Проблемы с пробросом портов в Mikrotik.
Нужно RDP на 4 компьютера
/ip firewall nat
add action=masquerade chain=srcnat out-interface=ether1
add action=dst-nat chain=dstnat dst-port=3390 in-interface=ether1 protocol=tcp to-addresses=192.168.88.10 to-ports=3389
add action=dst-nat chain=dstnat dst-port=3391 in-interface=ether1 protocol=tcp to-addresses=192.168.88.11 to-ports=3389
add action=dst-nat chain=dstnat dst-port=3392 in-interface=ether1 protocol=tcp to-addresses=192.168.88.12 to-ports=3389
add action=dst-nat chain=dstnat dst-port=3393 in-interface=ether1 protocol=tcp to-addresses=10.11.185.201 to-ports=3389
Но работают они странно
add action=dst-nat chain=dstnat dst-port=3390 in-interface=ether1 protocol=tcp to-addresses=192.168.88.10 to-ports=3389 отправляет на нужный комп
add action=dst-nat chain=dstnat dst-port=3391 in-interface=ether1 protocol=tcp to-addresses=192.168.88.11 to-ports=3389 не работает
add action=dst-nat chain=dstnat dst-port=3392 in-interface=ether1 protocol=tcp to-addresses=192.168.88.12 to-ports=3389 не работает
add action=dst-nat chain=dstnat dst-port=3393 in-interface=ether1 protocol=tcp to-addresses=10.11.185.201 to-ports=3389 При включении отправляет на комп 192.168.88.11
[admin@MikroTik] > export compact
# dec/01/2016 14:53:57 by RouterOS 6.38rc37
# software id =
/interface ethernet
set [ find default-name=ether1 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full mac-address=00:0C:29:40:4B:86 speed=100Mbps
/ip dhcp-server option
add code=249 name=static249 value=0x080A0A0BB901
add code=121 name=static121 value=0x080A0A0BB901
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc
/ip pool
add name=dhcp ranges=192.168.88.250-192.168.88.253
add name=ofis ranges=10.11.185.200-10.11.185.250
/ip dhcp-server
add add-arp=yes address-pool=dhcp disabled=no interface=ether2 name=dhcp1
add add-arp=yes address-pool=ofis disabled=no interface=ether3 name=ofis
/interface bridge port
add interface=ether2
/ip address
add address=81.163.39.158/28 comment="default configuration" interface=ether1 network=81.163.39.144
add address=192.168.88.1/24 interface=ether2 network=192.168.88.0
add address=10.11.185.254/24 interface=ether3 network=10.11.185.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=ether1
/ip dhcp-server lease
add address=192.168.88.10 client-id=1:0:c:29:bd:a1:22 mac-address=00:0C:29:BD:A1:22 server=dhcp1
add address=192.168.88.11 client-id=1:0:c:29:c3:52:f mac-address=00:0C:29:C3:52:0F server=dhcp1
add address=192.168.88.12 client-id=1:0:c:29:5f:6c:ad mac-address=00:0C:29:5F:6C:AD server=dhcp1
/ip dhcp-server network
add address=10.11.185.0/24 dhcp-option=static249,static121 dns-server=81.163.39.114 gateway=10.11.185.254 netmask=24
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
/ip dns
set servers=8.8.8.8
/ip firewall filter
add action=drop chain=input comment="drop ssh brute forcers" dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=12w6d chain=input connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=input connection-state=new dst-port=22 protocol=tcp
add action=drop chain=input comment="drop telnet brute forcers" dst-port=23 protocol=tcp src-address-list=telnet_blacklist
add action=add-src-to-address-list address-list=telnet_blacklist address-list-timeout=12w6d chain=input connection-state=new dst-port=23 protocol=tcp src-address-list=telnet_stage3
add action=add-src-to-address-list address-list=telnet_stage3 address-list-timeout=1m chain=input connection-state=new dst-port=23 protocol=tcp src-address-list=telnet_stage2
add action=add-src-to-address-list address-list=telnet_stage2 address-list-timeout=1m chain=input connection-state=new dst-port=23 protocol=tcp src-address-list=telnet_stage1
add action=add-src-to-address-list address-list=telnet_stage1 address-list-timeout=1m chain=input connection-state=new dst-port=23 protocol=tcp
add action=drop chain=input comment="drop ssh brute forcers" dst-port=8291 protocol=tcp src-address-list=winbox_blacklist
add action=add-src-to-address-list address-list=winbox_blacklist address-list-timeout=12w6d chain=input connection-state=new dst-port=8291 protocol=tcp src-address-list=winbox_stage3
add action=add-src-to-address-list address-list=winbox_stage3 address-list-timeout=1m chain=input connection-state=new dst-port=8291 protocol=tcp src-address-list=winbox_stage2
add action=add-src-to-address-list address-list=winbox_stage2 address-list-timeout=1m chain=input connection-state=new dst-port=8291 protocol=tcp src-address-list=winbox_stage1
add action=add-src-to-address-list address-list=winbox_stage1 address-list-timeout=1m chain=input connection-state=new dst-port=8291 protocol=tcp
add action=drop chain=input comment="drop telnet brute forcers" dst-port=80 protocol=tcp src-address-list=web_blacklist
add action=add-src-to-address-list address-list=web_blacklist address-list-timeout=12w6d chain=input connection-state=new dst-port=80 protocol=tcp src-address-list=web_stage3
add action=add-src-to-address-list address-list=web_stage3 address-list-timeout=1m chain=input connection-state=new dst-port=80 protocol=tcp src-address-list=web_stage2
add action=add-src-to-address-list address-list=web_stage2 address-list-timeout=1m chain=input connection-state=new dst-port=80 protocol=tcp src-address-list=web_stage1
add action=add-src-to-address-list address-list=web_stage1 address-list-timeout=1m chain=input connection-state=new dst-port=80 protocol=tcp
add action=drop chain=input comment="drop ftp brute forcers" dst-port=21 protocol=tcp src-address-list=ftp_blacklist
add action=accept chain=output content="530 Login incorrect" dst-limit=1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist address-list-timeout=3h chain=output content="530 Login incorrect" protocol=tcp
/ip firewall nat
/ip route
add distance=1 gateway=81.163.39.145
/system package update
set channel=release-candidate
[admin@MikroTik] >
Edited by fumufu86
В firewall добавьте разрешающие правило для RDP
В firewall нет запрещающих правил для RDP. По умолчанию все что не запрещено, то разрешено?
Отсутствие этого правила так же не мешает работать RDP на двух компьютерах.
Забыл об этом. Удалил. Проблему не решило.
# dec/08/2016 19:34:17 by RouterOS 6.38rc37
# software id =
/interface ethernet
/ip ipsec proposal
/ip pool
/ip dhcp-server
/queue simple
add max-limit=13M/13M name=queue1 target=10.11.185.75/32
/ip address
/ip dhcp-client
add address=192.168.88.11 always-broadcast=yes client-id=1:0:c:29:c3:52:f mac-address=00:0C:29:C3:52:0F server=dhcp1
add address=10.11.185.75 client-id=1:fc:aa:14:1c:e2:d1 mac-address=FC:AA:14:1C:E2:D1 server=ofis
/ip dns
set servers=8.8.8.8
/ip firewall filter
/ip firewall nat
/ip route
На самом деле у Вас почти всё работает. См. скрин.
Подозреваю, что тестируете Вы из той же локальной сети, обращаясь к внешнему IP-адресу. Чтобы работало И так нужно делать "hairpin nat".
Из Интернета серверы прекрасно видно.
Я когда пытаюсь зайти по этому же адресу попадаю на 3393. Я пытаюсь зайти не из локальной сети. С адреса 176.120.221.221. Но это один и тот же провайдер.
Спасибо за совет.
