Jazzy$
Пользователи
  • Публикации
    55
  • Зарегистрирован
  • Посещение
О Jazzy$
  • Звание
    Абитуриент
    Абитуриент
Контакты
  • ICQ
    Array
Посетители профиля
1466 просмотров профиля
  1. Берите 7210 Mxp, в нем четыре порта sfp+ Насколько я помню, платы расширения больше не производятся. А может и Эмка тоже End of Sale. Если надо - могу у Нокии узнать, пиши в ЛС.
  2. Мы ставим гиговые, только порт в 100м переводим - решение более универсальное.
  3. У Алкателя нужно смотреть доку по конкретной железке + конкретной adapter card + версии софта. Например на 7705 SAR OS: "This command overrides the default Committed Buffer Space (CBS) reserved for buffers of a specified queue. The value is configured in kilobytes. The value in kilobytes is converted automatically to the number of buffers. The conversion calculation uses a non-configurable buffer size of 2304 bytes or 512 bytes, depending on the type of adapter card. See Table 4 for a list of adapter cards and their associated buffers. The calculation is: Number of buffers = Configured CBS value in bytes / Buffer size in bytes At the egress of an N > 1 Apipe, the CBS value in a SAP egress QoS policy that is assigned to a SAP aggregation group causes n times that value of buffers to be committed, where n is the number of SAPs in the SAP aggregation group. See the show pools command for information about how to view buffer pools for SAPs that are members of a SAP aggregation group. See the 7705 SAR OS Services Guide for information about how to configure SAP aggregation groups. Default “default” (8 kbytes for adapter cards and platforms with 512 byte buffer size) (18 kbytes for adapter cards and platforms with 2304 byte buffer size). Parameters size-in-kbytes — this parameter is an integer expression of the number of kilobytes reserved for the queue. A value of 0 specifies that no reserved buffers are required by the queue (a minimal reserved size can still be applied for scheduling purposes). Values 0 to 131072 default — returns the CBS size to the default value"
  4. "С 1 декабря 2013 года вы сможете стать абонентом «Билайн», сохранив номер своего мобильного телефона из сотовой сети другого оператора." http://mobile.beeline.ru/murmansk/services/service.wbp?id=a798e776-62f1-470f-b5b3-2374d0d16c82
  5. vlan
    Но в антеге будет только тот влан, pvid которого прописан на порту. show gvrp <portlist> config gvrp <portlist> pvid <vlanid 1-4094>
  6. Есть еще ограничение в 256 интерфейсов в одном VPN на коробку. По 9300 было несколько тем уже, рекомендую так же ознакомиться: http://forum.nag.ru/forum/index.php?showtopic=73102&st=0&p=684384&hl=9300 http://forum.nag.ru/forum/index.php?showtopic=58044&st=0&p=628541&hl=9300
  7. Конечно, ведь на 2950 ip-интерфейсы создаются по умолчанию выключенными.
  8. 1. Можно, управляющий трафик не так велик. 2. Да, но управление я бы вынес в отдельный vrf, пусть даже и локальный.
  9. В него еще и лицензию нужно, для активации некоторых фич.
  10. Причем менять с запасом... 1536 или как РТК 9000...
  11. Берете тестер и смотрите, что на каких клеммах выдает ваш БП. Далее минус прикручиваете на "-48V" DSLAMa, а плюс на "RTN".
  12. Ну как я и думал. Апгрейд на версию выше - новый файл лицензий.
  13. Так это еще и лицензия новая нужна же?
  14. Сколько меток сейчас на 9300? Было то же самое, когда кол-во меток достигло 8 тысяч.
