Добрый день , коллеги .
Помогите разобратся в ситуации .
Собрана следующая схема
Конфигурация со стороны M7i
show configuration interfaces ge-1/3/0
flexible-vlan-tagging;
mtu 9000;
encapsulation flexible-ethernet-services;
unit 200 {
description "-= LSP1 SAKI =-";
vlan-id 200;
family inet {
address 10.0.2.0/31;
family mpls {
mtu 1538;
unit 300 {
description "-= LSP2 SAKI =-";
vlan-id 300;
family inet {
address 10.0.2.2/31;
family mpls {
mtu 1538;
show configuration protocols rsvp
load-balance bandwidth;
traceoptions {
file rsvp.log size 1m files 3;
interface ge-1/3/0.200;
interface ge-1/3/0.300;
interface lo0.0;
show configuration protocols mpls
path-mtu {
allow-fragmentation;
rsvp mtu-signaling;
traceoptions {
file mpls.log size 1m files 3;
label-switched-path Simf2Saki {
to 193.27.243.10;
bandwidth 100m;
priority 2 2;
primary Simf2Saki;
label-switched-path Simf2SakiB {
to 193.27.243.10;
bandwidth 100m;
priority 4 4;
primary Simf2SakiB;
path Simf2Saki {
10.0.2.1;
path Simf2SakiB {
10.0.2.3;
interface lo0.0;
traceoptions {
file ospf.log size 1m files 3;
traffic-engineering;
export EXPORT-TO-OSPF;
area 0.0.0.0 {
interface ge-0/0/0.803;
area 0.0.0.10 {
stub default-metric 10 no-summaries;
interface ge-1/3/0.300 {
interface-type p2p;
interface ge-1/3/0.200 {
interface-type p2p;
interface lo0.0;
Конфигурация со стороны ME
interface Loopback0
ip address 193.27.243.10 255.255.255.255
ip ospf 1 area 10
interface Tunnel0
description Saki2Simf
ip unnumbered Loopback0
load-interval 30
mpls traffic-eng tunnels
tunnel mode mpls traffic-eng
tunnel destination 195.3.244.10
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng priority 2 2
tunnel mpls traffic-eng bandwidth 1000000
tunnel mpls traffic-eng path-option 1 dynamic bandwidth 1000000
tunnel mpls traffic-eng path-option 5 explicit name Saki2Simf bandwidth 1000000
tunnel mpls traffic-eng record-route
tunnel mpls traffic-eng path-selection metric te
tunnel mpls traffic-eng auto-bw frequency 600
tunnel mpls traffic-eng load-share 1
interface Tunnel1
description Saki2SimfB
load-interval 30
tunnel mpls traffic-eng path-option 5 explicit name Saki2SimfB bandwidth 100000
interface Vlan200
description -= LSP1 =-
mtu 8978
ip address 10.0.2.1 255.255.255.254
ip ospf network point-to-point
ip ospf mtu-ignore
ip ospf 1 area 10
load-interval 30
carrier-delay msec 0
mpls ip
mpls mtu 2048
mpls traffic-eng administrative-weight 10
ip rsvp bandwidth 100000
ip rsvp signalling hello
interface Vlan300
description -= LSP2 =-
mtu 8978
ip address 10.0.2.3 255.255.255.254
ip ospf mtu-ignore
ip ospf 1 area 10
load-interval 30
mpls ip
mpls mtu 2048
mpls traffic-eng administrative-weight 100
ip rsvp bandwidth 1000000
router ospf 1
router-id 193.27.243.10
area 10 stub
redistribute connected
mpls traffic-eng router-id Loopback0
mpls traffic-eng area 10
Собственно вопрос
LSP поднимаются и со стороны Juniper и со стороны ME , проблема в том что трафик со стороны ME в сторону Juniper не попадает в тунель а со строны Juniper в сторону ME бежит по тунелю
show mpls lsp statistics
Ingress LSP: 2 sessions
To From State Packets Bytes LSPname
193.27.243.10 195.3.244.10 Up 1212 68322 Simf2Saki
193.27.243.10 195.3.244.10 Up 20561 30735751 Simf2SakiB
Total 2 displayed, Up 2, Down 0
Egress LSP: 2 sessions
195.3.244.10 193.27.243.10 Up NA NA Saki2Simf
195.3.244.10 193.27.243.10 Up NA NA Saki2SimfB
show mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or Tunnel Id Switched interface
17 [T] Pop Label 195.3.244.10/32 0 Tu0 point2point
[T] Pop Label 195.3.244.10/32 0 Tu1 point2point
807 No Label l2ckt(1) 52110 Vl50 point2point
show ip cef
Prefix Next Hop Interface
0.0.0.0/0 195.3.244.10 Tunnel0
195.3.244.10 Tunnel1
mtu 9000;
unit 200 {
vlan-id 200;
family inet {
family mpls {
mtu 1538;
unit 300 {
vlan-id 300;
family inet {
family mpls {
mtu 1538;
traceoptions {
interface lo0.0;
path-mtu {
rsvp mtu-signaling;
traceoptions {
to 193.27.243.10;
bandwidth 100m;
priority 2 2;
primary Simf2Saki;
to 193.27.243.10;
bandwidth 100m;
priority 4 4;
primary Simf2SakiB;
path Simf2Saki {
10.0.2.1;
path Simf2SakiB {
10.0.2.3;
interface lo0.0;
traceoptions {
area 0.0.0.0 {
area 0.0.0.10 {
interface-type p2p;
interface-type p2p;
interface lo0.0;
interface Loopback0
ip ospf 1 area 10
interface Tunnel0
load-interval 30
interface Tunnel1
load-interval 30
interface Vlan200
mtu 8978
ip ospf mtu-ignore
ip ospf 1 area 10
load-interval 30
mpls ip
mpls mtu 2048
interface Vlan300
mtu 8978
ip ospf mtu-ignore
ip ospf 1 area 10
load-interval 30
mpls ip
mpls mtu 2048
router ospf 1
area 10 stub
Собственно вопрос
show ip cef
а вы уверены в том что MPLS TE пашет с OSPF stub ;)
Edited by applx
Команда
засовывает в OSPF, adjastency до 195.3.244.10 сквозь ваши туннели, OSPF кост этих adjastency, равен наименьшему OSPF косту по реальным линкам. Соответственно в текущем виде, у вас должен получиться equal-cost multipath по трем LSP, нормальному LDPшному, и двумя туннельными. Чтобы это изменить нужно сделать так, чтобы OSPF cost анонсируемых туннелей был меньше чем реальный OSPFвный кост, делается это например так:
tunnel mpls traffic-eng autoroute metric relaitve -1
Возможно конечно, вы изменили это дефолтное поведение командами
Команда
Изменил
mpls traffic-eng administrative-weight - заменяем метрику IGP
tunnel mpls traffic-eng path-selection metric te - используем метрику administrative-weight при выборе туннеля
Но проблема в том , что трафик бежит по raw ip и никаким образом использовать lsp не хочет .
Тогда смотрите sh ip ospf database, с какой метрикой анонсируется маршрут через TE туннель, с какой - через raw ip.
Так или иначе autoroute annaunce всего лишь запихивает полученный MPLS TE туннель в OSPF database
Какой трафик Вы пытаетесь передать в тоннель и почему Вы думаете, что он туда не идет?
Любой ipv4 , где destanations any , те все что уходит в default gateway согласно
Считаю что не идет , потому что я его не вижу на Juniper
Я его не вижу на ME36
На оборудовании Cisco и Juniper по умолчанию включен PHP. Т.е. tail-end маршрутизатор для LSP анонсирует для него implicit null метку. И на последнем хопе в LSP метка не используется. По этой причине egress маршрутизатор не может идентифицировать входящий трафик, как трафик, пришедший из LSP. Именно поэтому в статистике Juniper-а стоит NA.
Командочка show mpls forwarding-table показывает статистику про трафик, который был скоммутирован по меткам. Т.е. чтобы там не было нулей устройство должно делать MPLS транзит. У Вас оно скорее всего не так.
Посмотрите лучше на интерфейсную статистику: show int tun1 Не знаю, как на ME, но на 76 и программных оно правду показывало.
Edited by nnm
MPLS коммутации по дороге нет , Juniper и ME включены "друг в друга" 2 вланами растянутыми по физике двух разных транспортных опрераторов .
Насколько я понимаю видимость Juniper c ME через тунель есть
ping mpls ipv4 195.3.244.10/32
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Total Time Elapsed 8 ms
show interfaces tunnel 1 summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* Tunnel1 0 0 0 0 0 0 0 0 0
#show interfaces tunnel 0 summary
*: interface is up
* Tunnel0 0 0 0 0 0 0 0 0 0
Edited by hub3
Возможно :)
Только проверяется это другой командой. Суффикс ipv4 значит, что Вы хотите использовать LDP FEC. Чтобы послать MPLS пинг в тоннель нужно писать что-то вроде tunnel-te <имя тоннеля>
Подробности вот здесь: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mpls/command/mp-cr-book/mp-m4.html#wp1468850429
ping mpls traffic-eng tunnel 0 verbose
Type escape sequence to abort.
! size 100, reply addr 195.3.244.10, return code 3
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
ping mpls traffic-eng tunnel 1 verbose
Total Time Elapsed 4 ms
  • 2 months later...
Читаю очередную статью про RSVP-TE, в 100й раз повторяется что для определенного типа трафика мы можем организовать защищенный канал, предоставить ему QoS, проложить через определённые узлы.
Но как это достигается когда у нас, например, между двумя PE просигнализирована одна RSVP LSP и есть два клиента которые купили допустим L3VPN на этой паре PE, причем трафик только одного нужно отправить "оптимальным" путем по дорогому линку к примеру. Ведь нужно как-то промаппить этот VPN к защищенному LSP, а другой отправить по обычному.
В Juniper есть политика в forwarding table на export где такое возможно, но как мне кажется это не best-pracice. а в циске есть что-то подобное?
И вообще правильно ли я понял логику...
1. Можно использовать difserv-te. Но я чесно не видел, чтобы SP использовали эту схему
2. Использовать на джуне экспопт на fib это нормальная практика.
почему ж везде тыкают в эту фичу...
спасибо. а в последнем терме нужно писать " then load balance per-packet" ?
В MPLS и TE не силён, но по-идее статически VPN-ы можно прибить к тоннелям вот так. Оно?
в принципе да, но думал что это фича более распространена и используема.
чет бред в статье:
LDP Adjacency over MPLS TE:
Since LDP was enabled on MPLS TE tunnels, LDP forms adjacency over TE tunnels. This is important for label exchange for Loopback prefixes 11.2.2.2/32 and 22.2.2.2/32 on PE3 router, and 11.1.1.1/32 and 22.1.1.1/32 on PE1 router
Зачем включать mpls ip на туннеле в данной топологии?
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/mpls/configuration/guide/b_mpls_cg43xasr9k/b_mpls_cg43asr9k_chapter_0100.html#con_1325561
чет бред в статье:
VPN-ы прибиты к лупам. Эти-же лупы в кач-ве unnambered ифейсов для TE. В кач-ве BGP-NH для впн-ов используются адреса этих лупов.
То есть ими нужно обменяться чтобы построился FEC через тоннель.
Вроде так?
(повторюсь: в MPLS не силён)
Нет, не так. ТЕ туннель - односторонний.
mpls ip внутри тоннеля нужен в другом случае с другой топологией.
Да, действительно. Я начал думать об одном, а в итоге пришёл к чему-то совершенно постороннему.
Я почему-то подумал, что LSP будет строиться поверх тоннеля, рассмотрев его как обычный тоннель.
