rostykk
Пользователи-
Публикации
6 -
Зарегистрирован
Посещение
О rostykk
Звание
Абитуриент
Контакты
ICQ
Array
Rtl8186 Firmware
тему ответил в dgreen пользователя rostykk в Беспроводные сети Wi-Fi, 3G/LTE/5G, LoRa...
to sfstudio Опять ДАП-1160 перешыл в 0.2.10 все работает пучком !!! Да кстати в 0.2.13 опять неработает WPA :-( вот бут лог 0.2.10 для дап-1160 Mounting ramdisk if RAM >= 16MB Creating tmpfs and mount it into /var Create tmpfs and mount it into /var OK Memsize >= 16MB Syslog daemon start DSS file exist Starting Macaddr: Ok Starting modules.dep generate... Starting sysctl: Ok Starting network... Starting eth0: ETH0 OK Starting eth1: ETH1 OK OK OK Vlan OK Starting wireless network... Configure wifi module Starting wlan0: Change WPA mib Config OK Ok Load bridge modules Add bridge interface bridge start eth0 bridge start eth1 bridge start wlan0 Set IP for BR Bridge up for local br0 From local config Clean multicast filter on br0 AdvancedBridge options br0 stp off br0 FD 0 br0 gcint 0 Select port fo multicast filter Set multicast bandwidth on eth0 Set multicast bandwidth on eth1 Set multicast bandwidth on br0 Vlan OK BurstModeStart At the end we must add special routes. (you know, default gw, etc..) Tune up network interfaces Ok Starting crontab: Ok Starting inetd: Ok Starting tc: Loading modules Set shaper rules Ok Starting WPA daemon in client-infra mode Setting Hostname: Wive-NG Starting LED: Ok Starrting boot services and tune system net.ipv4.conf.default.rp_filter = 1 net.ipv4.conf.all.accept_source_route = 0 Tune kernel to minimum memory usadge - 16MB Tune network stack net.core.rmem_max = 6090752 net.core.wmem_max = 6090752 net.ipv4.tcp_rmem = 4096 43689 3045376 net.ipv4.tcp_wmem = 4096 16384 3045376 net.ipv4.tcp_mem = 2048 2560 1522688 net.ipv4.netfilter.ip_conntrack_generic_timeout = 60 net.ipv4.netfilter.ip_conntrack_tcp_timeout_established = 30 net.ipv4.ip_conntrack_max = 2048 net.ipv4.netfilter.ip_conntrack_max = 2048 net.ipv4.netfilter.ip_conntrack_icmp_timeout = 30 net.ipv4.netfilter.ip_conntrack_udp_timeout_stream = 120 net.ipv4.netfilter.ip_conntrack_udp_timeout = 30 net.ipv4.netfilter.ip_conntrack_tcp_timeout_close = 10 net.ipv4.netfilter.ip_conntrack_tcp_timeout_time_wait = 60 net.ipv4.netfilter.ip_conntrack_tcp_timeout_last_ack = 30 net.ipv4.netfilter.ip_conntrack_tcp_timeout_close_wait = 60 net.ipv4.netfilter.ip_conntrack_tcp_timeout_fin_wait = 100 net.ipv4.netfilter.ip_conntrack_tcp_timeout_syn_sent = 30 net.ipv4.tcp_keepalive_time = 900 net.ipv4.tcp_keepalive_intvl = 225 net.ipv4.tcp_keepalive_probes = 4 net.ipv4.icmp_echo_ignore_all = 0 net.ipv4.conf.default.proxy_arp = 0 net.ipv4.conf.all.proxy_arp = 0 net.ipv4.neigh.default.gc_thresh3 = 768 net.ipv4.neigh.default.gc_thresh2 = 384 net.ipv4.neigh.default.gc_thresh1 = 32 net.ipv4.neigh.default.gc_interval = 20 net.ipv4.igmp_restrict = 1 net.ipv4.udp_restrict_pu = 1 net.ipv4.tcp_restrict_rst = 1 net.ipv4.tcp_restrict = 1 net.ipv4.icmp_restrict = 1 Start complete at Sat Jan 1 06:00:23 GMT 2000 а также месаге 0.2.10 дап-1160 Jan 1 06:00:05 syslogd started: BusyBox v1.12.4.-wive-ng.sf.net Jan 1 06:00:05 kernel: klogd started: BusyBox v1.12.4.-wive-ng.sf.net (2009-01-21 00:41:57 OMST) Jan 1 06:00:06 kernel: Workaround for:Zyxel P330W v.2 and others 16RAM 16Bit devicesLinux version 2.4.18.5-wive-ng.sf.net (wive-ng.sf.net@sfstudio.sadnet.lo) (gcc version 3.3.3) #1742 Wed, 21 Jan 2009 00:44 Jan 1 06:00:06 kernel: early printk enabled Jan 1 06:00:06 kernel: DetectRAMsequence Jan 1 06:00:06 kernel: REG returned:32[32] Jan 1 06:00:06 kernel: RAM after check region:16 Jan 1 06:00:06 kernel: FullviewRAM:16777216 Jan 1 06:00:06 kernel: Determined physical RAM map: Jan 1 06:00:06 kernel: memory: 01000000 @ 00000000 (usable) Jan 1 06:00:06 kernel: Initial ramdisk at: 0x80202000 (37845 bytes) Jan 1 06:00:06 kernel: On node 0 totalpages: 4096 Jan 1 06:00:06 kernel: zone(0): 4096 pages. Jan 1 06:00:06 kernel: zone(1): 0 pages. Jan 1 06:00:06 kernel: zone(2): 0 pages. Jan 1 06:00:06 kernel: Kernel command line: root=/dev/ram console=0 ramdisk_start=0 noisapnp pci=nobios Jan 1 06:00:06 kernel: 180.22 BogoMIPS Jan 1 06:00:06 kernel: Memory: 13848k/16384k available (1863k kernel code, 2536k reserved, 156k data, 64k init, 0k highmem) Jan 1 06:00:06 kernel: Dentry-cache hash table entries: 2048 (order: 2, 16384 bytes) Jan 1 06:00:06 kernel: Inode-cache hash table entries: 1024 (order: 1, 8192 bytes) Jan 1 06:00:06 kernel: Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Jan 1 06:00:06 kernel: Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes) Jan 1 06:00:06 kernel: Page-cache hash table entries: 4096 (order: 2, 16384 bytes) Jan 1 06:00:06 kernel: check_wait... unavailable. Jan 1 06:00:06 kernel: POSIX conformance testing by UNIFIX Jan 1 06:00:06 kernel: bogomips: Initialized. Jan 1 06:00:06 kernel: user_watchdog: Initialized. Jan 1 06:00:06 kernel: led0: Initialized. Jan 1 06:00:06 kernel: led1: Initialized. Jan 1 06:00:06 kernel: sysmem: Initialized. Jan 1 06:00:06 kernel: Linux NET4.0 for Linux 2.4 Jan 1 06:00:06 kernel: Based upon Swansea University Computer Society NET3.039 Jan 1 06:00:06 kernel: Initializing RT netlink socket Jan 1 06:00:06 kernel: Starting kswapd Jan 1 06:00:06 kernel: devfs: v1.10 (20020120) Richard Gooch (rgooch@atnf.csiro.au) Jan 1 06:00:06 kernel: devfs: boot_options: 0x0 Jan 1 06:00:06 kernel: pty: 256 Unix98 ptys configured Jan 1 06:00:06 kernel: Serial driver version 6.02 (2003-03-12) with no serial options enabled Jan 1 06:00:06 kernel: ttyS00 at 0x00c3 (irq = 3) is a rtl_uart1 Jan 1 06:00:06 kernel: state->flags=00000000 Jan 1 06:00:06 kernel: HDLC line discipline: version $Revision: 1.1.1.1 $, maxframe=4096 Jan 1 06:00:06 kernel: N_HDLC line discipline registered. Jan 1 06:00:06 kernel: block: 64 slots per queue, batch=16 Jan 1 06:00:06 kernel: RAMDISK driver initialized: 16 RAM disks of 512K size 1024 blocksize Jan 1 06:00:06 kernel: PPP generic driver version 2.4.2 Jan 1 06:00:06 kernel: PPP MPPE Compression module registered Jan 1 06:00:06 kernel: PPP Deflate Compression module registered Jan 1 06:00:06 kernel: PPP BSD Compression module registered Jan 1 06:00:06 kernel: RealTek E-Flash System Driver. © 2002 RealTek Corp. Jan 1 06:00:06 kernel: Found 1 x 4M Byte MXIC MX29LV320AB at 0xbe000000 Jan 1 06:00:06 kernel: => Scan for ROOT signature in flash from pos=0x000000 Jan 1 06:00:06 kernel: Founded at pos=0x0CFFF4 Jan 1 06:00:06 kernel: Checksumm ok for 0x10C000 bytes calced=0xF53B, stored=0xF53B) Checksumm OK. Use as ROOT partition (/dev/mtd1) Jan 1 06:00:06 kernel: Reallocate partition for root size=0x10C000 bytes Jan 1 06:00:06 kernel: Creating 4 MTD partitions on "DiskOnChip Millennium": Jan 1 06:00:06 kernel: 0x00000000-0x000d0000 : "boot+cfg+linux" Jan 1 06:00:06 kernel: 0x000d0000-0x001e0000 : "root fs" Jan 1 06:00:06 kernel: 0x003e0000-0x00400000 : "TGZfs" Jan 1 06:00:06 kernel: 0x00000000-0x00200000 : "all_flash" Jan 1 06:00:06 kernel: 8186NIC Ethernet driver v0.1.0-NG (15.10.2008) Jan 1 06:00:06 kernel: eth0: RTL8186-NIC at 0xbd200000, 00:01:02:03:04:05, IRQ 4 Jan 1 06:00:06 kernel: eth1: RTL8186-NIC at 0xbd300000, 04:05:06:07:08:09, IRQ 5 Jan 1 06:00:06 kernel: Check MII:phy 2, reg 31 Jan 1 06:00:06 kernel: 0x0000ffff Jan 1 06:00:06 kernel: Check MII:phy 2, reg 26 Jan 1 06:00:06 kernel: 0x0000ffff Jan 1 06:00:06 kernel: Asic.revision=0x00000007 Jan 1 06:00:06 kernel: RTL8185 driver version 1.14 (2008-02-15) Jan 1 06:00:06 kernel: NET4: Linux TCP/IP 1.0 for NET4.0 Jan 1 06:00:06 kernel: IP Protocols: ICMP, UDP, TCP, IGMP Jan 1 06:00:06 kernel: IP: routing cache hash table of 512 buckets, 4Kbytes Jan 1 06:00:06 kernel: TCP: Hash tables configured (established 1024 bind 2048) Jan 1 06:00:06 kernel: Linux IP multicast router 0.06 plus PIM-SM Jan 1 06:00:06 kernel: ip_conntrack version 2.1 (5953 buckets, 5953 max) - 320 bytes per conntrack Jan 1 06:00:06 kernel: PPTP netfilter connection tracking: registered Jan 1 06:00:06 kernel: ip_tables: © 2000-2002 Netfilter core team Jan 1 06:00:06 kernel: ipt_recent v0.3.1: Stephen Frost <sfrost@snowman.net>. http://snowman.net/projects/ipt_recent/ Jan 1 06:00:06 kernel: NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. Jan 1 06:00:06 kernel: RAMDISK: Compressed image found at block 0 Jan 1 06:00:06 kernel: Freeing initrd memory: 36k freed Jan 1 06:00:06 kernel: VFS: Mounted root (ext2 filesystem). Jan 1 06:00:06 kernel: Freeing unused kernel memory: 64k freed Jan 1 06:00:06 kernel: mount /proc file system ok! Jan 1 06:00:06 kernel: mount /dev/mtd1 file system ok! Jan 1 06:00:06 kernel: Algorithmics/MIPS FPU Emulator v1.5 Jan 1 06:00:10 kernel: NET4: Ethernet Bridge 008 for NET4.0 Jan 1 06:00:10 kernel: device eth0 entered promiscuous mode Jan 1 06:00:11 kernel: eth0:phy is 8201 Jan 1 06:00:11 kernel: device eth1 entered promiscuous mode Jan 1 06:00:12 kernel: eth1:phy is 8305 Jan 1 06:00:12 kernel: device wlan0 entered promiscuous mode Jan 1 06:00:13 kernel: br0: port 3(wlan0) entering listening state Jan 1 06:00:13 kernel: br0: port 2(eth1) entering listening state Jan 1 06:00:13 kernel: br0: port 1(eth0) entering listening state Jan 1 06:00:13 kernel: br0: clear port list of multicast filter Jan 1 06:00:13 kernel: br0: port 3(wlan0) entering learning state Jan 1 06:00:13 kernel: br0: port 2(eth1) entering learning state Jan 1 06:00:13 kernel: br0: port 1(eth0) entering learning state Jan 1 06:00:13 kernel: br0: port 3(wlan0) entering forwarding state Jan 1 06:00:13 kernel: br0: topology change detected, propagating Jan 1 06:00:13 kernel: br0: port 2(eth1) entering forwarding state Jan 1 06:00:13 kernel: br0: topology change detected, propagating Jan 1 06:00:13 kernel: br0: port 1(eth0) entering forwarding state Jan 1 06:00:13 kernel: br0: topology change detected, propagating Jan 1 06:00:13 kernel: br0: set port num [33168] of multicast filter Jan 1 06:00:13 kernel: br0: port 1(eth0) multicast bandwidth 80000kbps Jan 1 06:00:13 kernel: br0: port 2(eth1) multicast bandwidth 80000kbps Jan 1 06:00:13 kernel: br0: port 3(wlan0) multicast bandwidth 40000kbps Jan 1 06:00:23 kernel: auth uses obsolete (PF_INET,SOCK_PACKET) Jan 1 06:00:24 kernel: wlan0: Associate to AP successfully - 00:15:6D:A6:D2:DF Jan 1 06:00:24 syslog: wlan0: WPA-TKIP PSK authentication in progress... Jan 1 06:00:24 syslog: wlan0: Open and authenticated Jan 1 06:01:56 ssh[274]: Child connection from 192.168.0.3:1187 Jan 1 06:02:03 ssh[274]: password auth succeeded for 'root' from 192.168.0.3:1187 Позже зделаю логи для софта 0.2.13 блек-фв перед заменой софта заливаю всегда ! -
Rtl8186 Firmware
Тоже наблюдаю такуюже ситуацию правда на DAP-1160 а она 4мб флеш 16мб озу . Севодня вечером попробую откатить на прошывку постарше!!! -
Rtl8186 Firmware
Именно. Повторюсь - EAP/PSK - ужо мучил, не работает. AlexSmall, если возможно, возьмите пожалуйста клиент под W-NG и попробуйте его присоединить к любой АП, у меня в роли АП W-NG тоже НОРМАЛЬНО работает, проблема ТОЛЬКО в клиенте. Я повторяюсь что таже ситиация !!! (у меня в роли АП W-NG тоже НОРМАЛЬНО работает, проблема ТОЛЬКО в клиенте ! ) -
Rtl8186 Firmware
На жаль с такими настройками тоже неудалось подключится к точке . Пробовал wpa и wpa2 но результат ноль .Wpa/wpa2 general включон . Где можно копать и какие логи смотреть ? -
Rtl8186 Firmware
У меня работает, не плохо бы конфиг WPA засветить, как говорит sfstudio: "ясновидящих тут нет" ;) #0 - disable, 1 - WEP, 2 - WPA, 4 - WPA2 only, 6 - WPA2 mixedencryption = 2 #-string_value-, 1-32 char ssid = "net-077" #0/1 - disable/enable 1x Radius authentication enable1x = 0 #0/1 - disable/enable MAC authentication enableMacAuth = 0 #0/1 - disable/enable none WPA client support when WPA is set supportNonWpaClient = 0 #1 - WEP64, 2 - WEP128 Refer when encryption is set 1 (wep) wepKey = 0 wepGroupKey = "" #1 - Radius, 2 - PSK (pre-shared key) authentication = 2 #1 - TKIP, 2 - AES unicastCipher = 1 wpa2UnicastCipher = 2 #0 - use psk value as key in raw data, 1 - use passphrase algorithm to convert psk value usePassphrase = 0 #-string_value-, if usePassphrase=0 (raw data), it should be 64 hex digits. #If usePassphrase=1, the string length should be >=8 and <=64. psk = "0102030405" #Group key re-key time groupRekeyTime = 86400 #UDP Port number of radius server rsPort = 1812 #IP address of radius server (e.g., 192.168.1.1) rsIP = 0.0.0.0 #-string_value-, password of radius server with 31 char in max rsPassword = "" #Max retry number of request packet with radius server rsMaxReq = 3 #Timeout time (in second) of waiting rsp packet of radius rsAWhile = 5 #0/1 Б-? disable/enable accounting radius server accountRsEnabled = 0 #UDP Port number of accounting radius server accountRsPort = 1813 #IP address of accounting radius server accountRsIP = 0.0.0.0 #Б-°string_valueБ-?, password of accounting radius server with 31 char in max accountRsPassword = "" #0/1 Б-? disable/enable the feature of statistic update with accounting server accountRsUpdateEnabled = 0 #Update time in seconds accountRsUpdateTime = 60 #Max retry number of request packet with accounting radius server accountRsMaxReq = 3 #Timeout time (in second)of waiting rsp packet of accounting radius server accountRsAWhile = 5 -
Rtl8186 Firmware
Есть одна проблемка никак немогу зарустить wpa/psk !!! Роутер Длинк 624 клиент wive-ng непроходит авторизация в меседжаж пишет вот такую штуку Jan 1 07:01:16 kernel: wlan0: Deauthenticated by AP - 00:1B:11:26:65:A2 Jan 1 07:01:17 kernel: wlan0: Associate to AP successfully - 00:1B:11:26:65:A2 Jan 1 07:01:17 kernel: wlan0: A STA is rejected by 802.1x daemon - 00:1B:11:26:65:A2 Подскажыте пожалуста как ето побороть .
