Приветствую, подскажите как вкл. web ?
Alpha-A28F(config)# sh ver
Network Operating System
Copyright © 2006-2013 Orion Networks International, Inc.
Product name: Alpha-A28F
NOS Version NOS_4.14.1931.Alpha-A28F.000.20130813.(Compiled Aug 13 2013, 10:41
37)
Bootstrap Version Bootstrap_3.1.6.Alpha-A28F.0.20130813
FPGA Version
Hardware Alpha-A28F. Version Rev.D.0
System MacAddress is :f8f0.8271.0d56
Serial number: 140207000330S13B11S0028G
Alpha-A28F with
64M bytes DRAM
16M bytes Flash Memory
Switch uptime is 0 days, 0 hours, 11 minutes
Alpha-A28F(config)#terminal
ssh2 Ssh2 terminal
telnet Telnet terminal
с сайта nag, в описании - CLI/Telnet/SNMP/Web management
здесь - http://www.orionnetworks.com/catalog/alpha/a28f
Carrier Ethernet Service & Management - Supports IEEE 802.3ah Link OAM, IEEE 802.1ag end-to-end connectivity OAM and ITU-T Y.1731 end-to- end service and performance; Advanced QoS technology allows stream- marking based on CoS, DSCP and port priority; Scheduling modes including SP, WRR, SP+WRR; Support flow-based mirroring/rate-limit/redirection/ VLAN swapping and rewriting
про 26-й пишут
Monitor and management - A26 supports Simple Network Management Protocol (SNMP), in-band and out-of-band. Supports Command Line Interface(CLI) and WEB, supports Security IP function to prevent illegal users log in or change the configuration. As an important feature, OAM can help the user to monitor and manage the network across different protocols and equipments. A26 support 1:1 or N:1 port mirroring, monitor and manage the data flow of network, help locate the problem when breakdown happens. A26 supports Secure Shell(SSH), which will ensure the security of switch management and configuration. This series of switch can be managed by general network management platform with 3rd management software.
в мануале http://data.nag.ru/Orion%20Networks/Manuals/A10E_A28E_A28F%20Configuration%20Guide.pdf
ни hhtp,hhtps,web,www ничего не увидел
Здравствуйте,
В коммутаторах Orion Alpha A10E, A18E, A28E, A28F WEB-интерфейс отсутствует, он есть только в Orion A26.
Приносим свои извинения за неточность в описании, она будет исправлена.
P.S. В связи с большим количеством запросов сейчаc прорабатывается возможность добавления web-интерфейса на Orion A10E/A18E/A28E/A28F
  • 2 months later...
  • 6 months later...
Добрый день,
В прошивку внесено много изменений и исправлений, однозначно рекомендуется обновиться.
P.S. web-интерфейс пока не появился.
Появилась свежая прошивка от 27.04.2015
Добавлен ли Web-интерфейс?
Добрый день,
нет, не добавлен, но скоро будет
  • 1 month later...
Добрый день. С коммутатора (Name/OID: sysDescr.0; Value (OctetString): NOS Version NOS_4.14.1931.Alpha-A28F) по snmp параметры orionnetworksFanSpeedDueValue и orionnetworksTemperatureValue приходят со значением 0. DDM на модулях нет.
Исправит ли ситуацию обновление прошивки или с этого коммутатора уже не получить таких параметров? Хотелось бы выцепить больше системной информации с устройства, чтоб понимать что с ним происходит, когда например он перестает отвечать в жару и т.д. Спасибо.
  • 3 weeks later...
Скажите, а зачем она нужна?
Присоедениняюсь к вопросу.
ЗЫ: вообще ПО у дивайсов странное. Например, чтобы настроить интерфейс нужно входить в "conf t" режим, а чтобы поменять hostname или пользователя добавить - не надо.
хех... я на автомате conf t набираю
да и настройка в основном сводится к заливке типового конфига ;)
всё никак не мог привыкнуть что интерфейс et обзывается, теперь циске всё пытаюсь сказать sh int et status
в данной команде et бы выкинуть, всё равно других интерфейсов нету.
  • 11 months later...
Добрый день,
А когда оно, это "скоро" ?
Операторам веб-морда не нужна. А энтерпрайз-админам, не способным осилить CLI такие свитчи не особо нужны
А я не админ, но мне нужно добавлять вланы, смотреть маки, состояние портов. Изучать их консоль нет не желания, не времени. Поэтому мне такой свич не нужен.
Не согласен! Мне - нужна. И CLI нужен. Чтото удобно делать из CLI, чтото из WEB.
Кроме админов у провайдеров есть и другие службы. К примеру техподдержка, каждого не обучишь.
Обещано было, вот и спрашиваем.
Edited by ZaharovVV
Да и провайдеры бывают совершенно разных размеров. Бывает, что свичек этих тысячи и десятки тысяч. Тогда интерфейса, хоть CLI, хоть WEB вообще никто не видит. Целую историю представляет выяснить хотя бы ip адрес нужного коммутатора. И управляется это железо опосредовано через некий отросток биллинга/хелпдеска/чёрт_знает_чего_ещё. За бугром пошли ещё дальше. Есть масса производителей, как правило, у нас не представленных, которые делают железо практически БЕЗ интерфейса. Через примитивный CLI можно настроить базовый ip и snmp комьюнити. И всё. Остальное - SNMP. В лучшем случае, есть опциональный Java апплет для руления железкой мышкой посредством того же SNMP. Ну и ОЧЕНЬ развитый провизионинг. Так развитый, что до этого примитивного CLI можно вовсе и никогда не добраться. За ненадобностью.
А бывает нечто типа меня. С всего-то сотней совершенно разношёрстных коммутаторов. Вот только что поглядел, 28 моделей. И это не 28 моделей D-Link со сходным CLI. Помнить CLI для всех - взорвётся мосх. Писать коннекторы для всей этой орды к управляющему софту (в моих микромассштабах эту роль играет отросток биллинга) помрёшь. А мышкой в вебе тыкать удобно. Тем более, что модельное разнообразие растёт. Особенно, после посещения барахолок и визита к утилизаторам. Вот надысь пригрел за 3 т.р. свичку TELCO T5C-24F. Она такая одна и шанс найти к ней пару, чтобы не скучала, стремится к нулю. Что делать? Учить CLI? Писать коннектор к биллингу? Свичку эту выбросить? Или тыкать мышкой в веб?
А есть промежуточные варианты. Есть мой компаньон. Известный тут как heavydude. У него в менеджмент вилане заканчивается второй блок /24. Но зоопарк такой же, как у меня. Может, чуть поменьше. Админю его в стратегической части, по сути, я. А вот с географией ему не повезло. Он провайдит в одном из небольших городов Тверской области. Окружённом Болотистыми Пустошами. С комарами такого размера, что когда его убиваешь - слышно, как у комара ломается хребет. И у него в городе НЕТ квалифицированных админов и НЕТ квалифицированных саппортов. Не зародились. А те, что могли бы быть, уехали кто в Питер, кто в Москву. Сбор денег с территории таков, что пригласить Одмина Из Москвы на ПМЖ выльется в такую копеечку, что ну его нафиг. С Саппортами ситуация еще глупее. Саппорты местного разлива на уровне "Иди покорми Собаку и РУКАМИ НИЧЕГО НЕ ТРОГАЙ!!!". И вот в его ситуации веб интерфейс с возможность создания учётной записи "только посмотреть" - критически важно.
  • 2 weeks later...
странно пощупал коммутатор веб интерфейса нет. Сейчас даже в usb модемы пихают линукс с веб интерфейсами а тут нет ... все конечно пашет. Но пару тычек поставить через интерфейс мне бы хватило
  • 2 weeks later...
Ну как, есть успех?
Цитирую письмо из support'а
"Добрый день,
В тестовой прошивке с WEB обнаружены проблемы с утилизацией памяти, по этому на текущий момент мы не можем её предоставить .
Официальный релиз прошивки с WEB планируется на конец августа-начало сентября."
Так что пока ждем (((
Наверное, в НАГе не просто другой часовой пояс. Там наверное локальный сдвиг времени происходит. Ведь сегодня 22 августа. А это уже два дня как конец оного.
