Rtl8186 Firmware Всем, кто пишет под RTL8186
to sfstudio
Опять ДАП-1160 перешыл в 0.2.10 все работает пучком !!! Да кстати в 0.2.13 опять неработает WPA :-(
вот бут лог 0.2.10 для дап-1160
Mounting ramdisk if RAM >= 16MB
Creating tmpfs and mount it into /var
Create tmpfs and mount it into /var OK
Memsize >= 16MB
Syslog daemon start
DSS file exist
Starting Macaddr: Ok
Starting modules.dep generate...
Starting sysctl: Ok
Starting network...
Starting eth0: ETH0 OK
Starting eth1: ETH1 OK
OK
OK
Vlan
OK
Starting wireless network...
Configure wifi module
Starting wlan0: Change WPA mib
Config OK
Ok
Load bridge modules
Add bridge interface
bridge start eth0
bridge start eth1
bridge start wlan0
Set IP for BR
Bridge up for local br0
From local config
Clean multicast filter on br0
AdvancedBridge options
br0 stp off
br0 FD 0
br0 gcint 0
Select port fo multicast filter
Set multicast bandwidth on eth0
Set multicast bandwidth on eth1
Set multicast bandwidth on br0
Vlan
OK
BurstModeStart
At the end we must add special routes. (you know, default gw, etc..)
Tune up network interfaces Ok
Starting crontab: Ok
Starting inetd: Ok
Starting tc: Loading modules
Set shaper rules
Ok
Starting WPA daemon in client-infra mode
Setting Hostname: Wive-NG
Starting LED: Ok
Starrting boot services and tune system
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.accept_source_route = 0
Tune kernel to minimum memory usadge - 16MB
Tune network stack
net.core.rmem_max = 6090752
net.core.wmem_max = 6090752
net.ipv4.tcp_rmem = 4096 43689 3045376
net.ipv4.tcp_wmem = 4096 16384 3045376
net.ipv4.tcp_mem = 2048 2560 1522688
net.ipv4.netfilter.ip_conntrack_generic_timeout = 60
net.ipv4.netfilter.ip_conntrack_tcp_timeout_established = 30
net.ipv4.ip_conntrack_max = 2048
net.ipv4.netfilter.ip_conntrack_max = 2048
net.ipv4.netfilter.ip_conntrack_icmp_timeout = 30
net.ipv4.netfilter.ip_conntrack_udp_timeout_stream = 120
net.ipv4.netfilter.ip_conntrack_udp_timeout = 30
net.ipv4.netfilter.ip_conntrack_tcp_timeout_close = 10
net.ipv4.netfilter.ip_conntrack_tcp_timeout_time_wait = 60
net.ipv4.netfilter.ip_conntrack_tcp_timeout_last_ack = 30
net.ipv4.netfilter.ip_conntrack_tcp_timeout_close_wait = 60
net.ipv4.netfilter.ip_conntrack_tcp_timeout_fin_wait = 100
net.ipv4.netfilter.ip_conntrack_tcp_timeout_syn_sent = 30
net.ipv4.tcp_keepalive_time = 900
net.ipv4.tcp_keepalive_intvl = 225
net.ipv4.tcp_keepalive_probes = 4
net.ipv4.icmp_echo_ignore_all = 0
net.ipv4.conf.default.proxy_arp = 0
net.ipv4.conf.all.proxy_arp = 0
net.ipv4.neigh.default.gc_thresh3 = 768
net.ipv4.neigh.default.gc_thresh2 = 384
net.ipv4.neigh.default.gc_thresh1 = 32
net.ipv4.neigh.default.gc_interval = 20
net.ipv4.igmp_restrict = 1
net.ipv4.udp_restrict_pu = 1
net.ipv4.tcp_restrict_rst = 1
net.ipv4.tcp_restrict = 1
net.ipv4.icmp_restrict = 1
Start complete at Sat Jan 1 06:00:23 GMT 2000
а также месаге 0.2.10 дап-1160
Jan 1 06:00:05 syslogd started: BusyBox v1.12.4.-wive-ng.sf.net
Jan 1 06:00:05 kernel: klogd started: BusyBox v1.12.4.-wive-ng.sf.net (2009-01-21 00:41:57 OMST)
Jan 1 06:00:06 kernel: Workaround for:Zyxel P330W v.2 and others 16RAM 16Bit devicesLinux version 2.4.18.5-wive-ng.sf.net (wive-ng.sf.net@sfstudio.sadnet.lo) (gcc version 3.3.3) #1742 Wed, 21 Jan 2009 00:44
Jan 1 06:00:06 kernel: early printk enabled
Jan 1 06:00:06 kernel: DetectRAMsequence
Jan 1 06:00:06 kernel: REG returned:32[32]
Jan 1 06:00:06 kernel: RAM after check region:16
Jan 1 06:00:06 kernel: FullviewRAM:16777216
Jan 1 06:00:06 kernel: Determined physical RAM map:
Jan 1 06:00:06 kernel: memory: 01000000 @ 00000000 (usable)
Jan 1 06:00:06 kernel: Initial ramdisk at: 0x80202000 (37845 bytes)
Jan 1 06:00:06 kernel: On node 0 totalpages: 4096
Jan 1 06:00:06 kernel: zone(0): 4096 pages.
Jan 1 06:00:06 kernel: zone(1): 0 pages.
Jan 1 06:00:06 kernel: zone(2): 0 pages.
Jan 1 06:00:06 kernel: Kernel command line: root=/dev/ram console=0 ramdisk_start=0 noisapnp pci=nobios
Jan 1 06:00:06 kernel: 180.22 BogoMIPS
Jan 1 06:00:06 kernel: Memory: 13848k/16384k available (1863k kernel code, 2536k reserved, 156k data, 64k init, 0k highmem)
Jan 1 06:00:06 kernel: Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes)
Jan 1 06:00:06 kernel: Inode-cache hash table entries: 1024 (order: 1, 8192 bytes)
Jan 1 06:00:06 kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Jan 1 06:00:06 kernel: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 06:00:06 kernel: Page-cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 06:00:06 kernel: check_wait... unavailable.
Jan 1 06:00:06 kernel: POSIX conformance testing by UNIFIX
Jan 1 06:00:06 kernel: bogomips: Initialized.
Jan 1 06:00:06 kernel: user_watchdog: Initialized.
Jan 1 06:00:06 kernel: led0: Initialized.
Jan 1 06:00:06 kernel: led1: Initialized.
Jan 1 06:00:06 kernel: sysmem: Initialized.
Jan 1 06:00:06 kernel: Linux NET4.0 for Linux 2.4
Jan 1 06:00:06 kernel: Based upon Swansea University Computer Society NET3.039
Jan 1 06:00:06 kernel: Initializing RT netlink socket
Jan 1 06:00:06 kernel: Starting kswapd
Jan 1 06:00:06 kernel: devfs: v1.10 (20020120) Richard Gooch (rgooch@atnf.csiro.au)
Jan 1 06:00:06 kernel: devfs: boot_options: 0x0
Jan 1 06:00:06 kernel: pty: 256 Unix98 ptys configured
Jan 1 06:00:06 kernel: Serial driver version 6.02 (2003-03-12) with no serial options enabled
Jan 1 06:00:06 kernel: ttyS00 at 0x00c3 (irq = 3) is a rtl_uart1
Jan 1 06:00:06 kernel: state->flags=00000000
Jan 1 06:00:06 kernel: HDLC line discipline: version $Revision: 1.1.1.1 $, maxframe=4096
Jan 1 06:00:06 kernel: N_HDLC line discipline registered.
Jan 1 06:00:06 kernel: block: 64 slots per queue, batch=16
Jan 1 06:00:06 kernel: RAMDISK driver initialized: 16 RAM disks of 512K size 1024 blocksize
Jan 1 06:00:06 kernel: PPP generic driver version 2.4.2
Jan 1 06:00:06 kernel: PPP MPPE Compression module registered
Jan 1 06:00:06 kernel: PPP Deflate Compression module registered
Jan 1 06:00:06 kernel: PPP BSD Compression module registered
Jan 1 06:00:06 kernel: RealTek E-Flash System Driver. © 2002 RealTek Corp.
Jan 1 06:00:06 kernel: Found 1 x 4M Byte MXIC MX29LV320AB at 0xbe000000
Jan 1 06:00:06 kernel: => Scan for ROOT signature in flash from pos=0x000000
Jan 1 06:00:06 kernel: Founded at pos=0x0CFFF4
Jan 1 06:00:06 kernel: Checksumm ok for 0x10C000 bytes calced=0xF53B, stored=0xF53B) Checksumm OK. Use as ROOT partition (/dev/mtd1)
Jan 1 06:00:06 kernel: Reallocate partition for root size=0x10C000 bytes
Jan 1 06:00:06 kernel: Creating 4 MTD partitions on "DiskOnChip Millennium":
Jan 1 06:00:06 kernel: 0x00000000-0x000d0000 : "boot+cfg+linux"
Jan 1 06:00:06 kernel: 0x000d0000-0x001e0000 : "root fs"
Jan 1 06:00:06 kernel: 0x003e0000-0x00400000 : "TGZfs"
Jan 1 06:00:06 kernel: 0x00000000-0x00200000 : "all_flash"
Jan 1 06:00:06 kernel: 8186NIC Ethernet driver v0.1.0-NG (15.10.2008)
Jan 1 06:00:06 kernel: eth0: RTL8186-NIC at 0xbd200000, 00:01:02:03:04:05, IRQ 4
Jan 1 06:00:06 kernel: eth1: RTL8186-NIC at 0xbd300000, 04:05:06:07:08:09, IRQ 5
Jan 1 06:00:06 kernel: Check MII:phy 2, reg 31
Jan 1 06:00:06 kernel: 0x0000ffff
Jan 1 06:00:06 kernel: Check MII:phy 2, reg 26
Jan 1 06:00:06 kernel: Asic.revision=0x00000007
Jan 1 06:00:06 kernel: RTL8185 driver version 1.14 (2008-02-15)
Jan 1 06:00:06 kernel: NET4: Linux TCP/IP 1.0 for NET4.0
Jan 1 06:00:06 kernel: IP Protocols: ICMP, UDP, TCP, IGMP
Jan 1 06:00:06 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes
Jan 1 06:00:06 kernel: TCP: Hash tables configured (established 1024 bind 2048)
Jan 1 06:00:06 kernel: Linux IP multicast router 0.06 plus PIM-SM
Jan 1 06:00:06 kernel: ip_conntrack version 2.1 (5953 buckets, 5953 max) - 320 bytes per conntrack
Jan 1 06:00:06 kernel: PPTP netfilter connection tracking: registered
Jan 1 06:00:06 kernel: ip_tables: © 2000-2002 Netfilter core team
Jan 1 06:00:06 kernel: ipt_recent v0.3.1: Stephen Frost <sfrost@snowman.net>. http://snowman.net/projects/ipt_recent/
Jan 1 06:00:06 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Jan 1 06:00:06 kernel: RAMDISK: Compressed image found at block 0
Jan 1 06:00:06 kernel: Freeing initrd memory: 36k freed
Jan 1 06:00:06 kernel: VFS: Mounted root (ext2 filesystem).
Jan 1 06:00:06 kernel: Freeing unused kernel memory: 64k freed
Jan 1 06:00:06 kernel: mount /proc file system ok!
Jan 1 06:00:06 kernel: mount /dev/mtd1 file system ok!
Jan 1 06:00:06 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 06:00:10 kernel: NET4: Ethernet Bridge 008 for NET4.0
Jan 1 06:00:10 kernel: device eth0 entered promiscuous mode
Jan 1 06:00:11 kernel: eth0:phy is 8201
Jan 1 06:00:11 kernel: device eth1 entered promiscuous mode
Jan 1 06:00:12 kernel: eth1:phy is 8305
Jan 1 06:00:12 kernel: device wlan0 entered promiscuous mode
Jan 1 06:00:13 kernel: br0: port 3(wlan0) entering listening state
Jan 1 06:00:13 kernel: br0: port 2(eth1) entering listening state
Jan 1 06:00:13 kernel: br0: port 1(eth0) entering listening state
Jan 1 06:00:13 kernel: br0: clear port list of multicast filter
Jan 1 06:00:13 kernel: br0: port 3(wlan0) entering learning state
Jan 1 06:00:13 kernel: br0: port 2(eth1) entering learning state
Jan 1 06:00:13 kernel: br0: port 1(eth0) entering learning state
Jan 1 06:00:13 kernel: br0: port 3(wlan0) entering forwarding state
Jan 1 06:00:13 kernel: br0: topology change detected, propagating
Jan 1 06:00:13 kernel: br0: port 2(eth1) entering forwarding state
Jan 1 06:00:13 kernel: br0: port 1(eth0) entering forwarding state
Jan 1 06:00:13 kernel: br0: set port num [33168] of multicast filter
Jan 1 06:00:13 kernel: br0: port 1(eth0) multicast bandwidth 80000kbps
Jan 1 06:00:13 kernel: br0: port 2(eth1) multicast bandwidth 80000kbps
Jan 1 06:00:13 kernel: br0: port 3(wlan0) multicast bandwidth 40000kbps
Jan 1 06:00:23 kernel: auth uses obsolete (PF_INET,SOCK_PACKET)
Jan 1 06:00:24 kernel: wlan0: Associate to AP successfully - 00:15:6D:A6:D2:DF
Jan 1 06:00:24 syslog: wlan0: WPA-TKIP PSK authentication in progress...
Jan 1 06:00:24 syslog: wlan0: Open and authenticated
Jan 1 06:01:56 ssh[274]: Child connection from 192.168.0.3:1187
Jan 1 06:02:03 ssh[274]: password auth succeeded for 'root' from 192.168.0.3:1187
Позже зделаю логи для софта 0.2.13
блек-фв перед заменой софта заливаю всегда !
Share this post
Link to post
Share on other sites
Людиии! Пожалуйста посоветуйте оптимальную на сегодняшний день точку с 16M RAM в соотношении цена/качество. Вижу предыдущий мой пост просто проигнорировали :(
Share this post
Link to post
ну почему же, а это:
чистим флэш black_fw, шьём, сразу после того как сгенерированы ключи говорим
arg s SYSLOG_ENABLE no
arg s START_SHAPER no
arg s ETH1_ENABLED no
arg s ETH1_IN_BR0 no
fs save
reboot
Тупо копируем в консоль/ssh из буфера.
Если не заработало - распаиваем консоль и смотрим на чём спотыкается.
Edited by RAW
Share this post
Link to post
fs save
reboot
А при чем здесь это до выбора точки??? о_О
Edited by KnYaz2020
Share this post
Link to post
Это не к выбору точки отнеслось:
Также чтобы Г700 не выкидать, какая версия прошивки работает с ней стабильно? Так как с последних постов вижу что больше поддержки не будет.
По поводу точки доступа: лучше всего Zyxel P-330W.
Share this post
Link to post
Спасибо за ответ :)
Share this post
Link to post
Возможно повтор, но я не нашел ответа в этой теме.
Как в wive-ng зажать скорость скажем до 24Мбит?
Ткните носом на таблицу пожалуйста.
Кстати, бридж+нат+пптп(mtu 1000) на 8 метрах у Ж700:
::Wive-NG-0.2.13::
[Wive-NG@/]# uptime&&free
14:36:23 up 1 day, 13:52, load average: 0.28, 0.07, 0.02
              total         used         free       shared      buffers
  Mem:         5952         5228          724            0          112
Swap:            0            0            0
Total:         5952         5228          724
Разобрался уже.
Edited by quick
Share this post
Link to post
Все это дело повторяется дальше, пока не переткнуть питание.
Разницу увидел в частоте, здесь почему то 134MHz, а при включении 180MHz (после ребута бывает 179 и 178, если точка запускается).
Прикольно, т.е. ваша версия бута не реинитит проц после софтребут. Собсно вот тут и непорядок.
Share this post
Link to post
to sfstudio
Шаманизм. Радиочасть там не трогалась уже фиг знает сколько, так что по WPA вопрос открыт. Что касается работы 0.2.10 на дап это интересно, ибо именно в районе 0.2.10-11 был добавлен код для поддержки новых устройств от зюхеля и укропов (последних пока нет в продаже ;), т.е. менялась система инита, были убраны дубли кода реинициализации ибо бут сам инитит железку и в разных случаях требуются разные параметры шины памяти, т.е. wive-ng сейчас вообще не трогает дефолтовые параметры заданные бутом.
В общем нуно где-то нарыть железку с таким багом и прикручивать воркэраунд. Хотя Г-линк я под дулом пистолета покупать не буду ;)
Спасибо за ответ :)
Да, пока без вариантов, только крайне рекомендую брать v2 версию где коммутатор собран на rtl8306 а не на 05м чипе, в перспективе буду добавлять возможность управления коммутатором включая igmp/vlan/flow control. Чип сам по себе достаточно навороченный, но пока с его программированием не очень разобрался.
::Wive-NG-0.2.13::
Swap:            0            0            0
Разобрался уже.
Какое редкое извращение =) Сегодня постараюсь выложить тесты с выправленным accell pptp и начну разбираться с pppoe в ядре, где-то там какие-то чудеса. Т.е. с этого момента pptp будет жрать в разы меньше памяти т.к. избавляемся от userlevel pptp демона.
Edited by sfstudio
Share this post
Link to post
А есть нормальный бут для Г700?
Если можешь подскажи как собрать/склеять с твоей прошивкой, так чтобы full прошить через tftp?
Реально этот косяк напрягает, удаленно как только точка ребутнулась, все сразу вымерло.
Share this post
Link to post
Нуно слить бут с иоей боевой точки там какраз перелопаченная Г700 для экспериментов и отладки. Ночером сегодня попробую слить, сейчас пока другим занят.
Share this post
Link to post
Следующий тест:
http://sadnet.ru/downloads/wive-ng-0.2.14-test3.bin
1) Вместо userlevel pptp теперь используется ядерная реализация ACCEL-PPTP, тем самым решена проблема
низкой производительности pptp туннелей (огромное спасибо за помощь и код Андрею из http://www.ddixlab.ru)
2) Вместо userlevel l2tp теперь используется ядерная реализация openl2tp.
3) Добавлены раздельные опции для управления MTU/MRU для PPPOE/PPTP, также в interfaces перенесены настройки
логина/пароля для конкретного типа соединения
4) Решена проблема с большими пакетами при использовании pptp и l2tp без шифрования, для pppoe
проблема актуальна
5) Добавлен выбор userspace/kernelspace режима работы pppoe (последний пока не работает)
6) Исправлена ошибка в скрипте отслеживающим работоспособность eth интерфейсов приводившая к некорректному.
сохранению настроек при отказе одного из интерфейсов
7) Исправлена ошибка в pptp conntrack приводившая к перезагрузкам при падении туннеля
Share this post
Link to post
sfstudio
Не забудь слить бут нормальный для Г700.
Решил напомнить ;)
Share this post
Link to post
[Кстати, бридж+нат+пптп(mtu 1000) на 8 метрах у Ж700:
Возьмите последний тест, там решены все проблемы с pptp/l2tp более того они теперь работают в ядре. pptp 15мбит на 500 байтовых пакетах у меня с шифрованием делает легко и не принуждённо. Без шифрования думаю до 30мбит на 1300 байт пакетах достигните легко, ну и памяти оно терь жрёт меньше ибо в памяти не болтается pptp демон.
С pppoe сейчас разбираюсь, также думаю чего делать с девайсами со старым бутом, на бутах версии от до 1.3 с разной переодичностью при ребуте не устанавливаются параметры шины памяти и как результат имеем каку в виде глюков или полной неработоспособности до передёргивания питалова.
На моей боевой Г700 бут также 1.3 страбающей этой болячкой, исходя из ченджлога в 1.4 буте проблема исправлена. Самое прикольное что проблема проявляется лично у меня один раз из где-то 30 ребутов.
К сожалению возвращаться к схеме полного реинита аппаратуры уже из ядра совсем не хочется ибо теряется совместимость с новыми девайсами, в общем думаю самый простой вариант собрать 1.4 бут для Г700 подобных или взять с аналогичного устройства, но пока проверять это у меня нет времени ибо ошибке разработка встанет и начнуться старые танцы с jtag+g700 которая шьётся в зависимости от положения звёзд =)
Share this post
Link to post
Подкинь инфу по поводу сборки бута для Г700,а главное из чего собирать ;) Буду заниматься, как раз запорол бут на своей :)
Если все выйдет выложу бут дня нее.
Share this post
Link to post
Народ, подскажите, как консольный порт на Acorp WR-G распаять? В личку, чтоб топик не засорять...
Edited by akaHennessy
Share this post
Link to post
Смотря какая ревизия платы, не на всех ревизиях он разведён на гребёнку, на некоторых ревизиях только на проц паяться.
Share this post
Link to post
Ау, пользователи корбины вы где? Что насчёт теста скорости?
Сейчас добали persist режим в accel pptp и доделываю для l2tp чтобы точка долбилась до сервера до упора а не впадала в ступор из-за внешних факторов и будет релиз. В 0.2.15 будем занимаиться pppoe и есть мысли как обойти багу со старыми бутами без потери совместимости.
Share this post
Link to post
круть, sfstudio не перестает нас радовать =)) будем ждать новых релизов и исправления баги с бутами.
а пока попробуем поразбираться как эти буты собирать, заливать и где их искать.
Share this post
Link to post
Ну кто-нить меня бы ещё порадовал реальными тестами pptp и l2tp в последней бэте. Синтетика есть синтетика, а у мну нет канала шире 4х мегабит в паутину. ;( Москвичи с корбиной и прочими где вы?
Баги с бутами я исправлять не буду, есть возможность их обойти в принудиловку реинитя переферию по команде reboot, т.е. после первой загрузки читаем значения их нескольких регистров, кладём их куда-нить на fs и потом при ребуте делаем работу бута по иниту в ручную но уже с теми параметрами с которыми это сделал бут в первый раз. В общем тоже костыль блин.
У мну отрубильня DSL канал, сижу на скайлинке, как починят залью на sf.net последний бут из sdk 1.4d, всмысле сырцы, кто разберётся как его корректно собрать для 8Мб 16Бит устройств тот и решит проблему. Шьётся всё точно также по tftp, разница только в том что убив бут восстановление будет возможно только через jtag, поэтому нуно быть точно уверенным что данная сборка собрана для конкретно этого устройства. Для Г700 сборка должна быть revB 8Мб 16бит организации, для других устройств всё может быть совсем иначе.
Edited by sfstudio
Share this post
Link to post
похоже у меня второй случай, гребенок в принципе никаких не разведено.
фотки, если кому не лень смотреть (по 3,6 Мб каждая):
лицо, оборот
для сравнения могу выложить найденные на просторах фотодругой ревизии PCB
Share this post
Link to post
лицо, оборот
Ну как же вы смотрите блин? j1 - место под гребёнку это оно и есть. Дальше мультиметр в зубы, выясняем где на гребёнке GND(судя по фото морды это крайний левый) VCC(+3В или +5В иногда полное напряжение питания но это не ваш случай) и где при включении будет "прыгать" напряжение это TX ну и оставшиеся 2 ноги это RX и DCD или как там сигналы звать, собсно выяснить прозвоном с ноги проца (смотреть в даташите) на контакт, или тупо выяснить методом тыка. Ну и помним что там TTL уровни, т.е. нужен преобразователь на max232.
Share this post
Link to post
sfstudio, огромное спасибо!
думаю, что теперь все получится
Share this post
Link to post
wive-ng-0.2.14-test4
проблема актуальна
8) Добавлена поддержка persist в accel-pptp гарантирующая что соединение будет переустановлено как только
сервер вновь будет доступен
9) Обновлена реализация sha1 благодаря чему mppe теперь работает с любыми pptp серверами включая mpd
10) Исправлена проблема с некоторыми бутами не реинициализировавшими контроллер шины памяти при softreboot
(почти все G700 и DAP1150/60 и другие точки с бутом до 1.4 и 16bit организацией памяти)
http://sadnet.ru/downloads/wive-ng-0.2.14-test4.bin
Share this post
Link to post
http://sadnet.ru/downloads/wive-ng-0.2.14-test5.bin
11) Отклчены излишний вывод отладочных сообщений xl2tpd дабы не засорять логи
12) Тулчейн пересобран с текущими заголовочными файлами
Ну и кучка косметических правок. pptp уже полностью обкатан на предмет стабильности во всех позах. l2tp требует боевого тестирования хотя тоже вроде стабилен. Предыдущие правки для поддержки кривых платформ аля Г700 пока также ни разу не подвели. В общем всё готово к релизу и переходу с 0.2.15-test который будет последним в ветке 0.2.х и по сути версию 0.2.15 можно будет рекомендовать как stable версию. Дальнейшая разработка и расширение функциона пойдёт уже в 0.3.х ветке.
Т.к. тему отвязали то все изменения и тесты далее только у меня в блоге ибо кране неудобно теперь среди пионерии с усилителями постоянно выискивать тему. Напоминаю линк http://sfstudio.livejournal.com
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
