Имею локалку, где то с 1000 вечернего онлайна.
Стоит в сети DNS сервер, его задача всего лиш резолвить ДНС имена в локальные IP. Резолв всех остальных ДНС имен нельзя делать.
И грузит этот бинд9 CPU на 10-25% + ему на пару столько ко же съедает rsyslogd.
syslog растет со страшной скоростью, содержит примерно вот это
Mar 11 22:13:06 web named[2438]: client 172.16.120.98#9522: query (cache) 'www.ristex.jp/A/IN' denied
Mar 11 22:13:06 web named[2438]: client 172.16.112.62#2481: query (cache) 'dnl-04.geo.kaspersky.com/A/IN' denied
Mar 11 22:13:06 web named[2438]: client 172.16.100.74#65028: query (cache) 'dnl-00.geo.kaspersky.com/A/IN' denied
Mar 11 22:13:06 web named[2438]: client 172.16.112.62#2482: query (cache) 'dnl-05.geo.kaspersky.com/A/IN' denied
Mar 11 22:13:06 web named[2438]: client 172.16.112.62#2483: query (cache) 'dnl-06.geo.kaspersky.com/A/IN' denied
Mar 11 22:13:06 web named[2438]: client 172.16.120.98#27119: query (cache) 'avdesk.net.ua/A/IN' denied
named.conf.options содержит вот это
options {
directory "/var/cache/bind";
listen-on {172.16.0.1;localhost;};
version "Bind";
allow-query {172.16.0.0/16;localhost;};
allow-recursion {localhost;};
allow-transfer {none;};
// from bind 9:
// [fetch-glue] is obsolete. In BIND 8, fetch-glue yes caused the
// server to attempt to fetch glue resource records it didn't have
// when constructing the additional data section of a response.
// This is now considered a bad idea and BIND 9 never does it.
//fetch-glue no;
// If there is a firewall between you and nameservers you want
// to talk to, you might need to uncomment the query-source
// directive below. Previous versions of BIND always asked
// questions using port 53, but BIND 8.1 and later use an unprivileged
// port by default.
// query-source address * port 53;
// If your ISP provided one or more IP addresses for stable
// nameservers, you probably want to use them as forwarders.
// Uncomment the following block, and insert the addresses replacing
// the all-0's placeholder.
//forwarders {
// 192.168.64.1;
// 212.67.2.2;
// auth-nxdomain no;
ядро Linux version 2.6.26-2-amd64 (Debian 2.6.26-21lenny3) (dannf@debian.org) (gcc version 4.1.3 20080704 (prerelease) (Debian 4.1.2-25))
Вот в чем тут фишка? ни за что не поверю, что это норм загрузка CPU
И ещё
top
top - 23:10:46 up 57 min, 1 user, load average: 0.44, 0.43, 0.31
Tasks: 102 total, 1 running, 101 sleeping, 0 stopped, 0 zombie
Cpu(s): 2.9%us, 2.4%sy, 0.0%ni, 94.3%id, 0.0%wa, 0.3%hi, 0.2%si, 0.0%st
Mem: 4054356k total, 1068836k used, 2985520k free, 28448k buffers
Swap: 11880028k total, 0k used, 11880028k free, 803224k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
9169 bind 20 0 183m 11m 2312 S 23 0.3 3:26.36 named
2412 root 20 0 181m 1908 916 S 5 0.0 5:19.02 rsyslogd
1 root 20 0 10312 748 620 S 0 0.0 0:00.64 init
2 root 15 -5 0 0 0 S 0 0.0 0:00.00 kthreadd
3 root RT -5 0 0 0 S 0 0.0 0:00.00 migration/0
4 root 15 -5 0 0 0 S 0 0.0 0:00.02 ksoftirqd/0
5 root RT -5 0 0 0 S 0 0.0 0:00.00 watchdog/0
6 root RT -5 0 0 0 S 0 0.0 0:00.00 migration/1
7 root 15 -5 0 0 0 S 0 0.0 0:00.22 ksoftirqd/1
8 root RT -5 0 0 0 S 0 0.0 0:00.00 watchdog/1
9 root 15 -5 0 0 0 S 0 0.0 0:00.42 events/0
10 root 15 -5 0 0 0 S 0 0.0 0:00.48 events/1
11 root 15 -5 0 0 0 S 0 0.0 0:00.00 khelper
46 root 15 -5 0 0 0 S 0 0.0 0:00.10 kblockd/0
47 root 15 -5 0 0 0 S 0 0.0 0:00.04 kblockd/1
49 root 15 -5 0 0 0 S 0 0.0 0:00.00 kacpid
50 root 15 -5 0 0 0 S 0 0.0 0:00.00 kacpi_notify
131 root 15 -5 0 0 0 S 0 0.0 0:00.00 ksuspend_usbd
137 root 15 -5 0 0 0 S 0 0.0 0:00.00 khubd
140 root 15 -5 0 0 0 S 0 0.0 0:00.00 kseriod
185 root 20 0 0 0 0 S 0 0.0 0:00.00 pdflush
186 root 20 0 0 0 0 S 0 0.0 0:00.56 pdflush
187 root 15 -5 0 0 0 S 0 0.0 0:00.00 kswapd0
188 root 15 -5 0 0 0 S 0 0.0 0:00.00 aio/0
189 root 15 -5 0 0 0 S 0 0.0 0:00.00 aio/1
825 root 15 -5 0 0 0 S 0 0.0 0:00.00 ata/0
826 root 15 -5 0 0 0 S 0 0.0 0:00.00 ata/1
827 root 15 -5 0 0 0 S 0 0.0 0:00.00 ata_aux
837 root 15 -5 0 0 0 S 0 0.0 0:00.00 scsi_eh_0
838 root 15 -5 0 0 0 S 0 0.0 0:00.00 scsi_eh_1
944 root 15 -5 0 0 0 S 0 0.0 0:01.32 kjournald
1020 root 16 -4 16916 1124 484 S 0 0.0 0:00.10 udevd
1566 root 15 -5 0 0 0 S 0 0.0 0:00.00 kpsmoused
1749 root 15 -5 0 0 0 S 0 0.0 0:00.00 kjournald
2423 root 20 0 3796 596 476 S 0 0.0 0:00.00 acpid
2458 root 20 0 48864 1168 664 S 0 0.0 0:00.00 sshd
2498 root 20 0 17312 1444 1156 S 0 0.0 0:00.00 mysqld_safe
2535 mysql 20 0 243m 55m 6160 S 0 1.4 0:38.66 mysqld
2536 root 20 0 3780 596 496 S 0 0.0 0:00.00 logger
2856 Debian-e 20 0 42716 1012 612 S 0 0.0 0:00.00 exim4
2868 ntp 20 0 22380 1420 1016 S 0 0.0 0:00.00 ntpd
2880 proftpd 20 0 99.3m 1940 612 S 0 0.0 0:00.02 proftpd
2900 root 20 0 19832 1048 812 S 0 0.0 0:00.04 cron
2931 root 20 0 3796 580 484 S 0 0.0 0:00.00 getty
2932 root 20 0 3796 580 484 S 0 0.0 0:00.00 getty
2933 root 20 0 3796 580 484 S 0 0.0 0:00.00 getty
2934 root 20 0 3796 576 484 S 0 0.0 0:00.00 getty
2935 root 20 0 3796 580 484 S 0 0.0 0:00.00 getty
2936 root 20 0 3796 580 484 S 0 0.0 0:00.00 getty
2953 root 20 0 66068 3120 2476 S 0 0.1 0:00.78 sshd
3366 root 20 0 18748 1824 1356 S 0 0.0 0:00.00 bash
3372 root 20 0 32288 3384 2024 S 0 0.1 0:04.02 mc
3374 root 20 0 18816 1960 1436 S 0 0.0 0:00.44 bash
Что то тут не правильно, а что?
А каков великий смысл запрещать рекурсию, если, судя по потоку запросов, он указан как ресолвер у клиентов ? А если так и надо, то оторвите ему легирование данной ситуации. Кстати, при таком конфиге, если в кеше уже есть A запись для nl-04.geo.kaspersky.com, то 172.16.0.0/16 ее получат из кеша. Вы им запретите тогда и кеш. Ну и вообще поднимите зону . с
* IN A 127.0.0.1 унутре И прицепите ее во вью, отдающуюся 172.16.0.0/16
Попробуйте отключить логирование и посмотреть, как это повлияет на загрузку.
Погасил rsyslogd, да, он более не грузит CPU )))
а named по прежнему 20% (
Как в конфиге bind9 выключить лог? или хотя бы сделать его кратким.
Великий смысл в том, что инет ходит по пппое, а этот как локальный ДНС, ну чтоб оф. сайт работал, чат, торрент и прочее.
Как ему "легирование данной ситуации" ?
Как кеш запретить?
named.conf
// This is the primary configuration file for the BIND DNS server named.
// Please read /usr/share/doc/bind/README.Debian for information on the
// structure of BIND configuration files in Debian for BIND versions 8.2.1
// and later, *BEFORE* you customize this configuration file.
include "/etc/bind/named.conf.options";
// reduce log verbosity on issues outside our control
//logging {
// category lame-servers { null; };
// category cname { null; };
// prime the server with knowledge of the root servers
//zone "." {
// type hint;
// file "/etc/bind/db.root";
// be authoritative for the localhost forward and reverse zones, and for
// broadcast zones as per RFC 1912
zone "localhost" {
type master;
file "/etc/bind/db.local";
zone "127.in-addr.arpa" {
type master;
file "/etc/bind/db.127";
zone "0.in-addr.arpa" {
type master;
file "/etc/bind/db.0";
zone "255.in-addr.arpa" {
type master;
file "/etc/bind/db.255";
Ну и другие зоны удалёны, мало ли кто тут ходит...
include "/etc/bind/named.conf.local";
содержание db.127
; BIND reverse data file for local loopback interface
$TTL 604800
@ IN SOA localhost. root.localhost. (
2 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
604800 ) ; Negative Cache TTL
@ IN NS localhost.
1.0.0 IN PTR localhost.
Вот.
Yaten, здесь посмотрите: http://www.zytrax.com/books/dns/ch7/logging.html
Ок, спасибо. гугль что то мне не показал эту статью.... наверно не так искал.
Добавил в named.conf.options
logging{
channel null {
file "/var/log/named/bind.log" versions 3 size 5m;
severity 0;
print-time no;
print-severity no;
print-category no;
category default{
null;
syslog так и растет, теми же записями.
Ниче не пойму.
Поставьте nsd, там ни рекурсии ни кеша вообще нет и по производительности он хорош.
PS:Уберите channel null и
category queries { null; };
category config { null; };
category database { null;};
category default { null;};
category general {null;};
category notify { null;};
Edited by 2c2i
Получилось
logging{
category default{null; };
Ничего не изменилось
Включение/выключение логирования запросов делается командой rndc querylog. Включите/выключите и посмотрите загрузку. rsyslog убивать не правильно
Edited by s.lobanov
named.conf.options
options {
version "Bind";
//allow-transfer {none;};
allow-query-cache{localhost;};
// from bind 9:
//fetch-glue no;
// port by default.
//forwarders {
// 192.168.64.1;
// 212.67.2.2;
logging{
category security { null; };
В результате имею rsyslogd систему более не грузит, лог не растет, что уже не плохо.
но named по прежнему грузит до 50% CPU.
У кого, какие идеи ещё будут?
Просто отключать логи глупо, т.к. нужно устранять причины. Должно быть allow-recursion {172.16.0.0/16; localhost;}; Либо разрешите рекурсию на этом сервере (нужен белый IP), либо делайте forwarding на DNS вышестоящего провайдера. Еще стоит убедиться, что на сервере resolv.conf настроен на разрешение через себя, т.е. должно быть nameserver 127.0.0.1.
Edited by photon
если вы читали тему, то в ней написано, что рекурсии быть не должно.
Но клиенты по факту долбят ваш DNS именно запросами, требующими рекурсии (разрешение имен серверов из других сетей). Она у вас запрещена, клиенты продолжают делать запросы, и вы имеете мусор в логах. Нужно резать сами запросы на разрешение любых внешних имен, а не просто запрещать рекурсию.
Edited by photon
Повторяю ещё раз. этот ДНС сидит в локальной сети, и раздаётся всем по ДХЦП. Он нужен для резолва локальных ДНС имен в локальные ip адреса. Резолвить интернетовские ДНС имена он не должен, в противном случае получается дыра в системе безопастности, а именно появляется возможность установки DNS тунеля.
Клиенты ходят в интернет по ПППоЕ, и у тех, у кого в данный момент интернет не подключен - ясен пень ломятся запросами на локальный. И этот локальный должен дать отлуп всем запросам кроме pupkin.ru и всем ДНС именам 3го уровня из этого домена например.
Резать и запрещать в моём понимание - тождественно и этим должен заниматься bind.
Странная причина. И много у вас клиентов, желающих ходить в Интернет через DNS-туннели? Много ли вообще знающих что такое DNS и туннели?
Судя по логам в понимании авторов bind это не так. Вы запрещаете рекурсивное разрешение запросов, а не говорите bind-у, что нужно отбрасывать любые запросы на разрешение внешних имен. Поищите в документации какие-то другие ACL на эту тему. Если таких нет, то сервер можно настроить так, чтобы все внешние домены разрешались на какой-то тупой адрес вроде 127.0.0.1. В конце концов можно резать запросы с помощью iptables и модуля string. Edited by photon
В понимании бинда есть blackhole. Но автору оно не подойдет. Бинд вообще будет игнорировать запросы оттуда. А автору нужно туда отвечать на свои зоны. Можно попробовать сделать вью, где описать зону рут - пустую и свои зоны, запретить рекурсию итд. И ее привязать в 172 сети. Скорее всего нагрузку снизит. но чтобы до 0, врядли. Скорее всего искать DNS полегче надо. Который вообще не умеет рекурсию.
А сколько вообще запросов ? С кажем в минуту ? (еще неплохо бы проверить что за запросы, если 99% от 1% абонентов и это запросы MXов, то их нужно как то лечить...)
Расскажите поподробнее, как это сделать в бинде
Сейчас попробовал создать фейковую зону "." с соответствующими записями -- не получилось. Лучше действительно поднять вместо bind какой-то простой authoritative-only nameserver, типа tinydns, который в принципе не умеет делать рекурсию.
Edited by photon
попробывал iptables-om
iptables -A INPUT -i eth0 -p udp --dport 53 -m string --algo kmp --string '1.0.16.172.in-addr.arpa' -j RETURN
iptables -A INPUT -i eth0 -p udp --dport 53 -m string --algo kmp --string 'pupkin.ru' -j RETURN
iptables -A INPUT -i eth0 -p udp --dport 53 -j DROP
он все ДНС порезал. наверно строку не правильно вписал... кто как думает? --algo пробывал bm и kmp, одинаково все.
посмотрел счетчики, под правила
пакеты не попадают
глюк найден, в адресе pupkin.ru точка не обрабатывается. удалил её и правило начало срабатывать
iptables -A INPUT -i eth0 -p udp --dport 53 -m string --algo kmp --string 'in-addr' -j ACCEPT
iptables -A INPUT -i eth0 -p udp --dport 53 -m string --algo kmp --string 'pupkin' -j ACCEPT
И все левые запросы порезаны.
Загрузка CPU bind-ом 0-2%
