Просидел неделю не могу клиента и сервер соединить
route на сервере
root@r:~# route
Kernel IP routing table server
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
default         ser.mshome.net  0.0.0.0         UG    100    0        0 eth0
192.168.0.0     0.0.0.0         255.255.255.0   U     100    0        0 eth0
192.168.1.0     0.0.0.0         255.255.255.0   U     101    0        0 eth1
ip server 192.168.1.2, ip clenta 192.168.1.1
client
192.168.1.0     *               255.255.255.0   U     0      0        0 br-lan
root@client:~#
root@r:/etc/init.d# exportfs -rav
exporting *:/home/nfs4
root@r:/etc/init.d#
root@r:/etc/init.d# showmount -e 192.168.1.2
Export list for 192.168.1.2:
/home/nfs4 *
/home/nfs  *
root@r:/etc/init.d# showmount -e 192.168.1.1
clnt_create: RPC: Unable to receive
запустил в ручную portmap
clnt_create: RPC: Program not registered
с стороны клиента
root@client:/usr/sbin# showmount -e 192.168.1.1
root@client:/usr/sbin# showmount -e 192.168.1.2
/home/nfs4 *
/home/nfs  *
файл hosts на клиенте
root@client:/etc# cat hosts
127.0.0.1 localhost
192.168.1.1 client
192.168.1.2 r
на сервере
127.0.0.1    localhost
#127.0.1.1    r
192.168.1.2     r
192.168.1.1     client
# The following lines are desirable for IPv6 capable hosts
::1     localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
запуск на сервере
root@r:/etc/init.d# mount -t nfs4 -o nolock 192.168.1.1:/home/nfs4/ /home/nfs4/ -vvv
mount.nfs4: timeout set for Mon Oct 21 16:33:57 2019
mount.nfs4: trying text-based options 'nolock,vers=4.2,addr=192.168.1.1,clientaddr=192.168.1.2'
mount.nfs4: mount(2): Connection refused
mount.nfs4: trying text-based options 'nolock,addr=192.168.1.1'
mount.nfs4: prog 100003, trying vers=3, prot=6
mount.nfs4: portmap query retrying: RPC: Program not registered
mount.nfs4: prog 100003, trying vers=3, prot=17
mount.nfs4: portmap query failed: RPC: Program not registered
mount.nfs4: requested NFS version or transport protocol is not supported
запуск на клиенте
root@client:/sbin# mount -t nfs4 -o nolock 192.168.1.2:/home/nfs4/ /home/nfs4/ -
vvv
mount.nfs4: No such device
mount: mounting 192.168.1.2:/home/nfs4/ on /home/nfs4/ failed: No such device
root@client:/sbin# mount.nfs4 -o nolock 192.168.1.2:/home/nfs4/ /home/nfs4/ -vvv
mount.nfs4: timeout set for Thu Sep  8 17:41:11 2011
mount.nfs4: trying text-based options 'nolock,addr=192.168.1.2,clientaddr=192.168.1.1'
mount.nfs4: mount(2): No such device
root@r:/etc/init.d# rpcinfo
   program version netid     address                service    owner
    100000    4    tcp6      ::.0.111               portmapper superuser
    100000    3    tcp6      ::.0.111               portmapper superuser
    100000    4    udp6      ::.0.111               portmapper superuser
    100000    3    udp6      ::.0.111               portmapper superuser
    100000    4    tcp       0.0.0.0.0.111          portmapper superuser
    100000    3    tcp       0.0.0.0.0.111          portmapper superuser
    100000    2    tcp       0.0.0.0.0.111          portmapper superuser
    100000    4    udp       0.0.0.0.0.111          portmapper superuser
    100000    3    udp       0.0.0.0.0.111          portmapper superuser
    100000    2    udp       0.0.0.0.0.111          portmapper superuser
    100000    4    local     /run/rpcbind.sock      portmapper superuser
    100000    3    local     /run/rpcbind.sock      portmapper superuser
    100005    1    udp       0.0.0.0.147.17         mountd     superuser
    100005    1    tcp       0.0.0.0.202.45         mountd     superuser
    100005    1    udp6      ::.237.156             mountd     superuser
    100005    1    tcp6      ::.151.11              mountd     superuser
    100005    2    udp       0.0.0.0.206.119        mountd     superuser
    100005    2    tcp       0.0.0.0.132.71         mountd     superuser
    100005    2    udp6      ::.222.149             mountd     superuser
    100005    2    tcp6      ::.169.71              mountd     superuser
    100005    3    udp       0.0.0.0.172.26         mountd     superuser
    100005    3    tcp       0.0.0.0.205.91         mountd     superuser
    100005    3    udp6      ::.199.204             mountd     superuser
    100005    3    tcp6      ::.199.175             mountd     superuser
    100003    3    tcp       0.0.0.0.8.1            nfs        superuser
    100003    4    tcp       0.0.0.0.8.1            nfs        superuser
    100003    3    udp       0.0.0.0.8.1            nfs        superuser
    100003    3    tcp6      ::.8.1                 nfs        superuser
    100003    4    tcp6      ::.8.1                 nfs        superuser
    100003    3    udp6      ::.8.1                 nfs        superuser
    100021    1    udp       0.0.0.0.217.191        nlockmgr   superuser
    100021    3    udp       0.0.0.0.217.191        nlockmgr   superuser
    100021    4    udp       0.0.0.0.217.191        nlockmgr   superuser
    100021    1    tcp       0.0.0.0.171.111        nlockmgr   superuser
    100021    3    tcp       0.0.0.0.171.111        nlockmgr   superuser
    100021    4    tcp       0.0.0.0.171.111        nlockmgr   superuser
    100021    1    udp6      ::.159.47              nlockmgr   superuser
    100021    3    udp6      ::.159.47              nlockmgr   superuser
    100021    4    udp6      ::.159.47              nlockmgr   superuser
    100021    1    tcp6      ::.163.9               nlockmgr   superuser
    100021    3    tcp6      ::.163.9               nlockmgr   superuser
    100021    4    tcp6      ::.163.9               nlockmgr   superuser
запуск на сервере
mount.nfs4: timeout set for Mon Oct 21 17:09:07 2019
root@r:/etc/init.d#
запуск с стороны клиента
root@r:/etc/init.d# nfsstat
Server rpc stats:
calls      badcalls   badfmt     badauth    badclnt
61         2          2          0          0
Server nfs v3:
null             getattr          setattr          lookup           access
4        16%     6        24%     0         0%     4        16%     2         8%
readlink         read             write            create           mkdir
0         0%     0         0%     0         0%     0         0%     0         0%
symlink          mknod            remove           rmdir            rename
link             readdir          readdirplus      fsstat           fsinfo
0         0%     0         0%     0         0%     3        12%     4        16%
pathconf         commit
2         8%     0         0%
Server nfs v4:
null             compound
2         5%     34       94%
Server nfs v4 operations:
op0-unused       op1-unused       op2-future       access           close
0         0%     0         0%     0         0%     2         2%     0         0%
commit           create           delegpurge       delegreturn      getattr
0         0%     0         0%     0         0%     0         0%     18       21%
getfh            link             lock             lockt            locku
2         2%     0         0%     0         0%     0         0%     0         0%
lookup           lookup_root      nverify          open             openattr
open_conf        open_dgrd        putfh            putpubfh         putrootfh
0         0%     0         0%     18       21%     0         0%     4         4%
read             readdir          readlink         remove           rename
renew            restorefh        savefh           secinfo          setattr
setcltid         setcltidconf     verify           write            rellockowner
bc_ctl           bind_conn        exchange_id      create_ses       destroy_ses
0         0%     0         0%     4         4%     2         2%     2         2%
free_stateid     getdirdeleg      getdevinfo       getdevlist       layoutcommit
layoutget        layoutreturn     secinfononam     sequence         set_ssv
0         0%     0         0%     2         2%     24       28%     0         0%
test_stateid     want_deleg       destroy_clid     reclaim_comp     allocate
0         0%     0         0%     2         2%     2         2%     0         0%
copy             copy_notify      deallocate       ioadvise         layouterror
layoutstats      offloadcancel    offloadstatus    readplus         seek
write_same
0         0%
Client rpc stats:
calls      retrans    authrefrsh
62         0          62
Client nfs v3:
2         8%     6        26%     0         0%     4        17%     2         8%
0         0%     0         0%     0         0%     3        13%     4        17%
pathconf         commit
2         8%     0         0%
Client nfs v4:
null             read             write            commit           open
5        12%     0         0%     0         0%     0         0%     0         0%
open_conf        open_noat        open_dgrd        close            setattr
fsinfo           renew            setclntid        confirm          lock
4        10%     0         0%     0         0%     0         0%     0         0%
lockt            locku            access           getattr          lookup
0         0%     0         0%     2         5%     2         5%     2         5%
lookup_root      remove           rename           link             symlink
2         5%     0         0%     0         0%     0         0%     0         0%
create           pathconf         statfs           readlink         readdir
0         0%     2         5%     0         0%     0         0%     0         0%
server_caps      delegreturn      getacl           setacl           fs_locations
6        15%     0         0%     0         0%     0         0%     0         0%
rel_lkowner      secinfo          fsid_present     exchange_id      create_session
0         0%     0         0%     0         0%     4        10%     2         5%
destroy_session  sequence         get_lease_time   reclaim_comp     layoutget
2         5%     0         0%     0         0%     2         5%     0         0%
getdevinfo       layoutcommit     layoutreturn     secinfo_no       test_stateid
0         0%     0         0%     0         0%     2         5%     0         0%
free_stateid     getdevicelist    bind_conn_to_ses destroy_clientid seek
allocate         deallocate       layoutstats      clone
0         0%     0         0%     0         0%     0         0%
root@r:/etc/init.d#
root@r:/etc/init.d# rpcinfo -p 192.168.1.2
   program vers proto   port  service
    100000    4   tcp    111  portmapper
    100000    3   tcp    111  portmapper
    100000    2   tcp    111  portmapper
    100000    4   udp    111  portmapper
    100000    3   udp    111  portmapper
    100000    2   udp    111  portmapper
    100005    1   udp  37649  mountd
    100005    1   tcp  51757  mountd
    100005    2   udp  52855  mountd
    100005    2   tcp  33863  mountd
    100005    3   udp  44058  mountd
    100005    3   tcp  52571  mountd
    100003    3   tcp   2049  nfs
    100003    4   tcp   2049  nfs
    100003    3   udp   2049  nfs
    100021    1   udp  55743  nlockmgr
    100021    3   udp  55743  nlockmgr
    100021    4   udp  55743  nlockmgr
    100021    1   tcp  43887  nlockmgr
    100021    3   tcp  43887  nlockmgr
    100021    4   tcp  43887  nlockmgr
root@r:/etc/init.d#
root@r:/etc/init.d# rpcinfo -p 192.168.1.1
root@client:/# rpcinfo -p 192.168.1.1
-ash: rpcinfo: not found
root@client:/# rpcinfo -p 192.168.1.2
root@client:/#
root@r:/etc/init.d#
root@client:/#
Edited by ffs1980.
/home/nfs/ *(ro,async,all_squash,no_subtree_check)
/home/nfs4/ *(ro,sync,all_squash,fsid=0,crossmnt,no_subtree_check)
    100005    1   udp  36364  mountd
    100005    1   tcp  44195  mountd
    100005    2   udp  43950  mountd
    100005    2   tcp  36787  mountd
    100005    3   udp  60716  mountd
    100005    3   tcp  39633  mountd
    100021    1   udp  43848  nlockmgr
    100021    3   udp  43848  nlockmgr
    100021    4   udp  43848  nlockmgr
    100021    1   tcp  41023  nlockmgr
    100021    3   tcp  41023  nlockmgr
    100021    4   tcp  41023  nlockmgr
root@r:/etc/init.d#
на клиенте
root@client:/usr/sbin# lsmod
Module                  Size  Used by    Tainted: G
nf_nat_irc               784  0
nf_conntrack_irc        2464  1 nf_nat_irc
nf_nat_ftp               976  0
nf_conntrack_ftp        4416  1 nf_nat_ftp
ipt_MASQUERADE           976  1
iptable_nat             2544  1
nf_nat                 10384  4 nf_nat_irc,nf_nat_ftp,ipt_MASQUERADE,iptable_nat
pppoe                   8240  0
xt_conntrack            2064  3
xt_CT                   1424  0
xt_NOTRACK               528  0
iptable_raw              560  1
xt_state                 608  0
nf_conntrack_ipv4       4464  6 iptable_nat,nf_nat
nf_defrag_ipv4           656  1 nf_conntrack_ipv4
nf_conntrack           40448 12 nf_nat_irc,nf_conntrack_irc,nf_nat_ftp,nf_conntrack_ftp,ipt_MASQUERADE,iptable_nat,nf_nat,xt_conntrack,xt_CT,xt_NOTRACK,xt_state,nf_conntrack_ipv4
pppox                   1152  1 pppoe
ipt_REJECT              1712  2
xt_TCPMSS               2528  0
ipt_LOG                 6064  0
xt_comment               400  0
xt_multiport            1104  0
xt_mac                   528  0
xt_limit                 992  0
iptable_mangle           816  1
iptable_filter           592  1
ip_tables               8880  4 iptable_nat,iptable_raw,iptable_mangle,iptable_filter
xt_tcpudp               1600  1
x_tables                9936 18 ipt_MASQUERADE,iptable_nat,xt_conntrack,xt_CT,xt_NOTRACK,iptable_raw,xt_state,ipt_REJECT,xt_TCPMSS,ipt_LOG,xt_comment,xt_multiport,xt_mac,xt_limit,iptable_mangle,iptable_filter,ip_tables,xt_tcpudp
ppp_async               7136  0
ppp_generic            19648  3 pppoe,pppox,ppp_async
slhc                    3984  1 ppp_generic
lockd                  56704  0
sunrpc                162752  1 lockd
hfs                    39232  0
ath5k                 143856  0
ath                    15376  1 ath5k
mac80211              264576  1 ath5k
nls_base                4688  1 hfs
crc_ccitt                944  1 ppp_async
exportfs                2608  0
cfg80211              155696  3 ath5k,ath,mac80211
compat                  5872  3 ath5k,mac80211,cfg80211
arc4                     768  2
aes_generic            31536  0
crypto_algapi           9264  2 arc4,aes_generic
nf_nat_irc               784  0
nf_nat_ftp               976  0
iptable_nat             2544  1
pppoe                   8240  0
xt_conntrack            2064  3
xt_CT                   1424  0
xt_NOTRACK               528  0
iptable_raw              560  1
xt_state                 608  0
pppox                   1152  1 pppoe
ipt_REJECT              1712  2
xt_TCPMSS               2528  0
ipt_LOG                 6064  0
xt_comment               400  0
xt_multiport            1104  0
xt_mac                   528  0
xt_limit                 992  0
xt_tcpudp               1600  1
ppp_async               7136  0
lockd                  56704  0
hfs                    39232  0
ath5k                 143856  0
ath                    15376  1 ath5k
nls_base                4688  1 hfs
exportfs                2608  0
arc4                     768  2
aes_generic            31536  0
Edited by ffs1980.
12 часов назад, ffs1980. сказал:
ошибка тут должна, но по интернету перелазил и не помогло.
Могу ошибаться, но обычно такая ошибка выдается юзерспейсу когда не загружен нужный модуль ядра Linux. Возможно у в вашей сборке OpenWRT небыли собраны все нужные модули ядра.
