Есть у меня оптический коммутатор доступа (Eltex MES2324FB), на одном абонентском порту которого почему-то несколько дней назад начали расти ошибки.
Вот ошибки за 20 минут.
#sh int gi1/0/1
gigabitethernet1/0/1 is up (connected)
  Interface index is 49
  Hardware is gigabitethernet, MAC address is e0:d9:e3:ab:7c:c1
  Interface MTU is 9000
  Full-duplex, 100Mbps, link type is 100Mbps full-duplex, media type is 1G-Fiber
  Link is up for 0 days, 0 hours, 24 minutes and 30 seconds
  Flow control is off, MDIX mode is off
  15 second input rate is 34 Kbit/s
  15 second output rate is 3149 Kbit/s
      45133 packets input, 9923517 bytes received
      1 broadcasts, 0 multicasts
      19276 input errors, 4726 FCS, 0 alignment
      0 oversize, 14526 internal MAC
      0 pause frames received
      546480 packets output, 594848280 bytes sent
      5575 broadcasts, 185 multicasts
      0 output errors, 0 collisions
      0 excessive collisions, 0 late collisions
      0 pause frames transmitted
      0 symbol errors, 0 carrier, 0 SQE test error
На второй стороне (у абонента) установлен медиаконвертер 100М (такой).
Физику пока не меняли, но оборудование новое; абонента подключили месяца 4 назад и проблемы начались недавно, ранее все работало нормально.
На коммутаторе есть информация с SFP, но мне она не совсем понятна:
#sh fiber-ports optical-transceiver int gi1/0/1
   Port      Temp  Voltage Current  Output        Input        LOS  Transceiver
             [C]   [Volt]  [mA]     Power         Power             Type
                                    [mW / dBm]    [mW / dBm]
  gi1/0/1     28    3.32    10.35  0.24 / -6.14  0.14 / -8.40  N/S     Fiber
 Temp                      - Internally measured transceiver temperature
 Voltage                   - Internally measured supply voltage
 Current                   - Measured TX bias current
 Output Power              - Measured TX output power in milliWatts/dBm
 Input Power               - Measured RX received power in milliWatts/dBm
 LOS                       - Loss of signal
 N/A - Not Available, N/S - Not Supported, W - Warning, E - Error
        Transceiver information:
Vendor name: Gigalink
Serial number: G201802281557
Part number: GL-OT-SG14SC1-15
Vendor revision: 11.0
Connector type: SC
Type: SFP/SFP+
Compliance code: unknown
Laser wavelength: 1550 nm
Transfer distance: 20000 m
Diagnostic: supported
У SFP бюджет 14 дБ, у м/к бюджет 18 дБ.
-8,4 это нормальное значение? Или уровень сигнала низкий и нужно искать проблему на линии?
Медный патчкорд никак не должен влиять на ошибки в оптическом порту.
Завтра для пробы заменим физику.
Но таких абонентов у нас после праздников появилось штук 8, причины не совсем понятны.
Вы правы, не может.
И оптическая мощность с запасом (если верить измерениям, я бы перемерял прибором).
А общее среди восьми абонентов, может быть что то? Мороз к примеру.
У нас было пару абонов в частном секторе, где медиаконверторы стояли на крыше у абонов. Там при крепких морозах начинали CRC error прилетать.
Решалось заменой медиаконвертора с твердотелыми электролитическими конденсаторами.
Еще было от чудес с электрикой в частном секторе, но тогда CRC error появлялись, но со временем не увеличивались.
5 часов назад, asteroid сказал:
Был похожий случай, когда один из подрядчиков повесил оптику вдоль жд немного неправильно. В итоге, когда зимой были сильные морозы + шел груженый товарный поезд появлялись похоже проблемы с сигналом.
21 час назад, alibek сказал:
Возможно, проверим.
 Смущает аптайм порта в 24 минуты. А так - да, в морозы местные многое чего начинает дохнуть, в основном по БП. Ну и да - температура в трансиверах +28, это хорошо. Не знаю элтехи, но блинки например могут показать энвиронмент, и свою  температуру тоже. В древние годы просто укутывали свитчи в таких техпомещениях плёнкой с пузырями, иначе эта хрень после выключения-остывания просто не стартовала снова в морозе.
