NAS na mikrotik. PC router. Setevushki realtek 8169 Gigabit
ping s PC napramyu patchcordom
C:\Windows\system32>ping 192.168.100.254 -t
Pinging 192.168.100.254 with 32 bytes of data:
Reply from 192.168.100.254: bytes=32 time=63ms TTL=64
Reply from 192.168.100.254: bytes=32 time=61ms TTL=64
Reply from 192.168.100.254: bytes=32 time=59ms TTL=64
Reply from 192.168.100.254: bytes=32 time=57ms TTL=64
Reply from 192.168.100.254: bytes=32 time=55ms TTL=64
Reply from 192.168.100.254: bytes=32 time=53ms TTL=64
Reply from 192.168.100.254: bytes=32 time=52ms TTL=64
Reply from 192.168.100.254: bytes=32 time=50ms TTL=64
Reply from 192.168.100.254: bytes=32 time=48ms TTL=64
Reply from 192.168.100.254: bytes=32 time=46ms TTL=64
Reply from 192.168.100.254: bytes=32 time=45ms TTL=64
Reply from 192.168.100.254: bytes=32 time=44ms TTL=64
Reply from 192.168.100.254: bytes=32 time=43ms TTL=64
Reply from 192.168.100.254: bytes=32 time=42ms TTL=64
Reply from 192.168.100.254: bytes=32 time=40ms TTL=64
Reply from 192.168.100.254: bytes=32 time=38ms TTL=64
Reply from 192.168.100.254: bytes=32 time=36ms TTL=64
Reply from 192.168.100.254: bytes=32 time=34ms TTL=64
Reply from 192.168.100.254: bytes=32 time=32ms TTL=64
Reply from 192.168.100.254: bytes=32 time=30ms TTL=64
Reply from 192.168.100.254: bytes=32 time=28ms TTL=64
Reply from 192.168.100.254: bytes=32 time=27ms TTL=64
Reply from 192.168.100.254: bytes=32 time=26ms TTL=64
Reply from 192.168.100.254: bytes=32 time=23ms TTL=64
Reply from 192.168.100.254: bytes=32 time=22ms TTL=64
Reply from 192.168.100.254: bytes=32 time=21ms TTL=64
Reply from 192.168.100.254: bytes=32 time=19ms TTL=64
Reply from 192.168.100.254: bytes=32 time=17ms TTL=64
Reply from 192.168.100.254: bytes=32 time=14ms TTL=64
Reply from 192.168.100.254: bytes=32 time=12ms TTL=64
Reply from 192.168.100.254: bytes=32 time=10ms TTL=64
Reply from 192.168.100.254: bytes=32 time=8ms TTL=64
Reply from 192.168.100.254: bytes=32 time=6ms TTL=64
Reply from 192.168.100.254: bytes=32 time=5ms TTL=64
Reply from 192.168.100.254: bytes=32 time=3ms TTL=64
Reply from 192.168.100.254: bytes=32 time<1ms TTL=64
Reply from 192.168.100.254: bytes=32 time=98ms TTL=64
Reply from 192.168.100.254: bytes=32 time=97ms TTL=64
Reply from 192.168.100.254: bytes=32 time=96ms TTL=64
Reply from 192.168.100.254: bytes=32 time=95ms TTL=64
Ping s NAS do yandex normalnyi. Patchcord menyal.
V chem mozhet bit' problema?
Spasibo.
Sorry, na workstation net rus raskladki.
Лишнего бриджа нет?
net nichego krome ip adresa na interface i masquarading.
Razobralsya. Vikinul tolko chto raspakovannuyu setevushku. Postavil druguyu. Vse OK.
Proshu prosheniya za paniku. Spasibo.
