Приветствую. Не могу победить аггрегацию портов на A28E. Коммутатор лупит броадкаст пакеты в транке. Разные A28E, подключены к разным коммутаторам (Dlink, SNR) симптомы одинаковые. Текущая конфигурация:
Alpha-A28E#sh running-config
System current configuration:
!NOS Version NOS_4.14.1968.Alpha-A28E.002.20160302
!command in view_mode
!command in config_mode first-step
create vlan 100,200 active
lacp timeout fast
ip igmp snooping
mvr enable
mvr vlan 100
mvr vlan 100 group any
!command in aclmap_mode
!command in ipv6 aclmap_mode
!command in enable_mode
clock timezone + 6 0
!command in region_mode
!command in ip igmp profile mode
!command in service_mode
!command in port_mode
interface port 1-24
switchport access egress-allowed vlan 100
mvr type receiver
mvr immediate
interface port 25-28
switchport trunk allowed vlan 100,200
switchport mode trunk
ip dhcp snooping trust
mvr type source
!command in vlan configuration mode
!command in ip interface mode
interface ip 0
ip vlan 200
ip address 10.200.4.27 255.255.255.0 200
!command in cmap_mode
!command in pmap_mode
!command in aclgroup_mode
ip default-gateway 10.200.4.1
trunk loading-sharing mode smac
trunk group 1 port 25,26 lacp-static
snmp-server location 6-51
ip dhcp snooping
ip dhcp information option
logging file
sntp server 10.200.1.1
loopback-detection enable port-list 1-24
loopback-detection hello-time 1
loopback-detection down-time 60
lldp enable
Alpha-A28E#
Alpha-A28E#sh trunk
Trunk: Enable
Loading sharing mode: SMAC
Trunk Group Mode Member Ports Efficient Ports
1 static 25,26 25,26
Alpha-A28E#sh lacp internal
Flags:
S - Device is requesting Slow LACPDUs
F - Device is requesting Fast LACPDUs
A - Device is in Active mode
P - Device is in Passive mode
Port State Flags Port-Pri Admin-key Oper-key Port-State
25 active FA 32768 0x1 0x1 0x3F
26 active FA 32768 0x1 0x1 0x3F
Alpha-A28E#sh la
Alpha-A28E#sh lacp ne
Alpha-A28E#sh lacp neighbor
Flags:
Port Flags Port-Pri Dev-ID Age Oper-key Parter-Port Port-State
25 FA 1 ACF1.DF94.9600 0s 0x5 0x5 0x3F
26 FA 1 ACF1.DF94.9600 0s 0x5 0x6 0x3F
Аплинк
DGS-3420-28SC:admin#show link_aggregation group_id 3
Command: show link_aggregation group_id 3
Group ID : 3
Type : LACP
Master Port : 5
Member Port : 5-6
Active Port : 5-6
Status : Enabled
Flooding Port : 5
Trap : Disabled
Total Entries : 1
DGS-3420-28SC:admin#show lacp_port 5-6
Command: show lacp_port 5-6
Port Activity
5 Active
6 Active
Как только включаю второй порт, в дампе начинается флуд таких пакетов, данный мак начинает светиться на транковых портах.
00:25:90:6f:f9:03 > ff:ff:ff:ff:ff:ff, ethertype IPv4 (0x0800), length 606: (tos 0x0, ttl 64, id 0, offset 0, flags [none], proto UDP (17), length 592)
0.0.0.0.68 > 255.255.255.255.67: [udp sum ok] BOOTP/DHCP, Request from 00:25:90:6f:f9:03, length 564, xid 0x163cba70, Flags [none] (0x0000)
Client-Ethernet-Address 00:25:90:6f:f9:03
Vendor-rfc1048 Extensions
Magic Cookie 0x63825363
DHCP-Message Option 53, length 1: Discover
Client-ID Option 61, length 7: ether 00:25:90:6f:f9:03
Vendor-Class Option 60, length 12: "udhcp 1.13.2"
MSZ Option 57, length 2: 576
Parameter-Request Option 55, length 7:
Subnet-Mask, Default-Gateway, Domain-Name-Server, Hostname
Domain-Name, BR, NTP
Agent-Information Option 82, length 14:
Circuit-ID SubOption 1, length 4: ^@M-H^A^Z
Remote-ID SubOption 2, length 6: M-xM-pM-^Bq^IM-^\
END Option 255, length 0
PAD Option 0, length 0, occurs 268
В мануал режиме то же самое. То же самое с на стыке с SNR. Есть подозрение, что это какой то волшебный не стандартный dhcp запрос, или же я не дочитал мануалы по настройке, кто-нибудь сталкивался?
