffffffff807d044c at calltrap+0x8 #7 0xffffffff8067ee63 at pfil_run_hooks+0xb3 #8 0xffffffff8069fde3 at ip_output+0xb33 #9 0xffffffff81523232 at dummynet_send+0xf2 #10 0xffffffff81522cb5 at dummynet_task+0x2c5 #11 0xffffffff805cb0d4 at taskqueue_run_locked+0x154 #12 0xffffffff805cc238 at taskqueue_thread_loop+0x98 #13 0xffffffff8053d963 at fork_exit+0x83 #14 0xffffffff807d136e at fork_trampoline+0xe Uptime: 5d14h28m4s Dumping 535 out of 3979 MB:..3%..12%..21%..33%..42%..51%..63%..72%..81%..93% Reading symbols from /boot/kernel.min/zfs.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/zfs.ko.debug...done. done. Loaded symbols for /boot/kernel.min/zfs.ko Reading symbols from /boot/kernel.min/krpc.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/krpc.ko.debug...done. done. Loaded symbols for /boot/kernel.min/krpc.ko Reading symbols from /boot/kernel.min/opensolaris.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/opensolaris.ko.debug...done. done. Loaded symbols for /boot/kernel.min/opensolaris.ko Reading symbols from /boot/kernel.min/ipfw.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ipfw.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ipfw.ko Reading symbols from /boot/kernel.min/ipdivert.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ipdivert.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ipdivert.ko Reading symbols from /boot/kernel.min/dummynet.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/dummynet.ko.debug...done. done. Loaded symbols for /boot/kernel.min/dummynet.ko Reading symbols from /boot/kernel.min/netgraph.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/netgraph.ko.debug...done. done. Loaded symbols for /boot/kernel.min/netgraph.ko Reading symbols from /boot/kernel.min/ng_tee.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_tee.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_tee.ko Reading symbols from /boot/kernel.min/ng_ether.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_ether.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_ether.ko Reading symbols from /boot/kernel.min/ng_socket.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_socket.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_socket.ko Reading symbols from /boot/kernel.min/ng_mppc.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_mppc.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_mppc.ko Reading symbols from /boot/kernel.min/rc4.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/rc4.ko.debug...done. done. Loaded symbols for /boot/kernel.min/rc4.ko Reading symbols from /boot/kernel.min/ng_iface.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_iface.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_iface.ko Reading symbols from /boot/kernel.min/ng_pppoe.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_pppoe.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_pppoe.ko Reading symbols from /boot/kernel.min/ng_ppp.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/ng_ppp.ko.debug...done. done. Loaded symbols for /boot/kernel.min/ng_ppp.ko Reading symbols from /boot/kernel.min/pf.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/pf.ko.debug...done. done. Loaded symbols for /boot/kernel.min/pf.ko Reading symbols from /boot/kernel.min/accf_http.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/accf_http.ko.debug...done. done. Loaded symbols for /boot/kernel.min/accf_http.ko Reading symbols from /boot/kernel.min/uhid.ko...Reading symbols from /usr/lib/debug//boot/kernel.min/uhid.ko.debug...done. done. Loaded symbols for /boot/kernel.min/uhid.ko #0 doadump (textdump=<value optimized out>) at pcpu.h:229 229 pcpu.h: No such file or directory. in pcpu.h (kgdb) bt #0 doadump (textdump=<value optimized out>) at pcpu.h:229 #1 0xffffffff80572bdb in kern_reboot (howto=260) at /usr/src/sys/kern/kern_shutdown.c:383 #2 0xffffffff80573001 in vpanic (fmt=<value optimized out>, ap=<value optimized out>) at /usr/src/sys/kern/kern_shutdown.c:776 #3 0xffffffff80572e43 in panic (fmt=<value optimized out>) at /usr/src/sys/kern/kern_shutdown.c:707 #4 0xffffffff807f0fdf in trap_fatal (frame=0xfffffe011a338570, eva=0) at /usr/src/sys/amd64/amd64/trap.c:875 #5 0xffffffff807f1039 in trap_pfault (frame=0xfffffe011a338570, usermode=0) at pcpu.h:229 #6 0xffffffff807f0807 in trap (frame=0xfffffe011a338570) at /usr/src/sys/amd64/amd64/trap.c:415 #7 0xffffffff807d044c in calltrap () at /usr/src/sys/amd64/amd64/exception.S:231 #8 0x0000000000000000 in ?? () Current language: auto; currently minimal (kgdb) # cat /boot/loader.conf Показать содержимое kern.geom.label.disk_ident.enable="0" kern.geom.label.gptid.enable="0" vfs.zfs.min_auto_ashift=12 zfs_load="YES" kernel="kernel.min" kern.hz=5000 vm.pmap.pti=0 ipfw_load="YES" ipdivert_load="YES" dummynet_load="YES" netgraph_load="YES" ng_tee_load="YES" ng_ether_load="YES" ng_socket_load="YES" ng_mppc_load="YES" ng_iface_load="YES" ng_pppoe_load="YES" ng_ppp_load="YES" # cat /etc/sysctl.conf Показать содержимое vfs.zfs.min_auto_ashift=12 kern.ipc.somaxconn=1024 kern.ipc.maxsockbuf=83886080 net.link.ether.inet.max_age=600 net.link.ether.inet.log_arp_wrong_iface=0 net.inet.icmp.icmplim=5000 net.inet.ip.fw.one_pass=1 net.inet.ip.maxfragsperpacket=43 net.inet.ip.intr_queue_maxlen=10240 net.inet.ip.dummynet.io_fast=1 net.inet.ip.dummynet.hash_size=1024 net.inet.ip.dummynet.pipe_slot_limit=2048 Конфиг ядра: Показать содержимое # $FreeBSD: releng/11.2/sys/amd64/conf/BSDGW 341405 2018-12-01 $ cpu HAMMER ident MIN makeoptions DEBUG=-g # Build kernel with gdb(1) debug symbols makeoptions WITH_CTF=1 # Run ctfconvert(1) for DTrace support options SCHED_ULE # ULE scheduler options PREEMPTION # Enable kernel thread preemption options INET # InterNETworking options TCP_OFFLOAD # TCP offload options SCTP # Stream Control Transmission Protocol options FFS # Berkeley Fast Filesystem options SOFTUPDATES # Enable FFS soft updates support options UFS_ACL # Support for access control lists options UFS_DIRHASH # Improve performance on big directories options UFS_GJOURNAL # Enable gjournal-based UFS journaling options QUOTA # Enable disk quotas for UFS options MD_ROOT # MD is a potential root device options MSDOSFS # MSDOS Filesystem options CD9660 # ISO 9660 Filesystem options PROCFS # Process filesystem (requires PSEUDOFS) options PSEUDOFS # Pseudo-filesystem framework options GEOM_PART_GPT # GUID Partition Tables. options GEOM_RAID # Soft RAID functionality. options GEOM_LABEL # Provides labelization options COMPAT_FREEBSD32 # Compatible with i386 binaries options COMPAT_FREEBSD4 # Compatible with FreeBSD4 options COMPAT_FREEBSD5 # Compatible with FreeBSD5 options COMPAT_FREEBSD6 # Compatible with FreeBSD6 options COMPAT_FREEBSD7 # Compatible with FreeBSD7 options COMPAT_FREEBSD9 # Compatible with FreeBSD9 options COMPAT_FREEBSD10 # Compatible with FreeBSD10 options SCSI_DELAY=5000 # Delay (in ms) before probing SCSI options KTRACE # ktrace(1) support options STACK # stack(9) support options SYSVSHM # SYSV-style shared memory options SYSVMSG # SYSV-style message queues options SYSVSEM # SYSV-style semaphores options _KPOSIX_PRIORITY_SCHEDULING # POSIX P1003_1B real-time extensions options PRINTF_BUFR_SIZE=128 # Prevent printf output being interspersed. options KBD_INSTALL_CDEV # install a CDEV entry in /dev options HWPMC_HOOKS # Necessary kernel hooks for hwpmc(4) options AUDIT # Security event auditing options CAPABILITY_MODE # Capsicum capability mode options CAPABILITIES # Capsicum capabilities options MAC # TrustedBSD MAC Framework options KDTRACE_FRAME # Ensure frames are compiled in options KDTRACE_HOOKS # Kernel DTrace hooks options DDB_CTF # Kernel ELF linker loads CTF data options INCLUDE_CONFIG_FILE # Include this file in kernel # Debugging support. Always need this: options KDB # Enable kernel debugger support. options KDB_TRACE # Print a stack trace for a panic. # Make an SMP-capable kernel by default options SMP # Symmetric MultiProcessor Kernel options DEVICE_NUMA # I/O Device Affinity # CPU frequency control device cpufreq # Bus support. device acpi options ACPI_DMAR device pci options PCI_HP # PCI-Express native HotPlug options PCI_IOV # PCI SR-IOV support # ATA controllers device ahci # AHCI-compatible SATA controllers device ata # Legacy ATA/SATA controllers # ATA/SCSI peripherals device scbus # SCSI bus (required for ATA/SCSI) device da # Direct Access (disks) device cd # CD device pass # Passthrough device (direct ATA/SCSI access) # atkbdc0 controls both the keyboard and the PS/2 mouse device atkbdc # AT keyboard controller device atkbd # AT keyboard device psm # PS/2 mouse device kbdmux # keyboard multiplexer device vga # VGA video card driver options VESA # Add support for VESA BIOS Extensions (VBE) device splash # Splash screen and screen saver support # syscons is the default console driver, resembling an SCO console device sc options SC_PIXEL_MODE # add support for the raster text mode # vt is the new video console driver device vt device vt_vga device vt_efifb device agp # support several AGP chipsets # Serial (COM) ports device uart # Generic UART driver device puc # Multi I/O cards and multi-channel UARTs # PCI Ethernet NICs. device em # Intel PRO/1000 Gigabit Ethernet Family device igb # Intel PRO/1000 PCIE Server Gigabit Family device ix # Intel PRO/10GbE PCIE PF Ethernet device ixv # Intel PRO/10GbE PCIE VF Ethernet # PCI Ethernet NICs that use the common MII bus controller code. # NOTE: Be sure to keep the 'device miibus' line in order to use these NICs! device miibus # MII bus support device re # RealTek 8139C+/8169/8169S/8110S device rl # RealTek 8129/8139 # Pseudo devices. device loop # Network loopback device random # Entropy device device padlock_rng # VIA Padlock RNG device rdrand_rng # Intel Bull Mountain RNG device ether # Ethernet support device vlan # 802.1Q VLAN support device tun # Packet tunnel. device md # Memory "disks" device gif # IPv6 and IPv4 tunneling device firmware # firmware assist module # The `bpf' device enables the Berkeley Packet Filter. # Be aware of the administrative consequences of enabling this! # Note that 'bpf' is required for DHCP. device bpf # Berkeley packet filter # USB support options USB_DEBUG # enable debug msgs device uhci # UHCI PCI->USB interface device ohci # OHCI PCI->USB interface device ehci # EHCI PCI->USB interface (USB 2.0) device xhci # XHCI PCI->USB interface (USB 3.0) device usb # USB Bus (required) device ukbd # Keyboard device umass # Disks/Mass storage - Requires scbus and da # VirtIO support device virtio # Generic VirtIO bus (required) device virtio_pci # VirtIO PCI device device vtnet # VirtIO Ethernet device device virtio_blk # VirtIO Block device device virtio_scsi # VirtIO SCSI device device virtio_balloon # VirtIO Memory Balloon device # Xen HVM Guest Optimizations # NOTE: XENHVM depends on xenpci. They must be added or removed together. options XENHVM # Xen HVM kernel infrastructure device xenpci # Xen HVM Hypervisor services driver # VMware support device vmx # VMware VMXNET3 Ethernet # Netmap provides direct access to TX/RX rings on supported NICs device netmap # netmap(4) support Самого главного не вижу. ipfw list В каждой похожей теме совет один. deny_in на нат. Вставить ник Quote
adeep Posted December 17, 2018 Posted December 17, 2018 избавляйтесь от dummynet. переходите на нетграф шейпер/лимитер. этому багу сто лет уже Вставить ник Quote
BobroCoder Posted December 17, 2018 Author Posted December 17, 2018 (edited) Спасибо за помощь, NAT не используется у нас - только белые ip. Система FreeBSD 11.2-RELEASE-p5 На счет перехода на netgraph - интересный путь, биллинг NoDeny заточен на dummynet как понял. Надо почитать можно ли малым потом перевести... PS: С похожей нагрузкой сервер в другом месте работает исправно (но на FreeBSD 10.3) Ранее работало все исправно - падать начало то ли с увеличением нагрузки, то ли (что более вероятно) после обновления до FreeBSD 11 Сейчас около 1000 абонентов в пиках до 1Гбит/c трафика (до 600kpps) ipfw list Spoiler 00110 allow ip from any to any via lo0 00120 skipto 1000 ip from me to any 00130 deny icmp from any to any in icmptypes 5,9,13,14,15,16,17 00160 skipto 2000 ip from any to me 00200 skipto 500 ip from any to any { via vlan1335 or via vlan1336 } 00300 skipto 4500 ip from any to any in 00400 skipto 450 ip from any to any { recv vlan1335 or recv vlan1336 } 00420 tee 1 ip from any to any 00450 tee 2 ip from any to any 00490 allow ip from any to any 00500 skipto 32500 ip from any to any in 00510 tee 1 ip from any to any 00540 allow ip from any to any 01000 allow udp from any 53,7723 to any 01010 allow tcp from any to any setup keep-state :default 01020 allow udp from any to any keep-state :default 01100 allow ip from any to any 02000 check-state :default 02010 allow icmp from any to any 02020 allow tcp from any to any 22,80,443,5006 02030 allow tcp from table(101) to any 3306 02050 deny ip from any to any { via vlan1335 or via vlan1336 } 02060 allow udp from any to any 53,7723 02100 deny ip from any to any 04500 allow ip from any to table(100) 05000 skipto 18501 ip from table(24) to table(14) 05001 allow ip from table(44) to table(14) 05002 skipto 18502 ip from table(21) to table(11) 05003 allow ip from table(41) to table(11) 18500 deny ip from any to any 18501 pipe tablearg ip from table(24) to any 18502 pipe tablearg ip from table(21) to any 32000 deny ip from any to any 32490 deny ip from any to any 32500 allow ip from table(100) to any 33000 skipto 46501 ip from table(14) to table(34) 33001 allow ip from table(14) to table(44) 33002 skipto 46502 ip from table(11) to table(31) 33003 allow ip from table(11) to table(41) 46500 deny ip from any to any 46501 pipe tablearg ip from any to table(34) 46502 pipe tablearg ip from any to table(31) 60000 deny ip from any to any 65535 deny ip from any to any Edited December 17, 2018 by BobroCoder Вставить ник Quote
No_name Posted December 17, 2018 Posted December 17, 2018 uname -r 9.3 mpd+ipfw+dummynet uptime up 340 days работает стабильно, не глючит, не валится. На данный момент 2500 коннектов на текущем сервере ~1900G входящего ~500g исходящего ipfw тщательно "причесан" пока хватает Вставить ник Quote
paradox_ Posted December 17, 2018 Posted December 17, 2018 29 минут назад, BobroCoder сказал: FreeBSD 11.2-RELEASE-p5 обновитесь до стеибла в 11 ветке Вставить ник Quote
BobroCoder Posted December 17, 2018 Author Posted December 17, 2018 (edited) Порыскал еще - судя по всему проблема и есть в dummynet. По вашему стоит попробовать откатиться на предыдущую версию FreeBSD? Сейчас все что ниже 11.2 - End of Life. С другой стороны если стабильно работает можно наверно и не трогать. Хотя (может мыслю неправильно) хотелось бы быть на актуальной на данный момент версии. Обновиться до STABLE попробую. Edited December 17, 2018 by BobroCoder Вставить ник Quote
paradox_ Posted December 17, 2018 Posted December 17, 2018 от релиза до стеибл там много изменений и по сетевой части тоже было при наличии проблемы даже в стеибле запульте баг репорт в бсд Вставить ник Quote
rdc Posted January 2, 2019 Posted January 2, 2019 проблема возникает при удалении интерфейса, по которому в момент удаления идёт трафик. лечится этим патчем: https://reviews.freebsd.org/D12457 если на машине нет dummynet, после патча проблема прекращается полностью. также есть схожая проблема с dummynet, патч планируется. Вставить ник Quote
BobroCoder Posted January 14, 2019 Author Posted January 14, 2019 Большое спасибо за ответы. Проблема так пока и не решилась. На данный момент стоит FreeBSD 11.2-STABLE #0 r342164 Dummynet присутствует, хотелось бы увидеть попробовать патч. Для полной уверенности хотелось бы проверить железо сервера, хотя memtest говорит что все норм. Вставить ник Quote
YuryD Posted January 25, 2019 Posted January 25, 2019 Дамминет - это всего лишь шейпер от луиджи, рекомендовал бы откатиться с 11 до 10-ки хотя-бы. Уже писал - попытка завести ipfw+ipfnat+dummynet на 11 свежей у меня была неудачной абсолютно. Без грехов на железо, ибмские сервера(там память вообще с есс - сама себя корректирует). Переустановка старой 10-ки, и всё стабильно работает. ng и динамической маршрутизации не было, но всё падало. После даунгрейда до 10.2 и квагга заработала, и шейпер. Про падения железяки - бывало, но давно. Если есть куча динамических маршрутов - то стандартый снмп-демон гадил при их перестройке, или фиб использовалась. Посмотрите в эту сторону. Ну и у вас - я бы на ng перешел, там проще. Проблему с изменением количества динамических интерфейсов - я в мртг отписывал, для pptp-mpd. Вставить ник Quote
paradox_ Posted January 26, 2019 Posted January 26, 2019 баг репорт надо писать а не откатываться а то такими откатываниями и сами же бсд и угробите >BobroCoder бек трейсы не плохо приложить бы Вставить ник Quote
YuryD Posted January 27, 2019 Posted January 27, 2019 В 26.01.2019 в 10:37, paradox_ сказал: баг репорт надо писать а не откатываться а то такими откатываниями и сами же бсд и угробите Вам шашечки, или ехать ? Мне нужна стабильность. Было время - и багрепорты писал, ответ в форуме - в основном "не подтвердилось". Вставить ник Quote
paradox_ Posted January 27, 2019 Posted January 27, 2019 по вашему через лет 5 проблема сама рассосется к новому релизу бсд ? или сразу перейдете на линукс ? Вставить ник Quote
No_name Posted January 28, 2019 Posted January 28, 2019 Проблема может очень долго висеть и решать сиюминутно никто не будет, но баг репортить, конечно нужно. А для стабильной работы, лучше откатиться на старые, проверенные временем и работой релизы. Вставить ник Quote
rdc Posted January 28, 2019 Posted January 28, 2019 ещё раз повторяю. проблема с mpd известна, уже решена, ссылка на патч приведена выше. проблема с dummynet известна, патч планируется. в качестве временного решения прямо сейчас, могу посоветовать разнесение по разным тачкам mpd и dummynet. Вставить ник Quote
