Зашел на железку а тут такое. Извечный вопрос что делать?  Менять железку или можно что то подкрутить?
С другой стороны такой же свич и на нем картинка аналогичная. в свичах SFP модули и между ними оптика.
cisco WS-C3560G-48TS (PowerPC405) processor (revision D0) with 131072K bytes of memory.
System image file is "flash:/c3560-ipservicesk9-mz.122-58.SE2.bin"
#show interfaces gigabitEthernet 0/51
GigabitEthernet0/51 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 001a.a275.e6b3 (bia 001a.a275.e6b3)
  Description: ##
  MTU 1546 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 136/255, rxload 135/255
  Encapsulation ARPA, loopback not set
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is CWDM-1590 SFP
  input flow-control is off, output flow-control is unsupported
  ARP type: ARPA, ARP Timeout 04:00:00
  Last input 00:00:08, output 00:00:00, output hang never
  Last clearing of "show interface" counters never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 255088259 <------------!!!!!!!!!!!!!!!!!! Счетчик постоянно растет до 100-200 пакетов в сек
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 529876000 bits/sec, 120061 packets/sec
  5 minute output rate 535608000 bits/sec, 87899 packets/sec
     1889363508287 packets input, 1164319026344918 bytes, 0 no buffer
     Received 824394063 broadcasts (169360593 multicasts)
     483 runts, 0 giants, 0 throttles
     484 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 169360593 multicast, 0 pause input
     0 input packets with dribble condition detected
     1245893181645 packets output, 735164054324342 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 babbles, 0 late collision, 0 deferred
     0 lost carrier, 0 no carrier, 0 pause output
     0 output buffer failures, 0 output buffers swapped out
#show controllers ethernet-controller gigabitEthernet 0/51
     Transmit GigabitEthernet0/51             Receive
   3646833200 Bytes                        767894417 Bytes
   2528591090 Unicast frames              3072693108 Unicast frames
   1205563946 Multicast frames             169361915 Multicast frames
    931309078 Broadcast frames             655035676 Broadcast frames
            0 Too old frames              3816727148 Unicast bytes
            0 Deferred frames              674701413 Multicast bytes
            0 MTU exceeded frames         1459693541 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames            11470605 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames            14857735 Minimum size frames
            0 8 collision frames          2678288215 65 to 127 byte frames
            0 9 collision frames          4160405344 128 to 255 byte frames
            0 10 collision frames         1384243779 256 to 511 byte frames
            0 11 collision frames         1846916968 512 to 1023 byte frames
            0 12 collision frames         1315285612 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 1 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames         1098498244 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
      3852399 64 byte frames                       0 Valid frames, too small
   2942557881 127 byte frames
    886993666 255 byte frames                      0 Too old frames
     75101303 511 byte frames                      0 Valid oversize frames
   4034905515 1023 byte frames                     0 System FCS error frames
   3039708504 1518 byte frames                     0 RxPortFifoFull drop frame
   2272279439 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
22 минуты назад, uxcr сказал:
sh int mtu
#sh int mtu
Port      Name               MTU
Gi0/1     ##S               1546
Gi0/2     ##U               1546
Gi0/3     ##S               1546
Gi0/4     ##W               1546
Gi0/5     ##F               1546
Gi0/6     ##R               1546
Gi0/7     ##F               1546
Gi0/8     ##U               1546
Gi0/9     ##S               1546
Gi0/10    ##S               1546
Gi0/11    ##S               1546
Gi0/12    ##B               1546
Gi0/13    ##U               1546
Gi0/14    ##G               1546
Gi0/15    ##B               1546
Gi0/16    ##K               1546
Gi0/17    ##P               1546
Gi0/18    ##R               1546
Gi0/19    ##K               1546
Gi0/20    ##G               1546
Gi0/21    ##C               1546
Gi0/22    ##I               1546
Gi0/23    ##T               1546
Gi0/24    ##L               1546
Gi0/25    ##S               1546
Gi0/26    ##M               1546
Gi0/27    ##I               1546
Gi0/28    ##M               1546
Gi0/29    ##I               1546
Gi0/30    ##M               1546
Gi0/31    ##M               1546
Gi0/32    ##I               1546
Gi0/33    ##F               1546
Gi0/34    ##T               1546
Gi0/35    ##T               1546
Gi0/36    FOR               1546
Port      Nam               MTU
Gi0/37    ##T               1546
Gi0/38    ##I               1546
Gi0/39    ##L               1546
Gi0/40    ##L               1546
Gi0/41    ##T               1546
Gi0/42    ##K               1546
Gi0/43    ##R               1546
Gi0/44    ##I               1546
Gi0/45    ##M               1546
Gi0/46    ##B               1546
Gi0/47    ##C               1546
Gi0/48    ##K               1546
Gi0/49    ##C               1546
Gi0/50                      1546
Gi0/51    ##B               1546
Gi0/52    ##B               1546
Po1       ##K               1546
20 минут назад, v_r сказал:
sh mls qos interface gi0/51 statistics
#sh mls qos interface gi0/51 statistics
GigabitEthernet0/51 (All statistics are in packets)
  dscp: incoming
  0 -  4 :   737694715        12162       136339          639         5769
  5 -  9 :        2242         2876        21316       306038          344
 10 - 14 :      316305            0         8641          810          552
 15 - 19 :         276        98780           15        11830          120
 20 - 24 :        4594            0         1157            1       612143
 25 - 29 :           0         2595            0      1581531            0
 30 - 34 :         273            1         2245           16         7436
 35 - 39 :           0       114977            0           40            0
 40 - 44 :      169099            2            9            0            0
 45 - 49 :          34       473112            0      4987212          400
 50 - 54 :        1379           23           56            0           50
 55 - 59 :           2          126            0            1            0
 60 - 64 :           0            0           56          532
  dscp: outgoing
  0 -  4 :  1211442202          609           26            0           18
  5 -  9 :           0            0           89           60            0
 10 - 14 :        6259            0            0            0            0
 15 - 19 :           0           42            0         5393            0
 20 - 24 :        1679            0            0            0           45
 25 - 29 :           0          107            0            0            4
 30 - 34 :           0            1          311            0           91
 35 - 39 :           0            2            0            4            0
 40 - 44 :         207            0            0            0            0
 45 - 49 :           0        16069            0     18992031            0
 50 - 54 :           0            0            0           88            0
 55 - 59 :           0      5848662            0            0            0
 60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :   201513688            0       264624            3            2
  5 -  7 :           7      4928252      7297589
  cos: outgoing
  0 -  4 :   651848673         6319       874762          157          408
  5 -  7 :       16321     18992119     18638986
  output queues enqueued:
 queue:    threshold1   threshold2   threshold3
 queue 0:           0           0           0
 queue 1:  3806145283   238145717   154256265
 queue 2:           0           0           0
 queue 3:     5855130           0   146003867
  output queues dropped:
 queue 0:           0           0           0
 queue 1:   255779323        7773           0
 queue 2:           0           0           0
 queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:
2 часа назад, QWE сказал:
Так вот же они:
1 час назад, QWE сказал:
 queue 0:           0           0           0
 queue 2:           0           0           0
 queue 3:           0           0           0
Банально не хватает буферов, нужно настраивать QoS: либо разделять трафик по очередям, либо - проще всего - просто увеличить буферы для первой очереди.
1 час назад, v_r сказал:
Так вот же они:
Сорри, и как это сделать?
еще тоже самое нашел, вид сбоку
#show platform port-asic stats drop gigabitEthernet 0/51
  Interface Gi0/51 TxQueue Drop Statistics
    Queue 0
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 1
      Weight 0 Frames 256345642
      Weight 1 Frames 7823
      Weight 2 Frames 0
    Queue 2
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
    Queue 3
      Weight 0 Frames 0
      Weight 1 Frames 0
      Weight 2 Frames 0
Edited by QWE
Увеличение буферов для первой очереди:
mls qos queue-set output 1 buffers 10 70 10 10
Настраивается сразу для всех портов, лучше попробовать в не-бизнес время.
mls qos включать не надо (по идее команда отработает и без этого), ибо с включенным QoS свитч начнет раскладывать пакеты по очередям в соответствии с DSCP, а в вашем случае для начала надо просто увеличить буферы дефолтной очереди.
36 минут назад, v_r сказал:
спс
2 часа назад, v_r сказал:
переконфигурил, но дропы все равно есть. видимо от них не избавиться на 100% на этой железяке, или настраивать нужно трафик который нужно дропать.
Edited by QWE
3 часа назад, v_r сказал:
LACP между свитчами затруднительно собрать?
В настоящий момент 4948E  запускаем вместо 3560G. Вся суета сейчас - жалоба абонента, которая и выявила масштабную проблему на всех магистральных линках.
После запуска с 4948E  по (2)4 линка в LACP будет до свичей агрегации.
Насколько вообще LACP помогает от нехватки буфера при микроберстах?
Смотря какие микроберсты, может банально чуть-чуть не хватает буферов и расширение скорости поможет, а может понадобится замена на что-то более серьезное чем свитчи с разделяемыми буферами (либо перенастройка сервисов чтобы избежать появления микроберстов), думаю тут только экспериментально получится выяснить. Случай из практики: стример подлюченный 10Г портом периодически начинает слать трафик с микроберстами в течении 5-10 минут, на 1Г портах в сторону потребителей начинают появляться дропы до 100pps, причем как на свитчах типа C3750G, так и на Nexus 3064, настройка QoS не помогает, по усредненным графикам за 5 минут трафик не меняется (порты загружены меньше чем наполовину). Пока не порешалось, но причина кроется в сервере, уже поняли в какие моменты он начинает слать данные с микроберстами.
3 минуты назад, v_r сказал:
Видимо да.
А Вы не настраивали классификаторы трафика на входящей очереди интерфейса на 3560G или на 4948Е для того чтобы не критичный  трафик дропнуть в случае микроберстов?
11 минут назад, QWE сказал:
Настраивал, и увеличивал буферы для очереди, и делал очередь приоритетной, дропы есть, зависимость  дропов от настроек не отслеживал потому что QoS был настроен и раньше. По имеющейся информации на 3750G буферы 384К, на N3064 буферы 5М, вне зависимости от количества занятых портов дропы есть. Видимо в нашем случае сказывается переход 10Г -> 1Г потому что на всех транзитных 10Г линках дропы отсутствуют, а на всех 1Г линках с потребителями (и на свитче куда включен сервер, и далеко в другой части сети) дропы появляются синхронно. Так что в вашем случае апгрейд до 4948E с поднятием 10Г линка между свитчами скорее всего поможет, не потому что буферы больше (хотя там до 16М буферов), а в большей степени потому что данные будут отправляться быстрее.
8 минут назад, v_r сказал:
между свичами будет LACP - по 2 или 4 1Гбит линка.  10Г порт 4948E будет смотреть в бордер. ДАнные будут отправляться быстрее по маршруту 10Г--LACP линк.
Edited by QWE
13 минут назад, QWE сказал:
В таком случае заранее трудно сказать как будет работать. Раз дропы есть на этом свитче то по идее дропы (возможно в меньшей степени) будут и дальше на свитчах, и на порту потребителя, особенно если свитчи не такие продвинутые как Cisco - у некоторых счетчики по очередям QoS напрочь отсутствуют, о потерях можно только догадываться.
В 02.11.2017 в 10:15, QWE сказал:
На скОльких портах свитчей растут потери? Сколько downlink'ов всего?
COS включён? Трафик, я так понял, не раскрашивается, основная его масса попадает в очередь 0-4? Как распределены  буфера и пороги?
Покажите  sho run | inc qos  и  sho run int gi 0/51
1 час назад, andryas сказал:
# sho run | inc qos
mls qos queue-set output 2 threshold 2 600 600 50 700
mls qos queue-set output 1 buffers 25 55 10 10
mls qos queue-set output 2 buffers 8 75 8 9
 mls qos cos 7
 mls qos trust cos
sho run int gi 0/51
Building configuration...
Current configuration : 499 bytes
interface GigabitEthernet0/51
 description ###
 switchport trunk encapsulation dot1q
 switchport trunk allowed vlan add 890,891,953-998,2092
 switchport mode trunk
 load-interval 30
 queue-set 2
 spanning-tree cost 4
 hold-queue 4096 out
end
трафик не раскрашивается,
да и как его красить средствами этой железки если железка используется на сети провайдера?
потери растут не только на этом интерфейсе, потери есть еще в сторону свича агрегации, в сторону бордера и в другие интерфейсы.  downlink ов  много, кроме свичей агрегации в интерфейсах и абоненты сидят
Edited by QWE
54 минуты назад, QWE сказал:
У Вас часть портов работають по первому, часть по второму шаблону? В любом cлучае все пакеты дропаются на буфере второй очереди, остальные не используються, а память Вы им резервируете. Отдайте ей весь буфер в обеих шаблонах: 1 97 1 1
Если нагруженных портов 1-2, отдате им побольше памяти, увеличте пороги:  3100 3100 100 3200. Если таких портов 3-4: 400 200 50 1600 (и крутить вручную первый и последний порог), если нагруженных портов больше, то отключить qos и смириться с дропами (они неизбежны), либо же менять железку.
Это убрать
mls qos cos 7
Это добавить
mls qos srr-queue output cos-map queue 2 threshold 3 0
mls qos srr-queue output dscp-map queue 2 threshold 3 0
no mls qos rewrite ip dscp
mls qos
Как справедливо заметили выше, у cisco 2960/3560/3750 совсем маленькие буфера, т.е. они малопригодны для серьёзных нагрузок. Следует учесть, что включение QOS при дефолтных настройках на высоконагруженном коммутаторе из этой серии, обычно, только усуг***ет ситуацию, т.к. и без того маленький буфер разбивается на части. Нужно очень хорошо понимать, что настраивается.
Если же QOS не включать, то весь трафик будет дропаться в последней очереди, там можно поиграть с mls qos queue-set output N buffers 1 10 1 88. (в сумме должно быть 100%)
Возможно, упомянутые железки ухудшены умышленно, дабы стимулировать покупку более дорогих.
24 минуты назад, andryas сказал:
У Вас часть портов работають по первому, часть по второму шаблону? В любом влучае все пакеты дропаются на буфере второй очереди, остальные не используються, а память Вы им резервируете. Отдайте ей весь буфер в обеих шаблонах: 1 97 1 1
Это убрать
Это добавить
mls qos
Возможно, упомянутые железки ухудшены умышленно, дабы стимулировать покупку более дорогих железок.
я что то уже накрутил, как мне кажется полегчало. Меняю железку.
  • 2 years later...
Коллеги, подскажите что накручивать: cisco 3560g , 4*1G интерфейса в LAGG, загрузка до 700мбит на интерфейс, есть ошибки по output.
gi0/11
 queue 0:            0            0            0
 queue 1:            0            0            0
 queue 2:            0            0            0
 queue 3:            0            0     35507482
gi0/13
 queue 0:            0            0            0
 queue 1:            0            0            0
 queue 2:            0            0            0
 queue 3:            0            0     11226210
0/26
 queue 0:            0            0            0
 queue 1:            0            0            0
 queue 2:            0            0            0
 queue 3:            0            0      1448817
gi0/28
 queue 0:            0            0            0
 queue 1:            0            0            0
 queue 2:            0            0            0
 queue 3:            0            0      1527786
те все дропы по 4 очереди
