Всем привет! bdcom p3616. периодически отваливаются onu. на коммутаторе настроен qinq. когда применяю команду epon template-apply all interface ePON(0/1:2 пример) приходят в себя , можете подсказать в чем проблема ?
вот пример конфига
Current configuration:
!version 10.1.0E build 68964
service timestamps log date
service timestamps debug date
service password-encryption
logging buffered 4096
hostname Nzr_Kommunalnaya_BDCOM
system mtu 9000
port-protected 1
epon local-mac forward
spanning-tree mode mstp
spanning-tree mstp name nazran
spanning-tree mstp revision 1
spanning-tree mstp instance 1 vlan 1-1999
spanning-tree mstp instance 2 vlan 2000-4094
policy-map      MCAST401
 classify vlan 401
 action cos 7
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username root password 7 073E4A361E42410652277311
enable password 7 0749403F1F level 15
epon oam-version 1 0x21
epon oam-version 2 0x20
epon onu-config-template IPoE
 cmd-sequence 001 epon onu all-port loopback detect
 cmd-sequence 002 epon onu port 1 ctc vlan mode tag 147 priority 0
epon onu-config-template ACCESS
 cmd-sequence 001 epon onu all-port ctc vlan mode tag %1
 cmd-sequence 002 epon onu all-port storm-control mode 1 threshold 256
 cmd-sequence 003 epon onu all-port ctc loopback detect
 cmd-sequence 004 epon onu all-port ctc notify loopback
interface Null0
interface FastEthernet0/1
 no ip address
 no ip directed-broadcast
!!slot 0 85
interface GigaEthernet0/1
 switchport trunk vlan-allowed 6,30-31,147,401-402,419,4008
 switchport mode dot1q-tunnel-uplink
  dhcp snooping trust
interface GigaEthernet0/2
 switchport trunk vlan-allowed 6,30,147,4008
 switchport trunk vlan-untagged none
  dhcp snooping trust
interface GigaEthernet0/3
interface GigaEthernet0/4
interface GigaEthernet0/5
interface GigaEthernet0/6
interface GigaEthernet0/7
interface GigaEthernet0/8
interface TGigaEthernet0/1
 switchport trunk vlan-allowed 6,30,147,401-402,4008
 switchport mode trunk
interface TGigaEthernet0/2
 switchport trunk vlan-allowed 6,30,147,401-402,419,908,4008
interface EPON0/1
 epon pre-config-template ACCESS binded-onu-llid 64 param 3065
 epon pre-config-template ACCESS binded-onu-llid 63 param 3064
 epon pre-config-template ACCESS binded-onu-llid 62 param 3063
 epon pre-config-template ACCESS binded-onu-llid 61 param 3062
 epon pre-config-template ACCESS binded-onu-llid 60 param 3061
 epon pre-config-template ACCESS binded-onu-llid 59 param 3060
 epon pre-config-template ACCESS binded-onu-llid 58 param 3059
 epon pre-config-template ACCESS binded-onu-llid 57 param 3058
 epon pre-config-template ACCESS binded-onu-llid 56 param 3057
 epon pre-config-template ACCESS binded-onu-llid 55 param 3056
 epon pre-config-template ACCESS binded-onu-llid 54 param 3055
 epon pre-config-template ACCESS binded-onu-llid 53 param 3054
 epon pre-config-template ACCESS binded-onu-llid 52 param 3053
 epon pre-config-template ACCESS binded-onu-llid 51 param 3052
 epon pre-config-template ACCESS binded-onu-llid 50 param 3051
 epon pre-config-template ACCESS binded-onu-llid 49 param 3050
 epon pre-config-template ACCESS binded-onu-llid 48 param 3049
 epon pre-config-template ACCESS binded-onu-llid 47 param 3048
 epon pre-config-template ACCESS binded-onu-llid 46 param 3047
 epon pre-config-template ACCESS binded-onu-llid 45 param 3046
 epon pre-config-template ACCESS binded-onu-llid 44 param 3045
 epon pre-config-template ACCESS binded-onu-llid 43 param 3044
 epon pre-config-template ACCESS binded-onu-llid 42 param 3043
 epon pre-config-template ACCESS binded-onu-llid 41 param 3042
 epon pre-config-template ACCESS binded-onu-llid 40 param 3041
 epon pre-config-template ACCESS binded-onu-llid 39 param 3040
 epon pre-config-template ACCESS binded-onu-llid 38 param 3039
 epon pre-config-template ACCESS binded-onu-llid 37 param 3038
 epon pre-config-template ACCESS binded-onu-llid 36 param 3037
 epon pre-config-template ACCESS binded-onu-llid 35 param 3036
 epon pre-config-template ACCESS binded-onu-llid 34 param 3035
 epon pre-config-template ACCESS binded-onu-llid 33 param 3034
 epon pre-config-template ACCESS binded-onu-llid 32 param 3033
 epon pre-config-template ACCESS binded-onu-llid 31 param 3032
 epon pre-config-template ACCESS binded-onu-llid 30 param 3031
 epon pre-config-template ACCESS binded-onu-llid 29 param 3030
 epon pre-config-template ACCESS binded-onu-llid 28 param 3029
 epon pre-config-template ACCESS binded-onu-llid 27 param 3028
 epon pre-config-template ACCESS binded-onu-llid 26 param 3027
 epon pre-config-template ACCESS binded-onu-llid 25 param 3026
 epon pre-config-template ACCESS binded-onu-llid 24 param 3025
 epon pre-config-template ACCESS binded-onu-llid 23 param 3024
 epon pre-config-template ACCESS binded-onu-llid 22 param 3023
 epon pre-config-template ACCESS binded-onu-llid 21 param 3022
 epon pre-config-template ACCESS binded-onu-llid 20 param 3021
 epon pre-config-template ACCESS binded-onu-llid 19 param 3020
 epon pre-config-template ACCESS binded-onu-llid 18 param 3019
 epon pre-config-template ACCESS binded-onu-llid 17 param 3018
 epon pre-config-template ACCESS binded-onu-llid 16 param 3017
 epon pre-config-template ACCESS binded-onu-llid 15 param 3016
 epon pre-config-template ACCESS binded-onu-llid 14 param 3015
 epon pre-config-template ACCESS binded-onu-llid 13 param 3014
 epon pre-config-template ACCESS binded-onu-llid 12 param 3013
 epon pre-config-template ACCESS binded-onu-llid 11 param 3012
 epon pre-config-template ACCESS binded-onu-llid 10 param 3011
 epon pre-config-template ACCESS binded-onu-llid 9 param 3010
 epon pre-config-template ACCESS binded-onu-llid 8 param 3009
 epon pre-config-template ACCESS binded-onu-llid 7 param 3008
 epon pre-config-template ACCESS binded-onu-llid 6 param 3007
 epon pre-config-template ACCESS binded-onu-llid 5 param 3006
 epon pre-config-template ACCESS binded-onu-llid 4 param 3005
 epon pre-config-template ACCESS binded-onu-llid 3 param 3004
 epon pre-config-template ACCESS binded-onu-llid 2 param 3003
 epon pre-config-template ACCESS binded-onu-llid 1 param 3002
 epon bind-onu mac 8479.7323.f15f 1
 epon bind-onu mac 8007.1b44.7468 2
 epon bind-onu mac 8479.7374.dc45 3
 epon bind-onu mac 9845.6212.3ae3 4
 epon bind-onu mac 9845.6212.3ad7 5
 epon bind-onu mac 8479.7374.e4c2 6
 epon bind-onu mac 9845.623f.47f2 7
 epon bind-onu mac 8007.1b73.57d0 8
 epon bind-onu mac 9845.623f.335a 9
 epon bind-onu mac 0055.b11d.7f30 10
 epon bind-onu mac 9845.620b.df70 11
 epon bind-onu mac 9845.6212.3aa4 12
 epon bind-onu mac 9845.623f.377c 13
 epon bind-onu mac 9845.629f.824c 14
 epon bind-onu mac 9845.627f.81d8 15
 epon bind-onu mac 9845.6277.76ee 16
 epon bind-onu mac 8479.7374.da78 17
 epon bind-onu mac 8007.1b2c.9548 18
 epon bind-onu mac 9845.623f.4266 19
 epon bind-onu mac 9845.6277.fa7e 20
 epon bind-onu mac 9845.623f.49ab 21
 epon bind-onu mac 9845.620b.ed4d 22
 epon bind-onu mac 9845.629e.cdb3 23
 epon bind-onu mac 006d.61d3.fe90 24
 epon bind-onu mac 006d.61d4.9b98 25
 epon bind-onu mac 8479.7374.d6b4 26
 epon bind-onu mac 006d.61b9.ed10 27
 epon bind-onu mac 006d.61b9.ef48 28
 epon bind-onu mac 9845.623f.3b16 29
 epon bind-onu mac 9845.6212.95c0 30
 epon bind-onu mac 9845.620b.eb4f 31
 epon bind-onu mac 006d.61d2.1a00 32
 epon bind-onu mac e0e8.e630.b54f 33
 epon bind-onu mac bc60.6b24.12bb 34
 epon bind-onu mac bc60.6b24.009b 35
 epon bind-onu mac bc60.6b24.c42e 36
 switchport mode dot1q-translating-tunnel
 switchport pvid 4008
 switchport protected 1
interface EPON0/1:1
 switchport port-security dynamic maximum 10
 switchport port-security mode dynamic
  epon onu port 1 ctc vlan mode tag 3002 priority 0
  epon onu port 1 ctc loopback detect
  epon onu port 1 ctc notify loopback
  epon onu port 1 storm-control mode 1 threshold 256
interface EPON0/1:2
  epon onu port 1 ctc vlan mode tag 3003 priority 0
interface EPON0/1:3
  epon onu port 1 ctc vlan mode tag 3004 priority 0
interface EPON0/1:4
interface EPON0/1:5
  epon onu port 1 ctc vlan mode tag 3006 priority 0
interface EPON0/1:6
  epon onu port 1 ctc vlan mode tag 3007 priority 0
interface EPON0/1:7
interface EPON0/1:8
interface EPON0/1:9
  epon onu port 1 ctc vlan mode tag 3010 priority 0
модели onu  BDCOM, и есть VSOL небольшое количество. В основном onu отваливается когда моргнет свет. Вот к примеру сегодня была проблема, у абонента моргнул свет и ону отвалилась, помогло только перезагрузка ОЛТ.
статус ону deregistered
show ver
show version
BDCOM(tm) P3616-2TE Software, Version 10.1.0E Build 68964
Copyright by Shanghai Baud Data Communication CO. LTD.
Compiled: 2019-11-20 14:50:36 by SYS, Image text-base: 0x10000
ROM: System Bootstrap, Version 0.4.5, Serial num:00315074784
System image file is "Switch.bin"
hardware version:V1.0
(RISC) processor with 262144K bytes of memory, 32768K bytes of flash
Base ethernet MAC Address: 84:79:73:9e:ae:06
PCB version:B
snmp info:
  product_ID:2011   system_ID:1.3.6.1.4.1.3320.1.2011.0
Nzr_Kommunalnaya_BDCOM uptime is 53:23:47:57, The current time: 2023-2-21 15:46:5
  • 5 weeks later...
