Возникла проблема. 3 раза за сутки упал mpd c аналогичными симптомами. до этого работал с этим конфигом более 4-х месяцев
в чем может быть проблемка? куды копать?
логи и конфиг прилагаю ниже.
версия mpd 5.2, версия фри 7.1
конфиг мпд:
startup:
# enable TCP-Wrapper (hosts_access(5)) to block unfriendly clients
set global enable tcp-wrapper
# configure mpd users
set user admin bgggg
# configure the console
set console self 195.xx.xxx.xxx 5005
set console open
# configure the web server
# set web self 172.16.1.8 5006
set web open
# configure netflow
set netflow peer 195.xxx.xxx.xxx 9996
default:
set ippool add pool1 192.168.242.1 192.168.247.254
create bundle template B
set bundle enable compression
set ccp yes mppc
set mppc yes compress
set mppc yes e40
set mppc yes e56
set mppc yes e128
set mppc yes stateless
set iface idle 0
set iface mtu 1460
set iface enable tcpmssfix
set iface disable on-demand
set iface enable netflow-in
set iface enable netflow-out
set iface up-script /usr/local/etc/mpd5/scripts/pptp_up.sh
set iface down-script /usr/local/etc/mpd5/scripts/pptp_down.sh
set iface enable proxy-arp
set ipcp yes vjcomp
set ipcp dns 10.xxx.xxx.xxx 10.xxx.xxx.xxx
set ipcp ranges 192.168.255.254/32 ippool pool1
create link template L pptp
set link action bundle B
set link disable multilink
set link yes acfcomp protocomp
set link no pap chap
set link enable chap-md5
set link enable chap-msv2
set link enable chap-msv1
set link keep-alive 60 180
set link mtu 1460
set link mru 1460
set link enable incoming
set pptp disable windowing
set radius server 127.0.0.1 gthbvtnh 1812 1813
set radius retries 3
set radius timeout 8
set radius me 195.xxx.xxx.235
set auth enable radius-auth
# set auth enable radius-acct
[\CODE]
лог:
[code]
Mar 26 17:01:42 gw1 mpd: [L-26] LCP: protocol 0xfd92 was rejected
Mar 26 17:01:42 gw1 mpd: [L-26] LCP: rec'd Protocol Reject #12 (Req-Sent)
Mar 26 17:01:42 gw1 mpd: [L-30] LCP: rec'd Protocol Reject #45 (Req-Sent)
Mar 26 17:01:42 gw1 mpd: [L-30] LCP: protocol 0xfd92 was rejected
Mar 26 17:01:42 gw1 mpd: [L-30] LCP: rec'd Protocol Reject #46 (Req-Sent)
Mar 26 17:01:42 gw1 mpd: [L-28] CHAP: Auth return status: authenticated
Mar 26 17:01:42 gw1 mpd: [L-28] CHAP: Reply message: S=CF3858110EEC81305A48FCE6C7C96EED20748C6A
Mar 26 17:01:42 gw1 mpd: [L-28] CHAP: sending SUCCESS #1 len: 46
Mar 26 17:01:42 gw1 mpd: [L-28] LCP: authorization successful
Mar 26 17:01:42 gw1 mpd: [L-28] Link: Matched action 'bundle "B" ""'
Mar 26 17:01:42 gw1 mpd: [L-28] Creating new bundle using template "B".
Mar 26 17:01:42 gw1 mpd: [b-4] Bundle: Interface ng3 created
Mar 26 17:01:42 gw1 mpd: [L-28] Link: Join bundle "B-4"
Mar 26 17:01:42 gw1 mpd: [b-4] Bundle: Status update: up 1 link, total bandwidth 64000 bps
Mar 26 17:01:42 gw1 mpd: [b-4] IPCP: Open event
Mar 26 17:01:42 gw1 mpd: [b-4] IPCP: state change Initial --> Starting
Mar 26 17:01:42 gw1 mpd: [b-4] IPCP: LayerStart
Mar 26 17:01:42 gw1 mpd: [b-4] CCP: Open event
Mar 26 17:01:42 gw1 mpd: [b-4] CCP: state change Initial --> Starting
Mar 26 17:01:42 gw1 mpd: [b-4] CCP: LayerStart
Mar 26 17:01:42 gw1 mpd: [b-4] IPCP: Up event
Mar 26 17:01:42 gw1 mpd: [b-4] IPCP: state change Starting --> Req-Sent
Mar 26 17:01:42 gw1 mpd: [b-4] IPCP: SendConfigReq #1
Mar 26 17:01:42 gw1 mpd: [b-4] IPADDR 192.168.255.254
Mar 26 17:01:42 gw1 mpd: [b-4] COMPPROTO VJCOMP, 16 comp. channels, no comp-cid
Mar 26 17:01:42 gw1 mpd: [b-4] CCP: Up event
Mar 26 17:01:42 gw1 mpd: [b-4] CCP: state change Starting --> Req-Sent
Mar 26 17:01:42 gw1 mpd: [b-4] CCP: SendConfigReq #1
Mar 26 17:01:42 gw1 mpd: [b-4] MPPC
Mar 26 17:01:42 gw1 mpd: [b-4] 0x010000e0:MPPE(40, 56, 128 bits), stateless
Mar 26 17:01:42 gw1 mpd: [L-6] rec'd proto IPCP during authenticate phase
Mar 26 17:01:42 gw1 mpd: [L-3] rec'd proto IPCP during establishment phase
Mar 26 17:01:42 gw1 mpd: [L-3] LCP: rec'd Protocol Reject #53 (Ack-Sent)
Mar 26 17:01:42 gw1 mpd: [L-3] LCP: protocol CCP was rejected
Mar 26 17:01:42 gw1 mpd: [L-6] LCP: rec'd Protocol Reject #74 (Opened)
Mar 26 17:01:42 gw1 mpd: [L-6] LCP: protocol CCP was rejected
Mar 26 17:01:42 gw1 mpd: caught fatal signal segv
Mar 26 17:01:42 gw1 mpd: fatal error, exiting
Mar 26 17:01:42 gw1 mpd: [b-1] IFACE: Close event
Mar 26 17:01:42 gw1 mpd: [b-1] IPCP: Close event
Mar 26 17:01:42 gw1 mpd: [b-1] IPCP: state change Opened --> Closing
Mar 26 17:01:42 gw1 mpd: [b-1] IPCP: SendTerminateReq #2
Mar 26 17:01:42 gw1 mpd: [b-1] IPCP: LayerDown
Mar 26 17:01:42 gw1 mpd: [b-1] IFACE: Down event
Mar 26 17:01:42 gw1 mpd: [b-1] CCP: Close event
Mar 26 17:01:42 gw1 mpd: [b-1] CCP: state change Stopped --> Closed
Mar 26 17:01:42 gw1 mpd: [b-2] IFACE: Close event
Mar 26 17:01:42 gw1 mpd: [b-2] IPCP: Close event
Mar 26 17:01:42 gw1 mpd: [b-2] IPCP: state change Opened --> Closing
Mar 26 17:01:42 gw1 mpd: [b-2] IPCP: SendTerminateReq #2
Mar 26 17:01:42 gw1 mpd: [b-2] IPCP: LayerDown
Mar 26 17:01:42 gw1 mpd: [b-2] IFACE: Down event
Mar 26 17:01:42 gw1 mpd: [b-2] CCP: Close event
Mar 26 17:01:42 gw1 mpd: [b-2] CCP: state change Stopped --> Closed
Mar 26 17:01:42 gw1 mpd: [b-3] IFACE: Close event
Mar 26 17:01:42 gw1 mpd: [b-3] IPCP: Close event
[\CODE]
Edited by Denis Samsonov
PF включён?
(self) макрос используется?
Если оба да, то вы не одиноки :)
nas1# cat mpd.conf | grep self
set console self 10.1.1.2 5005
set web self 127.0.0.1 5006
set netflow self 10.1.1.2 8788
set pptp self 10.1.1.2
PF используется только в качестве ната. файрволом и шейпером служит ipfw + dummynet
+1, правда на последней
nas1# uname -a
FreeBSD nas1 7.1-RELEASE-p4 amd64
у Меня какие-то грабли были...Пользователи через нат нормально в нете сидят, а в онлайн игры играть не могут... Я посмотрел tcpdumpom, udp ходит сервер_онлайн_игры - мой_сервер, запрос_от_клиента мой_сервер, ответа нет... Попробовал просто дать Инет напрямую не через ВПН - онлайн игры тоже не работали :) И самое интересное - Я не знаю они вообще на 7.1 работали у Меня когда-то?...В общем ушел к ipfw-kernel-nat. И mpd5.2 перестал случайно падать...Вернее эта сволота не падала...просто повиснет - не убить, помогает только ребут...
nas1# cat /etc/pf.conf|grep -v #
ext_if="vlan20"
ext_if2="em0"
int_if="vr0"
table <local> { !192.168.0.0/16, !172.16.0.0/12, !10.0.0.0/8 }
table <inat> { 10.200.24.6 }
table <ext_ip> { 172.19.19.2,192.168.1.2 }
scrub in #включал, отключал - одын фыг
set skip on lo0
nat on $ext_if from <inat> -> {$ext_if:0}
pass all
Edited by weldpua2008
Повисший намертво mpd - вроде как древняя байка. Глебиус отзывался дурно о нетграфе, говорил, что будут править. До сих пор, что ли нетграф вешается?
Вешался mpd... Звонят Мне, говорят ошибка 800 у пользователей, Я на сервер, там висит процесс...киляю - не киляется...подождал... пришлось перезапускать...
Именно так. Но то давно было. Я уже там не работаю, так, дома поковыриваю фряху слегка. А тогда не поленился на руснет к Глебу на поклон сходить, разузнать что да как. Сказал тогда, что в нетграфе косяки, отлавливают здоровенным бреднем. По идее, уже к 6.1 должны были поправить.
Кстати, тогда не только mpd не килялся, модуль с ядра не выгонялся. Совсем, даже метлой (-f).
Кажется создавал топик.
У меня сервер из за мпд вешается намерво, в ситуации когда:
мпд конектит к инету по пппое
далее когда с инета клиент конектится по пптп к этому серверу то сервер перестаёт отвечать на всё...
Всё что было приконекчино к серверу отваливается, идёт только транзит в/с инета.
3 НАСа с mpd4.4.1 + freebsd7.0 работают идеально (юзаем pptp+ng_car) по 500 сессий он-лайн на каждом.
Как только на одном из них попробовали mpd5.2, получили тот же результат, что и weldpua2008. С тех пор не вижу причин для перехода на mpd5.2.
3 сервера на freebsd 7.1 + mpd 5.2 + ng_car + yandex em driver- все ок. Да, возился недели три, но сейчас проблем нет.
какое кол-во онлайн ?
у меня 5.2 виснет на 7.0,7.1 , сейчас пробую откатиться до mpd4.4.1
все симтомы описаны здесь и здесь
У меня тоже виснет , причем може при 200 сессий зависнуть а может и при 500 сессий. Система такая FreeBSD 7.1 , MPD 5.2 , IPFW, IPNAT , шэйпинг.
Причина зависания говорят в DUMMYNET.
Есть патч http://www.freebsd.org/cgi/cvsweb.cgi/src/...t/ip_dummynet.c
Может кто патчил, помогает ??
От 800 до 2000. Dummynet пока не использую. Шейпинг на ng_car.
Проблемы с зависаниями были, пока не убрал весь тюнинг. Кроме того, надо отключить devd.
по какой причине devd отключать ?
тюнинг сброшен по умолчанию системы ?
1. С devd с поднятых ng интерфейсов теряются айпи. Трафик не ходит, соединения подвисают. Лечится отключением devd. Дальше не копал.
2. Тюнинг нужен только самый общий. Если интересно могу привести конфиг.
3. Заметил еще одну проблему - при включенном net.isr.direct=1 и em драйверами от Yandexa - mpd периодически уходит в ступор.
4. NAT не использую в принципе. Отказались очень давно.
5. 3 сервера на freebsd 7.1 + mpd 5.2 + ng_car + yandex em driver. Все сервера близнецы браться 2хXeon 5405/4 Gb RAM/
devd отключали полностью? Или както конфигурили?
На счет тюнинга- приведите конфиг пожалуйста.
Edited by alexcom
Сегодня ночью перешел с Яндекс драйверов на поллинг
rc.conf - devd_enable="NO"
/etc/sysctl.conf
kern.ipc.somaxconn=16384        # ограничивает размер очереди для приема новых TCP соединений
net.inet.ip.fw.one_pass=0       # после пайпа опять возвращаться на следующее правило фаервола
net.inet.tcp.log_in_vain=0      # писать в логи, когда обращаются к портам без сервисов
net.inet.udp.log_in_vain=0      # писать в логи, когда обращаются к портам без сервисов
net.inet.udp.blackhole=0
net.inet.tcp.blackhole=0        # если 1, то SYN пакеты пришедшие на порты для которых нет
                                # активных сервисов, остаются без RST ответа, если 2,
                                # то на любые пакеты нет ответа (затрудняет сканирования портов
net.inet.tcp.nolocaltimewait=1  # не создания состояния TIME_WAIT для соединений в рамках localhost:
net.inet.tcp.sendspace=65535
net.inet.tcp.recvspace=65535
net.inet.ip.fw.autoinc_step=10
net.inet.ip.fastforwarding=1
net.isr.direct=1
net.inet.ip.rtmaxcache=16384
net.inet.ip.portrange.first=1024
net.inet.ip.portrange.last=65535
net.inet.ip.portrange.randomized=0
net.inet.tcp.syncookies=1
net.inet.ip.fw.verbose=1
net.inet.ip.fw.verbose_limit=5
net.inet.raw.maxdgram=65535
net.inet.raw.recvspace=65535
net.inet.icmp.icmplim=4000
net.inet.ip.intr_queue_maxlen=16384
net.route.netisr_maxqlen=16384
net.inet.tcp.rfc1323=1
#Polling
kern.polling.user_frac=10
kern.polling.idle_poll=1
kern.polling.each_burst=1000
kern.polling.burst_max=1000
dev.em.0.rx_int_delay=600
dev.em.0.tx_int_delay=600
dev.em.0.rx_abs_int_delay=1000
dev.em.0.tx_abs_int_delay=1000
dev.em.0.rx_processing_limit=4096
dev.em.1.rx_int_delay=600
dev.em.1.tx_int_delay=600
dev.em.1.rx_abs_int_delay=1000
dev.em.1.tx_abs_int_delay=1000
dev.em.1.rx_processing_limit=4096
# http://markmail.org/message/wpumnm2phciyhm7x#query:ngctl%3A%20send%20msg%3A%20No%20buffer%20space%20available+page:1+mid:vzjv2nuk3oiqyuqt+state:results
kern.ipc.maxsockbuf=8388608
net.graph.maxdgram=4194304
net.graph.recvspace=4194304
/boot/loader.conf
kern.maxusers=1024
kern.maxfiles=4096000
kern.maxfilesperproc=200000
ng_car_load="YES"
hw.em.rxd=4096
hw.em.txd=4096
kern.ipc.nmbclusters=524288
kernel="kernel.smp.pol"
Собственно все.
Но на этом сервере присутствует проблема с swi: net 100% загрузки....
Пока разбираюсь.
Edited by McLaut
Разгадка: сделать kern.polling.idle_poll=0 и никогда не включать обратно. Кроме того, параметры dev.em. имеют смысл только если используются прерывания, поллингу они ортогональны. Если это маршрутизатор, то незачем тюнить параметры буферов tcp, сокетов и открытых файлов. Он работает только с IP, а не принимает TCP-соединения.
Edited by photon
Вообщем отключал devd, ставил mpd 5.3 (после 5.2).
Система- 7.1. (7.0, 6.4), amd64, SMP. pfnat+ipfw+dummynet. (Также пробовал ipfw nat в 7.х).
Пробовал и споллингом и без. Пробовал сетевые em (re,vr). (Для em пробовал и поллинг и драйвера от Яндекса).
Также менялась вся аппаратная часть, дабы исключить глюки с железом.
Все равно через 8-10 часов система падает.
Видимо прийдется и дальше на poptop'e сидеть..
Edited by alexcom
kern.polling.idle_poll=0 не отключает polling насовсем, а просто не делает его внутри CPU idle loop. Поллинг включается и отключается на сетевых интерфейсах c помощью ifconfig. Можно перепробовать все, что угодно, и не получать никаких результатов только из-за непонимания того, что делаешь.
