Доброго времени суток. При установки collectd выдает ошибку
* Running autoconf ... [ !! ]
* Failed Running autoconf !
* Include in your bugreport the contents of:
* /var/tmp/portage/app-admin/collectd-5.0.0-r1/temp/autoconf.out
* ERROR: app-admin/collectd-5.0.0-r1 failed (prepare phase):
* Call stack:
* ebuild.sh, line 56: Called src_prepare
* environment, line 4301: Called eautoreconf
* environment, line 1489: Called eautoconf
* environment, line 1425: Called autotools_run_tool 'autoconf'
* environment, line 748: Called die
* The specific snippet of code:
* die "Failed Running $1 !";
* If you need support, post the output of 'emerge --info =app-admin/collectd-5.0.0-r1',
* the complete build log and the output of 'emerge -pqv =app-admin/collectd-5.0.0-r1'.
* The complete build log is located at '/var/tmp/portage/app-admin/collectd-5.0.0-r1/temp/build.log'.
* The ebuild environment file is located at '/var/tmp/portage/app-admin/collectd-5.0.0-r1/temp/environment'.
* S: '/var/tmp/portage/app-admin/collectd-5.0.0-r1/work/collectd-5.0.0'
>>> Failed to emerge app-admin/collectd-5.0.0-r1, Log file:
* Messages for package app-admin/collectd-5.0.0-r1:
* Call stack:
Как вылечить?
