Доброго времени суток, коллеги!
Вопрос конечно похож на ламерский, но все же прошу помочь.
Прелюдия: сеть провайдера 10.100.83.0/24
Инет через PPPoE.
Внутренняя сеть 192.168.15.0/24
Хаб DC++ 10.10.9.1
Харрактеристики роутера:
server# ifconfig
ste0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=8<VLAN_MTU>
inet 10.100.83.3 netmask 0xffffff00 broadcast 10.100.83.255
ether 00:22:15:d6:56:09
media: Ethernet autoselect (100baseTX <full-duplex>)
status: active
rl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=8<VLAN_MTU>
inet 192.168.15.1 netmask 0xffffff00 broadcast 192.168.15.255
ether 00:50:22:a4:21:7f
status: active
plip0: flags=108810<POINTOPOINT,SIMPLEX,MULTICAST,NEEDSGIANT> mtu 1500
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
inet6 ::1 prefixlen 128
inet 127.0.0.1 netmask 0xff000000
tun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1480
inet 172.16.yyy.xxx --> 172.16.0.0 netmask 0xffffffff
Opened by PID 434
server#
server# vi /etc/rc.conf
# -- sysinstall generated deltas -- # Fri May 1 20:05:21 2009
# Created: Fri May 1 20:05:21 2009
# Enable network daemons for user convenience.
# Please make all changes to this file, not to /etc/defaults/rc.conf.
# This file now contains just the overrides from /etc/defaults/rc.conf.
##nat##
gateway_enable="YES"
inetd_enable="YES"
natd_enable="YES"
natd_program="/sbin/natd"
natd_interface="ste0"
natd_flags="-u -s -m"
##ipfw###
firewall_enable="YES"
#firewall_script="/etc/rc.firewall"
firewall_type="/usr/local/etc/firewall.conf"
keymap="ru.koi8-r"
linux_enable="YES"
sshd_enable="YES"
# -- sysinstall generated deltas -- # Fri May 1 16:12:44 2009
ifconfig_ste0="inet 10.100.83.100 netmask 255.255.255.0"
defaultrouter="10.100.83.1"
hostname="server.rialcom.ru"
###pppoe####
ppp_enable="YES"
ppp_mode="ddial"
ppp_profile="rialcom"
# -- sysinstall generated deltas -- # Fri May 1 18:43:40 2009
ifconfig_rl0="inet 192.168.15.1 netmask 255.255.255.0"
# added by xorg-libraries port
local_startup="/usr/local/etc/rc.d"
static_routes="corbina1 corbina2 corbina3 corbina4"
route_corbina1="10.0.0.0/8 10.100.83.1"
# -- sysinstall generated deltas -- # Sun May 3 05:06:18 2009
ifconfig_ste0="DHCP"
/etc/rc.conf: unmodified: line 1
server# vi /usr/local/etc/firewall.conf
add 99 divert natd all from any to any out xmit ste0
add 100 divert natd all from any to me in recv ste0
add 200 allow all from any to any via lo0
add 210 deny tcp from any to me 20001
add 300 allow all from any to any via rl0
add 400 allow ICMP from any to any
add 500 allow udp from any to any 53 out
add 501 allow udp from any 53 to any
add 600 allow tcp from any to any 80,8080
add 601 allow tcp from any 80,8080 to any
add 700 allow tcp from any to any 22
add 701 allow tcp from any 22 to any
add 801 allow tcp from any to any 443
add 901 allow tcp from any 443 to any
add 910 allow tcp from any to any 5190
add 920 allow tcp from any 5190 to any
add 930 allow tcp from any to any 25,110
add 940 allow tcp from any 25,110 to any
###dc++###
add 931 allow tcp from any to any 30988
add 932 allow udp from any to any 22692
add 941 allow tcp from any 30988 to any
add 942 allow udp from any 22692 to any
add 945 allow gre from any to any
add 800 allow ip from me to 10.10.0.0/16 via ste0 keep-state
###torrents###
add 935 allow tcp from any to any 24432
add 936 allow udp from any to any 24432
add 937 allow tcp from any 24432 to any
add 938 allow udp from any 24432 to any
#Zapret X-scan:
add 1001 reject log tcp from any to any tcpflags fin, syn, rst, psh, ack, urg
#Zapret FIN-scan:
add 1003 reject log tcp from any to any not established tcpflags fin
#Zachita ot spuffinga
add 1004 deny log ip from any to any not verrevpath in
#ogranichenie soedineniy:
add 1005 allow ip from any to any setup limit src-addr 100
/usr/local/etc/firewall.conf: unmodified: line 1
server# ping 10.10.9.1
PING 10.10.9.1 (10.10.9.1): 56 data bytes
64 bytes from 10.10.9.1: icmp_seq=0 ttl=62 time=1.493 ms
64 bytes from 10.10.9.1: icmp_seq=1 ttl=62 time=0.931 ms
^C
--- 10.10.9.1 ping statistics ---
2 packets transmitted, 2 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.931/1.212/1.493/0.281 ms
server#
Хррактеристики клиента:
ОС: вигда
C:\Documents and Settings\_dmitr_>ipconfig
Настройка протокола IP для Windows
Подключение по локальной сети - Ethernet адаптер:
DNS-суффикс этого подключения . . :
IP-адрес . . . . . . . . . . . . : 192.168.15.22
Маска подсети . . . . . . . . . . : 255.255.255.0
Основной шлюз . . . . . . . . . . : 192.168.15.1
C:\Documents and Settings\_dmitr_>ping 10.10.9.1
Обмен пакетами с 10.10.9.1 по 32 байт:
Ответ от 10.10.9.1: число байт=32 время=1мс TTL=61
Ответ от 10.10.9.1: число байт=32 время<1мс TTL=61
Статистика Ping для 10.10.9.1:
Пакетов: отправлено = 4, получено = 4, потеряно = 0 (0% потерь),
Приблизительное время приема-передачи в мс:
Минимальное = 0мсек, Максимальное = 1 мсек, Среднее = 0 мсек
C:\Documents and Settings\_dmitr_>tracert 10.10.9.1
Трассировка маршрута к 10.10.9.1 с максимальным числом прыжков 30
1 <1 мс <1 мс <1 мс 192.168.15.1
2 1 ms 1 ms 1 ms 10.100.83.1
3 * * * Превышен интервал ожидания для запроса.
4 1 ms <1 мс <1 мс 10.10.9.1
Трассировка завершена.
В техподдержку провайдера обращаться бесполезно, там ребята совсем не опытные и ничего посоветовать не смогли, посоветуйте пожалуйста!!!
А в чем, собственно, вопрос? По пробросу порта?
В natd это делается через /etc/natd.conf
redirect_port tcp 192.168.15.22:8444 8444
redirect_port udp 192.168.15.22:8444 8444
Edited by Alexey K
server# cat /etc/natd.conf
redirect_port tcp 192.168.15.22:411 411
redirect_port udp 192.168.15.22:411 411
server#
и не качает :(
Нет, вам не надо прокидывать порт, используемый для соединения с хабом. Нужно прокинуть произвольный порт, описать его в правилах файрволла, а затем, в настройках клиента DC++ нужно выбрать тип соединения как "Firewall with manual port forwarding" (может описываться и по другому), где указать проброшенный порт.
server#
и не качает :(
не помогает, вот что выдает дс киент:
[15:56:17] *** Connecting to 10.10.9.1...
[15:56:17] *** Connected
[15:56:17] <Chehov.NET> This Hub Is Running Version 0.9.8d (Mon Mar 05 18:30 GMT 2007) of VerliHub [RunTime: 6weeks 1days ]. [Current User Count: 252 ].
[15:56:17] <Chehov.NET> This hub is enhanced by plugman for Verlihub.
[15:56:18] <MOTD> WELCOME TO DC++ HUB OF "AMERICA ONLINE" SERVICE PROVIDER
To help type +help in main window.
Please, check our rules, use +rules command.
[15:56:18] <Chehov.NET> Your info:
Nick: dmitrrrr
Class: Guest (0)
IP: 10.100.83.100
Country Code: --
[15:56:19] <Chehov.NET> Your reported IP: 192.168.15.22 does not match your real IP: 10.100.83.100
[15:56:19] *** Disconnected
411-ый порт открыт в фаере на гейте.
  • 3 weeks later...
411-й порт вообще не причём, пробрасывать его не надо. Надо пробросить один tcp (для скачки) и один udp (для поиска) на машину с клиентом. Если машин несколько - на каждую разные (любые незанятые). На всех машинах поставить режим "файрвол с ручным перенаправлением портов", обязательно указать внешний адрес (WAN) - адрес внешнего интерфейса роутера (смотрящий к провайдеру) и проброшенные порты. Всё. Все машины будут в активном режиме
проблема решена, возникла по моей же глупости.
У провайдера сетка по дхцп, а я прописывал статический адрес из сети провайдера, как только сменил на дхцп, был получен тот же адрес и все заработало...
