ffs1980.
Новичок-
Публикации
5 -
Зарегистрирован
Посещение
О ffs1980.
Звание
Абитуриент
nfs clent openwrt -server debian(или ubutnu)
тему ответил в ffs1980. пользователя ffs1980. в Программное обеспечение, биллинг и *unix системы
/home/nfs/ *(ro,async,all_squash,no_subtree_check) /home/nfs4/ *(ro,sync,all_squash,fsid=0,crossmnt,no_subtree_check) root@r:/etc/init.d# rpcinfo -p 192.168.1.1 program vers proto port service 100000 2 tcp 111 portmapper 100000 2 udp 111 portmapper root@r:/etc/init.d# showmount -e 192.168.1.1 clnt_create: RPC: Program not registered root@r:/etc/init.d# rpcinfo -p 192.168.1.2 program vers proto port service 100000 4 tcp 111 portmapper 100000 3 tcp 111 portmapper 100000 2 tcp 111 portmapper 100000 4 udp 111 portmapper 100000 3 udp 111 portmapper 100000 2 udp 111 portmapper 100005 1 udp 36364 mountd 100005 1 tcp 44195 mountd 100005 2 udp 43950 mountd 100005 2 tcp 36787 mountd 100005 3 udp 60716 mountd 100005 3 tcp 39633 mountd 100003 3 tcp 2049 nfs 100003 4 tcp 2049 nfs 100003 3 udp 2049 nfs 100021 1 udp 43848 nlockmgr 100021 3 udp 43848 nlockmgr 100021 4 udp 43848 nlockmgr 100021 1 tcp 41023 nlockmgr 100021 3 tcp 41023 nlockmgr 100021 4 tcp 41023 nlockmgr root@r:/etc/init.d# на клиенте root@client:/usr/sbin# lsmod Module Size Used by Tainted: G nf_nat_irc 784 0 nf_conntrack_irc 2464 1 nf_nat_irc nf_nat_ftp 976 0 nf_conntrack_ftp 4416 1 nf_nat_ftp ipt_MASQUERADE 976 1 iptable_nat 2544 1 nf_nat 10384 4 nf_nat_irc,nf_nat_ftp,ipt_MASQUERADE,iptable_nat pppoe 8240 0 xt_conntrack 2064 3 xt_CT 1424 0 xt_NOTRACK 528 0 iptable_raw 560 1 xt_state 608 0 nf_conntrack_ipv4 4464 6 iptable_nat,nf_nat nf_defrag_ipv4 656 1 nf_conntrack_ipv4 nf_conntrack 40448 12 nf_nat_irc,nf_conntrack_irc,nf_nat_ftp,nf_conntrack_ftp,ipt_MASQUERADE,iptable_nat,nf_nat,xt_conntrack,xt_CT,xt_NOTRACK,xt_state,nf_conntrack_ipv4 pppox 1152 1 pppoe ipt_REJECT 1712 2 xt_TCPMSS 2528 0 ipt_LOG 6064 0 xt_comment 400 0 xt_multiport 1104 0 xt_mac 528 0 xt_limit 992 0 iptable_mangle 816 1 iptable_filter 592 1 ip_tables 8880 4 iptable_nat,iptable_raw,iptable_mangle,iptable_filter xt_tcpudp 1600 1 x_tables 9936 18 ipt_MASQUERADE,iptable_nat,xt_conntrack,xt_CT,xt_NOTRACK,iptable_raw,xt_state,ipt_REJECT,xt_TCPMSS,ipt_LOG,xt_comment,xt_multiport,xt_mac,xt_limit,iptable_mangle,iptable_filter,ip_tables,xt_tcpudp ppp_async 7136 0 ppp_generic 19648 3 pppoe,pppox,ppp_async slhc 3984 1 ppp_generic lockd 56704 0 sunrpc 162752 1 lockd hfs 39232 0 ath5k 143856 0 ath 15376 1 ath5k mac80211 264576 1 ath5k nls_base 4688 1 hfs crc_ccitt 944 1 ppp_async exportfs 2608 0 cfg80211 155696 3 ath5k,ath,mac80211 compat 5872 3 ath5k,mac80211,cfg80211 arc4 768 2 aes_generic 31536 0 crypto_algapi 9264 2 arc4,aes_generic root@client:/usr/sbin# lsmod Module Size Used by Tainted: G nf_nat_irc 784 0 nf_conntrack_irc 2464 1 nf_nat_irc nf_nat_ftp 976 0 nf_conntrack_ftp 4416 1 nf_nat_ftp ipt_MASQUERADE 976 1 iptable_nat 2544 1 nf_nat 10384 4 nf_nat_irc,nf_nat_ftp,ipt_MASQUERADE,iptable_nat pppoe 8240 0 xt_conntrack 2064 3 xt_CT 1424 0 xt_NOTRACK 528 0 iptable_raw 560 1 xt_state 608 0 nf_conntrack_ipv4 4464 6 iptable_nat,nf_nat nf_defrag_ipv4 656 1 nf_conntrack_ipv4 nf_conntrack 40448 12 nf_nat_irc,nf_conntrack_irc,nf_nat_ftp,nf_conntrack_ftp,ipt_MASQUERADE,iptable_nat,nf_nat,xt_conntrack,xt_CT,xt_NOTRACK,xt_state,nf_conntrack_ipv4 pppox 1152 1 pppoe ipt_REJECT 1712 2 xt_TCPMSS 2528 0 ipt_LOG 6064 0 xt_comment 400 0 xt_multiport 1104 0 xt_mac 528 0 xt_limit 992 0 iptable_mangle 816 1 iptable_filter 592 1 ip_tables 8880 4 iptable_nat,iptable_raw,iptable_mangle,iptable_filter xt_tcpudp 1600 1 x_tables 9936 18 ipt_MASQUERADE,iptable_nat,xt_conntrack,xt_CT,xt_NOTRACK,iptable_raw,xt_state,ipt_REJECT,xt_TCPMSS,ipt_LOG,xt_comment,xt_multiport,xt_mac,xt_limit,iptable_mangle,iptable_filter,ip_tables,xt_tcpudp ppp_async 7136 0 ppp_generic 19648 3 pppoe,pppox,ppp_async slhc 3984 1 ppp_generic lockd 56704 0 sunrpc 162752 1 lockd hfs 39232 0 ath5k 143856 0 ath 15376 1 ath5k mac80211 264576 1 ath5k nls_base 4688 1 hfs crc_ccitt 944 1 ppp_async exportfs 2608 0 cfg80211 155696 3 ath5k,ath,mac80211 compat 5872 3 ath5k,mac80211,cfg80211 arc4 768 2 aes_generic 31536 0 crypto_algapi 9264 2 arc4,aes_generic root@client:/usr/sbin# -
mount.nfs4: No such device root@client:/usr/sbin# showmount -e 192.168.1.1 clnt_create: RPC: Program not registered ошибка тут должна, но по интернету перелазил и не помогло. -
клиент к серверу это понятно, обратное делал только для статистики. Перебрал всё никак не работает. -
точка доступа на openwrt, добавить просто пользователя там нет такой возможности, только смена пароля. -
Просидел неделю не могу клиента и сервер соединить route на сервере root@r:~# route Kernel IP routing table server Destination Gateway Genmask Flags Metric Ref Use Iface default ser.mshome.net 0.0.0.0 UG 100 0 0 eth0 192.168.0.0 0.0.0.0 255.255.255.0 U 100 0 0 eth0 192.168.1.0 0.0.0.0 255.255.255.0 U 101 0 0 eth1 ip server 192.168.1.2, ip clenta 192.168.1.1 client Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface 192.168.1.0 * 255.255.255.0 U 0 0 0 br-lan root@client:~# root@r:/etc/init.d# exportfs -rav exporting *:/home/nfs4 exporting *:/home/nfs root@r:/etc/init.d# root@r:/etc/init.d# showmount -e 192.168.1.2 Export list for 192.168.1.2: /home/nfs4 * /home/nfs * root@r:/etc/init.d# showmount -e 192.168.1.1 clnt_create: RPC: Unable to receive запустил в ручную portmap root@r:/etc/init.d# showmount -e 192.168.1.1 clnt_create: RPC: Program not registered с стороны клиента root@client:/usr/sbin# showmount -e 192.168.1.1 clnt_create: RPC: Program not registered root@client:/usr/sbin# showmount -e 192.168.1.2 Export list for 192.168.1.2: /home/nfs4 * /home/nfs * файл hosts на клиенте root@client:/etc# cat hosts 127.0.0.1 localhost 192.168.1.1 client 192.168.1.2 r на сервере 127.0.0.1 localhost #127.0.1.1 r 192.168.1.2 r 192.168.1.1 client # The following lines are desirable for IPv6 capable hosts ::1 localhost ip6-localhost ip6-loopback ff02::1 ip6-allnodes ff02::2 ip6-allrouters запуск на сервере root@r:/etc/init.d# mount -t nfs4 -o nolock 192.168.1.1:/home/nfs4/ /home/nfs4/ -vvv mount.nfs4: timeout set for Mon Oct 21 16:33:57 2019 mount.nfs4: trying text-based options 'nolock,vers=4.2,addr=192.168.1.1,clientaddr=192.168.1.2' mount.nfs4: mount(2): Connection refused mount.nfs4: trying text-based options 'nolock,addr=192.168.1.1' mount.nfs4: prog 100003, trying vers=3, prot=6 mount.nfs4: portmap query retrying: RPC: Program not registered mount.nfs4: prog 100003, trying vers=3, prot=17 mount.nfs4: portmap query failed: RPC: Program not registered mount.nfs4: requested NFS version or transport protocol is not supported запуск на клиенте root@client:/sbin# mount -t nfs4 -o nolock 192.168.1.2:/home/nfs4/ /home/nfs4/ - vvv mount.nfs4: No such device mount: mounting 192.168.1.2:/home/nfs4/ on /home/nfs4/ failed: No such device root@client:/sbin# mount.nfs4 -o nolock 192.168.1.2:/home/nfs4/ /home/nfs4/ -vvv mount.nfs4: timeout set for Thu Sep 8 17:41:11 2011 mount.nfs4: trying text-based options 'nolock,addr=192.168.1.2,clientaddr=192.168.1.1' mount.nfs4: mount(2): No such device mount.nfs4: No such device root@r:/etc/init.d# rpcinfo program version netid address service owner 100000 4 tcp6 ::.0.111 portmapper superuser 100000 3 tcp6 ::.0.111 portmapper superuser 100000 4 udp6 ::.0.111 portmapper superuser 100000 3 udp6 ::.0.111 portmapper superuser 100000 4 tcp 0.0.0.0.0.111 portmapper superuser 100000 3 tcp 0.0.0.0.0.111 portmapper superuser 100000 2 tcp 0.0.0.0.0.111 portmapper superuser 100000 4 udp 0.0.0.0.0.111 portmapper superuser 100000 3 udp 0.0.0.0.0.111 portmapper superuser 100000 2 udp 0.0.0.0.0.111 portmapper superuser 100000 4 local /run/rpcbind.sock portmapper superuser 100000 3 local /run/rpcbind.sock portmapper superuser 100005 1 udp 0.0.0.0.147.17 mountd superuser 100005 1 tcp 0.0.0.0.202.45 mountd superuser 100005 1 udp6 ::.237.156 mountd superuser 100005 1 tcp6 ::.151.11 mountd superuser 100005 2 udp 0.0.0.0.206.119 mountd superuser 100005 2 tcp 0.0.0.0.132.71 mountd superuser 100005 2 udp6 ::.222.149 mountd superuser 100005 2 tcp6 ::.169.71 mountd superuser 100005 3 udp 0.0.0.0.172.26 mountd superuser 100005 3 tcp 0.0.0.0.205.91 mountd superuser 100005 3 udp6 ::.199.204 mountd superuser 100005 3 tcp6 ::.199.175 mountd superuser 100003 3 tcp 0.0.0.0.8.1 nfs superuser 100003 4 tcp 0.0.0.0.8.1 nfs superuser 100003 3 udp 0.0.0.0.8.1 nfs superuser 100003 3 tcp6 ::.8.1 nfs superuser 100003 4 tcp6 ::.8.1 nfs superuser 100003 3 udp6 ::.8.1 nfs superuser 100021 1 udp 0.0.0.0.217.191 nlockmgr superuser 100021 3 udp 0.0.0.0.217.191 nlockmgr superuser 100021 4 udp 0.0.0.0.217.191 nlockmgr superuser 100021 1 tcp 0.0.0.0.171.111 nlockmgr superuser 100021 3 tcp 0.0.0.0.171.111 nlockmgr superuser 100021 4 tcp 0.0.0.0.171.111 nlockmgr superuser 100021 1 udp6 ::.159.47 nlockmgr superuser 100021 3 udp6 ::.159.47 nlockmgr superuser 100021 4 udp6 ::.159.47 nlockmgr superuser 100021 1 tcp6 ::.163.9 nlockmgr superuser 100021 3 tcp6 ::.163.9 nlockmgr superuser 100021 4 tcp6 ::.163.9 nlockmgr superuser запуск на сервере mount -t nfs4 -o nolock 192.168.1.1:/home/nfs4/ /home/nfs4/ -vvv mount.nfs4: timeout set for Mon Oct 21 17:09:07 2019 mount.nfs4: trying text-based options 'nolock,vers=4.2,addr=192.168.1.1,clientaddr=192.168.1.2' mount.nfs4: mount(2): Connection refused mount.nfs4: trying text-based options 'nolock,addr=192.168.1.1' mount.nfs4: prog 100003, trying vers=3, prot=6 mount.nfs4: portmap query retrying: RPC: Program not registered mount.nfs4: prog 100003, trying vers=3, prot=17 mount.nfs4: portmap query failed: RPC: Program not registered mount.nfs4: requested NFS version or transport protocol is not supported root@r:/etc/init.d# запуск с стороны клиента root@r:/etc/init.d# nfsstat Server rpc stats: calls badcalls badfmt badauth badclnt 61 2 2 0 0 Server nfs v3: null getattr setattr lookup access 4 16% 6 24% 0 0% 4 16% 2 8% readlink read write create mkdir 0 0% 0 0% 0 0% 0 0% 0 0% symlink mknod remove rmdir rename 0 0% 0 0% 0 0% 0 0% 0 0% link readdir readdirplus fsstat fsinfo 0 0% 0 0% 0 0% 3 12% 4 16% pathconf commit 2 8% 0 0% Server nfs v4: null compound 2 5% 34 94% Server nfs v4 operations: op0-unused op1-unused op2-future access close 0 0% 0 0% 0 0% 2 2% 0 0% commit create delegpurge delegreturn getattr 0 0% 0 0% 0 0% 0 0% 18 21% getfh link lock lockt locku 2 2% 0 0% 0 0% 0 0% 0 0% lookup lookup_root nverify open openattr 2 2% 0 0% 0 0% 0 0% 0 0% open_conf open_dgrd putfh putpubfh putrootfh 0 0% 0 0% 18 21% 0 0% 4 4% read readdir readlink remove rename 0 0% 0 0% 0 0% 0 0% 0 0% renew restorefh savefh secinfo setattr 0 0% 0 0% 0 0% 0 0% 0 0% setcltid setcltidconf verify write rellockowner 0 0% 0 0% 0 0% 0 0% 0 0% bc_ctl bind_conn exchange_id create_ses destroy_ses 0 0% 0 0% 4 4% 2 2% 2 2% free_stateid getdirdeleg getdevinfo getdevlist layoutcommit 0 0% 0 0% 0 0% 0 0% 0 0% layoutget layoutreturn secinfononam sequence set_ssv 0 0% 0 0% 2 2% 24 28% 0 0% test_stateid want_deleg destroy_clid reclaim_comp allocate 0 0% 0 0% 2 2% 2 2% 0 0% copy copy_notify deallocate ioadvise layouterror 0 0% 0 0% 0 0% 0 0% 0 0% layoutstats offloadcancel offloadstatus readplus seek 0 0% 0 0% 0 0% 0 0% 0 0% write_same 0 0% Client rpc stats: calls retrans authrefrsh 62 0 62 Client nfs v3: null getattr setattr lookup access 2 8% 6 26% 0 0% 4 17% 2 8% readlink read write create mkdir 0 0% 0 0% 0 0% 0 0% 0 0% symlink mknod remove rmdir rename 0 0% 0 0% 0 0% 0 0% 0 0% link readdir readdirplus fsstat fsinfo 0 0% 0 0% 0 0% 3 13% 4 17% pathconf commit 2 8% 0 0% Client nfs v4: null read write commit open 5 12% 0 0% 0 0% 0 0% 0 0% open_conf open_noat open_dgrd close setattr 0 0% 0 0% 0 0% 0 0% 0 0% fsinfo renew setclntid confirm lock 4 10% 0 0% 0 0% 0 0% 0 0% lockt locku access getattr lookup 0 0% 0 0% 2 5% 2 5% 2 5% lookup_root remove rename link symlink 2 5% 0 0% 0 0% 0 0% 0 0% create pathconf statfs readlink readdir 0 0% 2 5% 0 0% 0 0% 0 0% server_caps delegreturn getacl setacl fs_locations 6 15% 0 0% 0 0% 0 0% 0 0% rel_lkowner secinfo fsid_present exchange_id create_session 0 0% 0 0% 0 0% 4 10% 2 5% destroy_session sequence get_lease_time reclaim_comp layoutget 2 5% 0 0% 0 0% 2 5% 0 0% getdevinfo layoutcommit layoutreturn secinfo_no test_stateid 0 0% 0 0% 0 0% 2 5% 0 0% free_stateid getdevicelist bind_conn_to_ses destroy_clientid seek 0 0% 0 0% 0 0% 2 5% 0 0% allocate deallocate layoutstats clone 0 0% 0 0% 0 0% 0 0% root@r:/etc/init.d# root@r:/etc/init.d# rpcinfo -p 192.168.1.2 program vers proto port service 100000 4 tcp 111 portmapper 100000 3 tcp 111 portmapper 100000 2 tcp 111 portmapper 100000 4 udp 111 portmapper 100000 3 udp 111 portmapper 100000 2 udp 111 portmapper 100005 1 udp 37649 mountd 100005 1 tcp 51757 mountd 100005 2 udp 52855 mountd 100005 2 tcp 33863 mountd 100005 3 udp 44058 mountd 100005 3 tcp 52571 mountd 100003 3 tcp 2049 nfs 100003 4 tcp 2049 nfs 100003 3 udp 2049 nfs 100021 1 udp 55743 nlockmgr 100021 3 udp 55743 nlockmgr 100021 4 udp 55743 nlockmgr 100021 1 tcp 43887 nlockmgr 100021 3 tcp 43887 nlockmgr 100021 4 tcp 43887 nlockmgr root@r:/etc/init.d# root@r:/etc/init.d# rpcinfo -p 192.168.1.1 program vers proto port service 100000 2 tcp 111 portmapper 100000 2 udp 111 portmapper root@client:/# rpcinfo -p 192.168.1.1 -ash: rpcinfo: not found root@client:/# rpcinfo -p 192.168.1.2 -ash: rpcinfo: not found root@client:/# 100021 1 udp 55743 nlockmgr 100021 3 udp 55743 nlockmgr 100021 4 udp 55743 nlockmgr 100021 1 tcp 43887 nlockmgr 100021 3 tcp 43887 nlockmgr 100021 4 tcp 43887 nlockmgr root@r:/etc/init.d# root@r:/etc/init.d# rpcinfo -p 192.168.1.1 program vers proto port service 100000 2 tcp 111 portmapper 100000 2 udp 111 portmapper root@client:/# rpcinfo -p 192.168.1.1 -ash: rpcinfo: not found root@client:/# rpcinfo -p 192.168.1.2 -ash: rpcinfo: not found root@client:/#
