McSea Posted July 9, 2019 Posted July 9, 2019 RouterOS version 6.44.5 has been released in public "long-term" channel!Before an upgrade:1) Remember to make backup/export files before an upgrade and save them on another storage device;2) Make sure the device will not lose power during upgrade process;3) Device has enough free storage space for all RouterOS packages to be downloaded.What's new in 6.44.5 (2019-Jul-04 10:32):MAJOR CHANGES IN v6.44.5:----------------------!) security - fixed vulnerabilities CVE-2018-1157, CVE-2018-1158;!) security - fixed vulnerabilities CVE-2019-11477, CVE-2019-11478, CVE-2019-11479;!) security - fixed vulnerability CVE-2019-13074;----------------------Changes in this release:*) bridge - correctly handle bridge host table;*) capsman - fixed CAP system upgrading process for MMIPS;*) capsman - fixed interface-list usage in access list;*) certificate - removed "set-ca-passphrase" parameter;*) cloud - properly stop "time-zone-autodetect" after disable;*) conntrack - fixed GRE protocol packet connection-state matching (CVE-2014-8160);*) defconf - automatically set "installation" parameter for outdoor devices;*) dhcpv6-client - fixed status update when leaving "bound" state;*) dhcpv6-server - fixed dynamic IPv6 binding without proper reference to the server;*) dhcpv6-server - override prefix pool and/or DNS server settings by values received from RADIUS;*) discovery - fixed CDP packets not including address on slave ports (introduced in v6.44);*) e-mail - properly release e-mail sending session if the server's domain name can not be resolved;*) firewall - fixed fragmented packet processing when only RAW firewall is configured;*) firewall - process packets by firewall when accepted by RAW with disabled connection tracking;*) gps - strip unnecessary trailing characters from "longtitude" and "latitude" values;*) hotspot - moved "title" HTML tag after "meta" tags;*) ipv6 - improved system stability when receiving bogus packets;*) ovpn - added "verify-server-certificate" parameter for OVPN client (CVE-2018-10066);*) rb3011 - improved system stability when receiving bogus packets;*) rb921 - improved system stability ("/system routerboard upgrade" required);*) snmp - improved reliability on SNMP service packet validation;*) ssh - fixed non-interactive multiple command execution;*) supout - added IPv6 ND section to supout file;*) supout - added "pwr-line" section to supout file;*) supout - changed IPv6 pool section to output detailed print;*) winbox - do not allow setting "dns-lookup-interval" to "0";*) wireless - improved DFS radar detection when using non-ETSI regulated country;*) wireless - improved installation mode selection for wireless outdoor equipment;*) wireless - updated "china" regulatory domain information;*) www - improved client-initiated renegotiation within the SSL and TLS protocols (CVE-2011-1473); Вставить ник Quote
McSea Posted July 9, 2019 Author Posted July 9, 2019 Обратите внимание на *) conntrack - fixed GRE protocol packet connection-state matching (CVE-2014-8160); Теперь обязательно нужны правила, разрешающие GRE, иначе туннели, использующие этот протокол, не будут работать. Вставить ник Quote
gard Posted July 9, 2019 Posted July 9, 2019 (edited) Что-то все равно страшно... с 6.43 то.. Особо после первых двух пунктов в "Before an upgrade" Edited July 9, 2019 by gard Вставить ник Quote
prolan Posted July 9, 2019 Posted July 9, 2019 Before an upgrade вроде как общие рекомендации, при обновлении на любую версию. Вставить ник Quote
WideAreaNetwork Posted July 9, 2019 Posted July 9, 2019 53 минуты назад, prolan сказал: при обновлении на любую версию. я бы добавил - любого продукта Вставить ник Quote
seregaelcin Posted July 29, 2019 Posted July 29, 2019 В 09.07.2019 в 15:58, McSea сказал: Обратите внимание на *) conntrack - fixed GRE protocol packet connection-state matching (CVE-2014-8160); Теперь обязательно нужны правила, разрешающие GRE, иначе туннели, использующие этот протокол, не будут работать. Кстате у кого pptp клиент достаточно будет в /ip firewall service-port включить pptp, ну или прокидывать gre Вставить ник Quote
