Сегодня в процессе дебага обратил внимание
tcpdump -ee -nn -i eth4.3078 host 192.168.134.21 -c 100 (видно только исход с роутера)
15:32:59.864329 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 818: 5.9.238.20.80 > 192.168.134.21.42153: Flags [P.], seq 130320:131072, ack 1, win 57, options [nop,nop,TS val 276010223 ecr 419163833], length 752
15:33:00.117079 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.134.21.42153: Flags [.], seq 131072:132520, ack 1, win 57, options [nop,nop,TS val 276010286 ecr 419163839], length 1448
15:33:00.117086 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.134.21.42153: Flags [.], seq 132520:133968, ack 1, win 57, options [nop,nop,TS val 276010286 ecr 419163839], length 1448
15:33:00.117090 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.134.21.42153: Flags [.], seq 133968:135416, ack 1, win 57, options [nop,nop,TS val 276010286 ecr 419163839], length 1448
15:33:00.117094 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.134.21.42153: Flags [.], seq 135416:136864, ack 1, win 57, options [nop,nop,TS val 276010286 ecr 419163839], length 1448
15:33:00.117097 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.134.21.42153: Flags [.], seq 136864:138312, ack 1, win 57, options [nop,nop,TS val 276010286 ecr 419163839], length 1448
15:33:00.117101 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.134.21.42153: Flags [.], seq 138312:139760, ack 1, win 57, options [nop,nop,TS val 276010286 ecr 419163839], length 1448
15:33:00.117104 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.134.21.42153: Flags [.], seq 139760:141208, ack 1, win 57, options [nop,nop,TS val 276010286 ecr 419163839], length 1448
15:33:00.117155 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.134.21.42153: Flags [.], seq 141208:142656, ack 1, win 57, options [nop,nop,TS val 276010286 ecr 419163839], length 1448
15:33:00.117160 90:e2:ba:4a:d3:3c > f8:d1:11:a1:d5:d3, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.134.21.42153: Flags [.], seq 142656:144104, ack 1, win 57, options [nop,nop,TS val 276010286 ecr 419163839], length 1448
На родительском интерфейсе
tcpdump -ee -nn -i eth4 host 192.168.134.21 -c 100
15:33:07.516368 f8:d1:11:a1:d5:d3 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.134.21.42153 > 5.9.238.20.80: Flags [.], ack 53577, win 7059, options [nop,nop,TS val 419171486 ecr 276012136], length 0
15:33:07.516707 f8:d1:11:a1:d5:d3 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.134.21.42153 > 5.9.238.20.80: Flags [.], ack 56473, win 7059, options [nop,nop,TS val 419171486 ecr 276012136], length 0
15:33:07.516856 f8:d1:11:a1:d5:d3 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.134.21.42153 > 5.9.238.20.80: Flags [.], ack 59369, win 7059, options [nop,nop,TS val 419171487 ecr 276012136], length 0
15:33:07.517086 f8:d1:11:a1:d5:d3 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.134.21.42153 > 5.9.238.20.80: Flags [.], ack 62265, win 7059, options [nop,nop,TS val 419171487 ecr 276012136], length 0
15:33:07.517337 f8:d1:11:a1:d5:d3 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.134.21.42153 > 5.9.238.20.80: Flags [.], ack 65161, win 7059, options [nop,nop,TS val 419171487 ecr 276012136], length 0
15:33:07.517651 f8:d1:11:a1:d5:d3 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.134.21.42153 > 5.9.238.20.80: Flags [.], ack 68057, win 7059, options [nop,nop,TS val 419171487 ecr 276012136], length 0
15:33:07.517815 f8:d1:11:a1:d5:d3 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.134.21.42153 > 5.9.238.20.80: Flags [.], ack 70953, win 7059, options [nop,nop,TS val 419171488 ecr 276012136], length 0
Пока-что я никак не могу это понять
При этом по факту траффик ходит в обе стороны
Нагрузки на сервер нет, сетевка
ethtool -i eth4
driver: ixgbe
version: 3.22.3
firmware-version: 0x61c10001
bus-info: 0000:05:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
Какой-нибудь ВЛАН оффлоад или что то еще?
Вроде-бы ничего не менялось достаточно долго уже
ядро
Linux  3.17.4-1.el6.elrepo.x86_64 #1 SMP Sat Nov 22 09:31:20 EST 2014 x86_64 x86_64 x86_64 GNU/Linux
А так:
tcpdump -e -n -c 100 -i eth4.3078 src ip 192.168.134.21 or dst ip 192.168.134.21
При этом убедись что NAT у тебя там нет, а то он может как раз половину адресов и убирать.
А так:
Дело в том что я начал смотреть по маку (а ебтаблезов с мак-нат точно нет)
IP пингается но в дампе ether host MAC - траффик только в одну сторону
наверно так
tcpdump  -e -n  -c 100  -i eth4.3078 src host 192.168.134.21 or dst host 192.168.134.21
Показывает в одну сторону только - ОТ роутера к клиенту.
Нат есть но он дальше и собственно, даже если сделать tcpdump -e -n -c 100 -i eth4.3078 я не вижу никаого траффика К клиенту (что должно быть даже если чьо то натится
Странно все очень
Никогда не пользуюсь "host". Тогда ip src / ip dst.
Возможно линукс как то в обход пускает что в бпф/пкап не попадает.
Хм
tcpdump: syntax error
под Mac OS то же самое
А что говорит ethtool -k и ip -d link list?
P.S. я вон вообще недавно сюрприз обнаружил - http://www.spinics.net/lists/lartc/msg23421.html
на первый взгляд - ничего необычного нет
ethtool -k  eth4
Features for eth4:
rx-checksumming: on
tx-checksumming: on
      	tx-checksum-ipv4: on
      	tx-checksum-ip-generic: off [fixed]
      	tx-checksum-ipv6: on
      	tx-checksum-fcoe-crc: off [fixed]
      	tx-checksum-sctp: on
scatter-gather: on
      	tx-scatter-gather: on
      	tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: off
      	tx-tcp-segmentation: off
      	tx-tcp-ecn-segmentation: off [fixed]
      	tx-tcp6-segmentation: off
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: off
generic-receive-offload: off
large-receive-offload: off
rx-vlan-offload: off
tx-vlan-offload: off
ntuple-filters: on
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-ipip-segmentation: off [fixed]
tx-sit-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
l2-fwd-offload: off [fixed]
busy-poll: on [fixed]
6: eth4: <BROADCAST,MULTICAST,PROMISC,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
   link/ether 90:e2:ba:4a:d3:3c brd ff:ff:ff:ff:ff:ff
Хорошим впросом будет почему PROMISC =) Я пока не знаю
length 70:
а если -s 65000 добавить?
На родительском интерфейсе (там 300+ вланов и траффика под 2 гига - не много но дампать уже неудобно)
tcpdump  -nn -ee -s 65000 -i eth4 -c 10000 | grep 3078
tcpdump: WARNING: eth4: no IPv4 address assigned
Warning: Kernel filter failed: Bad address
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth4, link-type EN10MB (Ethernet), capture size 65000 bytes
15:34:26.719874 e8:94:f6:7b:ad:7d > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.142.48.54359 > 178.187.117.130.24502: Flags [s], seq 1202332650, win 8192, options [mss 1460,nop,wscale 2,nop,nop,sackOK], length 0
15:34:26.720144 90:e2:ba:4a:d3:3c > e8:94:f6:7b:ad:7d, ethertype 802.1Q (0x8100), length 388: vlan 3078, p 0, ethertype IPv4, 78.179.254.147.49271 > 192.168.142.48.57313: UDP, length 342
15:34:26.724109 90:e2:ba:4a:d3:3c > e8:94:f6:7b:ad:7d, ethertype 802.1Q (0x8100), length 66: vlan 3078, p 0, ethertype IPv4, 78.179.254.147.49271 > 192.168.142.48.57313: UDP, length 20
15:34:26.725130 90:e2:ba:4a:d3:3c > e8:94:f6:7b:ad:7d, ethertype 802.1Q (0x8100), length 66: vlan 3078, p 0, ethertype IPv4, 78.179.254.147.49271 > 192.168.142.48.57313: UDP, length 20
15:34:26.727319 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 975429763:975431211, ack 1754918519, win 57, options [nop,nop,TS val 297632671 ecr 1279736280], length 1448
15:34:26.727324 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 1448:2896, ack 1, win 57, options [nop,nop,TS val 297632671 ecr 1279736280], length 1448
15:34:26.727384 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 2896:4344, ack 1, win 57, options [nop,nop,TS val 297632671 ecr 1279736280], length 1448
15:34:26.727392 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 4344:5792, ack 1, win 57, options [nop,nop,TS val 297632671 ecr 1279736280], length 1448
<пропущено повторение>
15:34:26.727813 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 49232:50680, ack 1, win 57, options [nop,nop,TS val 297632671 ecr 1279736280], length 1448
15:34:26.727817 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 50680:52128, ack 1, win 57, options [nop,nop,TS val 297632671 ecr 1279736280], length 1448
15:34:26.728103 90:f6:52:5a:5f:43 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.136.224.42693 > 5.9.238.20.80: Flags [.], ack 2896, win 7059, options [nop,nop,TS val 1279736378 ecr 297632671], length 0
15:34:26.728340 90:f6:52:5a:5f:43 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.136.224.42693 > 5.9.238.20.80: Flags [.], ack 5792, win 7059, options [nop,nop,TS val 1279736379 ecr 297632671], length 0
15:34:26.728508 90:f6:52:5a:5f:43 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.136.224.42693 > 5.9.238.20.80: Flags [.], ack 8688, win 7059, options [nop,nop,TS val 1279736379 ecr 297632671], length 0
15:34:26.728790 90:f6:52:5a:5f:43 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.136.224.42693 > 5.9.238.20.80: Flags [.], ack 11584, win 7059, options [nop,nop,TS val 1279736379 ecr 297632671], length 0
15:34:26.728994 90:f6:52:5a:5f:43 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.136.224.42693 > 5.9.238.20.80: Flags [.], ack 14480, win 7059, options [nop,nop,TS val 1279736379 ecr 297632671], length 0
15:34:26.729164 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 52128:53576, ack 1, win 57, options [nop,nop,TS val 297632672 ecr 1279736378], length 1448
15:34:26.729235 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 53576:55024, ack 1, win 57, options [nop,nop,TS val 297632672 ecr 1279736378], length 1448
15:34:26.729244 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 55024:56472, ack 1, win 57, options [nop,nop,TS val 297632672 ecr 1279736378], length 1448
15:34:26.729252 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype 802.1Q (0x8100), length 1518: vlan 3078, p 0, ethertype IPv4, 5.9.238.20.80 > 192.168.136.224.42693: Flags [P.], seq 56472:57920, ack 1, win 57, options [nop,nop,TS val 297632672 ecr 1279736378], length 1448
15:34:26.729309 90:f6:52:5a:5f:43 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.136.224.42693 > 5.9.238.20.80: Flags [.], ack 17376, win 7059, options [nop,nop,TS val 1279736380 ecr 297632671], length 0
15:34:26.729519 90:f6:52:5a:5f:43 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 70: vlan 3078, p 0, ethertype IPv4, 192.168.136.224.42693 > 5.9.238.20.80: Flags [.], ack 20272, win 7059, options [nop,nop,TS val 1279736380 ecr 297632671], length 0
Т е как-бы вроде видно в обе стороны но при этом дампать на корневом интерфейсе не хочется
На влане
tcpdump  -nn -ee -s 65000 -i eth4.3078  -c 100
listening on eth4.3078, link-type EN10MB (Ethernet), capture size 65000 bytes
15:35:12.595727 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 998611379:998612827, ack 1754918519, win 57, options [nop,nop,TS val 297644139 ecr 1279782242], length 1448
15:35:12.595732 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 1448:2896, ack 1, win 57, options [nop,nop,TS val 297644139 ecr 1279782242], length 1448
15:35:12.595735 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.136.224.42693: Flags [.], seq 2896:4344, ack 1, win 57, options [nop,nop,TS val 297644139 ecr 1279782242], length 1448
15:35:12.595739 90:e2:ba:4a:d3:3c > 90:f6:52:5a:5f:43, ethertype IPv4 (0x0800), length 1514: 5.9.238.20.80 > 192.168.136.224.42693: Flags [P.], seq 4344:5792, ack 1, win 57, options [nop,nop,TS val 297644139 ecr 1279782242], length 1448
15:35:12.595798 ba:4a:d3:3c:90:f6 > 90:e2:ba:4a:90:e2, ethertype Unknown (0x525a), length 70:
      	0x0000:  5f43 0800 4500 0034 7c67 4000 3f06 82b6  _C..E..4|g@.?...
      	0x0010:  c0a8 88e0 0509 ee14 a6c5 0050 6899 ee77  ...........Ph..w
      	0x0020:  3b85 11f3 8010 1b93 d710 0000 0101 080a  ;...............
      	0x0030:  4c47 ed64 11bd b06a                      LG.d...j
<тут пропущено>
15:35:12.611406 ba:4a:d3:3c:74:d4 > 90:e2:ba:4a:90:e2, ethertype Unknown (0x3507), length 629:
      	0x0000:  777b 0800 4500 0263 5d25 4000 8006 3f6e  w{..E..c]%@...?n
      	0x0010:  c0a8 8d87 c1bb 4c16 f759 0050 b079 3dbb  ......L..Y.P.y=.
      	0x0020:  598f a3d9 5018 04be d4b2 0000 4745 5420  Y...P.......GET.
      	0x0030:  2f65 6130 3938 6137 6164 3461 6630 6666  /ea098a7ad4af0ff
      	0x0040:  3764 3339 6337 6138 3538 3733 3731 3134  7d39c7a858737114
      	0x0050:  345f 6d65 676f 676f 2f76 6f64 2f66 732f  4_megogo/vod/fs/
      	0x0060:  6f2f 3334 3831 3334 3531 2f70 2f43 5550  o/34813451/p/CUP
      	0x0070:  4552 5449 4e4f 2f62 2f34 3530 5f39 3030  ERTINO/b/450_900
      	0x0080:  5f31 3335 305f 3135 3030 5f32 3030 305f  _1350_1500_2000_
      	0x0090:  3530 3030 2f75 5f73 6964 2f72 6175 7675  5000/u_sid/rauvu
      	0x00a0:  6739 306e 7132 7373 7036 3961 3575 6636  g90nq2ssp69a5uf6
      	0x00b0:  6d37 6834 342f 755f 7569 642f 302f 755f  m7h44/u_uid/0/u_
      	0x00c0:  766f 642f 332f 755f 6465 7669 6365 2f66  vod/3/u_device/f
      	0x00d0:  6c61 7368 2f67 2f75 612f 612f 302f 7479  lash/g/ua/a/0/ty
      	0x00e0:  7065 2e61 6d6c 7374 2f6d 6564 6961 2d73  pe.amlst/media-s
      	0x00f0:  6964 3335 3239 3238 342d 6235 3030 3030  id3529284-b50000
      	0x0100:  3030 5f35 372e 7473 2048 5454 502f 312e  00_57.ts.HTTP/1.
      	0x0110:  310d 0a48 6f73 743a 2076 7331 322e 7663  1..Host:.vs12.vc
      	0x0120:  646e 2e62 697a 0d0a 5573 6572 2d41 6765  dn.biz..User-Age
      	0x0130:  6e74 3a20 4d6f 7a69 6c6c 612f 352e 3020  nt:.Mozilla/5.0.
      	0x0140:  2857 696e 646f 7773 204e 5420 362e 333b  (Windows.NT.6.3;
      	0x0150:  2057 4f57 3634 3b20 7276 3a34 372e 3029  .WOW64;.rv:47.0)
      	0x0160:  2047 6563 6b6f 2f32 3031 3030 3130 3120  .Gecko/20100101.
      	0x0170:  4669 7265 666f 782f 3437 2e30 0d0a 4163  Firefox/47.0..Ac
      	0x0180:  6365 7074 3a20 7465 7874 2f68 746d 6c2c  cept:.text/html,
      	0x0190:  6170 706c 6963 6174 696f 6e2f 7868 746d  application/xhtm
      	0x01a0:  6c2b 786d 6c2c 6170 706c 6963 6174 696f  l+xml,applicatio
      	0x01b0:  6e2f 786d 6c3b 713d 302e 392c 2a2f 2a3b  n/xml;q=0.9,*/*;
      	0x01c0:  713d 302e 380d 0a41 6363 6570 742d 4c61  q=0.8..Accept-La
      	0x01d0:  6e67 7561 6765 3a20 7275 2d52 552c 7275  nguage:.ru-RU,ru
      	0x01e0:  3b71 3d30 2e38 2c65 6e2d 5553 3b71 3d30  ;q=0.8,en-US;q=0
      	0x01f0:  2e35 2c65 6e3b 713d 302e 330d 0a41 6363  .5,en;q=0.3..Acc
      	0x0200:  6570 742d 456e 636f 6469 6e67 3a20 677a  ept-Encoding:.gz
      	0x0210:  6970 2c20 6465 666c 6174 650d 0a52 6566  ip,.deflate..Ref
      	0x0220:  6572 6572 3a20 6874 7470 3a2f 2f73 372e  erer:.http://s7.
      	0x0230:  7663 646e 2e62 697a 2f73 7461 7469 632f  vcdn.biz/static/
      	0x0240:  662f 3734 3837 3139 3137 310d 0a43 6f6e  f/748719171..Con
      	0x0250:  6e65 6374 696f 6e3a 206b 6565 702d 616c  nection:.keep-al
      	0x0260:  6976 650d 0a0d 0a                        ive....
Судя по последнему куску - это таки HTTP
но пока не могу понять как оно так вышло
ethertype 0x3507
я найти не смог что оно такое.
При этом на других интрефейсах я тоже вижу траффик с того же мака - ba:4a:d3:3c:74:d4
Забавно но так работает
tcpdump  -n -i eth4 -s 65535  -ee  -c 10000000 | grep 04:8d:38:c3:dc:06
16:36:46.418687 90:e2:ba:4a:d3:3c > 04:8d:38:c3:dc:06, ethertype 802.1Q (0x8100), length 95: vlan 3078, p 0, ethertype IPv4, 178.217.69.126.47135 > 192.168.137.119.ott: Flags [P.], seq 106:143, ack 149, win 64731, length 37
16:36:46.495619 90:e2:ba:4a:d3:3c > 04:8d:38:c3:dc:06, ethertype 802.1Q (0x8100), length 71: vlan 3078, p 0, ethertype IPv4, 40.127.160.178.50006 > 192.168.137.119.ft-role: Flags [P.], seq 118:131, ack 126, win 29200, length 13
16:36:46.496837 04:8d:38:c3:dc:06 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 64: vlan 3078, p 0, ethertype IPv4, 192.168.137.119.ft-role > 40.127.160.178.50006: Flags [.], ack 131, win 65405, length 0
16:36:46.496938 04:8d:38:c3:dc:06 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 64: vlan 3078, p 0, ethertype IPv4, 192.168.137.119.ft-role > 40.127.160.178.50006: Flags [P.], seq 126:130, ack 131, win 65405, length 4
16:36:46.603374 90:e2:ba:4a:d3:3c > 04:8d:38:c3:dc:06, ethertype 802.1Q (0x8100), length 192: vlan 3078, p 0, ethertype IPv4, 157.55.235.147.https > 192.168.137.119.kofax-svr: Flags [P.], seq 1259:1393, ack 7884, win 33580, length 134
16:36:46.605093 04:8d:38:c3:dc:06 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 94: vlan 3078, p 0, ethertype IPv4, 192.168.137.119.kofax-svr > 157.55.235.147.https: Flags [P.], seq 7884:7920, ack 1393, win 64143, length 36
16:36:46.636043 04:8d:38:c3:dc:06 > 90:e2:ba:4a:d3:3c, ethertype 802.1Q (0x8100), length 64: vlan 3078, p 0, ethertype IPv4, 192.168.137.119.ott > 178.217.69.126.47135: Flags [.], ack 157, win 65379, length 0
Т е дело в том что на уровне саб-девайса что-то не то а на уровне родительского - уже как-бы все хорошо
Интересно только что (
У меня подозрение на reorder_hdr. Раз offload отключен.
Однако
ip link set eth4.3099  type vlan reorder_hdr off
таки работает
Странно это - раньше поведение по-умолчанию было другим?
Я не могу сказать когда последний раз что-то дампал на вланах но вроде-бы при Сталине раньше такого поведения не было
