Andrei Опубликовано 16 марта, 2021 Вобщем ночером попробовал воплотить в жизнь описанное выше. Текущий конфиг router bgp 206538 bgp router-id 188.130.171.1 bgp log-neighbor-changes network 188.130.171.0/24 redistribute static neighbor 62.141.99.89 remote-as 3216 neighbor 62.141.99.89 description Bee neighbor 62.141.99.89 update-source 62.141.99.90 neighbor 62.141.99.89 weight 1000 neighbor 62.141.99.89 soft-reconfiguration inbound neighbor 62.141.99.89 route-map Bee-in in neighbor 62.141.99.89 route-map Bee-out out neighbor 77.95.132.140 remote-as 65002 neighbor 77.95.132.140 description RKN neighbor 77.95.132.140 ebgp-multihop 255 neighbor 77.95.132.140 update-source 188.130.171.1 neighbor 77.95.132.140 soft-reconfiguration inbound neighbor 77.95.132.140 prefix-list DENY-ANY-PREFIXES in neighbor 89.237.47.73 remote-as 28745 neighbor 89.237.47.73 description TTK neighbor 89.237.47.73 update-source 89.237.47.74 neighbor 89.237.47.73 weight 2000 neighbor 89.237.47.73 soft-reconfiguration inbound neighbor 89.237.47.73 route-map TT-in in neighbor 89.237.47.73 route-map TT-out out neighbor 188.130.171.2 remote-as 65001 neighbor 188.130.171.2 description CarbonReductor neighbor 188.130.171.2 ebgp-multihop 8 neighbor 188.130.171.2 soft-reconfiguration inbound neighbor 188.130.171.2 route-map BLACKHOLE in ! access-list TERMINAL permit 127.0.0.1/32 access-list TERMINAL deny any ! ip prefix-list ANY seq 5 permit any ip prefix-list DENY-ANY-PREFIXES seq 10 deny 0.0.0.0/0 le 32 ip prefix-list bogons seq 15 permit 0.0.0.0/8 le 32 ip prefix-list bogons seq 20 permit 127.0.0.0/8 le 32 ip prefix-list bogons seq 30 permit 10.0.0.0/8 le 32 ip prefix-list bogons seq 35 permit 172.16.0.0/12 le 32 ip prefix-list bogons seq 40 permit 192.168.0.0/16 le 32 ip prefix-list bogons seq 45 permit 169.254.0.0/16 le 32 ip prefix-list bogons seq 50 permit 224.0.0.0/4 le 32 ip prefix-list bogons seq 55 permit 240.0.0.0/4 le 32 ip prefix-list default seq 10 permit 0.0.0.0/0 ip prefix-list fullview seq 5 permit any ip prefix-list our-CIDR-blocks seq 5 permit 188.130.171.0/24 le 32 ip prefix-list reduced seq 10 permit 0.0.0.0/0 ge 25 ip prefix-list upstream-out seq 10 permit 188.130.171.0/24 ! ip as-path access-list 1 deny .* ip as-path access-list PRIV permit _6451[2-9]_ ip as-path access-list PRIV permit _645[2-9][0-9]_ ip as-path access-list PRIV permit _64[6-9][0-9][0-9]_ ip as-path access-list PRIV permit _65[0-9][0-9][0-9]_ ! route-map TT-in deny 100 match as-path PRIV ! route-map TT-in deny 110 match ip address prefix-list bogons ! route-map TT-in deny 115 match ip address prefix-list reduced ! route-map TT-in deny 120 match ip address prefix-list our-CIDR-blocks ! route-map TT-in permit 200 ! route-map TT-out permit 100 match ip address prefix-list upstream-out ! route-map TT-out deny 200 ! route-map BLACKHOLE permit 10 match ip address prefix-list ANY set community 9930:666 additive set local-preference 200 ! route-map Bee-out permit 100 match ip address prefix-list upstream-out ! route-map Bee-out deny 200 ! route-map Bee-in deny 100 match as-path PRIV ! route-map Bee-in deny 110 match ip address prefix-list bogons ! route-map Bee-in deny 115 match ip address prefix-list reduced ! route-map Bee-in deny 120 match ip address prefix-list our-CIDR-blocks ! route-map Bee-in permit 200 ! line vty access-class TERMINAL ! end Работает, FV с обеих ног. AS206538# sh ip bgp sum BGP router identifier 188.130.171.1, local AS number 206538 RIB entries 1557496, using 166 MiB of memory Peers 4, using 18 KiB of memory Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd 62.141.99.89 4 3216 206115 523 0 0 0 08:40:41 829367 77.95.132.140 4 65002 0 0 0 0 0 never Active 89.237.47.73 4 28745 303558 526 0 0 0 08:40:44 840314 188.130.171.2 4 65001 530 242625 0 0 0 08:40:44 3687 Total number of neighbors 4 Но есть странности. Почему-то ничего не анонсится во вторую ногу sh ip bgp nei 62.141.99.89 adv (пусто) И трассировка с обычного клиента во вторую ногу выглядит так tracert -d 62.141.99.90 Трассировка маршрута к 62.141.99.90 с максимальным числом прыжков 30 1 1 ms 3 ms 1 ms 192.168.1.1 2 1 ms 1 ms 3 ms 10.1.1.1 3 1 ms 1 ms 1 ms 62.141.99.90 Трассировка завершена. tracert -d 62.141.99.89 Трассировка маршрута к 62.141.99.89 с максимальным числом прыжков 30 1 1 ms 1 ms 1 ms 192.168.1.1 2 1 ms 1 ms 1 ms 10.1.1.1 3 4 ms 1 ms 4 ms 188.130.171.65 4 * * * Превышен интервал ожидания для запроса. 5 * * * Превышен интервал ожидания для запроса. Роуты на сервере при этом ip route | grep default default via 89.237.47.73 dev vlan150 proto zebra ip route | grep 0.0.0.0 20.0.0.0/11 via 89.237.47.73 dev vlan150 proto zebra 40.0.0.0/19 via 89.237.47.73 dev vlan150 proto zebra 40.0.0.0/10 via 89.237.47.73 dev vlan150 proto zebra .. и т.д. Видно, что и во вторую ногу bgp что-то отправил ip route | grep 62.141.99.89 1.9.206.0/24 via 62.141.99.89 dev vlan502 proto zebra 5.100.224.0/21 via 62.141.99.89 dev vlan502 proto zebra 5.180.30.0/24 via 62.141.99.89 dev vlan502 proto zebra 5.255.200.0/24 via 62.141.99.89 dev vlan502 proto zebra 8.238.70.0/24 via 62.141.99.89 dev vlan502 proto zebra ... и т.д. Но если посмотреть трассировку до ресурсов, на которые bgp сделал роуты через вторую ногу, то увы: traceroute 1.9.206.1 traceroute to 1.9.206.1 (1.9.206.1), 30 hops max, 60 byte packets 1 62.141.99.89 (62.141.99.89) 5.233 ms 5.221 ms 5.205 ms 2 * * * 3 * * * 4 * * * 5 * * * 6 * * * Если сделать weight одинаковым для обеих ног, т.е. и для второй сказать "neighbor 62.141.99.89 weight 2000", то инет пропадает. AS206538# sh ip bgp 62.141.99.89 BGP routing table entry for 62.141.64.0/18 Paths: (2 available, best #1, table Default-IP-Routing-Table) Advertised to non peer-group peers: 188.130.171.2 28745 20485 3216 89.237.47.73 from 89.237.47.73 (176.56.13.1) Origin IGP, localpref 100, weight 2000, valid, external, best Last update: Wed Mar 17 01:35:35 2021 3216 62.141.99.89 from 62.141.99.89 (79.104.32.14) Origin IGP, localpref 100, weight 1000, valid, external Community: 3216:2001 3216:2999 3216:4100 Last update: Wed Mar 17 01:48:06 2021 AS206538# sh ip bgp nei 62.141.99.89 BGP neighbor is 62.141.99.89, remote AS 3216, local AS 206538, external link Description: Bee BGP version 4, remote router ID 79.104.32.14 BGP state = Established, up for 09:06:13 Last read 00:00:28, hold time is 180, keepalive interval is 60 seconds Neighbor capabilities: 4 Byte AS: advertised and received Route refresh: advertised and received(old & new) Address family IPv4 Unicast: advertised and received Message statistics: Inq depth is 0 Outq depth is 0 Sent Rcvd Opens: 1 1 Notifications: 0 0 Updates: 0 208702 Keepalives: 547 1 Route Refresh: 0 0 Capability: 0 0 Total: 548 208704 Minimum time between advertisement runs is 30 seconds Update source is 62.141.99.90 Default weight 1000 For address family: IPv4 Unicast Inbound soft reconfiguration allowed Community attribute sent to this neighbor(both) Inbound path policy configured Outbound path policy configured Route map for incoming advertisements is *Bee-in Route map for outgoing advertisements is *Bee-out 829263 accepted prefixes Connections established 1; dropped 0 Last reset never Local host: 62.141.99.90, Local port: 22158 Foreign host: 62.141.99.89, Foreign port: 179 Nexthop: 62.141.99.90 Nexthop global: :: Nexthop local: :: BGP connection: non shared network Read thread: on Write thread: off AS206538# sh ip bgp 89.237.47.73 BGP routing table entry for 89.237.47.0/24 Paths: (2 available, best #1, table Default-IP-Routing-Table) Advertised to non peer-group peers: 188.130.171.2 28745 89.237.47.73 from 89.237.47.73 (176.56.13.1) Origin IGP, metric 0, localpref 100, weight 2000, valid, external, best Last update: Wed Mar 17 01:35:39 2021 3216 20485 28745 62.141.99.89 from 62.141.99.89 (79.104.32.14) Origin IGP, localpref 100, weight 1000, valid, external Community: 3216:1000 3216:1014 3216:1108 20485:10074 20485:65102 Last update: Wed Mar 17 01:48:10 2021 AS206538# sh ip bgp nei 89.237.47.73 BGP neighbor is 89.237.47.73, remote AS 28745, local AS 206538, external link Description: TTK BGP version 4, remote router ID 176.56.13.1 BGP state = Established, up for 09:06:52 Last read 00:00:14, hold time is 180, keepalive interval is 60 seconds Neighbor capabilities: 4 Byte AS: advertised and received Route refresh: advertised and received(old & new) Address family IPv4 Unicast: advertised and received Graceful Restart Capabilty: received Remote Restart timer is 120 seconds Address families by peer: IPv4 Unicast(not preserved) Graceful restart informations: End-of-RIB send: IPv4 Unicast End-of-RIB received: IPv4 Unicast Message statistics: Inq depth is 0 Outq depth is 0 Sent Rcvd Opens: 1 1 Notifications: 0 0 Updates: 2 305633 Keepalives: 548 1 Route Refresh: 1 0 Capability: 0 0 Total: 552 305635 Minimum time between advertisement runs is 30 seconds Update source is 89.237.47.74 Default weight 2000 For address family: IPv4 Unicast Inbound soft reconfiguration allowed Community attribute sent to this neighbor(both) Inbound path policy configured Outbound path policy configured Route map for incoming advertisements is *TT-in Route map for outgoing advertisements is *TT-out 840265 accepted prefixes Connections established 1; dropped 0 Last reset never Local host: 89.237.47.74, Local port: 33285 Foreign host: 89.237.47.73, Foreign port: 179 Nexthop: 89.237.47.74 Nexthop global: :: Nexthop local: :: BGP connection: non shared network Read thread: on Write thread: off Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
disappointed Опубликовано 17 марта, 2021 Цитата ! route-map TT-out permit 100 match ip address prefix-list upstream-out ! route-map TT-out deny 200 ! Цитата route-map Bee-out permit 100 match ip address prefix-list upstream-out ! route-map Bee-out deny 200 ! Убрать, политика роут-мапов по умолчанию - deny, не нужно писать это в конце отдельно. Цитата neighbor 62.141.99.89 weight 1000 neighbor 89.237.47.73 weight 2000 Убрать. Временно для экспериментов добавить статический дефолт ip r a def via 89.237.47.73 чтобы не "пропадал инет". И показать sh ip bg nei 62.141.99.89 adv Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrei Опубликовано 17 марта, 2021 18 минут назад, disappointed сказал: Убрать, политика роут-мапов по умолчанию - deny, не нужно писать это в конце отдельно. AS206538# conf t AS206538(config)# no route-map TT-out deny 200 AS206538(config)# no route-map Bee-out deny 200 19 минут назад, disappointed сказал: Временно для экспериментов добавить статический дефолт ip r a def via 89.237.47.73 чтобы не "пропадал инет". # ip r a def via 89.237.47.73 Error: an inet prefix is expected rather than "def". # ip r a default via 89.237.47.73 RTNETLINK answers: File exists 20 минут назад, disappointed сказал: Цитата neighbor 62.141.99.89 weight 1000 neighbor 89.237.47.73 weight 2000 Убрать. AS206538> en AS206538# conf t AS206538(config)# router bgp 206538 AS206538(config-router)# no neighbor 62.141.99.89 weight 1000 AS206538(config-router)# no neighbor 89.237.47.73 weight 2000 AS206538(config-router)# AS206538# clear ip bgp * soft in AS206538# sh ip bgp sum BGP router identifier 188.130.171.1, local AS number 206538 RIB entries 1558138, using 166 MiB of memory Peers 4, using 18 KiB of memory Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd 62.141.99.89 4 3216 270037 945 0 0 0 15:42:41 829776 77.95.132.140 4 65002 0 0 0 0 0 never Active 89.237.47.73 4 28745 344066 948 0 0 0 15:42:44 840706 188.130.171.2 4 65001 952 376320 0 0 0 15:42:44 3687 Total number of neighbors 4 AS206538# sh ip bg nei 62.141.99.89 adv AS206538# sh ip bg nei 89.237.47.73 adv BGP table version is 0, local router ID is 188.130.171.1 Status codes: s suppressed, d damped, h history, * valid, > best, i - internal, r RIB-failure, S Stale, R Removed Origin codes: i - IGP, e - EGP, ? - incomplete Network Next Hop Metric LocPrf Weight Path *> 188.130.171.0/24 89.237.47.74 0 32768 i После чего инет все же пропал. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
disappointed Опубликовано 17 марта, 2021 sh ip bg nei 62.141.99.89 adv не увидел через билайн вообще что-то ходит нет? rp filter отключён? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
disappointed Опубликовано 17 марта, 2021 И нет анонса 188.130.171.0/24 через Билайн, не вижу сейчас. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrei Опубликовано 17 марта, 2021 20 минут назад, disappointed сказал: sh ip bg nei 62.141.99.89 adv не увидел 31 минуту назад, Andrei сказал: AS206538# sh ip bg nei 62.141.99.89 adv Пусто 20 минут назад, disappointed сказал: через билайн вообще что-то ходит нет? Сейчас нет. Раньше с ними bgp не было, был выдан просто 1 ip-адрес 62.141.99.90 (стыковая сетка 62.141.99.88/30), его прописали прямо на cisco, термнирующую pppoe и на него повесили НАТ. Сейчас клиентов с НАТа убрали, этот единственный ip и НАТ с циски убрали, ip перенесли на сервак с quagga. 20 минут назад, disappointed сказал: rp filter отключён? В Билайн: # cat /proc/sys/net/ipv4/conf/vlan502/rp_filter 0 В ТТК: # cat /proc/sys/net/ipv4/conf/vlan150/rp_filter 0 9 минут назад, disappointed сказал: И нет анонса 188.130.171.0/24 через Билайн, не вижу сейчас. Да, почему-то нет. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
disappointed Опубликовано 17 марта, 2021 @Andrei clear ip bgp 3216 подождать 30 сек sh ip bg nei 62.141.99.89 adv Вот теперь вижу Пошёл входящий через Би? Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
st_re Опубликовано 17 марта, 2021 5 часов назад, Andrei сказал: В Билайн: # cat /proc/sys/net/ipv4/conf/vlan502/rp_filter 0 В ТТК: # cat /proc/sys/net/ipv4/conf/vlan150/rp_filter 0 есть еще all для того чтобы тут работал 0, там тоже надо 0 Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrei Опубликовано 17 марта, 2021 В тележеньке порешали все с disappointed Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrei Опубликовано 20 марта, 2021 Вчера наступил на грабли, не связанные с кваггой, но повлиявшие на ее работу. Издавна на сервере с кваггой стоит shorewall. Вчера прописывал новые интерфейсы на сервере, разумеется внес их в списки интерфейсов и хостов в настройках shorewall, после чего его рестартовал. И bgp перестал нормально работать. Выяснилось, что по умолчанию в shorewall.conf есть параметр ROUTE_FILTER=Yes . И shorewall при рестарте заново включил rp_filter на всех интерфейсах. Вещь не очевидная. Может кому пригодится такой опыт. Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
h3ll1 Опубликовано 25 марта, 2021 (изменено) On 3/20/2021 at 9:28 AM, Andrei said: Вчера наступил на грабли Думаю ето для zebra (там разние люди разбираюстя) Изменено 25 марта, 2021 пользователем h3ll1 Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
Andrei Опубликовано 26 марта, 2021 7 часов назад, h3ll1 сказал: Думаю ето для zebra (там разние люди разбираюстя) Сорри, не понял всю глубину мысли :) Вставить ник Цитата Ответить с цитированием Поделиться сообщением Ссылка на сообщение Поделиться на других сайтах More sharing options...
