Друзья, поставил домой Mikrotik hAP lite и упёрся в настройку IPTV. IPTV смотрю в через wifi на ТВ Samsung ( через PeersTV), иногда, на ноуте (тоже через вайфай). Картинка появляется, но сыпется безбожно и подвисает. Через богомерзкий dlink dir 300 таких проблем не появлялось.
Включил wmm-support=enabled и multicast-helper=full.
Подскажите, плиз, куда копать.
# aug/24/2017 20:55:56 by RouterOS 6.40.1
# software id =
# model = RouterBOARD 941-2nD
# serial number =
/interface bridge
add name=bridge-local
/interface ethernet
set [ find default-name=ether1 ] comment=WAN name=ethet1
set [ find default-name=ether2 ] name=ethet2
set [ find default-name=ether3 ] master-port=ethet2
set [ find default-name=ether4 ] master-port=ethet2
/interface wireless security-profiles
add authentication-types=wpa2-psk eap-methods="" management-protection=\
   allowed mode=dynamic-keys name=profile1 supplicant-identity="" \
   wpa-pre-shared-key=****** wpa2-pre-shared-key=******
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
   default-forwarding=no disabled=no mode=ap-bridge multicast-helper=full \
   security-profile=profile1 wmm-support=enabled
/ip pool
add name=dhcp_pool0 ranges=192.168.88.2-192.168.88.20
/ip dhcp-server
add address-pool=dhcp_pool0 disabled=no interface=bridge-local name=dhcp1
/interface bridge port
add bridge=bridge-local interface=ethet2
add bridge=bridge-local interface=wlan1
/ip address
add address=192.168.88.1/24 interface=bridge-local network=192.168.88.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ethet1
/ip dhcp-server network
add address=192.168.88.0/24 gateway=192.168.88.1
/ip dns
set allow-remote-requests=yes
/ip firewall filter
add action=accept chain=input comment="Allow IGMP" in-interface=ethet1 protocol=igmp
add action=accept chain=input comment="IPTV UDP incoming" dst-port=1234 in-interface=ethet1 protocol=udp
add action=accept chain=forward comment="IPTV UDP forwarding" dst-port=1234 in-interface=ethet1 protocol=udp
/ip firewall nat
add action=masquerade chain=srcnat out-interface=ethet1
/ip route
add distance=1 gateway=10.21.22.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/routing igmp-proxy
set query-interval=1s query-response-interval=1s quick-leave=yes
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=ethet1 upstream=yes
add interface=bridge-local
/system clock
set time-zone-name=Europe/Moscow
/system ntp client
set enabled=yes primary-ntp=195.151.98.66 secondary-ntp=80.240.216.155
#error exporting /system routerboard mode-button
Edited by vadiara50
vadiara50, я бы начал с /interface wireless set name=wlan1 band=2ghz-onlyn bridge-mode=disabled и показом /interface wireless registration-table print
Извольте
 # INTERFACE            RADIO-NAME       MAC-ADDRESS       AP  SIGNAL-STRENGTH TX-RATE UPTIME
0        wlan1                           AC:E0:10:26:42:F1      no  -57dBm@1Mbps     144.... 2m31s
1        wlan1                           FC:3D:93:44:34:33      no  -55dBm@1Mbps    54Mbps  2m30s
2        wlan1                           7C:FA:DF:C5:BC:1F      no  -61dBm@6Mbps    65Mb... 2m30s
3        wlan1                           78:AB:BB:E9:71:DD      no  -40dBm@HT20-3   86.6... 59s
/interface wireless set name=wlan1 band=2ghz-onlyn bridge-mode=disabled не спасло отца русской демократии
В 24.08.2017 в 21:03, vadiara50 сказал:
Бессмысленно, у вас ни одного запрещающего правила нет.
/routing igmp-proxy set query-interval=1s query-response-interval=1s quick-leave=yes
Откуда такие дикие значения query-interval и query-response-interval? Зачем меняли? Верните дефолтные, первое 00:02:05, второе 00:00:10. Тест скорости через wifi-подключение делали?
31 минуту назад, vnkorol сказал:
Микротик + мультикаст - это уже трагедия.
Не надо драм, за исключением до недавнего времени отсутствовавшего igmp-snooping-а ничего трагичного в мультикасте у МТ не наблюдалось. И по wifi тоже. Другой вопрос, что у ТС с локальным состоянием глобально засранного в 2,4Ghz эфира.
17 минут назад, vnkorol сказал:
Появился IGMP snooping?
В changelog пишут:
Other changes since 6.40.2:
*) bridge - added initial support for hardware "igmp-snooping" on CRS1xx/2xx (CLI only);
*) bridge - fixed multicast forwarding (introduced in v6.40rc36);
*) bridge - implemented software based "igmp-snooping" (CLI only);
А wifi вполне нормально пропускал изначально (с соответствующими настройками).
3 часа назад, DRiVen сказал:
interface bridge set name=bridge_local igmp-snooping=yes
Не получается.
[admin@MikroTik-2-multicast] > interface bridge set name=bridge-vlan0122 igmp-snooping=yes
expected end of command (line 1 column 56)
Подсвечивается символ знака "равно".
16 часов назад, DRiVen сказал:
В этом коротком предложении прекрасно все.
И initial support, и on CRS1xx/2xx, и CLI only.
Надо бы у Saab95 спросить, когда у мультикаста отменили статус "устаревшей технологии".
Понятия не имею, я в Микротиках разочаровался давно и с тех пор желания экспериментировать нет.
Но changelog с таким количеством оговорок заставляет сомневаться, что в RouterOS решили проблему с нормальной работой мультикаста.
Я чем больше с микротом дело имею, теб больше убеждаюсь, что пусть он как роутер и неплох местами, но как коммутатор - ад. Т.е. подключить одним кабелем к свитчу и вланами развести - еще куда не шло, а пользоваться портами на борту - слишком много граблей уже собрал...
Микротик это неплохая железка для дома и небольшого офиса (при условии, что не используется мультикаст). Ну или для радиомостов.
Для операторских или корпоративных задач он подходит плохо.
1 час назад, vnkorol сказал:
Так я не пойму, оно только на CRS работает?
На CRS аппаратно, софтово - на остальных, все на последней бете (6.41rc20), и ессно через консоль (cli).  Лень открыть changelog?
Угу. Правда перемены некоторые есть, но мелкие и редкие.
alibek , а зачем в корпоративном контексте мультикаст? МТ, как роутер, мультик обрабатывает нормально, вот как soho-гибрид да, кисло было без igmp-snooping.
Только что, DRiVen сказал:
За корпоратив не скажу, но например видеонаблюдение или голосовые оповещения.
А у операторов — IPTV через мультикаст. У нас работает замечательно.
В 26.08.2017 в 20:51, DRiVen сказал:
Правила запрещающие были, я заново конфиг сбросил для чистоты эксперимента.
значения query-interval и query-response-interval вернул на место, теперь они по дефолту.
Картинка не изменилась.
Поставил 6.41rc20. Где тут волшебная галка в винбоксе, которая сделает зашибись?
vadiara50 , тест скорости доступа по wifi делали? Сколько АР вокруг? Каков средний битрэйт у мультикаста? /interface wireless export еще раз покажите.
Вот на этом конфиге вполне себе живет stb и пара смартов:
/interface wireless
set [ find default-name=wlan1 ] adaptive-noise-immunity=ap-and-client-mode band=2ghz-onlyn basic-rates-a/g=24Mbps \
    basic-rates-b="" bridge-mode=disabled channel-width=20mhz disabled=no frequency=auto hw-retries=5 \
    mode=ap-bridge multicast-helper=full name=wlan2.4 noise-floor-threshold=-90 preamble-mode=short rate-set=configured \
    ssid=******** supported-rates-a/g=24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b="" tx-power=12 tx-power-mode=\
    all-rates-fixed wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
49 минут назад, DRiVen сказал:
Скорость померил с ноута, точки оттуда же. или это надо с микротика сделать? Где глянуть битрейт у мультикаста?
# software id = *******
# serial number = 7C2C07B*****
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed \
    mode=dynamic-keys name=profile1 supplicant-identity="" wpa-pre-shared-key=\
    ******** wpa2-pre-shared-key=********
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-onlyn bridge-mode=disabled \
    channel-width=20/40mhz-Ce default-forwarding=no disabled=no mode=ap-bridge \
    multicast-helper=full security-profile=profile1 wmm-support=enabled
Спасибо, уже нашёл. улучшилось положение немного, но всё равно подсыпается периодически картинка.
