mav Posted January 6, 2005 Posted January 6, 2005 какую лучше поставить? Сеть 100 компьютеров, ОС FreeBSD. Вставить ник Quote
Денис Креминский Posted January 6, 2005 Posted January 6, 2005 какую лучше поставить? Сеть 100 компьютеров, ОС FreeBSD. Рекомендую гугглинг про mpd. Вставить ник Quote
mav Posted January 9, 2005 Author Posted January 9, 2005 Установил mpd, настроил следующим образом: /usr/local/etc/mpd.conf default: load pptp0 load pptp1 load pptp2 load pptp3 load pptp4 load pptp5 load pptp6 load pptp7 load pptp8 load pptp9 load pptp10 pptp0: new -i ng0 pptp0 pptp0 load pptpst pptp1: new -i ng1 pptp1 pptp1 load pptpst pptp2: new -i ng2 pptp2 pptp2 load pptpst pptp3: new -i ng3 pptp3 pptp3 load pptpst pptp4: new -i ng4 pptp4 pptp4 load pptpst pptp5: new -i ng5 pptp5 pptp5 load pptpst pptp6: new -i ng6 pptp6 pptp6 load pptpst pptp7: new -i ng7 pptp7 pptp7 load pptpst pptp8: new -i ng8 pptp8 pptp8 load pptpst pptp9: new -i ng9 pptp9 pptp9 load pptpst pptp10: new -i ng10 pptp10 pptp10 load pptpst pptpst: set iface disable on-demand set bundle disable multilink set link yes acfcomp protocomp set link no pap chap set link enable chap set link keep-alive 60 180 set ipcp yes vjcomp set iface route 10.99.78.0/24 set iface enable proxy-arp set bundle enable compression set ccp yes mppc set ccp yes mpp-e40 set ccp yes mpp-e128 set ccp yes mpp-stateless set bundle yes crypt-reqd set link type pptp set pptp self 10.99.77.3 set pptp enable incoming set pptp disable originate /usr/local/etc/mpd/mpd.secrets user3 pass3 10.99.78.3 user4 pass4 10.99.78.4 ... То есть если 100 юзеров, надо в mpd.conf 100 пунктов pptp0-pptp100. Так? Вставить ник Quote
Денис Креминский Posted January 9, 2005 Posted January 9, 2005 Установил mpd, настроил следующим образом:/usr/local/etc/mpd.conf default: load pptp0 load pptp1 load pptp2 load pptp3 load pptp4 load pptp5 load pptp6 load pptp7 load pptp8 load pptp9 load pptp10 pptp0: new -i ng0 pptp0 pptp0 load pptpst pptp1: new -i ng1 pptp1 pptp1 load pptpst pptp2: new -i ng2 pptp2 pptp2 load pptpst pptp3: new -i ng3 pptp3 pptp3 load pptpst pptp4: new -i ng4 pptp4 pptp4 load pptpst pptp5: new -i ng5 pptp5 pptp5 load pptpst pptp6: new -i ng6 pptp6 pptp6 load pptpst pptp7: new -i ng7 pptp7 pptp7 load pptpst pptp8: new -i ng8 pptp8 pptp8 load pptpst pptp9: new -i ng9 pptp9 pptp9 load pptpst pptp10: new -i ng10 pptp10 pptp10 load pptpst pptpst: set iface disable on-demand set bundle disable multilink set link yes acfcomp protocomp set link no pap chap set link enable chap set link keep-alive 60 180 set ipcp yes vjcomp set iface route 10.99.78.0/24 set iface enable proxy-arp set bundle enable compression set ccp yes mppc set ccp yes mpp-e40 set ccp yes mpp-e128 set ccp yes mpp-stateless set bundle yes crypt-reqd set link type pptp set pptp self 10.99.77.3 set pptp enable incoming set pptp disable originate /usr/local/etc/mpd/mpd.secrets user3 pass3 10.99.78.3 user4 pass4 10.99.78.4 ... То есть если 100 юзеров, надо в mpd.conf 100 пунктов pptp0-pptp100. Так? Да. Плохо помню наизусть, но кажется еще mpd.links нужно будет писать. Вставить ник Quote
Sultan Posted January 10, 2005 Posted January 10, 2005 нужно еще добавить "set iface enable tcpmssfix" Вставить ник Quote
mav Posted January 10, 2005 Author Posted January 10, 2005 нужно еще добавить "set iface enable tcpmssfix" что означает эта опция? Вставить ник Quote
terapeut Posted January 10, 2005 Posted January 10, 2005 На http://www.dellroad.org/mpd/index не нашёл =(( попробуй тут - http://www.google.ru/search?num=100&hl=ru&...D1%81%D0%BA&lr= потом нам расскажешь. Вставить ник Quote
mav Posted January 10, 2005 Author Posted January 10, 2005 нашел: Ограничение на размер исходящих пакетов значением MTU Вставить ник Quote
terapeut Posted January 10, 2005 Posted January 10, 2005 Да, а где это в мануалах? Или просто из беседы на некоем форуме? Вставить ник Quote
Денис Креминский Posted January 10, 2005 Posted January 10, 2005 нашел: Ограничение на размер исходящих пакетов значением MTU не MTU, а TCP Maximum Segment Size, если мне не изменяет моя дырявая память. В общем, вставлять в конфиги обязательно, иначе будут очень странные глюки типа "фтп позволяет закачать файлы не больше 3Кб" Вставить ник Quote
terapeut Posted January 10, 2005 Posted January 10, 2005 Умгу, и сайты у некоторых пользователей - открываться очень выборочно =))) , а у некоторых - нормально. Вставить ник Quote
ToSHiC Posted January 11, 2005 Posted January 11, 2005 строк вида pptp0: new -i ng0 pptp0 pptp0 load pptpst должно быть столько, сколько у тебя клиентов одновременно в инете будут сидеть. сделай сначала половину от общеего количества, не будет хватать - ещё добавишь... Вставить ник Quote
