Здравствуйте.
Имееться Cisco ASR 1002. Пытаюсь настроить ISG. Автризация проходит нормально, а с аккаунтингом поблема(tcpdump port 1813 на radius сервере не ловит ни одного пакета). Кто сталкивался помогите пожалуйста.
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISE-M), Version 15.0(1)S, RELEASE SOFTWARE (fc1)
ROM: IOS-XE ROMMON
cisco ASR1002 (2RU) processor with 1724178K/6147K bytes of memory.
конфиг CISCO
Current configuration : 4423 bytes
! Last configuration change at 11:02:57 UTC Thu May 12 2011 by root
version 15.0
service timestamps debug datetime msec
service timestamps log datetime msec
service password-encryption
service unsupported-transceiver
hostname router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
vrf definition default
enable password 7
aaa new-model
aaa session-mib disconnect
aaa group server radius SERVER_GROUP1
server 10.11.0.2 auth-port 1812 acct-port 1813
aaa authentication login AUTHEN_LIST1 group SERVER_GROUP1
aaa authorization network default group SERVER_GROUP1
aaa authorization subscriber-service AUTHOR_LIST1 group SERVER_GROUP1
aaa authorization subscriber-service AUTHEN_LIST1 group SERVER_GROUP1
aaa authorization subscriber-service ACCNT_LIST1 group SERVER_GROUP1
aaa accounting delay-start all
aaa accounting update periodic 5
aaa accounting network ACCNT_LIST1 start-stop group SERVER_GROUP1
aaa nas port extended
aaa session-id unique
ip source-route
no ip domain lookup
ip dhcp relay information policy keep
ip dhcp relay information trust-all
subscriber service session-accounting
subscriber service accounting interim-interval 1
subscriber authorization enable
redirect server-group REDIRECT_SERVER_GROUP1
server ip 10.11.0.2 port 80
multilink bundle-name authenticated
username root secret 4 8JejqDMXnmP5UU1C8NQ8zGNuw6r7tBqA46betnB4ghE
redundancy
mode none
class-map type traffic match-any account
policy-map type service ACC
class type traffic account
 accounting aaa list AUTHOR_LIST1
policy-map type control RULE_IP_SESSION2a
class type control always event session-start
 5 collect identifier nas-port
 10 service-policy type service aaa list AUTHOR_LIST1 identifier nas-port
class type control always event account-logon
 10 service-policy type service aaa list ACCNT_LIST1 identifier nas-port
class type control always event service-stop
 1 service-policy type service unapply identifier service-name
 10 log-session-state
class type control always event session-restart
 30 service-policy type service aaa list AUTHOR_LIST1 identifier nas-port
 40 service-policy type service name SERVICE_406_L4R
gw-accounting aaa
interface GigabitEthernet0/0/0
ip address X.X.X.X 255.255.255.252
ip nat outside
ip flow ingress
ip virtual-reassembly
negotiation auto
interface GigabitEthernet0/0/1
no ip address
negotiation auto
interface GigabitEthernet0/0/1.1000
encapsulation dot1Q 1000
ip address 10.11.0.3 255.255.255.0
ip nat inside
no ip virtual-reassembly
interface GigabitEthernet0/0/1.1011
encapsulation dot1Q 1011
ip address 192.168.0.1 255.255.255.0
ip helper-address 10.11.0.2
ip nat inside
service-policy type control RULE_IP_SESSION2a
ip subscriber routed
 initiator dhcp class-aware
interface GigabitEthernet0/0/2
no ip address
speed 100
no negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip nat inside source list 2 interface GigabitEthernet0/0/0 overload
no ip http server
ip route 0.0.0.0 0.0.0.0 X.X.X.X
ip route 10.0.0.0 255.0.0.0 10.11.0.1
ip radius source-interface GigabitEthernet0/0/1.1000
logging esm config
access-list 1 permit 10.11.0.2
access-list 2 permit 192.0.0.0 0.255.255.255
radius-server attribute 44 include-in-access-req
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 32 include-in-access-req
radius-server attribute 32 include-in-accounting-req
radius-server attribute 55 include-in-acct-req
radius-server attribute 55 access-request include
radius-server attribute 25 access-request include
radius-server attribute nas-port format e UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
radius-server host 10.11.0.2 auth-port 1812 acct-port 1813 key 7 12485744
radius-server retransmit 5
radius-server timeout 30
radius-server directed-request
radius-server vsa send accounting
radius-server vsa send authentication
control-plane
gateway
timer receive-rtp 1200
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7
end
AAA Accounting debugging
*May 12 11:19:55.870: AAA/ACCT/HC(00000033): Register Iedge IP SIP/570000C1 64 bit counter support not configured
*May 12 11:19:55.870: AAA/ACCT/HC(00000033): Update Iedge IP SIP/570000C1
*May 12 11:19:55.870: AAA/ACCT/HC(00000033): no HC Iedge IP SIP/570000C1
*May 12 11:19:55.870: AAA/ACCT/EVENT/(00000033): CALL START
*May 12 11:19:55.870: Getting session id for NET(00000033) : db=42204CE4
*May 12 11:19:55.870: AAA/ACCT(00000000): add node, session 724
*May 12 11:19:55.870: AAA/ACCT/NET(00000033): add, count 1
*May 12 11:19:55.871: Getting session id for NONE(00000033) : db=42204CE4
*May 12 11:20:01.928: AAA/ACCT/EVENT/(00000033): IPCP_PASS
*May 12 11:20:01.928: AAA/ACCT/NET(00000033): Method list not found
log radius сервера
05-12/11:27:01  INFO [pool-1-thread-37] radius -  AUTH:.
Type=AUTHENTICATION_REQUEST
Attributes:.
<------>User-Name=nas-port:10.11.0.3:0/0/1/1011
<------>NAS-Identifier=router
<------>NAS-Port-Id=0/0/1/1011
<------>User-Password=cisco
<------>NAS-IP-Address=10.11.0.3
<------>NAS-Port=721
<------>Service-Type=5
<------>Acct-Session-Id=0/0/1/1011_000002D1
<------>NAS-Port-Type=15
<------>cisco-avpair=vendor-class-id-tag=MSFT 5.0
05-12/11:27:01  INFO [pool-1-thread-37] radius -  RESPONSE:
Type=AUTHENTICATION_ACCEPT
Process time auth: 122 init_tariff: 0; set_ip: 0; common_auth: 12
Attributes:.
<------>Acct-Interim-Interval=60
<------>Service-Type=2
<------>Framed-Protocol=1
Trace:
Login found.
Edited by CheBuRashka
  • Replies 63
  • Created
  • Last Reply
Top Posters In This Topic
sh radius server-group all
и
sh radius statistics
м?
Server group radius
   Sharecount = 1  sg_unconfigured = FALSE
   Type = standard  Memlocks = 1
   Server(10.11.0.2:1812,1813) Transactions:
   Authen: 0   Author: 0       Acct: 0
   Server_auto_test_enabled: FALSE
Server group SERVER_GROUP1
   Authen: 0   Author: 2       Acct: 0
                                  Auth.      Acct.       Both
        Maximum inQ length:         NA         NA          1
      Maximum waitQ length:         NA         NA          1
      Maximum doneQ length:         NA         NA          1
      Total responses seen:         37          0         37
    Packets with responses:         37          0         37
 Packets without responses:          0          0          0
 Access Rejects           :         16
Average response delay(ms):        195          0        195
Maximum response delay(ms):        325          0        325
 Number of Radius timeouts:          0          0          0
      Duplicate ID detects:          0          0          0
Buffer Allocation Failures:          0          0          0
Maximum Buffer Size (bytes):        233          0        233
Malformed Responses        :          0          0          0
Bad Authenticators         :          0          0          0
Unknown Responses          :          0          0          0
Source Port Range: (2 ports only)
1645 - 1646
Last used Source Port/Identifier:
1645/47
1646/0
Attributes:.
Может быть я и ошибаюсь, но похоже аккаунтинг не идет, потому что пользователю в Auth_accept пакете не подключился сервис ACC (policy-map type service ACC), по которому у вас должен идти аккаунтинг
если добавить
20 service-policy type service name ACC
то ACC почемуто начинает отправляться как имя пользователя
лог радиуса
05-12/16:04:42  INFO [pool-1-thread-7] radius -  AUTH:.
Attributes:.
<------>User-Name=ACC
<------>NAS-Port=217
<------>Acct-Session-Id=0/0/1/1011_000000DC:000403f30001
<------>cisco-avpair=circuit-id-tag=000403f30001
<------>cisco-avpair=remote-id-tag=010131
05-12/16:04:42  INFO [pool-1-thread-7] radius -  RESPONSE:
Type=AUTHENTICATION_REJECT
Process time auth: 239 common_auth: 82
Attributes:.
<------>Reply-Message=14
циска почему-то не находит этот сервис ACC у себя как локально определенный сервис, и пытается запросить его у RADIUSа, а на RADUIS-сервере. он, похоже, не определен
я не знаю тонкости ASR1002, но попробуйте добавить в конфиг, чтобы циска искала серисы сначала локально, а потом уже запрашивала их у радиуса:
aaa authorization subscriber-service default local group SERVER_GROUP1
Сделал так. Cisco не отправлят ACC как имя пользователя, но перестала авторизовывать по nas-port.
Изменил
 10 authorize aaa list AUTHOR_LIST1 password cisco identifier nas-port
Авторизация стала проходить, но аккаунтинг по прежнему не идет.В дебаге тоже самое.
а пользователю через этот сервис подключается?
можете снова показать пакет AUTHENTICATION_ACCEPT от радиуса?
и в профиле пользователя поставить что-то типа
Cisco-Account-Info += AACT
Edited by C@T
пользователь подключаеться
router#sh subscriber session detailed
Current Subscriber Information: Total sessions 1
Unique Session ID: 90
Identifier: nas-port:10.11.0.3:0/0/1/1011
SIP subscriber access type(s): IP
Current SIP options: Req Fwding/Req Fwded
Session Up-time: 00:01:12, Last Changed: 00:01:12
Policy information:
 Context 300B02C4: Handle 5A0001A0
 AAA_id 00000068: Flow_handle 0
 Authentication status: authen
 Downloaded User profile, excluding services:
   service-type         2 [Framed]
   Framed-Protocol      1 [PPP]
   clid-mac-addr        00 15 E9 F1 C7 B3
   addr                 192.168.0.15
   netmask              255.255.255.255
   config-source-dpm    True
   vendor-class-id-tag  "MSFT 5.0"
 Downloaded User profile, including services:
   addr                 192.168.0.15
 Config history for session (recent to oldest):
   Access-type: IP Client: DHCP
    Policy event: Session-Update
     Profile name: apply-config-only, 2 references
       addr                 192.168.0.15
   Access-type: IP Client: SM
    Policy event: Service Selection Request
     Profile name: nas-port:10.11.0.3:0/0/1/1011, 2 references
 Rules, actions and conditions executed:
   subscriber rule-map RULE_IP_SESSION2a
     condition always event session-start
       10 authorize aaa list AUTHOR_LIST1 identifier nas-port
Configuration sources associated with this session:
Interface: GigabitEthernet0/0/1.1011, Active Time = 00:01:12
05-12/16:45:29  INFO [pool-1-thread-3] radius -  AUTH:.
Attributes:.
<------>NAS-Port=1679
<------>Acct-Session-Id=0/0/1/1011_0000068F
05-12/16:45:29  INFO [pool-1-thread-3] radius -  RESPONSE:
Process time auth: 121 init_tariff: 0; set_ip: 0; common_auth: 14
Attributes:.
Trace:
Login found.
профиля пользователя как такого нет.
Cisco настраиваю в связке с bgbilling.
в bgbilling используете bitel.billing.server.processor.PoDNASConnectionInspector или новый
bitel.billing.server.processor.ISGNasConnectionInspector ? Весрия 5.1 , 5.0 или 4.6 ?
Через модуль IPN или BGRadiusDialup?
в любом случае попробуйте передать атрибут Cisco-Account-Info = AACT через bgbilling'овский radius, если не знаете как, пишите, IPN не знаю, а если BGRadiusDialup, то подскажу
Edited by C@T
bgbilling 5.0
Попробую разобраться, если не получиться отпишусь.
За помощь огромное спасибо.
Есть еще способ сказать циске, чтобы она все-таки слала аккаунтинг, это
передать в AUTHENTICATION_ACCEPT пакете с RADIUS-сервера атрибуты
1. Cisco-Avpair="accounting-list=accounting-mlist-name" (видимо ACCNT_LIST1)
2. Acct-Interim-Interval (attribute 85)
но попробовать мне это так и не удалось, не знаю, будет ли работать
Спасибо огромное, все заработало.
  • 6 years later...
Доброго времени суток всем!
помогите!
конфиг
Building configuration...
Current configuration : 10870 bytes
! Last configuration change at 14:36:05 UTC Mon Jun 26 2017 by admin
! NVRAM config last updated at 07:40:55 UTC Mon Jun 26 2017 by admin
version 15.2
hostname KharinoIPoE
boot-start-marker
boot system disk2:c7200-advipservicesk9-mz.152-4.S7.bin
boot-end-marker
no logging console
enable secret 5 $1$G4sK$Q616cITrTmXUIz0iS0.Sz1
aaa new-model
aaa group server radius RADIUS_IPOE
server-private 10.1.0.2 auth-port 1812 acct-port 1813 timeout 3 retransmit 2 key 7 035C025C54597848180F48014F
ip radius source-interface GigabitEthernet0/3.10
deadtime 1
aaa authentication login ISG_IPOE group RADIUS_IPOE
aaa authentication ppp ISG_IPOE group RADIUS_IPOE
aaa authorization network ISG_IPOE group RADIUS_IPOE
aaa authorization subscriber-service default local group RADIUS_IPOE
aaa authorization subscriber-service ISG_IPOE local group RADIUS_IPOE
aaa accounting jitter maximum 10
aaa accounting update periodic 20
aaa accounting network ISG_IPOE
action-type start-stop
group RADIUS_IPOE
aaa server radius dynamic-author
client 10.1.0.2 server-key 7 897269d6f1d8
auth-type any
aaa session-id common
aaa policy interface-config allow-subinterface
ip cef
ip flow-cache timeout inactive 30
ip flow-cache timeout active 20
ip domain name Kharino
no ipv6 cef
subscriber service multiple-accept
service-policy type control CTRL_IPOE
archive
log config
hidekeys
username admin privilege 15 secret 5 $1$J9.1$Hy5OeGNL40k..5Bam.EsU/
redirect server-group REDIRECT_NOPAY
server ip 10.1.0.2 port 80
redirect server-group OFF-LINE-REDIRECT
redirect server-group DOWN-REDIRECT
redirect server-group PASSIVE-REDIRECT
redirect session-limit 256
ip ssh version 1
class-map type traffic match-any RADUIS_DEFAULT
match access-group input 103
match access-group output 104
class-map type traffic match-any REDIRECT-PASSIVE
match access-group input name PASSIVE
class-map type traffic match-any REDIRECT-DOWN
match access-group input name DOWN
class-map type traffic match-any REDIRECT-OFF-LINE
match access-group input name OFF-LINE
class-map type traffic match-any ACL-PASSIVE
match access-group output name PASSIVE
class-map type traffic match-any ACL-DOWN
match access-group output name DOWN
class-map type traffic match-any ACL-OFF-LINE
match access-group output name OFF-LINE
class-map type traffic match-any ACL-ON-LINE
match access-group output name ON-LINE
match access-group input name ON-LINE
class-map type traffic match-any avaria
match access-group input 102
match access-group output 101
class-map type control match-all ACC-ON-LINE
match authen-status authenticated
match timer TIMER_AUTH
class-map type control match-all ACC-UNAUTH
match authen-status unauthenticated
match timer UNAUTH-TIMER
policy-map type service ON-LINE-SERVICE
service local
class type traffic ACL-ON-LINE
class type traffic default in-out
policy-map type service OFF-LINE-SERVICE
service local
class type traffic ACL-OFF-LINE
policy-map type service SRV-OFF-LINE-REDIRECT
service local
class type traffic REDIRECT-OFF-LINE
redirect to group OFF-LINE-REDIRECT
drop
policy-map type service DOWN-SERVICE
service local
class type traffic ACL-DOWN
policy-map type service SRV-DOWN-REDIRECT
service local
class type traffic REDIRECT-DOWN
redirect to group DOWN-REDIRECT
drop
policy-map type service PASSIVE-SERVICE
service local
class type traffic ACL-PASSIVE
policy-map type service SRV-PASSIVE-REDIRECT
service local
class type traffic REDIRECT-PASSIVE
redirect to group PASSIVE-REDIRECT
drop
policy-map type service RADIUS-DEFAULT
service local
class type traffic RADUIS_DEFAULT
police input 2048000
police output 2048000
policy-map type control CTRL_IPOE
class type control always event radius-timeout
10 set-timer TIMER_UNAUTH 10
20 service-policy type service name RADIUS-DEFAULT
10 authorize aaa list ISG_IPOE password ISG identifier source-ip-address
20 set-timer TIMER_UNAUTH 10
30 service-policy type service name PASSIVE-SERVICE
40 service-policy type service name SRV-PASSIVE-REDIRECT
50 service-policy type service name DOWN-SERVICE
60 service-policy type service name SRV-DOWN-REDIRECT
interface GigabitEthernet0/2
no ip address
shutdown
media-type rj45
speed auto
duplex auto
no negotiation auto
no ip address
media-type rj45
speed auto
duplex auto
no negotiation auto
ip address 10.1.0.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/3.250
encapsulation dot1Q 250
ip address 172.1.0.1 255.255.248.0
ip nat inside
ip flow ingress
ip flow egress
initiator unclassified ip-address
ip access-list extended DOWN
permit ip host 10.1.0.2 any
permit ip any host 10.1.0.2
permit tcp any any eq www
deny ip any any
ip access-list extended OFF-LINE
deny ip any any
ip access-list extended ON-LINE
permit ip any any
ip access-list extended PASSIVE
deny ip any any
logging host 10.1.0.2
radius-server attribute 44 include-in-access-req default-vrf
radius-server attribute 44 extend-with-addr
radius-server attribute 31 mac format unformatted lower-case
radius-server vsa send cisco-nas-port
end
Server group radius
Server group RADIUS_IPOE
Server(10.1.0.2:1812,1813) Transactions:
Authen: 0 Author: 896 Acct: 0
Keywrap enabled: FALSE
sh radius st
Auth. Acct. Both
Maximum doneQ length: NA NA 0
Total responses seen: 1978 0 1978
Packets with responses: 1978 0 1978
Access Rejects : 1978
Average response delay(ms): 1010 0 1010
Maximum response delay(ms): 1804 0 1804
Maximum Buffer Size (bytes): 165 0 165
1645 - 1646
1645/16
1646/0
Elapsed time since counters last cleared: 1h8m
Radius Latency Distribution:
<= 2ms : 0 0
3-5ms : 0 0
5-10ms : 0 0
10-20ms: 0 0
20-50ms: 0 0
50-100m: 0 0
>100ms : 1978 0
Current inQ length : 0
Current doneQ length: 0
абонент не авторизуется
sh subsc ses
Codes: Lterm - Local Term, Fwd - forwarded, unauth - unathenticated, authen -
authenticated, TC Ct. - Number of Traffic Classes on the main session
Current Subscriber Information: Total sessions 31
Uniq ID Interface State Service Up-time TC Ct. Identifier
1572 IP unauthen Attempting 00:00:00 0 172.1.0.102
на Freeradiuse при авторизации ничего не происодит
Raduisd -X
# radiusd -X
radiusd: FreeRADIUS Version 2.2.9, for host amd64-portbld-freebsd10.3, built on Apr 24 2017 at 17:47:58
Copyright © 1999-2015 The FreeRADIUS server project and contributors.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
You may redistribute copies of FreeRADIUS under the terms of the
GNU General Public License.
For more information about these matters, see the file named COPYRIGHT.
Starting - reading configuration files ...
including configuration file /usr/local/etc/raddb/radiusd.conf
including files in directory /usr/local/etc/raddb/modules/
including configuration file /usr/local/etc/raddb/modules/always
including configuration file /usr/local/etc/raddb/modules/attr_filter
including configuration file /usr/local/etc/raddb/modules/attr_rewrite
including configuration file /usr/local/etc/raddb/modules/cache
including configuration file /usr/local/etc/raddb/modules/chap
including configuration file /usr/local/etc/raddb/modules/checkval
including configuration file /usr/local/etc/raddb/modules/counter
including configuration file /usr/local/etc/raddb/modules/cui
including configuration file /usr/local/etc/raddb/modules/detail
including configuration file /usr/local/etc/raddb/modules/detail.example.com
including configuration file /usr/local/etc/raddb/modules/detail.log
including configuration file /usr/local/etc/raddb/modules/dhcp_sqlippool
including configuration file /usr/local/etc/raddb/sql/mysql/ippool-dhcp.conf
including configuration file /usr/local/etc/raddb/modules/digest
including configuration file /usr/local/etc/raddb/modules/dynamic_clients
including configuration file /usr/local/etc/raddb/modules/echo
including configuration file /usr/local/etc/raddb/modules/etc_group
including configuration file /usr/local/etc/raddb/modules/exec
including configuration file /usr/local/etc/raddb/modules/expiration
including configuration file /usr/local/etc/raddb/modules/expr
including configuration file /usr/local/etc/raddb/modules/files
including configuration file /usr/local/etc/raddb/modules/inner-eap
including configuration file /usr/local/etc/raddb/modules/ippool
including configuration file /usr/local/etc/raddb/modules/krb5
including configuration file /usr/local/etc/raddb/modules/ldap
including configuration file /usr/local/etc/raddb/modules/linelog
including configuration file /usr/local/etc/raddb/modules/logintime
including configuration file /usr/local/etc/raddb/modules/otp
including configuration file /usr/local/etc/raddb/modules/mac2ip
including configuration file /usr/local/etc/raddb/modules/mac2vlan
including configuration file /usr/local/etc/raddb/modules/mschap
including configuration file /usr/local/etc/raddb/modules/ntlm_auth
including configuration file /usr/local/etc/raddb/modules/opendirectory
including configuration file /usr/local/etc/raddb/modules/pam
including configuration file /usr/local/etc/raddb/modules/pap
including configuration file /usr/local/etc/raddb/modules/passwd
including configuration file /usr/local/etc/raddb/modules/perl
including configuration file /usr/local/etc/raddb/modules/policy
including configuration file /usr/local/etc/raddb/modules/preprocess
including configuration file /usr/local/etc/raddb/modules/radrelay
including configuration file /usr/local/etc/raddb/modules/radutmp
including configuration file /usr/local/etc/raddb/modules/realm
including configuration file /usr/local/etc/raddb/modules/redis
including configuration file /usr/local/etc/raddb/modules/rediswho
including configuration file /usr/local/etc/raddb/modules/replicate
including configuration file /usr/local/etc/raddb/modules/smbpasswd
including configuration file /usr/local/etc/raddb/modules/smsotp
including configuration file /usr/local/etc/raddb/modules/soh
including configuration file /usr/local/etc/raddb/modules/sql_log
including configuration file /usr/local/etc/raddb/modules/sqlcounter_expire_on_login
including configuration file /usr/local/etc/raddb/modules/sradutmp
including configuration file /usr/local/etc/raddb/modules/unix
including configuration file /usr/local/etc/raddb/modules/wimax
including configuration file /usr/local/etc/raddb/modules/acct_unique
including configuration file /usr/local/etc/raddb/eap.conf
including configuration file /usr/local/etc/raddb/sql.conf
including configuration file /usr/local/etc/raddb/sql/mysql/dialup.conf
including files in directory /usr/local/etc/raddb/sites-enabled/
including configuration file /usr/local/etc/raddb/sites-enabled/default
including configuration file /usr/local/etc/raddb/sites-enabled/inner-tunnel
including configuration file /usr/local/etc/raddb/sites-enabled/control-socket
main {
user = "freeradius"
group = "freeradius"
allow_core_dumps = no
including dictionary file /usr/local/etc/raddb/dictionary
main {
name = "radiusd"
prefix = "/usr/local"
localstatedir = "/var"
sbindir = "/usr/local/sbin"
logdir = "/var/log"
run_dir = "/var/run/radiusd"
libdir = "/usr/local/lib/freeradius-2.2.0"
radacctdir = "/var/log/radacct"
hostname_lookups = no
max_request_time = 30
cleanup_delay = 5
max_requests = 1024
pidfile = "/var/run/radiusd/radiusd.pid"
checkrad = "/usr/local/sbin/checkrad"
debug_level = 0
proxy_requests = yes
log {
stripped_names = yes
auth = yes
auth_badpass = yes
auth_goodpass = no
security {
max_attributes = 200
reject_delay = 1
status_server = yes
allow_vulnerable_openssl = no
radiusd: #### Loading Realms and Home Servers ####
radiusd: #### Loading Clients ####
radiusd: #### Instantiating modules ####
instantiate {
Module: Linked to module rlm_exec
Module: Instantiating module "exec" from file /usr/local/etc/raddb/modules/exec
exec {
wait = no
input_pairs = "request"
shell_escape = yes
timeout = 10
Module: Linked to module rlm_expr
Module: Instantiating module "expr" from file /usr/local/etc/raddb/modules/expr
radiusd: #### Loading Virtual Servers ####
server { # from file /usr/local/etc/raddb/radiusd.conf
modules {
Module: Creating Auth-Type = digest
Module: Checking authenticate {...} for more modules to load
Module: Linked to module rlm_pap
Module: Instantiating module "pap" from file /usr/local/etc/raddb/modules/pap
pap {
encryption_scheme = "auto"
auto_header = no
Module: Linked to module rlm_chap
Module: Instantiating module "chap" from file /usr/local/etc/raddb/modules/chap
Module: Linked to module rlm_mschap
Module: Instantiating module "mschap" from file /usr/local/etc/raddb/modules/mschap
mschap {
use_mppe = yes
require_encryption = no
require_strong = no
with_ntdomain_hack = no
allow_retry = yes
Module: Linked to module rlm_digest
Module: Instantiating module "digest" from file /usr/local/etc/raddb/modules/digest
Module: Linked to module rlm_unix
Module: Instantiating module "unix" from file /usr/local/etc/raddb/modules/unix
unix {
radwtmp = "/var/log/radwtmp"
Module: Linked to module rlm_eap
Module: Instantiating module "eap" from file /usr/local/etc/raddb/eap.conf
eap {
default_eap_type = "md5"
timer_expire = 60
ignore_unknown_eap_types = no
cisco_accounting_username_bug = no
max_sessions = 1024
Module: Linked to sub-module rlm_eap_md5
Module: Instantiating eap-md5
Module: Linked to sub-module rlm_eap_leap
Module: Instantiating eap-leap
Module: Linked to sub-module rlm_eap_gtc
Module: Instantiating eap-gtc
gtc {
challenge = "Password: "
auth_type = "PAP"
Module: Linked to sub-module rlm_eap_tls
Module: Instantiating eap-tls
tls {
rsa_key_exchange = no
dh_key_exchange = yes
rsa_key_length = 512
dh_key_length = 512
verify_depth = 0
CA_path = "/usr/local/etc/raddb/certs"
pem_file_type = yes
private_key_file = "/usr/local/etc/raddb/certs/server.pem"
certificate_file = "/usr/local/etc/raddb/certs/server.pem"
CA_file = "/usr/local/etc/raddb/certs/ca.pem"
private_key_password = "whatever"
dh_file = "/usr/local/etc/raddb/certs/dh"
fragment_size = 1024
include_length = yes
check_crl = no
check_all_crl = no
cipher_list = "DEFAULT"
make_cert_command = "/usr/local/etc/raddb/certs/bootstrap"
ecdh_curve = "prime256v1"
cache {
enable = no
lifetime = 24
max_entries = 255
verify {
ocsp {
enable = no
override_cert_url = yes
url = "http://127.0.0.1/ocsp/"
use_nonce = yes
timeout = 0
softfail = no
Module: Linked to sub-module rlm_eap_ttls
Module: Instantiating eap-ttls
ttls {
copy_request_to_tunnel = no
use_tunneled_reply = no
virtual_server = "inner-tunnel"
Module: Linked to sub-module rlm_eap_peap
Module: Instantiating eap-peap
peap {
default_eap_type = "mschapv2"
proxy_tunneled_request_as_eap = yes
soh = no
Module: Linked to sub-module rlm_eap_mschapv2
Module: Instantiating eap-mschapv2
mschapv2 {
send_error = no
Module: Checking authorize {...} for more modules to load
Module: Linked to module rlm_preprocess
Module: Instantiating module "preprocess" from file /usr/local/etc/raddb/modules/preprocess
preprocess {
huntgroups = "/usr/local/etc/raddb/huntgroups"
hints = "/usr/local/etc/raddb/hints"
with_ascend_hack = no
ascend_channels_per_line = 23
with_specialix_jetstream_hack = no
with_cisco_vsa_hack = no
with_alvarion_vsa_hack = no
reading pairlist file /usr/local/etc/raddb/huntgroups
reading pairlist file /usr/local/etc/raddb/hints
Module: Linked to module rlm_sql
Module: Instantiating module "sql" from file /usr/local/etc/raddb/sql.conf
sql {
driver = "rlm_sql_mysql"
server = "localhost"
port = "3306"
login = "root"
password = "mysd2b9e237"
radius_db = "stg"
read_groups = yes
sqltrace = no
sqltracefile = "/var/log/sqltrace.sql"
readclients = yes
deletestalesessions = yes
num_sql_socks = 5
lifetime = 0
max_queries = 0
sql_user_name = "%{User-Name}"
default_user_profile = ""
nas_query = "SELECT (@cnt := @cnt + 1) AS `id`, `nasname`, `shortname`, `type`, `secret`, `server` FROM `radius_clients` CROSS JOIN (SELECT @cnt := 0) AS `dummy` ORDER BY `id`"
authorize_check_query = "SELECT (@cnt := @cnt + 1) AS `id`, `UserName`, `Attribute`, `Value`, `op` FROM `radius_check` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `UserName` = '%{SQL-User-Name}' ORDER BY `id`"
authorize_reply_query = "SELECT (@cnt := @cnt + 1) AS `id`, `UserName`, `Attribute`, `Value`, `op` FROM `radius_reply` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `UserName` = '%{SQL-User-Name}' ORDER BY `id`"
authorize_group_check_query = "SELECT (@cnt := @cnt + 1) AS `id`, `GroupName`, `Attribute`, `Value`, `op` FROM `radius_groupcheck` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `GroupName` = '%{Sql-Group}' ORDER BY `id`"
authorize_group_reply_query = "SELECT (@cnt := @cnt + 1) AS `id`, `GroupName`, `Attribute`, `Value`, `op` FROM `radius_groupreply` CROSS JOIN (SELECT @cnt := 0) AS `dummy` WHERE `GroupName` = '%{Sql-Group}' ORDER BY `id`"
accounting_onoff_query = " UPDATE radius_acct SET acctstoptime = '%S', acctsessiontime = unix_timestamp('%S') - unix_timestamp(acctstarttime), acctterminatecause = '%{Acct-Terminate-Cause}', acctstopdelay = %{%{Acct-Delay-Time}:-0} WHERE acctstoptime IS NULL AND nasipaddress = '%{NAS-IP-Address}' AND acctstarttime <= '%S'"
accounting_update_query = " UPDATE radius_acct SET framedipaddress = '%{Framed-IP-Address}', acctsessiontime = '%{Acct-Session-Time}', acctinputoctets = '%{%{Acct-Input-Gigawords}:-0}' << 32 | '%{%{Acct-Input-Octets}:-0}', acctoutputoctets = '%{%{Acct-Output-Gigawords}:-0}' << 32 | '%{%{Acct-Output-Octets}:-0}' WHERE acctsessionid = '%{Acct-Session-Id}' AND username = '%{SQL-User-Name}' AND nasipaddress = '%{NAS-IP-Address}'"
accounting_update_query_alt = " INSERT INTO radius_acct (acctsessionid, acctuniqueid, username, realm, nasipaddress, nasportid, nasporttype, acctstarttime, acctsessiontime, acctauthentic, connectinfo_start, acctinputoctets, acctoutputoctets, calledstationid, callingstationid, servicetype, framedprotocol, framedipaddress, acctstartdelay, xascendsessionsvrkey) VALUES ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}', '%{SQL-User-Name}', '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}', '%{NAS-Port-Type}', DATE_SUB('%S', INTERVAL (%{%{Acct-Session-Time}:-0} + %{%{Acct-Delay-Time}:-0}) SECOND), '%{Acct-Session-Time}', '%{Acct-Authentic}', '', '%{%{Acct-Input-Gigawords}:-0}' << 32 | '%{%{Acct-Input-Octets}:-0}', '%{%{Acct-Output-Gigawords}:-0}' << 32 | '%{%{Acct-Output-Octets}:-0}', '%{Called-Station-Id}', '%{Calling-Station-Id}', '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}', '0', '%{X-Ascend-Session-Svr-Key}')"
accounting_start_query = " INSERT INTO radius_acct (acctsessionid, acctuniqueid, username, realm, nasipaddress, nasportid, nasporttype, acctstarttime, acctstoptime, acctsessiontime, acctauthentic, connectinfo_start, connectinfo_stop, acctinputoctets, acctoutputoctets, calledstationid, callingstationid, acctterminatecause, servicetype, framedprotocol, framedipaddress, acctstartdelay, acctstopdelay, xascendsessionsvrkey) VALUES ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}', '%{SQL-User-Name}', '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}', '%{NAS-Port-Type}', '%S', NULL, '0', '%{Acct-Authentic}', '%{Connect-Info}', '', '0', '0', '%{Called-Station-Id}', '%{Calling-Station-Id}', '', '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}', '%{%{Acct-Delay-Time}:-0}', '0', '%{X-Ascend-Session-Svr-Key}')"
accounting_start_query_alt = " UPDATE radius_acct SET acctstarttime = '%S', acctstartdelay = '%{%{Acct-Delay-Time}:-0}', connectinfo_start = '%{Connect-Info}' WHERE acctsessionid = '%{Acct-Session-Id}' AND username = '%{SQL-User-Name}' AND nasipaddress = '%{NAS-IP-Address}'"
accounting_stop_query = " UPDATE radius_acct SET acctstoptime = '%S', acctsessiontime = '%{Acct-Session-Time}', acctinputoctets = '%{%{Acct-Input-Gigawords}:-0}' << 32 | '%{%{Acct-Input-Octets}:-0}', acctoutputoctets = '%{%{Acct-Output-Gigawords}:-0}' << 32 | '%{%{Acct-Output-Octets}:-0}', acctterminatecause = '%{Acct-Terminate-Cause}', acctstopdelay = '%{%{Acct-Delay-Time}:-0}', connectinfo_stop = '%{Connect-Info}' WHERE acctsessionid = '%{Acct-Session-Id}' AND username = '%{SQL-User-Name}' AND nasipaddress = '%{NAS-IP-Address}'"
accounting_stop_query_alt = " INSERT INTO radius_acct (acctsessionid, acctuniqueid, username, realm, nasipaddress, nasportid, nasporttype, acctstarttime, acctstoptime, acctsessiontime, acctauthentic, connectinfo_start, connectinfo_stop, acctinputoctets, acctoutputoctets, calledstationid, callingstationid, acctterminatecause, servicetype, framedprotocol, framedipaddress, acctstartdelay, acctstopdelay) VALUES ('%{Acct-Session-Id}', '%{Acct-Unique-Session-Id}', '%{SQL-User-Name}', '%{Realm}', '%{NAS-IP-Address}', '%{NAS-Port}', '%{NAS-Port-Type}', DATE_SUB('%S', INTERVAL (%{%{Acct-Session-Time}:-0} + %{%{Acct-Delay-Time}:-0}) SECOND), '%S', '%{Acct-Session-Time}', '%{Acct-Authentic}', '', '%{Connect-Info}', '%{%{Acct-Input-Gigawords}:-0}' << 32 | '%{%{Acct-Input-Octets}:-0}', '%{%{Acct-Output-Gigawords}:-0}' << 32 | '%{%{Acct-Output-Octets}:-0}', '%{Called-Station-Id}', '%{Calling-Station-Id}', '%{Acct-Terminate-Cause}', '%{Service-Type}', '%{Framed-Protocol}', '%{Framed-IP-Address}', '0', '%{%{Acct-Delay-Time}:-0}')"
group_membership_query = "SELECT `GroupName` FROM `radius_usergroup` WHERE `UserName` = '%{SQL-User-Name}' ORDER BY `priority`"
connect_failure_retry_delay = 60
simul_count_query = ""
simul_verify_query = "SELECT radacctid, acctsessionid, username, nasipaddress, nasportid, framedipaddress, callingstationid, framedprotocol FROM radius_acct WHERE username = '%{SQL-User-Name}' AND acctstoptime IS NULL"
postauth_query = "INSERT INTO radius_postauth (username, pass, reply, authdate) VALUES ( '%{User-Name}', '%{%{User-Password}:-%{Chap-Password}}', '%{reply:Packet-Type}', '%S')"
safe-characters = "@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /"
rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
rlm_sql (sql): Attempting to connect to root@localhost:3306/stg
rlm_sql (sql): starting 0
rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
rlm_sql_mysql: Starting connect to MySQL server for #0
rlm_sql (sql): Connected new DB handle, #0
rlm_sql (sql): starting 1
rlm_sql (sql): Attempting to connect rlm_sql_mysql #1
rlm_sql_mysql: Starting connect to MySQL server for #1
rlm_sql (sql): Connected new DB handle, #1
rlm_sql (sql): starting 2
rlm_sql (sql): Attempting to connect rlm_sql_mysql #2
rlm_sql_mysql: Starting connect to MySQL server for #2
rlm_sql (sql): Connected new DB handle, #2
rlm_sql (sql): starting 3
rlm_sql (sql): Attempting to connect rlm_sql_mysql #3
rlm_sql_mysql: Starting connect to MySQL server for #3
rlm_sql (sql): Connected new DB handle, #3
rlm_sql (sql): starting 4
rlm_sql (sql): Attempting to connect rlm_sql_mysql #4
rlm_sql_mysql: Starting connect to MySQL server for #4
rlm_sql (sql): Connected new DB handle, #4
rlm_sql (sql): Processing generate_sql_clients
rlm_sql (sql) in generate_sql_clients: query is SELECT (@cnt := @cnt + 1) AS `id`, `nasname`, `shortname`, `type`, `secret`, `server` FROM `radius_clients` CROSS JOIN (SELECT @cnt := 0) AS `dummy` ORDER BY `id`
rlm_sql (sql): Reserving sql socket id: 4
rlm_sql (sql): Read entry nasname=127.0.0.1,shortname=Local,secret=dec0071981b1
rlm_sql (sql): Adding client 127.0.0.1 (Local, server=<none>) to clients list
rlm_sql (sql): Read entry nasname=10.1.0.1,shortname=Cisco 7201 Kharino,secret=897269d6f1d8
rlm_sql (sql): Adding client 10.1.0.1 (Cisco 7201 Kharino, server=<none>) to clients list
rlm_sql (sql): Read entry nasname=172.1.0.1,shortname=Cisco 7201,secret=c1394e9f030e
rlm_sql (sql): Adding client 172.1.0.1 (Cisco 7201, server=<none>) to clients list
rlm_sql (sql): Released sql socket id: 4
Module: Linked to module rlm_expiration
Module: Instantiating module "expiration" from file /usr/local/etc/raddb/modules/expiration
expiration {
reply-message = "Password Has Expired "
Module: Linked to module rlm_logintime
Module: Instantiating module "logintime" from file /usr/local/etc/raddb/modules/logintime
logintime {
reply-message = "You are calling outside your allowed timespan "
minimum-timeout = 60
Module: Checking preacct {...} for more modules to load
Module: Linked to module rlm_acct_unique
Module: Instantiating module "acct_unique" from file /usr/local/etc/raddb/modules/acct_unique
acct_unique {
key = "User-Name, Acct-Session-Id, NAS-IP-Address, NAS-Identifier, NAS-Port"
Module: Checking accounting {...} for more modules to load
Module: Linked to module rlm_attr_filter
Module: Instantiating module "attr_filter.accounting_response" from file /usr/local/etc/raddb/modules/attr_filter
attr_filter attr_filter.accounting_response {
attrsfile = "/usr/local/etc/raddb/attrs.accounting_response"
key = "%{User-Name}"
relaxed = no
reading pairlist file /usr/local/etc/raddb/attrs.accounting_response
Module: Checking session {...} for more modules to load
Module: Linked to module rlm_radutmp
Module: Instantiating module "radutmp" from file /usr/local/etc/raddb/modules/radutmp
radutmp {
filename = "/var/log/radutmp"
username = "%{User-Name}"
case_sensitive = yes
check_with_nas = yes
perm = 384
callerid = yes
Module: Checking post-proxy {...} for more modules to load
Module: Checking post-auth {...} for more modules to load
Module: Instantiating module "attr_filter.access_reject" from file /usr/local/etc/raddb/modules/attr_filter
attr_filter attr_filter.access_reject {
attrsfile = "/usr/local/etc/raddb/attrs.access_reject"
relaxed = no
reading pairlist file /usr/local/etc/raddb/attrs.access_reject
} # modules
} # server
server inner-tunnel { # from file /usr/local/etc/raddb/sites-enabled/inner-tunnel
modules {
Module: Linked to module rlm_realm
Module: Instantiating module "suffix" from file /usr/local/etc/raddb/modules/realm
realm suffix {
format = "suffix"
delimiter = "@"
ignore_default = no
ignore_null = no
Module: Linked to module rlm_files
Module: Instantiating module "files" from file /usr/local/etc/raddb/modules/files
files {
usersfile = "/usr/local/etc/raddb/users"
acctusersfile = "/usr/local/etc/raddb/acct_users"
preproxy_usersfile = "/usr/local/etc/raddb/preproxy_users"
compat = "no"
reading pairlist file /usr/local/etc/raddb/users
reading pairlist file /usr/local/etc/raddb/acct_users
reading pairlist file /usr/local/etc/raddb/preproxy_users
} # modules
} # server
radiusd: #### Opening IP addresses and Ports ####
listen {
type = "auth"
ipaddr = *
port = 0
listen {
type = "acct"
ipaddr = *
port = 0
listen {
type = "control"
listen {
socket = "/var/run/radiusd/radiusd.sock"
listen {
type = "auth"
ipaddr = 127.0.0.1
port = 18120
Listening on authentication address * port 1812
Listening on accounting address * port 1813
Listening on command file /var/run/radiusd/radiusd.sock
Listening on authentication address 127.0.0.1 port 18120 as server inner-tunnel
Listening on proxy address * port 1814
Ready to process requests.
сейчас при перезагрузке Freeradius абонент авторизовался, но радиус не видит?????
sh subsc ses ui 1781
Type: IP, UID: 1781, State: unauthen, Identity: 172.1.0.102
IPv4 Address: 172.1.0.102
Session Up-time: 00:01:02, Last Changed: 00:01:02
Switch-ID: 127920
Policy information:
Authentication status: unauthen
Active services associated with session:
name "RADIUS-DEFAULT", applied before account logon
subscriber rule-map CTRL_IPOE
10 authorize aaa list ISG_IPOE identifier source-ip-address
condition always event radius-timeout
Classifiers:
Class-id Dir Packets Bytes Pri. Definition
0 In 192 14249 0 Match Any
1 Out 165 24045 0 Match Any
81574 In 192 14249 0 Match ACL 103
81575 Out 165 24045 0 Match ACL 104
Features:
Policing:
Class-id Dir Avg. Rate Normal Burst Excess Burst Source
81574 In 2048000 384000 768000 RADIUS-DEFAULT
81575 Out 2048000 384000 768000 RADIUS-DEFAULT
Configuration Sources:
Type Active Time AAA Service ID Name
SVC 00:01:03 - RADIUS-DEFAULT
USR 00:01:03 - Peruser
INT 00:01:03 - GigabitEthernet0/3.250
Session Up-time: 00:05:35, Last Changed: 00:05:35
Switch-ID: 127920
Policy information:
Context 6843CF4C: Handle 3D00054E
AAA_id 000455F6: Flow_handle 0
username 0 "RADIUS-DEFAULT"
sss-service 0 6 [local-termination]
traffic-class 0 "input access-group 103"
traffic-class 0 "output access-group 104"
ssg-service-info 0 "QU;2048000;D;2048000"
Access-type: IP Client: Invalid
Policy event: Service Selection Request (Service)
Profile name: RADIUS-DEFAULT, 3 references
password 0 <hidden>
Classifiers:
0 In 998 84616 0 Match Any
1 Out 825 114047 0 Match Any
81574 In 998 84616 0 Match ACL 103
81575 Out 825 114047 0 Match ACL 104
Features:
Policing:
SVC 00:05:38 - RADIUS-DEFAULT
USR 00:05:38 - Peruser
INT 00:05:38 - GigabitEthernet0/3.250
при повторной авторизации то же самое
из атрибутов только пароль и IP
при этом попрежнему
Server group radius
Authen: 0 Author: 1244 Acct: 0
sh radius st
Auth. Acct. Both
Total responses seen: 2297 0 2297
Packets with responses: 2297 0 2297
Packets without responses: 1 0 1
Access Rejects : 2297
Number of Radius timeouts: 3 0 3
1645 - 1646
1645/80
1646/0
Elapsed time since counters last cleared: 1h31m
<= 2ms : 0 0
3-5ms : 0 0
5-10ms : 0 0
10-20ms: 0 0
20-50ms: 0 0
50-100m: 0 0
>100ms : 2297 0
при просмотре интерфейса на Freeradius во время авторизации
# tcpdump -n -i bce0 port 1812 or udp port 1813
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on bce0, link-type EN10MB (Ethernet), capture size 65535 bytes
тишина
ping 10.1.0.2
#ping 10.1.0.2
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 10.1.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
show arp 10.1.0.2
#show arp 10.1.0.2
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.1.0.2 7 001f.29e0.56fa ARPA GigabitEthernet0/3.10
debug radius authen
#debug radius authen
Radius protocol debugging is on
Radius protocol brief debugging is off
Radius protocol verbose debugging is off
Radius packet hex dump debugging is off
Radius packet protocol (authentication) debugging is on
Radius packet protocol (accounting) debugging is off
Radius elog debugging debugging is off
Radius packet retransmission debugging is off
Radius server fail-over debugging is off
смотрю, конечно!
режим отладки
но пока не доходит
если речь о логах то они идут на 10.1.0.2
мне надо запустить отладку
и меня их нет
show debug condition
% No conditions found
Edited by Andrey75
так отладка включена
#show debug
General OS:
AAA Authentication debugging is on
Radius protocol brief debugging is on
Radius protocol verbose debugging is on
Radius packet protocol (accounting) debugging is on
Radius elog debugging debugging is on
Radius packet retransmission debugging is on
Radius server fail-over debugging is on
не понимаю как посмотреть что происходит?
