AntonS Posted May 18, 2010 Posted May 18, 2010 Поставил на сервак с mpd5.5 quagga bgp стали проскакивать пинги до 70мс на другом сервере там где нету bgp такого не наблюдается last pid: 84143; load averages: 8.41, 4.91, 5.18 up 0+06:03:25 11:40:36 205 processes: 19 running, 154 sleeping, 32 waiting CPU: 1.4% user, 0.0% nice, 18.4% system, 0.0% interrupt, 80.2% idle Mem: 358M Active, 601M Inact, 1238M Wired, 464K Cache, 821M Buf, 5626M Free Swap: 16G Total, 16G Free PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND 18 root 1 171 ki31 0K 16K CPU8 8 301:36 93.99% idle: cpu8 15 root 1 171 ki31 0K 16K CPU11 11 324:19 90.67% idle: cpu11 11 root 1 171 ki31 0K 16K CPU15 15 325:30 90.38% idle: cpu15 12 root 1 171 ki31 0K 16K CPU14 14 322:26 89.60% idle: cpu14 21 root 1 171 ki31 0K 16K CPU5 5 312:01 88.67% idle: cpu5 14 root 1 171 ki31 0K 16K CPU12 12 318:33 88.48% idle: cpu12 19 root 1 171 ki31 0K 16K CPU7 7 312:06 88.28% idle: cpu7 13 root 1 171 ki31 0K 16K CPU13 13 327:30 87.60% idle: cpu13 16 root 1 171 ki31 0K 16K CPU10 10 312:18 87.35% idle: cpu10 23 root 1 171 ki31 0K 16K CPU3 3 310:11 86.87% idle: cpu3 22 root 1 171 ki31 0K 16K CPU4 4 282:42 86.28% idle: cpu4 20 root 1 171 ki31 0K 16K CPU6 6 295:57 85.35% idle: cpu6 25 root 1 171 ki31 0K 16K CPU1 1 310:24 84.08% idle: cpu1 26 root 1 171 ki31 0K 16K CPU0 0 261:16 81.98% idle: cpu0 17 root 1 171 ki31 0K 16K RUN 9 320:51 76.56% idle: cpu9 24 root 1 171 ki31 0K 16K RUN 2 269:59 75.20% idle: cpu2 837 root 1 108 0 121M 116M CPU9 9 6:59 53.17% zebra 1440 root 2 44 0 110M 33992K select 6 0:00 8.15% mpd5 #em tun dev.em.0.rx_kthreads=8 dev.em.1.rx_kthreads=8 dev.em.2.rx_kthreads=8 dev.em.3.rx_kthreads=8 dev.em.4.rx_kthreads=8 dev.em.5.rx_kthreads=8 dev.em.0.rx_int_delay=600 dev.em.0.tx_int_delay=600 dev.em.0.rx_abs_int_delay=800 dev.em.0.tx_abs_int_delay=800 dev.em.1.rx_int_delay=600 dev.em.1.tx_int_delay=600 dev.em.1.rx_abs_int_delay=800 dev.em.1.tx_abs_int_delay=800 dev.em.2.rx_int_delay=600 dev.em.2.tx_int_delay=600 dev.em.2.rx_abs_int_delay=800 dev.em.2.tx_abs_int_delay=800 dev.em.3.rx_int_delay=600 dev.em.3.tx_int_delay=600 dev.em.3.rx_abs_int_delay=800 dev.em.3.tx_abs_int_delay=800 dev.em.4.rx_int_delay=600 dev.em.4.tx_int_delay=600 dev.em.4.rx_abs_int_delay=800 dev.em.4.tx_abs_int_delay=800 dev.em.5.rx_int_delay=600 dev.em.5.tx_int_delay=600 dev.em.5.rx_abs_int_delay=800 dev.em.5.tx_abs_int_delay=800 Вставить ник Quote
jab Posted May 18, 2010 Posted May 18, 2010 Читайте документацию, как его включить. Вставить ник Quote
AntonS Posted May 18, 2010 Author Posted May 18, 2010 график загрузки CPU как забор но не привышает 50% по топу нагрузка плавает +-15% Вставить ник Quote
AntonS Posted May 18, 2010 Author Posted May 18, 2010 у меня ядро собрано только makeoptions DEBUG=-g как я понял надо еще options DEBUG_LOCKS options DEBUG_VFS_LOCKS options DIAGNOSTIC ? Вставить ник Quote
Dm1try Posted May 18, 2010 Posted May 18, 2010 Эммм... Вам, насколько я понял какбе номекали включить debug в quagga. Вставить ник Quote
mikevlz Posted May 18, 2010 Posted May 18, 2010 квагга реагирует на динамические интерфейсы? Поднялся интерфейс - проходит задержка, или постоянно задержка есть? Вставить ник Quote
AntonS Posted May 18, 2010 Author Posted May 18, 2010 походу реагирут на интерфейсы у меня просто ospf настроен нужне для статических ip но только с bgp такое щас bgp отключил ospf работает нормально Вставить ник Quote
AntonS Posted May 18, 2010 Author Posted May 18, 2010 чтобы не рушилось bgp при создании удалении интерфейса рекомендуют на lo0 алиасом посадить Ip который является шлюзом в pptp у кого нить есть такая связка mpd5+quagga(bgp+ospf) ? Вставить ник Quote
RussianE39 Posted May 19, 2010 Posted May 19, 2010 Если фря восьмерка - попробуйте выключить FLOWTABLE (net.inet.flowtable.enable=0). Ссылки для повышения квалификации: http://groups.google.ru/group/lucky.freebs...06d530123?pli=1 http://daemonflux.blogspot.com/2008/10/flo...erformance.html http://daemonflux.blogspot.com/2010/01/updates.html Вставить ник Quote
YuryD Posted May 19, 2010 Posted May 19, 2010 у кого нить есть такая связка mpd5+quagga(bgp+ospf) ? Есть , mpd5.5+quagga(bgp) в связке с 7204 и еще одним компом с nat. И случайно bsnmpd не используете ? Если да, то замените на на snmpd из портов. Вставить ник Quote
AntonS Posted May 19, 2010 Author Posted May 19, 2010 FreeBSD 7.3-STABLE #1 bgp 3 магистрала full-view использую /usr/ports/net-mgmt/net-snmp/ полностью обновлена вместе с портами Вставить ник Quote
jab Posted May 19, 2010 Posted May 19, 2010 flowtable не при чем, если в BGP не зафильтрованы p2p интерфейсы, то он обязательно будет перемолачивать всю таблицу при каждом изменении состояния, так как в отличие от OSPF не воспринимает разницы между backbone и stub-area Вставить ник Quote
AntonS Posted May 19, 2010 Author Posted May 19, 2010 Вопрос теперь как их отфильтровать в bgp и оставить в ospf? Вставить ник Quote
YuryD Posted May 19, 2010 Posted May 19, 2010 Вопрос теперь как их отфильтровать в bgpи оставить в ospf? А смысл ? Все равно эти маршруты будут появляться-исчезать в таблице маршрутизации. Ну не будете вы их анонсировать куда-либо, ядру от этого легче не станет. Вставить ник Quote
AntonS Posted May 19, 2010 Author Posted May 19, 2010 дык дергается bgp сессия из-за этого то что будут появлятся и хрен сним главное чтобы bgp не калбасило от подключений\отключений к брасу Вставить ник Quote
AntonS Posted May 20, 2010 Author Posted May 20, 2010 есть мысли как завести такой комбайн? mpd5+quagga(bgp+ospf)? Вставить ник Quote
AntonS Posted May 20, 2010 Author Posted May 20, 2010 да он и был отделен щас вернулся к старой схеме выбил у магистралов сети /29 под bgp взаимодействие поставил по гигабитному свичу на каждого магистрала и туда впн сервера повтыкать хотел если бы недергание bgp сессии от подключений\отключений клиентов было бы все красиво либо искать как так сделать чтобы bgp сессию не передергивало Вставить ник Quote
jab Posted May 20, 2010 Posted May 20, 2010 отделить бордер от браса. Комбайнёрам такое не советуют... ;-))) Вставить ник Quote
AntonS Posted May 20, 2010 Author Posted May 20, 2010 надо будет попробовать с lo0 пишут что если на этот интерфейс повесить алиасом шлюз для p2p соединений то bgp не калбасит Вставить ник Quote
AntonS Posted May 20, 2010 Author Posted May 20, 2010 https://bugzilla.quagga.net/show_bug.cgi?id=572 Вставить ник Quote
