Tem Posted September 13, 2014 Posted September 13, 2014 Поднимаю BGP на quagga, uplink KTTK bgpd.conf hostname AS58217 password *** enable password *** log file /var/log/quagga/bgpd.log log stdout debug bgp events debug bgp updates ! bgp multiple-instance ! router bgp 58217 bgp router-id 195.206.122.254 network 193.41.93.0/24 network 195.206.122.0/23 bgp log-neighbor-changes neighbor 80.72.237.33 remote-as 20870 neighbor 80.72.237.33 description UplinkKTTK neighbor 80.72.237.33 next-hop-self neighbor 80.72.237.33 soft-reconfiguration inbound zebra.conf hostname AS58217 password *** enable password *** log file /var/log/quagga/zebra.log ! debug zebra events debug zebra packet ! interface eth1 ipv6 nd suppress-ra interface eth2 ipv6 nd suppress-ra ! ! ip route 10.0.0.0/8 Null0 254 ip route 172.16.0.0/12 Null0 254 ip route 192.168.0.0/16 Null0 254 ! ip forwarding ! ! line vty exec-timeout 0 0 KTTK у себя меня вроде как прописал remarks: BELCOMSTROY import: from AS58217 action pref=100; accept AS58217 export: to AS58217 announce ANY Но сессия не поднимается, в логах 2014/09/13 13:04:40 BGP: Import timer expired. 2014/09/13 13:04:44 BGP: 80.72.237.33 [Event] Connect start to 80.72.237.33 fd 14 2014/09/13 13:04:44 BGP: 80.72.237.33 [Event] Connect failed (Operation now in progress) 2014/09/13 13:04:55 BGP: Import timer expired. Вставить ник Quote
Умник Posted September 13, 2014 Posted September 13, 2014 Что скажет telnet 80.72.237.33 179 ? Вставить ник Quote
s.lobanov Posted September 13, 2014 Posted September 13, 2014 сделвйте дапм tcpdump-ом. может у вас фаервол режет Вставить ник Quote
Tem Posted September 13, 2014 Author Posted September 13, 2014 Что скажет telnet 80.72.237.33 179 ? telnet 80.72.237.33 179 Trying 80.72.237.33... telnet: Unable to connect to remote host: Connection refused ip ro get 80.72.237.33 ip route get 80.72.237.33 80.72.237.33 dev eth1 src 80.72.237.34 cache сделвйте дапм tcpdump-ом. может у вас фаервол режет tcpdump: listening on eth1, link-type EN10MB (Ethernet), capture size 65535 bytes 17:54:19.057456 IP (tos 0xc0, ttl 1, id 6857, offset 0, flags [DF], proto TCP (6), length 60) 80.72.237.34.33959 > 80.72.237.33.bgp: Flags [s], cksum 0x7b03 (incorrect -> 0x6a46), seq 236137310, win 29200, options [mss 1460,sackOK,TS val 7483799 ecr 0,nop,wscale 7], length 0 Вставить ник Quote
Tem Posted September 13, 2014 Author Posted September 13, 2014 а .33 пигается? Да, на этом же канале юзеры висят с ipшниками, ктр мне кттк выдал, сейчас вот решил bgp поднять. Вставить ник Quote
Умник Posted September 13, 2014 Posted September 13, 2014 "Connection refused" - значит порт TCP 179 на маршрутизаторе КТТК либо закрыт, либо на нем не слушает никакой процесс. До Quagga дело даже не доходит. Не поднимается TCP-соединение. Вставить ник Quote
s.lobanov Posted September 13, 2014 Posted September 13, 2014 вообще, connection refused это странно, обычно это подразумевает наличие tcp-rst или icmp unreachable, но в дампе нет ни того, ни другого Вставить ник Quote
Tem Posted September 13, 2014 Author Posted September 13, 2014 В общем в понедельник буду созваниваться с саппортом и буду уточнять у них. Вставить ник Quote
Abram Posted September 13, 2014 Posted September 13, 2014 А аплинк вообще в курсе, что он с вами BGP-пиринг поднимает? Вставить ник Quote
Tem Posted September 13, 2014 Author Posted September 13, 2014 Конечно знает ) https://apps.db.ripe.net/search/query.html?searchtext=AS20870&search%3AdoSearch=Search#resultsAnchor remarks: BELCOMSTROY import: from AS58217 action pref=100; accept AS58217 export: to AS58217 announce ANY В пятницу созванивался с ними, спросил готово ли все и можно ли будет поднять в субботу, на что мне ответили, что все должно работать, но точно они сказать не могут. Вставить ник Quote
xxxupg Posted September 14, 2014 Posted September 14, 2014 может быть дело в файрволе на локальной машине? Вставить ник Quote
Tem Posted September 14, 2014 Author Posted September 14, 2014 Фаер я сразу потушил, да и если сделать telnet на порт 179 ip_моего второго шлюза в другом городе, то соединение проходит. Вставить ник Quote
Abram Posted September 14, 2014 Posted September 14, 2014 Похоже на то, что у аплинка тупо кто-то забыл включить BGP. Вставить ник Quote
vlad11 Posted September 14, 2014 Posted September 14, 2014 Скорее всего они не включили у себя BGP. Но без tcpdump - это гадание на кофейной гуще. Вставить ник Quote
Tem Posted September 14, 2014 Author Posted September 14, 2014 Скорее всего они не включили у себя BGP. Но без tcpdump - это гадание на кофейной гуще. Вот вывод Tcpdump tcpdump: listening on eth1, link-type EN10MB (Ethernet), capture size 65535 bytes 21:15:09.311670 IP (tos 0xc0, ttl 1, id 62685, offset 0, flags [DF], proto TCP (6), length 60) 80.72.237.34.36110 > 80.72.237.33.bgp: Flags [s], cksum 0x7b03 (incorrect -> 0x3ab4), seq 2610574518, win 29200, options [mss 1460,sackOK,TS val 32096363 ecr 0,nop,wscale 7], length 0 21:15:09.316328 IP (tos 0x0, ttl 255, id 1463, offset 0, flags [none], proto TCP (6), length 40) 80.72.237.33.bgp > 80.72.237.34.36110: Flags [R.], cksum 0xd6e8 (correct), seq 0, ack 2610574519, win 0, length 0 Вставить ник Quote
s.lobanov Posted September 14, 2014 Posted September 14, 2014 ну вот теперь нормальный дамп. видно, что .33 шлёт tcp-reset (FLAGS R). этот вывод отправляйте в (?)ТТК. (?) потому что хз кто у них рулит региональными AS. я как-то решал проблему с каким-то локальным ТТК, но ответ приходил из МСК Вставить ник Quote
Tem Posted September 15, 2014 Author Posted September 15, 2014 (edited) Всем спасибо, открыл утром тикет и через 20 минут все заработало sh ip bgp neighbors BGP neighbor is 80.72.237.33, remote AS 20870, local AS 58217, external link Description: UplinkKTTK BGP version 4, remote router ID 10.123.0.211 BGP state = Established, up for 00:04:53 Last read 00:00:00, hold time is 180, keepalive interval is 60 seconds Neighbor capabilities: 4 Byte AS: advertised and received Route refresh: advertised and received(old & new) Address family IPv4 Unicast: advertised and received Message statistics: Inq depth is 0 Outq depth is 0 Sent Rcvd Opens: 1 1 Notifications: 0 0 Updates: 1 85894 Keepalives: 6 1 Route Refresh: 0 0 Capability: 0 0 Total: 8 85896 Minimum time between advertisement runs is 30 seconds Но не вижу свои префиксы извне , хотя show ip bgp neighbor 80.72.237.33 advertised-routes BGP table version is 0, local router ID is 195.206.122.254 Status codes: s suppressed, d damped, h history, * valid, > best, i - internal, r RIB-failure, S Stale, R Removed Origin codes: i - IGP, e - EGP, ? - incomplete Network Next Hop Metric LocPrf Weight Path *> 193.41.93.0 80.72.237.34 0 32768 i *> 195.206.122.0/23 80.72.237.34 0 32768 i Edited September 15, 2014 by Tem Вставить ник Quote
Умник Posted September 15, 2014 Posted September 15, 2014 Думаю, что это снова вопрос к ТТК. Вставить ник Quote
Tem Posted September 15, 2014 Author Posted September 15, 2014 Все пошло, нужно было просто подождать. Вставить ник Quote
