Edward78 Posted December 20, 2023 Posted December 20, 2023 После перезагрузки нормально пишет при выводе команды show switch Вставить ник Quote
pilotpuza Posted February 15, 2024 Posted February 15, 2024 Приветствую всех. Коллеги, ни у кого нет прошивки под X440-G2? Выдали коммутатор, не грузится ни с одного образа, бесконечная перезагрузка. Пишет вот чего Copyright 2016 Starting CRC of Default image Using Default image ... Press and hold the <spacebar> to enter the bootrom... Copyright 2016 Starting CRC of Default image Using Default image ... Press and hold the <spacebar> to enter the bootrom... boot_sel image selection invalid, defaulting to primary Setting default value for stack environment variable 1 Setting default value for stack environment variable 9 Setting default value for stack environment variable 8 Setting default value for stack environment variable 11 Setting default value for stack environment variable 10 Setting default value for stack environment variable 2 Setting default value for stack environment variable 4 Setting default value for stack environment variable 5 Setting default value for stack environment variable 8 Setting default value for stack environment variable 9 Setting default value for stack environment variable 10 Setting default value for stack environment variable 11 Starting ExtremeXOS 21.1.3b7 Copyright (C) 1996-2016 Extreme Networks. All rights reserved. This product is protected by one or more US patents listed at http://www.extremenetworks.com/patents along with their foreign counterparts. Setting default value for stack environment variable 10 readObject failed with -11Process epm pid 1296 died with signal 5 Code: 40a9f0 24a50514 addiu a1,a1,1300 40a9f4 0c101360 jal 0x404d80 (0x80404d80) 40a9f8 00403021 addu a2,v0,zero 40a9fc <00000034>????????????????????????? OP 0Unknown at 0x40a9fc, 0x00000034, op 0 40aa00 24040001 addiu a0,zero,1 40aa04 24a51f70 addiu a1,a1,8048 40aa08 0c101360 jal 0x404d80 (0x80404d80) 40aa0c 02803021 addu a2,s4,zero 40aa10 08102a34 j 0x40a8d0 ***** ***** ERROR: EXOS startup failed -- rebooting system ***** Sending SIGKILL to all processes Requesting system reboot Restarting system. Вставить ник Quote
asrer Posted March 23, 2024 Posted March 23, 2024 Коллеги, а ни у кого нет BootROM: 2.0.2.3 для х440?, когда то здесь брал, но к сожалению файлы уже недоступны ( Вставить ник Quote
GREEN_Line_TAP Posted December 15, 2024 Posted December 15, 2024 (edited) Присоединился бы к запросу . Честно бы весь список bootrom бы иметь Пожалуйста, если есть у кого - поделитесь.... Вот например у меня есть SummitX-pmon_Combined_1.0.3.1.xtr - но, не уверен что оно верное и что это реально всем Extreme подходящее, так как по некоторым источникам наименование расширения файла должно быть (.xtr.bin) (статья правда относится к G2 - а файл называется приблизительно так - u-boot-oct-def-rel-1.0.2.1.xtr.bin), а ко мне файл SummitX-pmon_Combined_1.0.3.1.xtr из доступных источников попал внутри папки (Summit X250e), что вроде бы указывает на его принадлежность к серии 250... Прошиться и окирпичить устройство совсем не хотелось.... Может кто знает как уже установленную прошивку и/или bootloader скаЧать обратно в файл образа ?-) чтобы так сказать с еще живых экземпляром лечить уже не совсем живые полукирпичи ++++++++++++++++++++++++++ Скажите еще, Люди дорогие, кто знает ? С какой версии Bootloader они в целях безопасности отключили config none unconfigure switch all в 2.0.2.1 уже точно нет этого в 1.0.1.8 и 1.0.2.1 точно было можно использовать "config none", но вот до какой версии? (участвовал в испытании x440-48 первое поколение, хотя в тестах и по огромному количеству x460-g2, x670-G2 - все они были поголовно с версией bootloader 1.0.2.1 или 1.0.1.8 и подобными) Вот образец как это выглядит в 1.0.2.1 "BootRom > help ? - alias for 'help' boot - boot primary or secondary OS image clearcmd - clear cmdline in sram config - Specifies using no configuration configip - configure Mgmt Ethernet network parameters download - download OS image to recover flash drive help - print command description/usage mtest - simple RAM read/write test ping - send ICMP ECHO_REQUEST to network host printenv - print environment variables reboot - Reset system setdiag - set sram diag type tag and value update - update bootloader images from network version - display build date, alternate and default bootloader image version BootRom > version Copyright 2014 Extreme Networks, Inc. (Jun 04 2014 - 14:35:21) Alternate Bootstrap = 1.0.2.1 Default Bootloader = 1.0.2.1 BootRom > config ? config - Specifies using no configuration Usage: config none BootRom > config none" А уже вот так выглядит в 2.0.2.1 "BootRom > config config: Command not found. Try 'h' for help" И нет ли у кого понимания, что за команда loader и чьей загрузкой у куда она командует в Bootloader 2.0.2.1 "BootRom > help Boot and Load -------------- pboot boot oload load memory from hostport load load file boot boot an image Misc -------------- loader Sets which BootLoader BootStrap will boot" Информации по команде LOADER в BootRom не нашел, и ни какой помощи, подсказок не увидел, как и в открытых источниках... Edited December 15, 2024 by GREEN_Line_TAP Вставить ник Quote
techich Posted July 8, 2025 Posted July 8, 2025 Коллеги, поделитесь пожалуйста Bootrom для х460 2.0.2.3 или подскажите как можно их получить на https://extreme-networks.my.site.com/ Вставить ник Quote
onik Posted March 28 Posted March 28 Здравствуйте коллеги! Поделитесь пжлста может у кого есть прошивка на Extreme 200 серии 1.02.06.0009. Заранее благодарю. Вставить ник Quote
uxcr Posted September 11 Posted September 11 Есть старый свич ещё выпускавшийся avaya https://documentation.extremenetworks.com/release_notes/ERS_Series/ERS4800/ERS4800ReleaseNotes_5.12.6_RN.pdf может у кого найдётся последняя прошивка под ERS4850GTS ? Вставить ник Quote
