Добрый вечер форумчане
Есть кто-то кто настраивал прозрачный кэш прокси на squid v3.3.8 ?
Есть Ubuntu 14 на котором развернут squid 3.3.8
Сейчас при текущей конфигурации:
acl localnet src 10.20.30.0/24
http_access allow all
acl SSL_ports port 443
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 443 # https
acl Safe_ports port 70 # gopher
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl Safe_ports port 280 # http-mgmt
acl Safe_ports port 488 # gss-http
acl Safe_ports port 591 # filemaker
acl Safe_ports port 777 # multiling http
acl CONNECT method CONNECT
#http_access deny !Safe_ports
#http_access deny CONNECT !SSL_ports
#http_access allow localhost manager
#http_access allow manager
#http_access allow localnet
#http_access deny all
#dns_v4_first on
dns_nameservers 8.8.8.8
visible_hostname mynetwork
http_port 10.20.30.254:3128 intercept (пробовал делать transparent)
http_port 10.20.30.254:3129
http_reply_access allow all
coredump_dir /home/mhz/cache
cache_dir ufs /home/mhz/cache 100 16 256
access_log /home/mhz/access.log
в access.log следующее:
1428431950.118      0 10.20.30.254 TCP_MISS/403 4042 GET http://www.squid-cache.org/Artwork/SN.png - HIER_NONE/- text/html
1428431950.119      1 10.20.30.245 TCP_MISS/403 4137 GET http://www.squid-cache.org/Artwork/SN.png - HIER_DIRECT/10.20.30.254 text/html
в cache.log:
2015/04/07 23:39:51| WARNING: Error Pages Missing Language: en-ru
2015/04/07 23:39:51| WARNING: Forwarding loop detected for:
GET /Artwork/SN.png HTTP/1.1
Host: www.squid-cache.org
Accept: image/webp,*/*;q=0.8
User-Agent: Mozilla/5.0 (Linux; Android 4.4.3; HTC One dual sim Build/KTU84L) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2272.96 Mobile Safari/537.36
Referer: http://www.e1.ru/
Accept-Encoding: gzip, deflate, sdch
Accept-Language: en-RU,en-US;q=0.8,en;q=0.6
Via: 1.1 network (squid/3.3.8)
X-Forwarded-For: 10.20.30.245
Cache-Control: max-age=259200
Connection: keep-alive
по схеме users(10.20.30.0/24) --- mikrotik(10.20.30.1) --- squid3(10.20.30.254 прозрачный) --- internet
iptables на убунте со squid3 совершенно пуст т.к форвардинг на порт 3128 делается микротиком.
Собственно исходя из всего этого вопрос, где недоглядел?
Edited by megahertz
Раскомментируй, и вообще, конфиг какой то покоцанный.
А за 8.8.8.8 дай себе молотком по...любой части тела.
на самом деле это уже все эксперементы в прцоессе запуска, но тем не менее убрал и получил:
access.log - чист, ничего не сыпется
cache.log - NF getsockopt(SO_ORIGINAL_DST) failed on local=10.20.30.254:3128 remote=10.20.30.245:37071 FD 10 flags=33: (92
) Protocol not available
Он у вас адрес подделать не может. Смотрите в сторону опций ip_nonlocal_bind в sysctl/ядре.
День добрый
В общем сделал следующее:
добавил sysctl.conf
# Controls IP packet forwarding
net.ipv4.ip_forward = 1
# Controls source route verification
net.ipv4.conf.default.rp_filter = 0
# Do not accept source routing
net.ipv4.conf.default.accept_source_route = 0
Далее
echo 1 > /proc/sys/net/ipv4/ip_nonlocal_bind
echo 1 > /proc/sys/net/ipv4/ip_forward
iptables --table nat --append POSTROUTING -j MASQUERADE -s 10.20.30.0/24 -d 0.0.0.0/0
iptables --append FORWARD --in-interface eth1 -j ACCEPT
Если iptables не троогать(оставить пустой ситуация не меняется)
Конфиг сквида привел к такому виду:
acl localnet src all
#dns_v4_first on
#forwarded_for off
http_port 3128 intercept
http_port 3129
#access_log /home/mhz/access.log
#cache_log /home/mhz/cache.log
Теперь в логах:
2015/04/09 18:46:34| '/usr/share/squid3/errors/en-ru/ERR_ACCESS_DENIED': (2) No such file or directory
2015/04/09 18:46:34| WARNING: Error Pages Missing Language: en-ru
2015/04/09 18:47:18| WARNING: Forwarding loop detected for:
GET / HTTP/1.1
Host: www.e1.ru
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8
Cookie: urbid=VQrS4AAAZnUDA84CWqkgFTNYzcM=; _cb_ls=1; __utma=21800495.1885430
408.1428058292.1428058292.1428060436.2; __utmz=21800495.1428058292.1.1.utmcsr=e1.ru|utmccn=(referral)|utmcmd=referral|utmcct=/; _chartbeat2=CCITPECh2lNNBUU9gp.
1427077391655.1428399429343.10000010
00110001; __utma=57904556.28456296.1426769057.1428413369.1428427670.27; __utmz=57904556.1426769057.1.1.utmcsr=(d
irect)|utmccn=(direct)|utmcmd=(none); ngs_avc=2; doh=10
Via: 1.1 mynetwork (squid/3.3.8)
2015/04/09 18:47:18| '/usr/share/squid3/errors/en-ru/ERR_ACCESS_DENIED': (2) No such file or directory
2015/04/09 18:47:18| WARNING: Error Pages Missing Language: en-ru
В access.log
1428587379.690     38 10.20.30.254 TCP_MISS/403 4571 GET http://www.e1.ru/ - HIER_NONE/- text/html
1428587379.691     46 10.20.30.245 TCP_MISS/403 4672 GET http://www.e1.ru/ - HIER_DIRECT/10.20.30.254 text/html
1428587379.752      0 10.20.30.254 TCP_MISS/403 4054 GET http://www.squid-cache.org/Artwork/SN.png - HIER_NONE/- text/html
1428587379.752      5 10.20.30.245 TCP_MISS/403 4155 GET http://www.squid-cache.org/Artwork/SN.png - HIER_DIRECT/10.20.30.254 text/html
1428587391.779      0 10.20.30.254 TCP_MISS/403 3656 GET http://94.230.140.113/generate_204 - HIER_NONE/- text/html
1428587391.780      2 10.20.30.245 TCP_MISS/403 3757 GET http://94.230.140.113/generate_204 - HIER_DIRECT/10.20.30.254 text/html
1428587392.891      0 10.20.30.254 TCP_MISS/403 3781 GET http://clients3.google.com/generate_204 - HIER_NONE/- text/html
1428587392.892      9 10.20.30.245 TCP_MISS/403 3882 GET http://clients3.google.com/generate_204 - HIER_DIRECT/10.20.30.254 text/html
Edited by megahertz
WARNING: Error Pages Missing Language: en-ru - что не понятно то?
Или пропиши в настройках скивда правильный язык или положи страничики с ошибками локализованные куда надо.
Что с е1 - хз, толи сам сайт по кругу редиректит толи что то ещё в настройках.
А вот пользовательские куки выкладывать в паблик не хорошо, разве что они твои и тебе не жалко :)
В общем добился таки прозрачности таким образом:
На микротике:
chain=prerouting action=mark-routing new-routing-mark=squid passthrough=yes protocol=tcp
     dst-port=80 log=no log-prefix=""
ip route add dst-address=0.0.0.0/0 gateway=10.20.30.254 distance=1 routing-mark=squid
На Ubuntu 14.04 c squid3.3.8 делаем так:
iptables -t nat -A PREROUTING -s 10.20.30.254 -p tcp --dport 80 -j ACCEPT
iptables -t nat -A PREROUTING -p tcp --dport 80 -j DNAT --to-destination 10.20.30.254:3128
iptables -t nat -A POSTROUTING -j MASQUERADE
iptables -t mangle -A PREROUTING -p tcp --dport 3128 -j DROP
получаем...
428854785.537    245 10.20.30.245 TCP_MISS/200 61355 GET http://www.e1.ru/ - HIER_DIRECT/212.193.163.6 text/html
1428854786.745    549 10.20.30.245 TCP_MISS/200 361 GET http://reklama.ngs.ru/ap-js/? - HIER_DIRECT/195.93.187.3 application/javascript
1428854786.745    549 10.20.30.245 TCP_MISS/200 1527 GET http://reklama.ngs.ru/ap-js/? - HIER_DIRECT/195.93.187.3 application/javascript
1428854786.745    547 10.20.30.245 TCP_MISS/200 356 GET http://counter.yadro.ru/hit;hsdigital/rn/main/66? - HIER_DIRECT/88.212.201.199 image/gif
1428854786.745    495 10.20.30.245 TCP_MISS/200 356 GET http://counter.yadro.ru/hit;e1_ru? - HIER_DIRECT/88.212.201.199 image/gif
1428854786.855    346 10.20.30.245 TCP_MISS/200 522 GET http://www.tns-counter.ru/V13a***R%3E*hfs_ru/ru/UTF-8/tmsec=e1_main/94451653 - HIER_DIRECT/217.73.200.218 image/gif
1428854786.855    494 10.20.30.245 TCP_MISS/200 1437 GET http://reklama.ngs.ru/ap-js/? - HIER_DIRECT/195.93.187.3 application/javascript
1428854787.169    280 10.20.30.245 TCP_MISS/200 1455 GET http://reklama.ngs.ru/ap-js/? - HIER_DIRECT/195.93.187.3 application/javascript
1428854787.271   1656 10.20.30.245 TCP_MISS/200 201843 GET http://www.e1.ru/ - HIER_DIRECT/212.193.163.6 text/html
1428854787.276    533 10.20.30.245 TCP_MISS/200 2747 GET http://auto.ngs.ru/pview/offers/d6e8ed18b91f90672b061be42391ca70_50_38_c.jpg - HIER_DIRECT/195.93.187.3 image/jpeg
1428854787.277    535 10.20.30.245 TCP_MISS/200 2406 GET http://static.ngs.ru/cache//realty/photo/884dbb0583a113af92f71ce706cc788d_50_38_c.jpg - HIER_DIRECT/195.93.187.2 image/jpeg
1428854787.277    536 10.20.30.245 TCP_MISS/200 2366 GET http://do.e1.ru/preview/market/189dbbecf848cf99c6386cf2e0839a0a_1428854085_50_40_c.jpg - HIER_DIRECT/195.93.187.3 image/jpeg
1428854787.277    533 10.20.30.245 TCP_MISS/200 2786 GET http://auto.ngs.ru/pview/offers/36b7685038a03552edb36f900ddb1e9d_50_38_c.jpg - HIER_DIRECT/195.93.187.3 image/jpeg
1428854787.412    354 10.20.30.245 TCP_MISS/200 2434 GET http://do.e1.ru/preview/market/9439447813d64f481706e5bed29ed39c_1428853924_50_40_c.jpg - HIER_DIRECT/195.93.187.3 image/jpeg
1428854787.412    353 10.20.30.245 TCP_MISS/200 2809 GET http://do.e1.ru/preview/market/3b392e857e125e203c41d217ff5a8237_1428853455_50_40_c.jpg - HIER_DIRECT/195.93.187.3 image/jpeg
1428854787.497     36 10.20.30.245 TCP_MISS/200 1436 GET http://reklama.ngs.ru/ap-js/? - HIER_DIRECT/195.93.187.3 application/javascript
1428854787.516     40 10.20.30.245 TCP_MISS/200 1527 GET http://reklama.ngs.ru/ap-js/? - HIER_DIRECT/195.93.187.3 application/javascript
1428854787.653     48 10.20.30.245 TCP_MISS/200 3638 GET http://reklama.ngs.ru/ap-js/? - HIER_DIRECT/195.93.187.3 application/javascript
1428854787.783     33 10.20.30.245 TCP_MISS/200 323 GET http://reklama.ngs.ru/zxgfmzxztj/tpx? - HIER_DIRECT/195.93.187.3 image/gif
1428854787.836     65 10.20.30.245 TCP_MISS/200 1591 GET http://hc.uralweb.ru/hc/ekaterinburg6? - HIER_DIRECT/87.224.128.14 image/gif
1428854787.863     55 10.20.30.245 TCP_MISS/200 323 GET http://reklama.ngs.ru/zsqszsrwqw/tpx? - HIER_DIRECT/195.93.187.3 image/gif
1428854787.864     39 10.20.30.245 TCP_MISS/200 323 GET http://reklama.ngs.ru/zlzlyuvhzs/tpx? - HIER_DIRECT/195.93.187.3 image/gif
1428854787.864     39 10.20.30.245 TCP_MISS/200 323 GET http://reklama.ngs.ru/zlxgwbkqox/tpx? - HIER_DIRECT/195.93.187.3 image/gif
1428854787.893     57 10.20.30.245 TCP_MISS/200 323 GET http://reklama.ngs.ru/ztwzqwcvxf/tpx? - HIER_DIRECT/195.93.187.3 image/gif
1428854787.926     63 10.20.30.245 TCP_MISS/200 323 GET http://reklama.ngs.ru/zjvuxfzwqw/tpx? - HIER_DIRECT/195.93.187.3 image/gif
то есть теперь трафик бегает, странички открываются но джпег, гифы и прочее не кэшится...копаю в сторону refresh_pattern
и Собственно текущий конфиг:
cat squid.conf | egrep -v "^\s*(#|$)"
forwarded_for delete
refresh_pattern -i ^http: 5 100% 1440
acl localnet src 10.0.0.0/8	# RFC1918 possible internal network
http_access deny manager
http_port 3127
cache_dir ufs /home/mhz/cache 4096 16 256
minimum_object_size 2 KB
coredump_dir /var/spool/squid3
refresh_pattern ^ftp:		1440	20%	10080
refresh_pattern ^gopher:	1440	0%	1440
refresh_pattern -i (/cgi-bin/|\?) 0	0%	0
refresh_pattern (Release|Packages(.gz)*)$      0       20%     2880
refresh_pattern (\.gif|\.jpg|\.jpeg)$   129600 100% 129600
refresh_pattern .		0	20%	4320
Edited by megahertz
Все больше ресурсов отдают свой контент по https, его все же без nginx трудно как-то кэшировать, я про соц. сети в частности.
Да, но по сути что мешает кэшировать *.jpg,*.jpeg, *.png и т.п? интерес как раз в том чтобы кэшировать только эти ресурсы, при большом количестве пользователей повторное обращение к тем же ресурсам существенно снизят нагрузку на аплинк, сейчас у меня squid3.3.8 вообще ничего не кэширует, в логах светятся одни TCP_MISS/200
с вашего совета смотрю в сторону nginx
Edited by megahertz
Связка squid+nginx, если лень изначально самому разбираться с конфигами, то советую https://aacable.wordpress.com/2014/07/02/lusca-automated-install-script , работает из коробки.
Edited by npokypop
да, lusca завелся сходу, без шаманства, прозрачно работает но все тот же трабл с кэшированием
1429261692.131 285 10.20.30.245 TCP_MISS/302 457 GET http://habrastorage.org/files/623/d37/d81/623d37d812404ce4ad5e67c70cd9ec5a.jpg - DIRECT
/82.192.95.170 text/html
1429261692.280 253 10.20.30.245 TCP_MISS/302 457 GET http://habrastorage.org/files/482/1a8/146/4821a81465b448da935039214674ebd0.jpg - DIRECT
1429261693.199 518 10.20.30.245 TCP_MISS/200 49010 GET http://hsto.org/files/623/d37/d81/623d37d812404ce4ad5e67c70cd9ec5a.jpg - DIRECT/108.1
62.207.55 image/jpeg
1429261693.394 712 10.20.30.245 TCP_MISS/200 60318 GET http://hsto.org/files/482/1a8/146/4821a81465b448da935039214674ebd0.jpg -
видно что ничего не закэшировалось
конфиг:
http_port 3128 transparent
server_http11 on
pid_filename /var/run/squid.pid
coredump_dir /var/spool/squid/
error_directory /usr/share/squid/errors/English
icon_directory /usr/share/squid/icons
mime_table /etc/squid/mime.conf
access_log daemon:/var/log/squid/access.log squid
cache_log none
referer_log /var/log/squid/referer.log
cache_store_log none
store_dir_select_algorithm  round-robin
logfile_daemon /usr/lib/squid/logfile-daemon
logfile_rotate 1
cache_mem 256 MB
maximum_object_size_in_memory 0 KB
memory_replacement_policy heap GDSF
cache_replacement_policy heap LFUDA
minimum_object_size 0 KB
maximum_object_size 1 GB
cache_swap_low 98
cache_swap_high 99
cache_dir aufs /home/mhz/cache 5000 16 256
acl all src all
acl manager proto cache_object
acl localhost src 127.0.0.1/32
acl to_localhost dst 127.0.0.0/8
acl localnet src 172.16.0.0/12        # RFC1918 possible internal network
acl localnet src 192.168.0.0/16        # RFC1918 possible internal network
acl localnet src 125.165.92.1        # RFC1918 possible internal network
acl purge method PURGE
acl snmppublic snmp_community public
acl range dstdomain .windowsupdate.com
range_offset_limit -1 KB range
acl DENYCACHE urlpath_regex \.(ini|ui|lst|inf|pak|ver|patch|md5|cfg|lst|list|rsc|log|conf|dbd|db)$
acl DENYCACHE urlpath_regex (notice.html|afs.dat|dat.asp|patchinfo.xml|version.list|iepngfix.htc|updates.txt|patchlist.txt)
acl DENYCACHE urlpath_regex (pointblank.css|login_form.css|form.css|noupdate.ui|ahn.ui|3n.mh)$
acl DENYCACHE urlpath_regex (Loader|gamenotice|sources|captcha|notice|reset)
no_cache deny DENYCACHE
range_offset_limit 1 MB !DENYCACHE
uri_whitespace strip
acl ads url_regex -i .youtube\.com\/ad_frame?
acl ads url_regex -i .(s|s[0-90-9])\.youtube\.com
acl ads url_regex -i .googlesyndication\.com
acl ads url_regex -i .doubleclick\.net
acl ads url_regex -i ^http:\/\/googleads\.*
acl ads url_regex -i ^http:\/\/(ad|ads|ads[0-90-9]|ads\d|kad|a[b|d]|ad\d|adserver|adsbox)\.[a-z0-9]*\.[a-z][a-z]*
acl ads url_regex -i ^http:\/\/openx\.[a-z0-9]*\.[a-z][a-z]*
acl ads url_regex -i ^http:\/\/[a-z0-9]*\.openx\.net\/
acl ads url_regex -i ^http:\/\/[a-z0-9]*\.u-ad\.info\/
acl ads url_regex -i ^http:\/\/adserver\.bs\/
acl ads url_regex -i !^http:\/\/adf\.ly
http_access deny ads
http_reply_access deny ads
strip_query_terms off
acl yutub url_regex -i .*youtube\.com\/.*$
acl yutub url_regex -i .*youtu\.be\/.*$
logformat squid1 %{Referer}>h %ru
access_log /var/log/squid/yt.log squid1 yutub
acl store_rewrite_list urlpath_regex \/(get_video\?|videodownload\?|videoplayback.*id)
acl store_rewrite_list urlpath_regex \.(mp2|mp3|mid|midi|mp[234]|wav|ram|ra|rm|au|3gp|m4r|m4a)\?
acl store_rewrite_list urlpath_regex \.(mpg|mpeg|mp4|m4v|mov|avi|asf|wmv|wma|dat|flv|swf)\?
acl store_rewrite_list urlpath_regex \.(jpeg|jpg|jpe|jp2|gif|tiff?|pcx|png|bmp|pic|ico)\?
acl store_rewrite_list urlpath_regex \.(chm|dll|doc|docx|xls|xlsx|ppt|pptx|pps|ppsx|mdb|mdbx)\?
acl store_rewrite_list urlpath_regex \.(txt|conf|cfm|psd|wmf|emf|vsd|pdf|rtf|odt)\?
acl store_rewrite_list urlpath_regex \.(class|jar|exe|gz|bz|bz2|tar|tgz|zip|gzip|arj|ace|bin|cab|msi|rar)\?
acl store_rewrite_list urlpath_regex \.(htm|html|mhtml|css|js)\?
acl store_rewrite_list_web url_regex ^http:\/\/([A-Za-z-]+[0-9]+)*\.[A-Za-z]*\.[A-Za-z]*
acl store_rewrite_list_web_CDN url_regex ^http:\/\/[a-z]+[0-9]\.google\.com doubleclick\.net
acl store_rewrite_list_path urlpath_regex \.(mp2|mp3|mid|midi|mp[234]|wav|ram|ra|rm|au|3gp|m4r|m4a)$
acl store_rewrite_list_path urlpath_regex \.(mpg|mpeg|mp4|m4v|mov|avi|asf|wmv|wma|dat|flv|swf)$
acl store_rewrite_list_path urlpath_regex \.(jpeg|jpg|jpe|jp2|gif|tiff?|pcx|png|bmp|pic|ico)$
acl store_rewrite_list_path urlpath_regex \.(chm|dll|doc|docx|xls|xlsx|ppt|pptx|pps|ppsx|mdb|mdbx)$
acl store_rewrite_list_path urlpath_regex \.(txt|conf|cfm|psd|wmf|emf|vsd|pdf|rtf|odt)$
acl store_rewrite_list_path urlpath_regex \.(class|jar|exe|gz|bz|bz2|tar|tgz|zip|gzip|arj|ace|bin|cab|msi|rar)$
acl store_rewrite_list_path urlpath_regex \.(htm|html|mhtml|css|js)$
acl getmethod method GET
storeurl_access deny !getmethod
storeurl_access allow store_rewrite_list_web_CDN
storeurl_access allow store_rewrite_list_web store_rewrite_list_path
storeurl_access deny all
storeurl_rewrite_program /etc/squid/storeurl.pl
storeurl_rewrite_children 10
storeurl_rewrite_concurrency 40
refresh_pattern (get_video\?|videoplayback\?|videodownload\?|\.flv\?|\.fid\?) 43200 99% 43200 override-expire ignore-reload ignore-must-revalidate ignore-private
refresh_pattern -i (get_video\?|videoplayback\?|videodownload\?) 5259487 999% 5259487 override-expire ignore-reload reload-into-ims ignore-no-cache ignore-private
refresh_pattern ^http://*.jobstreet.com.*/.* 720 100% 10080 override-expire override-lastmod ignore-no-cache
refresh_pattern ^http://*.indowebster.com.*/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-reload ignore-no-cache ignore-auth
refresh_pattern ^http://*.21cineplex.*/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-reload ignore-no-cache ignore-auth
refresh_pattern ^http://*.atmajaya.*/.* 720 100% 10080 override-expire ignore-no-cache ignore-auth
refresh_pattern ^http://*.kompas.*/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.theinquirer.*/.* 720 100% 10080 override-expire ignore-no-cache ignore-auth
refresh_pattern ^http://*.blogspot.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.wordpress.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache
refresh_pattern ^http://*.photobucket.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.tinypic.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.imageshack.us/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.kaskus.*/.* 720 100% 28800 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://www.kaskus.com/.* 720 100% 28800 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.detik.*/.* 720 50% 2880 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.detiknews.*/*.* 720 50% 2880 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://video.liputan6.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://static.liputan6.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.friendster.com/.* 720 100% 10080 override-expire override-lastmod ignore-no-cache ignore-auth
refresh_pattern ^http://*.facebook.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://apps.facebook.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.fbcdn.net/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://profile.ak.fbcdn.net/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://static.playspoon.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://cooking.game.playspoon.com/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern -i http://[^a-z\.]*onemanga\.com/? 720 80% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://media?.onemanga.com/.* 720 80% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.yahoo.com/.* 720 80% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.google.com/.* 720 80% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.forummikrotik.com/.* 720 80% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern ^http://*.linux.or.id/.* 720 100% 10080 override-expire override-lastmod reload-into-ims ignore-no-cache ignore-auth
refresh_pattern -i \.(mp2|mp3|mid|midi|mp[234]|wav|ram|ra|rm|au|3gp|m4r|m4a)(\?.*|$) 5259487 999% 5259487 override-expire ignore-reload reload-into-ims ignore-no-cache ignore-private
refresh_pattern -i \.(mpg|mpeg|mp4|m4v|mov|avi|asf|wmv|wma|dat|flv|swf)(\?.*|$) 5259487 999% 5259487 override-expire ignore-reload reload-into-ims ignore-no-cache ignore-private
refresh_pattern -i \.(jpeg|jpg|jpe|jp2|gif|tiff?|pcx|png|bmp|pic|ico)(\?.*|$) 5259487 999% 5259487 override-expire ignore-reload reload-into-ims ignore-no-cache ignore-private
refresh_pattern -i \.(chm|dll|doc|docx|xls|xlsx|ppt|pptx|pps|ppsx|mdb|mdbx)(\?.*|$) 5259487 999% 5259487 override-expire ignore-reload reload-into-ims ignore-no-cache ignore-private
refresh_pattern -i \.(txt|conf|cfm|psd|wmf|emf|vsd|pdf|rtf|odt)(\?.*|$) 5259487 999% 5259487 override-expire ignore-reload reload-into-ims ignore-no-cache ignore-private
refresh_pattern -i \.(class|jar|exe|gz|bz|bz2|tar|tgz|zip|gzip|arj|ace|bin|cab|msi|rar)(\?.*|$) 5259487 999% 5259487 override-expire ignore-reload reload-into-ims ignore-no-cache ignore-private
refresh_pattern -i \.(htm|html|mhtml|css|js)(\?.*|$) 1440 90% 86400 override-expire ignore-reload reload-into-ims
refresh_pattern ^ftp: 10080 95% 10080 override-lastmod reload-into-ims
refresh_pattern . 0 20% 10080 override-lastmod reload-into-ims
http_access allow manager localhost
http_access allow purge localhost
icp_access allow localnet
icp_access deny all
icp_port 0
buffered_logs on
acl shoutcast rep_header X-HTTP09-First-Line ^ICY.[0-9]
upgrade_http0.9 deny shoutcast
acl apache rep_header Server ^Apache
broken_vary_encoding allow apache
forwarded_for off
header_access From deny all
header_access Server deny all
header_access Link deny all
header_access Via deny all
header_access X-Forwarded-For deny all
httpd_suppress_version_string on
shutdown_lifetime 10 seconds
snmp_port 3401
snmp_access allow snmppublic all
dns_timeout 1 minutes
dns_nameservers 8.8.8.8 8.8.4.4
fqdncache_size 5000    #16384
ipcache_size 5000    #16384
ipcache_low 98
ipcache_high 99
log_fqdn off
log_icp_queries off
memory_pools off
maximum_single_addr_tries 2
retry_on_error on
icp_hit_stale on
query_icmp on
reload_into_ims on
emulate_httpd_log off
negative_ttl 0 seconds
pipeline_prefetch on
vary_ignore_expire on
half_closed_clients off
high_page_fault_warning 2
nonhierarchical_direct on
prefer_direct off
cache_mgr aacable@hotmail.com
cache_effective_user proxy
cache_effective_group proxy
visible_hostname proxy.zaib
unique_hostname syed_jahanzaib
cachemgr_passwd none all
client_db on
max_filedescriptors 8192
zph_mode tos
zph_local 0x30
zph_parent 0
zph_option 136
TCP_IMS_HIT304 325 GET http://cdn.clicktale.net/www/tc/WRe21.js - NONE/- application/javascript
TCP_IMS_HIT/304 325 GET http://cdn.clicktale.net/www/ChangeMonitor-latest.js - NONE/- application/javascript
TCP_MEM_HIT/200 347 GET http://www.msftconnecttest.com/connecttest.txt - NONE/- text/plain
а вот JS пролез
Edited by megahertz
lusca у меня хорошо кэширует такие ресурсы как megogo и аналоги, youtube кэшировать так я ее и не заставил.
он у меня банально jpeg не кэшит, можешь свои pattern'ы показать?
