alexaaa Posted January 23, 2011 Posted January 23, 2011 (edited) Кто сталкивался с этой софтиной, очень мало информации и много непонятного как создать l2tp сервер. Здесь можно почитать http://wiki.debian.org/ru/OpenL2TP?action=...t=ru%2Fopenl2tp Здесь скачать ftp://ftp.openl2tp.org/releases У кого работает такой сервер? А вот пример конфига сервера: > LNS SERVER config > > ======================================================================== > > peer profile modify profile_name=default \ > tunnel_profile_name=lns1 \ > session_profile_name=lns1 \ > ppp_profile_name=lns1\ > lac_lns=lns\ > > tunnel profile create profile_name=lns1 our_udp_port=1701\ > auth_mode=challenge \ > rx_window_size=256 \ > tx_window_size=256 \ > secret=test \ > trace_flags=4294967295 \ > ppp_profile_name=lns1 \ > do_pmtu_discovery=no \ > mtu=1492 \ > peer_profile_name=default \ > session_profile_name=lns1 \ > > > session profile create profile_name=lns1 \ > ppp_profile_name=lns1 \ > session_type=lnic \ > framing_type=any \ > bearer_type=any \ > reorder_timeout=30 \ > > > ppp profile create profile_name=lns1 \ > local_ipaddr=10.10.10.1 \ > ip_pool_name=default \ > radius_hint=/etc/radiusclient/radiusclient.conf\ > use_radius=yes \ > multilink=yes \ > > ============================================================================ > > LAC SERVER config > > ============================================================================ > > tunnel create tunnel_name=tun1 dest_ipaddr=192.168.123.102 secret=test \ > > session create tunnel_name=tun1 user_name=debian1 user_password=test > > peer profile modify profile_name=default \ > lac_lns=lns \ > ppp_profile_name=lns1\ > > ppp profile create profile_name=lns1 \ > ip_pool_name=default \ > multilink=yes \ > use_radius=yes \ > radius_hint=/etc/radiusclient/radiusclient.conf Edited January 23, 2011 by alexaaa Вставить ник Quote
Abram Posted January 23, 2011 Posted January 23, 2011 Вам IPSec нужен или просто как замена PPTP? Во втором варианте - accel-pppd. Вставить ник Quote
alexaaa Posted January 23, 2011 Author Posted January 23, 2011 Вам IPSec нужен или просто как замена PPTP? Во втором варианте - accel-pppd. замена PPTP. accel-ppp уже тестировали. Вставить ник Quote
naves Posted January 23, 2011 Posted January 23, 2011 xl2tpd with IPSec с вендой работает, настраивается так же как и pptpd, конфиги практически идентичны Вставить ник Quote
alexaaa Posted January 23, 2011 Author Posted January 23, 2011 (edited) xl2tpd with IPSec с вендой работает, настраивается так же как и pptpd, конфиги практически идентичны xl2tp тестировали тоже, он CID в биллинг не передаёт. привязка не работает поэтому не подходит. хотелось бы openl2tp испытать. Edited January 23, 2011 by alexaaa Вставить ник Quote
Abram Posted January 24, 2011 Posted January 24, 2011 Я как-то с openl2tp игрался. Мой вам совет: он слишком монструозен для такой просто задачи. Если хотите PPP over L2TP - не ебите себе мозги. Поставьте accel-pppd. Вставить ник Quote
alexaaa Posted January 25, 2011 Author Posted January 25, 2011 Я как-то с openl2tp игрался. Мой вам совет: он слишком монструозен для такой просто задачи. Если хотите PPP over L2TP - не ебите себе мозги. Поставьте accel-pppd. с accel-ppp намучались, используем одновременно на нём pptp и l2tp, падает, причём самые новые версии использовали, может есть конфиг openl2tp. Вставить ник Quote
Abram Posted January 25, 2011 Posted January 25, 2011 (edited) Я как-то с openl2tp игрался. Мой вам совет: он слишком монструозен для такой просто задачи. Если хотите PPP over L2TP - не ебите себе мозги. Поставьте accel-pppd. с accel-ppp намучались, используем одновременно на нём pptp и l2tp, падает, причём самые новые версии использовали, может есть конфиг openl2tp. ССЗБ. Собирайте в Debug, запускайте под gdb, в случае падения делайте bt и результат - в соседнюю тему. xeb довольно оперативно фиксит баги (например, у меня падало, отправлял репорты - итого уже 2 или 3 штуки исправлено, в результате все стабильно работает). Edited January 25, 2011 by Abram Вставить ник Quote
alexaaa Posted January 26, 2011 Author Posted January 26, 2011 +1. На mpd тоже работает. mpd пробовали, FreeBSD не больно владеeм, но хорошего результата не добились, у нас пока на 700 онлайн клиетов, трафик 400 Мбит/с на сервере пролетает. Вставить ник Quote
