Andrey75 Posted June 4, 2019 Posted June 4, 2019 (edited) Скажите как можно организовать QinQ на маршрутизаторе cisco 7206 #sh ver Скрытый текст Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9-M), Version 15.2(4)S7, RELEASE SOFTWARE (fc4) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2015 by Cisco Systems, Inc. Compiled Wed 01-Apr-15 20:30 by prod_rel_team ROM: System Bootstrap, Version 12.3(4r)T1, RELEASE SOFTWARE (fc1) KharinoIPoE uptime is 23 weeks, 4 days, 1 hour, 40 minutes System returned to ROM by power-on System restarted at 16:24:20 MVT Fri Dec 21 2018 System image file is "disk2:c7200-adventerprisek9-mz.152-4.S7.bin" Last reload type: Normal Reload Last reload reason: power-on This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at:http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. Cisco 7206VXR (NPE-G1) processor (revision B) with 229376K/32768K bytes of memory. Processor board ID 37051912 SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache 6 slot VXR midplane, Version 2.11 Last reset from power-on PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points. Current configuration on bus mb1 has a total of 0 bandwidth points. This configuration is within the PCI bus capacity and is supported. PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points. Current configuration on bus mb2 has a total of 0 bandwidth points. This configuration is within the PCI bus capacity and is supported. Please refer to the following document "Cisco 7200 Series Port Adaptor Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com> for c7200 bandwidth points oversubscription and usage guidelines. 3 Gigabit Ethernet interfaces 509K bytes of NVRAM. 125440K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes). 16384K bytes of Flash internal SIMM (Sector size 256K). Configuration register is 0x2102 Edited June 4, 2019 by Andrey75 Вставить ник Quote
Butch3r Posted June 4, 2019 Posted June 4, 2019 Только у вас 7206-g1 :) Хотите терминировать qinq? Вставить ник Quote
Andrey75 Posted June 4, 2019 Author Posted June 4, 2019 (edited) 1 час назад, Butch3r сказал: Только у вас 7206-g1 :) Хотите терминировать qinq? изменил тему на 7206 (спасибо) да пробросить свои vlan через оператора Edited June 4, 2019 by Andrey75 Вставить ник Quote
Andrey75 Posted June 4, 2019 Author Posted June 4, 2019 нашел это: interface GigabitEthernet0/1 mtu 1508 no ip address media-type gbic speed auto duplex auto negotiation auto ! interface GigabitEthernet0/1.50 encapsulation dot1Q 50 second-dot1q 10 ip unnumbered Loopback1 ! interface GigabitEthernet0/1.51 encapsulation dot1Q 50 second-dot1q 20 ip unnumbered Loopback1 ! interface GigabitEthernet0/1.52 encapsulation dot1Q 50 second-dot1q 30 ip unnumbered Loopback1 ! interface GigabitEthernet0/1.53 encapsulation dot1Q 50 second-dot1q 40 ip unnumbered Loopback1 ! interface Loopback1 ip address xx.xx.xx.249 255.255.255.248 Вставить ник Quote
zhenya` Posted June 4, 2019 Posted June 4, 2019 это терминация. добавить второй тэг скорее всего на 7200 не выйдет. Вставить ник Quote
RN3DCX Posted June 4, 2019 Posted June 4, 2019 (edited) 7206_Primary(config)#interface GigabitEthernet0/2.1234 7206_Primary(config-subif)#encapsulation dot1Q 1234 ? native Make this as native vlan second-dot1q Configure this subinterface as a 1Q-in-1Q subinterface <cr> 7206_Primary(config-subif)#encapsulation dot1Q 1234 second-dot1q ? WORD Second (inner) VLAN IDs e.g. 100,200-300,400,500-600 any All Inner VLAN IDs not configured on another subinterface Всё она может. Edited June 4, 2019 by RN3DCX Вставить ник Quote
Andrey75 Posted June 4, 2019 Author Posted June 4, 2019 (edited) any All Inner VLAN IDs not configured on another subinterface это все VLAN GigabitEthernet0/2 или любого порта? можно сделать без interface Loopback1 сразу на GigabitEthernet0/2.ХХХХХ два VLAN? Edited June 4, 2019 by Andrey75 Вставить ник Quote
sol Posted June 4, 2019 Posted June 4, 2019 ТС, объясните внятно что надо сделать. И, да, ТС. Это маршрутизатор а не коммутатор. Вставить ник Quote
UglyAdmin Posted June 6, 2019 Posted June 6, 2019 И маршрутизатор софтовый, с очень слабым (по сегодняшним меркам) процессором. Есть им пытаться коммутировать - он и 100М не осилит. Вставить ник Quote
