При запуски появляется ошибка:
kvm: -drive file=/var/lib/vz/images/100/vm-100-disk-1.qcow2,if=none,id=drive-ide0,format=qcow2,aio=native,cache=none,detect-zeroes=on: file system may not support O_DIRECT
kvm: -drive file=/var/lib/vz/images/100/vm-100-disk-1.qcow2,if=none,id=drive-ide0,format=qcow2,aio=native,cache=none,detect-zeroes=on: could not open disk image /var/lib/vz/images/100/vm-100-disk-1.qcow2: Could not open '/var/lib/vz/images/100/vm-100-disk-1.qcow2': Invalid argument
TASK ERROR: start failed: command '/usr/bin/kvm -id 100 -chardev 'socket,id=qmp,path=/var/run/qemu-server/100.qmp,server,nowait' -mon 'chardev=qmp,mode=control' -vnc unix:/var/run/qemu-server/100.vnc,x509,password -pidfile /var/run/qemu-server/100.pid -daemonize -smbios 'type=1,uuid=23f1d264-91c8-408e-bb84-9ac94cf529fc' -name TServer -smp '4,sockets=1,cores=4,maxcpus=4' -nodefaults -boot 'menu=on,strict=on,reboot-timeout=1000' -vga cirrus -cpu kvm64,+lahf_lm,+x2apic,+sep -m 10240 -k en-us -cpuunits 1000 -device 'piix3-usb-uhci,id=uhci,bus=pci.0,addr=0x1.0x2' -device 'usb-tablet,id=tablet,bus=uhci.0,port=1' -device 'virtio-balloon-pci,id=balloon0,bus=pci.0,addr=0x3' -iscsi 'initiator-name=iqn.1993-08.org.debian:01:5ed3e1eb441e' -drive 'file=/var/lib/vz/template/iso/debian-8.0.0-amd64-DVD-1.iso,if=none,id=drive-ide2,media=cdrom,aio=native' -device 'ide-cd,bus=ide.1,unit=0,drive=drive-ide2,id=ide2,bootindex=200' -drive 'file=/var/lib/vz/images/100/vm-100-disk-1.qcow2,if=none,id=drive-ide0,format=qcow2,aio=native,cache=none,detect-zeroes=on' -device 'ide-hd,bus=ide.0,unit=0,drive=drive-ide0,id=ide0,bootindex=100' -netdev 'type=tap,id=net0,ifname=tap100i0,script=/var/lib/qemu-server/pve-bridge,downscript=/var/lib/qemu-server/pve-bridgedown' -device 'e1000,mac=E6:03:E9:F0:74:81,netdev=net0,bus=pci.0,addr=0x12,id=net0,bootindex=300'' failed: exit code 1
В консоле показывает:
root@pve:~# kvm
Could not initialize SDL(No available video device) - exiting
root@pve:~# lspci | grep VGA
07:0b.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 10)
Сервер DELL PowerEdge 1100, никто с такой проблемой не сталкивался?
Какой адаптер? Он диск найти не может...
Напомнило только что прилетевший тикет от клиента:
я новый администратор в компании, подскажите как перезагрузить сервер.
Ну что вы так сразу... Тоже не сразу патчить, да компилировать стали... Человек старается, хоть как-то развивается. Пните его просто в нужную сторону.
  • 4 months later...
Приветствую !
Сообщение :
Parameter verification failed. (400)
net1: hotplug problem - VM 1003 qmp command 'netdev_add' failed - Device 'tap' could not be initialized
Может быть из - за того что порт сервера eth1 ( в net1) сейчас лежит ?
  • 3 months later...
  • 1 month later...
