Столкнулся с новой для себя проблемой на pppoe сервере с FreeBSD 10.1-RELEASE amd 64, время от времени а точнее раз в неделю полторы вне зависимости от нагрузки происходит kernel panic с таким выводом:
Fatal trap 18: integer divide fault while in kernel mode
cpuid = 0; apic id = 00
instruction pointer     = 0x20:0xffffffff80785266
stack pointer           = 0x28:0xfffffe0000283050
frame pointer           = 0x28:0xfffffe00002830e0
code segment            = base 0x0, limit 0xfffff, type 0x1b
                       = DPL 0, pres 1, long 1, def32 0, gran 1
processor eflags        = interrupt enabled, resume, IOPL = 0
current process         = 12 (irq286: igb3:que 0)
trap number             = 18
panic: integer divide fault
cpuid = 0
На сервере имеется 4 сетевых карты igb и из них собраны 2 lagg интерфейса, из установленного:
autoconf-2.69 Automatically configure source code on many Un*x platforms
autoconf-wrapper-20131203 Wrapper script for GNU autoconf
automake-1.14_1 GNU Standards-compliant Makefile generator
automake-wrapper-20131203 Wrapper script for GNU automake
bash-4.3.30_1 The GNU Project's Bourne Again SHell
bison-2.7.1,1 Parser generator from FSF, (mostly) compatible with Yacc
dialog4ports-0.1.5_2 Console Interface to configure ports
expat-2.1.0_2 XML 1.0 parser written in C
gawk-4.1.1_1 The GNU version of Awk
gettext-runtime-0.19.3 GNU gettext runtime libraries and programs
gettext-tools-0.19.3 GNU gettext development and translation tools
gmake-4.1_1 GNU version of 'make' utility
gmake-lite-4.1_1 Minimalist version of gnu make
help2man-1.43.3_1 Automatically generating simple manual pages from program output
indexinfo-0.2 Utility to regenerate the GNU info page index
libsigsegv-2.10_1 Handling page faults in user mode
libtool-2.4.2.418 Generic shared library support script
m4-1.4.17_1,1 GNU m4
mpd5-5.7_1 Multi-link PPP daemon based on netgraph(4)
net-snmp-5.7.2_17 Extendable SNMP implementation
ng_ipacct-20061223_3 Netgraph IP accounting
p5-Locale-gettext-1.05_4 Message handling functions
perl5-5.18.4_10 Practical Extraction and Report Language
pkg-1.3.8_3 Package manager
quagga-0.99.23.1_2 Free RIPv1, RIPv2, OSPFv2, BGP4, IS-IS route software
kernel config
options CONFIG_AUTOGENERATED
ident GENERIC
machine amd64
cpu HAMMER
makeoptions WITH_CTF=1
makeoptions DEBUG=-g
options RADIX_MPATH
options HZ=1000
options DEVICE_POLLING
options NETGRAPH_NETFLOW
options NETGRAPH_IPFW
options NETGRAPH_VJC
options NETGRAPH_UI
options NETGRAPH_TTY
options NETGRAPH_TEE
options NETGRAPH_RFC1490
options NETGRAPH_PPP
options NETGRAPH_ONE2MANY
options NETGRAPH_MPPC_ENCRYPTION
options NETGRAPH_LMI
options NETGRAPH_L2TP
options NETGRAPH_KSOCKET
options NETGRAPH_IFACE
options NETGRAPH_HOLE
options NETGRAPH_FRAME_RELAY
options NETGRAPH_ECHO
options NETGRAPH_BPF
options NETGRAPH_PPTPGRE
options NETGRAPH_PPPOE
options NETGRAPH_SOCKET
options NETGRAPH_ETHER
options NETGRAPH
options DUMMYNET
options IPDIVERT
options IPFIREWALL_VERBOSE_LIMIT=100
options IPFIREWALL
options XENHVM
options USB_DEBUG
options SC_PIXEL_MODE
options VESA
options AHD_REG_PRETTY_PRINT
options AHC_REG_PRETTY_PRINT
options ATA_STATIC_ID
options ACPI_DMAR
options SMP
options KDB_TRACE
options KDB
options INCLUDE_CONFIG_FILE
options DDB_CTF
options KDTRACE_HOOKS
options KDTRACE_FRAME
options MAC
options PROCDESC
options CAPABILITIES
options CAPABILITY_MODE
options AUDIT
options HWPMC_HOOKS
options KBD_INSTALL_CDEV
options PRINTF_BUFR_SIZE=128
options _KPOSIX_PRIORITY_SCHEDULING
options SYSVSEM
options SYSVMSG
options SYSVSHM
options STACK
options KTRACE
options SCSI_DELAY=5000
options COMPAT_FREEBSD7
options COMPAT_FREEBSD6
options COMPAT_FREEBSD5
options COMPAT_FREEBSD4
options COMPAT_FREEBSD32
options GEOM_LABEL
options GEOM_RAID
options GEOM_PART_GPT
options PSEUDOFS
options PROCFS
options CD9660
options MSDOSFS
options NFS_ROOT
options NFSLOCKD
options NFSD
options NFSCL
options MD_ROOT
options QUOTA
options UFS_GJOURNAL
options UFS_DIRHASH
options UFS_ACL
options SOFTUPDATES
options FFS
options SCTP
options TCP_OFFLOAD
options INET
options PREEMPTION
options SCHED_ULE
options NEW_PCIB
options GEOM_PART_MBR
options GEOM_PART_EBR_COMPAT
options GEOM_PART_BSD
device isa
device mem
device io
device uart_ns8250
device cpufreq
device acpi
device pci
device fdc
device ahci
device ata
device mvs
device siis
device ahc
device ahd
device esp
device hptiop
device isp
device mpt
device mps
device mpr
device sym
device trm
device adv
device adw
device aic
device bt
device isci
device scbus
device ch
device da
device sa
device cd
device pass
device ses
device amr
device arcmsr
device ciss
device dpt
device hptmv
device hptnr
device hptrr
device hpt27xx
device iir
device ips
device mly
device twa
device tws
device aac
device aacp
device aacraid
device ida
device mfi
device mlx
device mrsas
device twe
device atkbdc
device atkbd
device psm
device kbdmux
device vga
device splash
device sc
device vt
device vt_vga
device vt_efifb
device agp
device cbb
device pccard
device cardbus
device uart
device ppc
device ppbus
device lpt
device ppi
device puc
device em
device igb
device ixgbe
device miibus
device loop
device random
device padlock_rng
device rdrand_rng
device ether
device vlan
device tun
device md
device gif
device faith
device firmware
device bpf
device uhci
device ohci
device ehci
device xhci
device usb
device ukbd
device umass
device mmc
device mmcsd
device sdhci
device virtio
device virtio_pci
device vtnet
device virtio_blk
device virtio_scsi
device virtio_balloon
device hyperv
device xenpci
device vmx
device lagg
rc.conf
ihostname="nas"
gateway_enable="YES"
ifconfig_igb0="up"
ifconfig_igb1="up"
ifconfig_igb2="up"
ifconfig_igb3="up"
ifconfig_lagg0="laggproto lacp laggport igb0 laggport igb1 xx.xx.xx.xx netmask xx.xx.xx.xx"
ifconfig_lagg1="laggproto lacp laggport igb2 laggport igb3 xx.xx.xx.xx netmask xx.xx.xx.xx"
defaultrouter="xx.xx.xx.xx"
cloned_interfaces="lagg0 lagg1 vlan51 vlan52 vlan53 vlan54 vlan55 vlan56 vlan57 vlan58 vlan59 vlan60 vlan61 vlan62 vlan63 vlan64 vlan65 vlan66 vlan67 vlan68 vlan69 vlan70 vlan71 vlan101 vlan102 vlan103 vlan104 vlan105 vlan106 vlan107 vlan108 vlan109 vlan110 vlan151 vlan152 vlan153 vlan154 vlan155 vlan156 vlan157 vlan158 vlan159 vlan160 vlan161 vlan162 vlan163 vlan164 vlan165 vlan166 vlan167 vlan201 vlan202 vlan203 vlan204 vlan205 vlan206 vlan207 vlan208 vlan209 vlan210 vlan211 vlan212 vlan213 vlan214 vlan215 vlan216 vlan217 vlan218 vlan219 vlan220 vlan221 vlan222 vlan223 vlan224 vlan225 vlan226 vlan227 vlan228 vlan229 vlan230 vlan231 vlan232 vlan233 vlan234 vlan235 vlan251 vlan252 vlan253 vlan254 vlan255 vlan256 vlan257 vlan258 vlan259 vlan260 vlan261 vlan262 vlan263 vlan264 vlan265 vlan266 vlan267 vlan268 vlan269 vlan270 vlan271 vlan272 vlan273 vlan274 vlan275 vlan276 vlan277 vlan278 vlan279 vlan280 vlan281 vlan305 vlan306 vlan307 vlan308 vlan309 vlan310 vlan311 vlan312 vlan313 vlan314 vlan315 vlan316 vlan317 vlan318 vlan319 vlan320 vlan321 vlan322 vlan323 vlan324 vlan325 vlan326 vlan327 vlan328 vlan329 vlan330 vlan331 vlan332 vlan333 vlan334 vlan335 vlan351 vlan352 vlan353 vlan354 vlan355 vlan356 vlan357 vlan358 vlan359 vlan360 vlan361 vlan362 vlan363 vlan364 vlan365 vlan366 vlan367 vlan368 vlan369 vlan370 vlan371 vlan372 vlan373 vlan374 vlan375"
ifconfig_vlan51="vlan 51 vlandev lagg1"
ifconfig_vlan52="vlan 52 vlandev lagg1"
ifconfig_vlan53="vlan 53 vlandev lagg1"
ifconfig_vlan54="vlan 54 vlandev lagg1"
ifconfig_vlan55="vlan 55 vlandev lagg1"
ifconfig_vlan56="vlan 56 vlandev lagg1"
ifconfig_vlan57="vlan 57 vlandev lagg1"
ifconfig_vlan58="vlan 58 vlandev lagg1"
ifconfig_vlan59="vlan 59 vlandev lagg1"
ifconfig_vlan60="vlan 60 vlandev lagg1"
ifconfig_vlan61="vlan 61 vlandev lagg1"
ifconfig_vlan62="vlan 62 vlandev lagg1"
ifconfig_vlan63="vlan 63 vlandev lagg1"
ifconfig_vlan64="vlan 64 vlandev lagg1"
ifconfig_vlan65="vlan 65 vlandev lagg1"
ifconfig_vlan66="vlan 66 vlandev lagg1"
ifconfig_vlan67="vlan 67 vlandev lagg1"
ifconfig_vlan68="vlan 68 vlandev lagg1"
ifconfig_vlan69="vlan 69 vlandev lagg1"
ifconfig_vlan70="vlan 70 vlandev lagg1"
ifconfig_vlan71="vlan 71 vlandev lagg1"
ifconfig_vlan101="vlan 101 vlandev lagg1"
ifconfig_vlan102="vlan 102 vlandev lagg1"
ifconfig_vlan103="vlan 103 vlandev lagg1"
ifconfig_vlan104="vlan 104 vlandev lagg1"
ifconfig_vlan105="vlan 105 vlandev lagg1"
ifconfig_vlan106="vlan 106 vlandev lagg1"
ifconfig_vlan107="vlan 107 vlandev lagg1"
ifconfig_vlan108="vlan 108 vlandev lagg1"
ifconfig_vlan109="vlan 109 vlandev lagg1"
ifconfig_vlan110="vlan 110 vlandev lagg1"
ifconfig_vlan151="vlan 151 vlandev lagg1"
ifconfig_vlan152="vlan 152 vlandev lagg1"
ifconfig_vlan153="vlan 153 vlandev lagg1"
ifconfig_vlan154="vlan 154 vlandev lagg1"
ifconfig_vlan155="vlan 155 vlandev lagg1"
ifconfig_vlan156="vlan 156 vlandev lagg1"
ifconfig_vlan157="vlan 157 vlandev lagg1"
ifconfig_vlan158="vlan 158 vlandev lagg1"
ifconfig_vlan159="vlan 159 vlandev lagg1"
ifconfig_vlan160="vlan 160 vlandev lagg1"
ifconfig_vlan161="vlan 161 vlandev lagg1"
ifconfig_vlan162="vlan 162 vlandev lagg1"
ifconfig_vlan163="vlan 163 vlandev lagg1"
ifconfig_vlan164="vlan 164 vlandev lagg1"
ifconfig_vlan165="vlan 165 vlandev lagg1"
ifconfig_vlan166="vlan 166 vlandev lagg1"
ifconfig_vlan167="vlan 167 vlandev lagg1"
ifconfig_vlan201="vlan 201 vlandev lagg1"
ifconfig_vlan202="vlan 202 vlandev lagg1"
ifconfig_vlan203="vlan 203 vlandev lagg1"
ifconfig_vlan204="vlan 204 vlandev lagg1"
ifconfig_vlan205="vlan 205 vlandev lagg1"
ifconfig_vlan206="vlan 206 vlandev lagg1"
ifconfig_vlan207="vlan 207 vlandev lagg1"
ifconfig_vlan208="vlan 208 vlandev lagg1"
ifconfig_vlan209="vlan 209 vlandev lagg1"
ifconfig_vlan210="vlan 210 vlandev lagg1"
ifconfig_vlan211="vlan 211 vlandev lagg1"
ifconfig_vlan212="vlan 212 vlandev lagg1"
ifconfig_vlan213="vlan 213 vlandev lagg1"
ifconfig_vlan214="vlan 214 vlandev lagg1"
ifconfig_vlan215="vlan 215 vlandev lagg1"
ifconfig_vlan216="vlan 216 vlandev lagg1"
ifconfig_vlan217="vlan 217 vlandev lagg1"
ifconfig_vlan218="vlan 218 vlandev lagg1"
ifconfig_vlan219="vlan 219 vlandev lagg1"
ifconfig_vlan220="vlan 220 vlandev lagg1"
ifconfig_vlan221="vlan 221 vlandev lagg1"
ifconfig_vlan222="vlan 222 vlandev lagg1"
ifconfig_vlan223="vlan 223 vlandev lagg1"
ifconfig_vlan224="vlan 224 vlandev lagg1"
ifconfig_vlan225="vlan 225 vlandev lagg1"
ifconfig_vlan226="vlan 226 vlandev lagg1"
ifconfig_vlan227="vlan 227 vlandev lagg1"
ifconfig_vlan228="vlan 228 vlandev lagg1"
ifconfig_vlan229="vlan 229 vlandev lagg1"
ifconfig_vlan230="vlan 230 vlandev lagg1"
ifconfig_vlan231="vlan 231 vlandev lagg1"
ifconfig_vlan232="vlan 232 vlandev lagg1"
ifconfig_vlan233="vlan 233 vlandev lagg1"
ifconfig_vlan234="vlan 234 vlandev lagg1"
ifconfig_vlan235="vlan 235 vlandev lagg1"
ifconfig_vlan251="vlan 251 vlandev lagg1"
ifconfig_vlan252="vlan 252 vlandev lagg1"
ifconfig_vlan253="vlan 253 vlandev lagg1"
ifconfig_vlan254="vlan 254 vlandev lagg1"
ifconfig_vlan255="vlan 255 vlandev lagg1"
ifconfig_vlan256="vlan 256 vlandev lagg1"
ifconfig_vlan257="vlan 257 vlandev lagg1"
ifconfig_vlan258="vlan 258 vlandev lagg1"
ifconfig_vlan259="vlan 259 vlandev lagg1"
ifconfig_vlan260="vlan 260 vlandev lagg1"
ifconfig_vlan261="vlan 261 vlandev lagg1"
ifconfig_vlan262="vlan 262 vlandev lagg1"
ifconfig_vlan263="vlan 263 vlandev lagg1"
ifconfig_vlan264="vlan 264 vlandev lagg1"
ifconfig_vlan265="vlan 265 vlandev lagg1"
ifconfig_vlan266="vlan 266 vlandev lagg1"
ifconfig_vlan267="vlan 267 vlandev lagg1"
ifconfig_vlan268="vlan 268 vlandev lagg1"
ifconfig_vlan269="vlan 269 vlandev lagg1"
ifconfig_vlan270="vlan 270 vlandev lagg1"
ifconfig_vlan271="vlan 271 vlandev lagg1"
ifconfig_vlan272="vlan 272 vlandev lagg1"
ifconfig_vlan273="vlan 273 vlandev lagg1"
ifconfig_vlan274="vlan 274 vlandev lagg1"
ifconfig_vlan275="vlan 275 vlandev lagg1"
ifconfig_vlan276="vlan 276 vlandev lagg1"
ifconfig_vlan277="vlan 277 vlandev lagg1"
ifconfig_vlan278="vlan 278 vlandev lagg1"
ifconfig_vlan279="vlan 279 vlandev lagg1"
ifconfig_vlan280="vlan 280 vlandev lagg1"
ifconfig_vlan281="vlan 281 vlandev lagg1"
ifconfig_vlan305="vlan 305 vlandev lagg1"
ifconfig_vlan306="vlan 306 vlandev lagg1"
ifconfig_vlan307="vlan 307 vlandev lagg1"
ifconfig_vlan308="vlan 308 vlandev lagg1"
ifconfig_vlan309="vlan 309 vlandev lagg1"
ifconfig_vlan310="vlan 310 vlandev lagg1"
ifconfig_vlan311="vlan 311 vlandev lagg1"
ifconfig_vlan312="vlan 312 vlandev lagg1"
ifconfig_vlan313="vlan 313 vlandev lagg1"
ifconfig_vlan314="vlan 314 vlandev lagg1"
ifconfig_vlan315="vlan 315 vlandev lagg1"
ifconfig_vlan316="vlan 316 vlandev lagg1"
ifconfig_vlan317="vlan 317 vlandev lagg1"
ifconfig_vlan318="vlan 318 vlandev lagg1"
ifconfig_vlan319="vlan 319 vlandev lagg1"
ifconfig_vlan320="vlan 320 vlandev lagg1"
ifconfig_vlan321="vlan 321 vlandev lagg1"
ifconfig_vlan322="vlan 322 vlandev lagg1"
ifconfig_vlan323="vlan 323 vlandev lagg1"
ifconfig_vlan324="vlan 324 vlandev lagg1"
ifconfig_vlan325="vlan 325 vlandev lagg1"
ifconfig_vlan326="vlan 326 vlandev lagg1"
ifconfig_vlan327="vlan 327 vlandev lagg1"
ifconfig_vlan328="vlan 328 vlandev lagg1"
ifconfig_vlan329="vlan 329 vlandev lagg1"
ifconfig_vlan330="vlan 330 vlandev lagg1"
ifconfig_vlan331="vlan 331 vlandev lagg1"
ifconfig_vlan332="vlan 332 vlandev lagg1"
ifconfig_vlan333="vlan 333 vlandev lagg1"
ifconfig_vlan334="vlan 334 vlandev lagg1"
ifconfig_vlan335="vlan 335 vlandev lagg1"
ifconfig_vlan351="vlan 351 vlandev lagg1"
ifconfig_vlan352="vlan 352 vlandev lagg1"
ifconfig_vlan353="vlan 353 vlandev lagg1"
ifconfig_vlan354="vlan 354 vlandev lagg1"
ifconfig_vlan355="vlan 355 vlandev lagg1"
ifconfig_vlan356="vlan 356 vlandev lagg1"
ifconfig_vlan357="vlan 357 vlandev lagg1"
ifconfig_vlan358="vlan 358 vlandev lagg1"
ifconfig_vlan359="vlan 359 vlandev lagg1"
ifconfig_vlan360="vlan 360 vlandev lagg1"
ifconfig_vlan361="vlan 361 vlandev lagg1"
ifconfig_vlan362="vlan 362 vlandev lagg1"
ifconfig_vlan363="vlan 363 vlandev lagg1"
ifconfig_vlan364="vlan 364 vlandev lagg1"
ifconfig_vlan365="vlan 365 vlandev lagg1"
ifconfig_vlan366="vlan 366 vlandev lagg1"
ifconfig_vlan367="vlan 367 vlandev lagg1"
ifconfig_vlan368="vlan 368 vlandev lagg1"
ifconfig_vlan369="vlan 369 vlandev lagg1"
ifconfig_vlan370="vlan 370 vlandev lagg1"
ifconfig_vlan371="vlan 371 vlandev lagg1"
ifconfig_vlan372="vlan 372 vlandev lagg1"
ifconfig_vlan373="vlan 373 vlandev lagg1"
ifconfig_vlan374="vlan 374 vlandev lagg1"
ifconfig_vlan375="vlan 375 vlandev lagg1"
#SNMP
snmpd_enable="YES"
#MPD
mpd_enable="YES"
mpd_flags="-b"
#IPFW
firewall_enable="YES"
quagga_enable=YES
quagga_daemons="zebra bgpd"
#keymap="us.iso.kbd"
sshd_enable="YES"
ntpd_enable="YES"
# Set dumpdev to "AUTO" to enable crash dumps, "NO" to disable
dumpdev="AUTO"
dump
FreeBSD 10.1-RELEASE FreeBSD 10.1-RELEASE amd64
GNU gdb 6.1.1 [FreeBSD]
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "amd64-marcel-freebsd"...
Unread portion of the kernel message buffer:
trap number = 18
cpuid = 0
KDB: stack backtrace:
#0 0xffffffff80705900 at kdb_backtrace+0x60
#1 0xffffffff806caa25 at panic+0x155
#2 0xffffffff80a8585f at trap_fatal+0x38f
#3 0xffffffff80a854bc at trap+0x75c
#4 0xffffffff80a6b0c2 at calltrap+0x8
#5 0xffffffff807b607f at ng_bpf_rcvdata+0x8f
#6 0xffffffff807b359c at ng_apply_item+0x22c
#7 0xffffffff807b31b3 at ng_snd_item+0x1a3
#8 0xffffffff807b359c at ng_apply_item+0x22c
#9 0xffffffff807b31b3 at ng_snd_item+0x1a3
#10 0xffffffff807b359c at ng_apply_item+0x22c
#11 0xffffffff807b31b3 at ng_snd_item+0x1a3
#12 0xffffffff807c3d68 at ng_ppp_comp_recv+0x148
#13 0xffffffff807b359c at ng_apply_item+0x22c
#14 0xffffffff807b31b3 at ng_snd_item+0x1a3
#15 0xffffffff807b359c at ng_apply_item+0x22c
#16 0xffffffff807b31b3 at ng_snd_item+0x1a3
#17 0xffffffff807c6e0c at ng_pppoe_rcvdata_ether+0x27c
Uptime: 5d21h31m53s
Dumping 834 out of 8139 MB:..2%..12%..22%..31%..41%..52%..62%..71%..81%..91%
Reading symbols from /boot/kernel/ng_tcpmss.ko.symbols...done.
Loaded symbols for /boot/kernel/ng_tcpmss.ko.symbols
Reading symbols from /boot/kernel/ng_car.ko.symbols...done.
Loaded symbols for /boot/kernel/ng_car.ko.symbols
#0 doadump (textdump=<value optimized out>) at pcpu.h:219
219 pcpu.h: No such file or directory.
in pcpu.h
(kgdb) #0 doadump (textdump=<value optimized out>) at pcpu.h:219
#1 0xffffffff806ca6a2 in kern_reboot (howto=260)
at /usr/src/sys/kern/kern_shutdown.c:452
#2 0xffffffff806caa64 in panic (fmt=<value optimized out>)
at /usr/src/sys/kern/kern_shutdown.c:759
#3 0xffffffff80a8585f in trap_fatal (frame=<value optimized out>,
eva=<value optimized out>) at /usr/src/sys/amd64/amd64/trap.c:865
#4 0xffffffff80a854bc in trap (frame=<value optimized out>)
at /usr/src/sys/amd64/amd64/trap.c:203
#5 0xffffffff80a6b0c2 in calltrap ()
at /usr/src/sys/amd64/amd64/exception.S:232
#6 0xffffffff80785266 in bpf_filter (pc=0xfffff80016a14e04,
p=0xfffff8000ba97816 "E", wirelen=327, buflen=327)
at /usr/src/sys/net/bpf_filter.c:466
#7 0xffffffff807b607f in ng_bpf_rcvdata (hook=<value optimized out>,
item=<value optimized out>) at /usr/src/sys/netgraph/ng_bpf.c:476
#8 0xffffffff807b359c in ng_apply_item (node=0xfffff8014684e600,
item=0xfffff80146021380, rw=0) at /usr/src/sys/netgraph/ng_base.c:2397
#9 0xffffffff807b31b3 in ng_snd_item (item=0xfffff80146021380,
flags=<value optimized out>) at /usr/src/sys/netgraph/ng_base.c:2314
#10 0xffffffff807b359c in ng_apply_item (node=0xfffff80146830500,
#11 0xffffffff807b31b3 in ng_snd_item (item=0xfffff80146021380,
#12 0xffffffff807b359c in ng_apply_item (node=0xfffff80146fb7800,
#13 0xffffffff807b31b3 in ng_snd_item (item=0xfffff80146021380,
#14 0xffffffff807c3d68 in ng_ppp_comp_recv (node=<value optimized out>,
item=0xfffff80146021380, proto=<value optimized out>,
linkNum=<value optimized out>) at /usr/src/sys/netgraph/ng_ppp.c:947
#15 0xffffffff807b359c in ng_apply_item (node=0xfffff801468bc200,
#16 0xffffffff807b31b3 in ng_snd_item (item=0xfffff80146021380,
#17 0xffffffff807b359c in ng_apply_item (node=0xfffff8014679d700,
#18 0xffffffff807b31b3 in ng_snd_item (item=0xfffff80146021380,
#19 0xffffffff807c6e0c in ng_pppoe_rcvdata_ether (hook=<value optimized out>,
item=0xfffff80146021380) at /usr/src/sys/netgraph/ng_pppoe.c:1387
#20 0xffffffff807b359c in ng_apply_item (node=0xfffff80146d06000,
#21 0xffffffff807b31b3 in ng_snd_item (item=0xfffff80146021380,
#22 0xffffffff80791016 in ether_demux (ifp=0xfffff8000b548800,
m=0xfffff80218ae1e00) at /usr/src/sys/net/if_ethersubr.c:868
#23 0xffffffff80791b4e in ether_nh_input (m=<value optimized out>)
at /usr/src/sys/net/if_ethersubr.c:646
#24 0xffffffff8079cba2 in netisr_dispatch_src (proto=<value optimized out>,
source=<value optimized out>, m=0x3730316c)
at /usr/src/sys/net/netisr.c:972
#25 0xffffffff80790ed1 in ether_demux (ifp=0xfffff80009eaa000,
m=0xfffff80218ae1e00) at /usr/src/sys/net/if_ethersubr.c:760
#26 0xffffffff80791b4e in ether_nh_input (m=<value optimized out>)
#27 0xffffffff8079cba2 in netisr_dispatch_src (proto=<value optimized out>,
#28 0xffffffff803e53e8 in igb_rxeof (que=0xfffff800044dfc00, count=99,
done=0x0) at /usr/src/sys/dev/e1000/if_igb.c:4797
#29 0xffffffff803e5993 in igb_msix_que (arg=0xfffff800044dfc00)
at /usr/src/sys/dev/e1000/if_igb.c:1621
#30 0xffffffff8069e51b in intr_event_execute_handlers (
p=<value optimized out>, ie=0xfffff800044da300)
at /usr/src/sys/kern/kern_intr.c:1263
#31 0xffffffff8069e966 in ithread_loop (arg=0xfffff800044fe0e0)
at /usr/src/sys/kern/kern_intr.c:1276
#32 0xffffffff8069c13a in fork_exit (
callout=0xffffffff8069e8d0 <ithread_loop>, arg=0xfffff800044fe0e0,
frame=0xfffffe0000283ac0) at /usr/src/sys/kern/kern_fork.c:996
#33 0xffffffff80a6b5fe in fork_trampoline ()
at /usr/src/sys/amd64/amd64/exception.S:606
#34 0x0000000000000000 in ?? ()
Current language: auto; currently minimal
(kgdb)
ps -axlww
UID PID PPID CPU PRI NI VSZ RSS MWCHAN STAT TT TIME COMMAND
0 0 0 0 -8 0 0 18014389971124704 - DLs - 21:13.74 [kernel]
0 1 0 0 20 0 9472 17979214879562752 wait DLs - 0:00.36 [init]
0 2 0 0 -16 0 0 18014389971124704 - DL - 0:02.44 [cam]
0 3 0 0 -16 0 0 18014389971124704 waiting_ DL - 0:00.01 [sctp_iterator]
0 4 0 0 -16 0 0 18014389971124704 idle DL - 0:00.22 [enc_daemon0]
0 5 0 0 -16 0 0 18014389971124704 psleep DL - 0:05.13 [pagedaemon]
0 6 0 0 -16 0 0 18014389971124704 psleep DL - 0:00.00 [vmdaemon]
0 7 0 0 -16 0 0 18014389971124704 pollid DL - 0:00.40 [idlepoll]
0 8 0 0 155 0 0 18014389971124704 pgzero DL - 0:00.00 [pagezero]
0 9 0 0 20 0 0 18014389971124704 sdflush DL - 0:15.97 [bufdaemon]
0 10 0 0 -16 0 0 18014389971124704 audit_wo DL - 0:00.00 [audit]
0 11 0 0 155 0 0 18014389971124704 - RL - 43748:37.72 [idle]
0 12 0 0 -76 0 0 18014389971124704 - WL - 6091:01.22 [intr]
0 13 0 0 -16 0 0 18014389971124704 sleep DL - 11:36.24 [ng_queue]
0 14 0 0 -8 0 0 18014389971124704 - DL - 0:00.02 [geom]
0 15 0 0 -16 0 0 18014389971124704 - DL - 103:12.93 [rand_harvestq]
0 16 0 0 -68 0 0 18014389971124704 - DL - 0:39.91 [usb]
0 17 0 0 -16 0 0 18014389971124704 tzpoll DL - 0:02.57 [acpi_thermal]
0 18 0 0 -16 0 0 18014389971124704 cooling DL - 0:00.24 [acpi_cooling0]
0 19 0 0 -16 0 0 18014389971124704 vlruwt DL - 0:01.38 [vnlru]
0 20 0 0 16 0 0 18014389971124704 syncer DL - 4:21.01 [syncer]
101 6790 1 0 20 0 31840 17979214901499136 select Ds - 56:55.69 [zebra]
101 6796 1 0 20 0 34800 17979214881672704 select Ds - 2:40.56 [bgpd]
0 7857 1 0 52 0 13164 0 select Ds - 0:06.30 [devd]
0 8315 1 0 20 0 14492 17979214894690560 select Ds - 0:03.84 [syslogd]
0 8490 1 0 23 0 281368 17979214898344192 select Ds - 583:16.16 [mpd5]
0 8667 1 0 24 0 76796 0 select D - 290:31.62 [snmpd]
0 8695 1 0 20 0 25448 17979214897788928 select Ds - 3:18.19 [ntpd]
0 8736 1 0 20 0 61204 17979214881648896 select Ds - 0:05.24 [sshd]
0 8739 1 0 20 0 24104 17979214894067968 select Ds - 0:05.45 [sendmail]
25 8742 1 0 20 0 24104 17979214899163392 pause Ds - 0:00.09 [sendmail]
0 8746 1 0 52 0 16592 17979214897892864 nanslp Ds - 0:01.02 [cron]
0 8792 1 0 52 0 14488 17979214879546368 ttyin Ds+ - 0:00.00 [getty]
0 8793 1 0 52 0 14488 17979214881681664 ttyin Ds+ - 0:00.00 [getty]
0 8794 1 0 52 0 14488 17979214894277376 ttyin Ds+ - 0:00.00 [getty]
0 8795 1 0 52 0 14488 17979214896412672 ttyin Ds+ - 0:00.00 [getty]
0 8796 1 0 52 0 14488 0 ttyin Ds+ - 0:00.00 [getty]
0 8797 1 0 52 0 14488 17979214881639936 ttyin Ds+ - 0:00.00 [getty]
0 8798 1 0 52 0 14488 17979214898337024 ttyin Ds+ - 0:00.00 [getty]
0 8799 1 0 52 0 14488 17979214879569920 ttyin Ds+ - 0:00.00 [getty]
vmstat -s
764749945 cpu context switches
439100610 device interrupts
497473979 software interrupts
369010503 traps
2463897317 system calls
20 kernel threads created
285323 fork() calls
74865 vfork() calls
0 rfork() calls
0 swap pager pageins
0 swap pager pages paged in
0 swap pager pageouts
0 swap pager pages paged out
1006 vnode pager pageins
8193 vnode pager pages paged in
0 vnode pager pageouts
0 vnode pager pages paged out
0 page daemon wakeups
0 pages examined by the page daemon
792 pages reactivated
12404768 copy-on-write faults
20508 copy-on-write optimized faults
23168251 zero fill pages zeroed
0 zero fill pages prezeroed
0 intransit blocking page faults
56707364 total VM faults taken
792 page faults requiring I/O
0 pages affected by kernel thread creation
10714372 pages affected by fork()
2616845 pages affected by vfork()
0 pages affected by rfork()
0 pages cached
75208405 pages freed
0 pages freed by daemon
0 pages freed by exiting processes
4401 pages active
280985 pages inactive
0 pages in VM cache
148799 pages wired down
1589428 pages free
4096 bytes per page
19109796 total name lookups
cache hits (76% pos + 6% neg) system 0% per-directory
deletions 0%, falsehits 0%, toolong 0%
vmstat -m
Type InUse MemUse HighUse Requests Size(s)
acpiintr 1 1K - 1 64
cdev 5 2K - 5 256
acpica 4733 438K - 372424 16,32,64,128,256,512,1024,2048
filedesc 48 309K - 360552 16,32,64,128,256,2048,4096,8192,16384,32768,65536
sigio 1 1K - 1 64
filecaps 0 0K - 10 16,64
kdtrace 274 61K - 7269254 64,256
kenv 74 11K - 79 16,32,64,128,8192
kqueue 0 0K - 46465 256,2048
proc-args 20 2K - 342316 16,32,64,128,256
hhook 2 1K - 2 256
ithread 203 34K - 203 32,128,256
KTRACE 100 13K - 100 128
CAM path 17 1K - 111 32
linker 154 31K - 168 16,32,64,128,256,512,1024,2048
lockf 26 3K - 8148 64,128
loginclass 2 1K - 3633 64
devbuf 19190 40887K - 19613 16,32,64,128,256,512,1024,2048,4096,8192,32768,65536
temp 2522 83K - 123076135 16,32,64,128,256,1024,2048,4096
acpitask 1 16K - 1 16384
module 387 49K - 387 128
mtx_pool 2 16K - 2 8192
acpisem 20 3K - 20 128
CAM periph 10 3K - 35 16,32,64,128,256
pmchooks 1 1K - 1 128
entropy 1026 65K - 1877 32,64,4096
acpidev 89 6K - 89 64
pgrp 20 3K - 13149 128
session 20 3K - 13126 128
proc 2 32K - 2 16384
subproc 159 220K - 360328 512,4096
cred 68 11K - 4318774 64,256
plimit 12 3K - 12545 256
uidinfo 4 5K - 11517 128,4096
CAM queue 23 38K - 98 16,32,512,16384
sysctl 0 0K - 532791 16,32,64
sysctloid 6510 326K - 6761 16,32,64,128
sysctltmp 0 0K - 6967562 16,32,64,128
CAM dev queue 10 1K - 10 64
tidhash 1 32K - 1 32768
callout 7 2696K - 7
umtx 2106 264K - 2106 128
p1003.1b 1 1K - 1 16
SWAP 2 2189K - 2 64
bus 1084 107K - 57135 16,32,64,128,256,1024
bus-sc 90 371K - 4732 16,32,64,128,256,512,1024,2048,4096,8192,16384,32768,65536
devstat 14 29K - 14 32,4096
eventhandler 100 8K - 100 64,128
DEVFS3 151 38K - 184 256
DEVFS1 125 63K - 151 512
kobj 243 972K - 620 4096
Per-cpu 1 1K - 1 32
DEVFS_RULE 55 26K - 55 64,512
DEVFS 17 1K - 18 16,128
rman 313 36K - 731 16,32,128
sbuf 0 0K - 143190 16,32,64,128,256,512,1024,2048,4096,8192,16384,32768,65536
taskqueue 69 10K - 69 16,32,256
Unitno 212 8K - 13961236 32,64
vmem 3 400K - 8 1024,2048,4096,8192,16384
ioctlops 0 0K - 229246551 16,32,64,128,256,512,1024
select 914 115K - 914 128
iov 0 0K - 6063697 16,64,128,256,512
msg 4 30K - 4 2048,4096,8192,16384
sem 4 106K - 4 2048,4096
shm 1 32K - 1 32768
tty 19 19K - 21 1024
pts 0 0K - 2 256
mbuf_tag 681 22K - 16941246458 32
shmfd 1 8K - 1 8192
soname 6 1K - 271676131 16,32,128
pcb 391 1197K - 7017046 16,32,64,128,1024,2048,8192
vfscache 1 2048K - 1
cl_savebuf 0 0K - 58 64
vfs_hash 1 1024K - 1
vnodes 1 1K - 1 256
mount 61 3K - 164 16,32,64,128,256
vnodemarker 0 0K - 131001 512
BPF 1073 135K - 12998 128
ifnet 1074 2162K - 13006 128,256,512,1024,2048,4096,8192,16384
ifaddr 3077 1025K - 44395 32,512,4096
ether_multi 1818 72K - 36730 16,64
clone 8 1K - 8 128
arpcom 177 3K - 177 16
lltable 1083 539K - 13149 256,512
vlan 173 22K - 174 64,128,256
routetbl 7123 313K - 820024 32,128,256,512
netflow_hash 1 3072K - 1
netflow_general 1 1K - 1 256
netgraph 7469 20369K - 22338355 16,64,128,256,4096
netgraph_msg 0 0K - 204032335 64,128,256,512,1024
netgraph_hook 38044 4756K - 89575184 128
netgraph_node 9602 2784K - 22364352 128,256,512,1024,2048,4096,8192,16384,32768,65536
netgraph_bpf 34344 6516K - 923186 128,512,1024
netgraph_iface 895 112K - 12820 128
netgraph_ksock 1 1K - 1 128
netgraph_mppc 0 0K - 1 1024
netgraph_ppp 895 14320K - 12820 16384
netgraph_pppoe 1644 2955K - 22206987 64,512,16384
netgraph_path 0 0K - 156715418 16,32
netgraph_sock 1535 113K - 22244578 32,128,256,512,1024,2048,4096,8192,16384,32768
igmp 1073 269K - 12998 256
in_multi 898 225K - 18353 256
sctp_a_it 0 0K - 1605 16
sctp_vrf 1 1K - 1 64
sctp_ifa 3 1K - 804 128
sctp_ifn 3 1K - 18353 128
sctp_iter 0 0K - 1605 256
hostcache 1 32K - 1 32768
syncache 1 64K - 1 65536
dummynet 3 3K - 3 512,1024
IpFw/IpAcct 15 36K - 24 16,32,64,128,1024,32768
ipfw_tbl 30 8K - 30 256
rpc 2 16K - 2 8192
audit_evclass 187 6K - 228 32
pagedep 5 1025K - 1173 256
inodedep 13 4101K - 10769 512
bmsafemap 5 33K - 2905 256,8192
newblk 5 8193K - 28371 256
indirdep 0 0K - 368 128,32768
freefrag 0 0K - 386 128
freeblks 1 1K - 1413 256
freefile 0 0K - 1315 64
diradd 8 1K - 7658 128
mkdir 0 0K - 16 128
dirrem 8 1K - 7654 128
newdirblk 0 0K - 8 64
freework 5 1K - 1908 64,128
freedep 0 0K - 8 64
jaddref 0 0K - 7674 128
jremref 0 0K - 7670 128
jnewblk 0 0K - 28367 128
jfreefrag 0 0K - 386 128
jseg 1 1K - 4087 128
jsegdep 17 2K - 44097 64
sbdep 0 0K - 4063 64
savedino 0 0K - 1143 256
jblocks 8 2K - 8 128,256
softdep 4 2K - 4 512
ufs_dirhash 585 138K - 585 16,32,64,128,256,512,1024,8192,16384
ufs_quota 1 1024K - 1
ufs_mount 12 66K - 13 512,4096,8192,16384
vm_pgdata 2 1025K - 2 128
UMAHash 6 11K - 15 512,1024,2048,4096
pfs_nodes 21 6K - 21 256
GEOM 151 40K - 1709 16,32,64,128,256,512,1024,2048,8192,16384
CAM SIM 10 3K - 10 256
memdesc 1 4K - 1 4096
scsi_cd 0 0K - 5 16
UART 6 5K - 6 16,1024
atkbddev 2 1K - 2 64
kbdmux 6 22K - 6 16,512,1024,2048,16384
LED 32 3K - 32 16,128
raid_data 0 0K - 258 32,128,256
scsi_da 0 0K - 111 16,32,64,512
CAM XPT 49 5K - 220 16,32,64,128,256,512,1024,2048,65536
SCSI ENC 25 100K - 76446 16,64,256,2048,32768
pci_link 16 2K - 16 16,128
CAM DEV 13 26K - 37 2048
md_nvidia_data 0 0K - 42 512
mps 13 479K - 29 16,32,64,128,256,512,1024,4096,8192,65536
md_sii_data 0 0K - 42 512
USB 50 94K - 60 16,32,128,256,512,1024,4096,16384,32768
USBdev 35 4K - 35 32,64,128,256,512
apmdev 1 1K - 1 128
madt_table 0 0K - 1 4096
io_apic 2 4K - 2 2048
MCA 18 3K - 18 128
msi 38 5K - 38 128
nexusdev 3 1K - 3 16
isadev 7 1K - 7 128
CAM CCB 0 0K - 394283 2048
vmstat -z
ITEM SIZE LIMIT USED FREE REQ FAIL SLEEP
UMA Kegs: 384, 0, 109, 1, 109, 0, 0
UMA Zones: 1408, 0, 109, 1, 109, 0, 0
UMA Slabs: 80, 0, 9971, 29, 44122, 0, 0
UMA RCntSlabs: 88, 0, 14340, 15, 14340, 0, 0
UMA Hash: 256, 0, 3, 12, 9, 0, 0
4 Bucket: 32, 0, 194, 2181, 181116, 0, 0
6 Bucket: 48, 0, 0, 2075, 51934, 0, 0
8 Bucket: 64, 0, 79, 2587, 322891, 11, 0
12 Bucket: 96, 0, 183, 1375, 1184143, 0, 0
16 Bucket: 128, 0, 179, 1061, 57103, 0, 0
32 Bucket: 256, 0, 155, 1450, 77854, 49, 0
64 Bucket: 512, 0, 426, 390, 57902, 49, 0
128 Bucket: 1024, 0, 404, 352, 236336, 0, 0
256 Bucket: 2048, 0, 347, 135,405046114, 0, 0
vmem btag: 56, 0, 38844, 1839, 64664, 287, 0
VM OBJECT: 256, 0, 49787, 1093,12736130, 0, 0
RADIX NODE: 144, 0, 23302, 1160,18922650, 0, 0
MAP: 240, 0, 3, 61, 3, 0, 0
KMAP ENTRY: 128, 0, 7, 148, 7, 0, 0
MAP ENTRY: 128, 0, 1389, 1122,16233219, 0, 0
VMSPACE: 448, 0, 20, 277, 360190, 0, 0
fakepg: 104, 0, 0, 0, 0, 0, 0
mt_zone: 4112, 0, 346, 0, 346, 0, 0
16: 16, 0, 4169, 2357,420106948, 0, 0
32: 32, 0, 16127, 3123,17075281501, 0, 0
64: 64, 0, 16601, 21157,256138645, 0, 0
128: 128, 0, 81315, 8833,196830127, 0, 0
256: 256, 0, 13810, 12425,77157379, 0, 0
512: 512, 0, 5728, 656,11414749, 0, 0
1024: 1024, 0, 1873, 259,24896167, 0, 0
2048: 2048, 0, 1166, 134, 786677, 0, 0
4096: 4096, 0, 4821, 619,92632052, 0, 0
8192: 8192, 0, 27, 12, 247, 0, 0
16384: 16384, 0, 1085, 95, 13628, 0, 0
32768: 32768, 0, 58, 11, 27058, 0, 0
65536: 65536, 0, 33, 11, 18536, 0, 0
SLEEPQUEUE: 80, 0, 1054, 465, 1054, 0, 0
64 pcpu: 8, 0, 7670, 522, 7670, 0, 0
Files: 80, 0, 452, 1448,155645130, 0, 0
TURNSTILE: 136, 0, 1054, 166, 1054, 0, 0
rl_entry: 40, 0, 99, 1501, 99, 0, 0
umtx pi: 96, 0, 0, 0, 0, 0, 0
MAC labels: 40, 0, 0, 0, 0, 0, 0
PROC: 1216, 0, 39, 78, 360208, 0, 0
THREAD: 1168, 0, 233, 820, 6909044, 0, 0
cpuset: 72, 0, 130, 420, 154, 0, 0
audit_record: 1248, 0, 0, 0, 0, 0, 0
mbuf_packet: 256, 3237795, 25586, 3009,30158359799, 0, 0
mbuf: 256, 3237795, 1, 2535,46892563122, 0, 0
mbuf_cluster: 2048, 505904, 28589, 11, 28589, 0, 0
mbuf_jumbo_page: 4096, 252951, 0, 40, 52956, 0, 0
mbuf_jumbo_9k: 9216, 224844, 0, 0, 0, 0, 0
mbuf_jumbo_16k: 16384, 168632, 0, 0, 0, 0, 0
mbuf_ext_refcnt: 4, 0, 0, 0, 0, 0, 0
NetGraph items: 72, 4123, 174, 1469,3736959070, 0, 0
NetGraph data items: 72, 527, 2, 525,33963205599,2096006, 600
ttyinq: 160, 0, 120, 255, 375, 0, 0
ttyoutq: 256, 0, 64, 251, 198, 0, 0
g_bio: 248, 0, 0, 928, 655616, 0, 0
DMAR_MAP_ENTRY: 120, 0, 0, 0, 0, 0, 0
ata_request: 336, 0, 0, 0, 0, 0, 0
vtnet_tx_hdr: 24, 0, 0, 0, 0, 0, 0
FPU_save_area: 832, 0, 0, 0, 0, 0, 0
VNODE: 472, 0, 101821, 203, 3049311, 0, 0
VNODEPOLL: 112, 0, 0, 0, 0, 0, 0
BUF TRIE: 144, 0, 509, 52249, 146300, 0, 0
NAMEI: 1024, 0, 0, 120,11438836, 0, 0
S VFS Cache: 108, 0, 85057, 24948, 2772689, 0, 0
STS VFS Cache: 148, 0, 0, 0, 0, 0, 0
L VFS Cache: 328, 0, 24922, 230, 337307, 0, 0
LTS VFS Cache: 368, 0, 0, 0, 0, 0, 0
NCLNODE: 528, 0, 0, 0, 0, 0, 0
DIRHASH: 1024, 0, 1900, 40, 1900, 0, 0
pipe: 744, 0, 5, 115, 214585, 0, 0
procdesc: 128, 0, 0, 0, 0, 0, 0
Mountpoints: 816, 0, 5, 10, 5, 0, 0
ksiginfo: 112, 0, 106, 944, 21192, 0, 0
itimer: 352, 0, 1, 32, 1, 0, 0
KNOTE: 128, 0, 0, 651, 38060, 0, 0
socket: 696, 260470, 396, 854,151597581, 0, 0
unpcb: 240, 260480, 11, 485, 2248301, 0, 0
ipq: 56, 15833, 0, 284, 18586, 0, 0
udp_inpcb: 392, 260470, 16, 914,149325109, 0, 0
udpcb: 16, 260538, 16, 2745,149325109, 0, 0
tcp_inpcb: 392, 260470, 18, 272, 23754, 0, 0
tcpcb: 1024, 260472, 18, 86, 23754, 0, 0
tcptw: 88, 27810, 0, 630, 587, 0, 0
syncache: 160, 15375, 0, 375, 14309, 0, 0
hostcache: 136, 15370, 0, 377, 278, 0, 0
tcpreass: 40, 31700, 0, 1600, 494, 0, 0
sackhole: 32, 0, 0, 1625, 439, 0, 0
sctp_ep: 1400, 260470, 0, 0, 0, 0, 0
sctp_asoc: 2408, 40000, 0, 0, 0, 0, 0
sctp_laddr: 48, 80012, 0, 1577, 1605, 0, 0
sctp_raddr: 720, 80000, 0, 0, 0, 0, 0
sctp_chunk: 136, 400026, 0, 0, 0, 0, 0
sctp_readq: 104, 400026, 0, 0, 0, 0, 0
sctp_stream_msg_out: 104, 400026, 0, 0, 0, 0, 0
sctp_asconf: 40, 400000, 0, 0, 0, 0, 0
sctp_asconf_ack: 48, 400060, 0, 0, 0, 0, 0
udplite_inpcb: 392, 260470, 0, 0, 0, 0, 0
ripcb: 392, 260470, 0, 180, 59, 0, 0
rtentry: 200, 0, 7064, 336, 95683, 0, 0
IPFW dynamic rule: 120, 4125, 0, 0, 0, 0, 0
divcb: 392, 260470, 0, 0, 0, 0, 0
selfd: 56, 0, 1338, 3277,33232376812, 0, 0
SWAPMETA: 288, 1011816, 0, 0, 0, 0, 0
FFS inode: 168, 0, 101792, 466, 3049223, 0, 0
FFS1 dinode: 128, 0, 0, 0, 0, 0, 0
FFS2 dinode: 256, 0, 101792, 328, 3049223, 0, 0
NetFlow IPv4 cache: 88, 1048606, 11696, 12267,1687062925, 0, 0
vmstat -i
interrupt total rate
irq1: atkbd0 18 0
irq20: ehci1 1783366 22016
irq21: ehci0 764300 9435
cpu0:timer 573905864 7085257
irq264: mps0 215697 2662
irq265: igb0:que 0 5116774278 63170052
irq266: igb0:que 1 965101817 11914837
irq267: igb0:que 2 1004307976 12398863
irq268: igb0:que 3 873135428 10779449
irq269: igb0:que 4 906809984 11195184
irq270: igb0:que 5 929111202 11470508
irq271: igb0:link 2 0
irq272: igb1:que 0 887549483 10957401
irq273: igb1:que 1 923241933 11398048
irq274: igb1:que 2 871187089 10755396
irq275: igb1:que 3 862168757 10644058
irq276: igb1:que 4 871874088 10763877
irq277: igb1:que 5 894344374 11041288
irq278: igb1:link 3 0
irq279: igb2:que 0 3796559067 46871099
irq280: igb2:que 1 1240655816 15316738
irq281: igb2:que 2 1217730053 15033704
irq282: igb2:que 3 1143788663 14120847
irq283: igb2:que 4 1159196347 14311066
irq284: igb2:que 5 1180726459 14576869
irq285: igb2:link 2 0
irq286: igb3:que 0 3916945630 48357353
irq287: igb3:que 1 1217085413 15025745
irq288: igb3:que 2 1232307777 15213676
irq289: igb3:que 3 1150802266 14207435
irq290: igb3:que 4 1199016877 14802677
irq291: igb3:que 5 1235654787 15254997
irq292: igb3:link 3 0
irq293: ahci0 23 0
cpu4:timer 499826582 6170698
cpu3:timer 491639350 6069621
cpu2:timer 510401440 6301252
cpu1:timer 498680834 6156553
cpu5:timer 513536932 6339962
Total 37886829980 467738641
pstat -T
452/260468 files
0M/16383M swap space
pstat -s
Device 512-blocks Used Avail Capacity
/dev/da0p3 33554176 0 33554176 0%
iostat
iostat: kvm_read(_tk_nin): invalid address (0x0)
iostat: disabling TTY statistics
da0 da1 cd0 cpu
KB/t tps MB/s KB/t tps MB/s KB/t tps MB/s us ni sy in id
29.41 2635 75.68 2.34 1 0.00 0.00 0 0.00 1 0 1 12 85
ipcs -a
Message Queues:
T ID KEY MODE OWNER GROUP CREATOR CGROUP CBYTES QNUM QBYTES LSPID LRPID
STIME RTIME CTIME
Shared Memory:
T ID KEY MODE OWNER GROUP CREATOR CGROUP NATTCH SEGSZ CPID LPID ATIME DTIME CTIME
Semaphores:
T ID KEY MODE OWNER GROUP CREATOR CGROUP NSEMS OTIME CTIME
ipcs -T
msginfo:
msgmax: 16384 (max characters in a message)
msgmni: 40 (# of message queues)
msgmnb: 2048 (max characters in a message queue)
msgtql: 40 (max # of messages in system)
msgssz: 8 (size of a message segment)
msgseg: 2048 (# of message segments in system)
shminfo:
shmmax: 536870912 (max shared memory segment size)
shmmin: 1 (min shared memory segment size)
shmmni: 192 (max number of shared memory identifiers)
shmseg: 128 (max shared memory segments per process)
shmall: 131072 (max amount of shared memory in pages)
seminfo:
semmni: 50 (# of semaphore identifiers)
semmns: 340 (# of semaphores in system)
semmnu: 150 (# of undo structures in system)
semmsl: 340 (max # of semaphores per id)
semopm: 100 (max # of operations per semop call)
semume: 50 (max # of undo entries per process)
semusz: 632 (size in bytes of undo structure)
semvmx: 32767 (semaphore maximum value)
semaem: 16384 (adjust on exit max value)
nfsstat
Client Info:
Rpc Counts:
Getattr Setattr Lookup Readlink Read Write Create Remove
0 0 0 0 0 0 0 0
Rename Link Symlink Mkdir Rmdir Readdir RdirPlus Access
0 0 0 0 0 0 0 0
Mknod Fsstat Fsinfo PathConf Commit
0 0 0 0 0
Rpc Info:
TimedOut Invalid X Replies Retries Requests
0 0 0 0 0
Cache Info:
Attr Hits Misses Lkup Hits Misses BioR Hits Misses BioW Hits Misses
0 0 0 0 0 0 0 0
BioRLHits Misses BioD Hits Misses DirE Hits Misses Accs Hits Misses
0 0 0 0 0 0 0 0
Server Info:
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
0 0 0 0 0
Server Ret-Failed
Server Faults
Server Cache Stats:
Inprog Idem Non-idem Misses
0 0 0 0
Server Write Gathering:
WriteOps WriteRPC Opsaved
0 0 0
netstat -s
tcp:
855358 packets sent
449592 data packets (54704894 bytes)
1177 data packets (458611 bytes) retransmitted
97 data packets unnecessarily retransmitted
0 resends initiated by MTU discovery
391135 ack-only packets (366105 delayed)
0 URG only packets
0 window probe packets
31 window update packets
13429 control packets
892129 packets received
472415 acks (for 54684803 bytes)
9161 duplicate acks
0 acks for unsent data
448632 packets (37143127 bytes) received in-sequence
510 completely duplicate packets (81521 bytes)
3 old duplicate packets
55 packets with some dup. data (26807 bytes duped)
494 out-of-order packets (13968 bytes)
0 packets (0 bytes) of data after window
0 window probes
34 window update packets
4199 packets received after close
2 discarded for bad checksums
0 discarded for bad header offset fields
0 discarded because packet too short
0 discarded due to memory problems
48 connection requests
14234 connection accepts
0 bad connection attempts
0 listen queue overflows
323 ignored RSTs in the windows
14263 connections established (including accepts)
23736 connections closed (including 1022 drops)
8813 connections updated cached RTT on close
8814 connections updated cached RTT variance on close
3052 connections updated cached ssthresh on close
14 embryonic connections dropped
470254 segments updated rtt (of 461352 attempts)
1318 retransmit timeouts
1 connection dropped by rexmit timeout
0 persist timeouts
0 connections dropped by persist timeout
0 Connections (fin_wait_2) dropped because of timeout
0 keepalive timeouts
0 keepalive probes sent
0 connections dropped by keepalive
347534 correct ACK header predictions
379142 correct data packet header predictions
14309 syncache entries added
611 retransmitted
399 dupsyn
0 dropped
14234 completed
0 bucket overflow
0 cache overflow
314 reset
38 stale
0 aborted
0 badack
13 unreach
0 zone failures
14309 cookies sent
290 cookies received
278 hostcache entries added
0 bucket overflow
12 SACK recovery episodes
8 segment rexmits in SACK recovery episodes
5200 byte rexmits in SACK recovery episodes
751 SACK options (SACK blocks) received
3 SACK options (SACK blocks) sent
0 SACK scoreboard overflow
0 packets with ECN CE bit set
0 packets with ECN ECT(0) bit set
0 packets with ECN ECT(1) bit set
0 successful ECN handshakes
0 times ECN reduced the congestion window
0 packets with valid tcp-md5 signature received
0 packets with invalid tcp-md5 signature received
0 packets with tcp-md5 signature mismatch
0 packets with unexpected tcp-md5 signature received
0 packets without expected tcp-md5 signature received
udp:
38509015 datagrams received
0 with incomplete header
0 with bad data length field
0 with bad checksum
12658 with no checksum
3073 dropped due to no socket
31454405 broadcast/multicast datagrams undelivered
2 dropped due to full socket buffers
0 not for hashed pcb
7051535 delivered
63838730 datagrams output
0 times multicast source filter matched
ip:
29970680408 total packets received
220 bad header checksums
0 with size smaller than minimum
1027 with data size < data length
0 with ip length > max ip packet size
0 with header length < data size
0 with data length < header length
0 with bad options
1 with incorrect version number
55758 fragments received
0 fragments dropped (dup or out of space)
0 fragments dropped after timeout
18586 packets reassembled ok
40250640 packets for this host
691511 packets for unknown/unsupported protocol
29916204550 packets forwarded (0 packets fast forwarded)
663841 packets not forwardable
0 packets received for unknown multicast group
0 redirects sent
66221784 packets sent from this host
0 packets sent with fabricated ip header
0 output packets dropped due to no bufs, etc.
0 output packets discarded due to no route
5530041 output datagrams fragmented
11060498 fragments created
153568 datagrams that can't be fragmented
0 tunneling packets that can't find gif
4397 datagrams with bad address in header
icmp:
729253 calls to icmp_error
903 errors not generated in response to an icmp message
Output histogram:
echo reply: 790839
destination unreachable: 616720
time exceeded: 105551
0 messages with bad code fields
0 messages less than the minimum length
1 message with bad checksum
1 message with bad length
0 multicast echo requests ignored
0 multicast timestamp requests ignored
Input histogram:
echo reply: 1
destination unreachable: 517129
routing redirect: 186
echo: 849487
time exceeded: 1368
790839 message responses generated
0 invalid return addresses
0 no return routes
igmp:
172835 messages received
0 messages received with too few bytes
0 messages received with wrong TTL
0 messages received with bad checksum
114 V1/V2 membership queries received
0 V3 membership queries received
114 membership queries received with invalid field(s)
0 general queries received
0 group queries received
0 group-source queries received
0 group-source queries dropped
6336 membership reports received
0 membership reports received with invalid field(s)
0 membership reports received for groups to which we belong
278 V3 reports received without Router Alert
0 membership reports sent
arp:
1288 ARP requests sent
124 ARP replies sent
80065 ARP requests received
1322 ARP replies received
17797441 ARP packets received
8 total packets dropped due to no ARP entry
140 ARP entrys timed out
0 Duplicate IPs seen
netstat -m
netstat: invalid address (0x0)
25587/5544/31131 mbufs in use (current/cache/total)
25580/3020/28600/505904 mbuf clusters in use (current/cache/total/max)
25586/3009 mbuf+clusters out of packet secondary zone in use (current/cache)
0/40/40/252951 4k (page size) jumbo clusters in use (current/cache/total/max)
0/0/0/224844 9k jumbo clusters in use (current/cache/total/max)
0/0/0/168632 16k jumbo clusters in use (current/cache/total/max)
57578K/7586K/65164K bytes allocated to network (current/cache/total)
0/0/0 requests for mbufs denied (mbufs/clusters/mbuf+clusters)
0/0/0 requests for mbufs delayed (mbufs/clusters/mbuf+clusters)
0/0/0 requests for jumbo clusters delayed (4k/9k/16k)
0/0/0 requests for jumbo clusters denied (4k/9k/16k)
fstat
fstat: can't read file 1 at 0x200007fffffffff
fstat: can't read file 2 at 0x4000000001fffff
fstat: can't read file 4 at 0x780000ffff
fstat: can't read file 5 at 0x600000000
fstat: can't read file 5 at 0x400000000
fstat: can't read file 7 at 0x200007fffffffff
fstat: can't read file 8 at 0x4000000001fffff
fstat: can't read file 10 at 0x780000ffff
fstat: can't read file 11 at 0x400000000
fstat: can't read file 13 at 0x200007fffffffff
fstat: can't read file 14 at 0x4000000001fffff
fstat: can't read file 16 at 0x780000ffff
fstat: can't read file 17 at 0x400000000
fstat: can't read file 19 at 0x200007fffffffff
fstat: can't read file 20 at 0x4000000001fffff
fstat: can't read file 22 at 0x780000ffff
fstat: can't read file 23 at 0x2200000001
fstat: can't read file 11 at 0x600000000
fstat: can't read file 23 at 0xe00000001
fstat: can't read file 25 at 0x200007fffffffff
fstat: can't read file 26 at 0x4000000001fffff
fstat: can't read file 28 at 0x780000ffff
fstat: can't read file 29 at 0x200000001
fstat: can't read file 31 at 0x200007fffffffff
fstat: can't read file 32 at 0x4000000001fffff
fstat: can't read file 34 at 0x780000ffff
fstat: can't read file 35 at 0xa00000001
fstat: can't read file 37 at 0x200007fffffffff
fstat: can't read file 38 at 0x4000000001fffff
fstat: can't read file 40 at 0x780000ffff
fstat: can't read file 41 at 0x600000001
fstat: can't read file 43 at 0x200007fffffffff
fstat: can't read file 44 at 0x4000000001fffff
fstat: can't read file 46 at 0x780000ffff
fstat: can't read file 47 at 0x200000000
fstat: can't read file 49 at 0x200007fffffffff
fstat: can't read file 50 at 0x4000000001fffff
fstat: can't read file 52 at 0x780000ffff
fstat: can't read file 53 at 0x200000000
fstat: can't read file 55 at 0x200007fffffffff
fstat: can't read file 56 at 0x4000000001fffff
fstat: can't read file 58 at 0x780000ffff
fstat: can't read file 59 at 0x200000001
fstat: can't read file 61 at 0x200007fffffffff
fstat: can't read file 62 at 0x4000000001fffff
fstat: can't read file 64 at 0x780000ffff
fstat: can't read file 65 at 0x200000001
fstat: can't read file 67 at 0x200007fffffffff
fstat: can't read file 68 at 0x4000000001fffff
fstat: can't read file 70 at 0x780000ffff
fstat: can't read file 71 at 0x200000001
fstat: can't read file 73 at 0x200007fffffffff
fstat: can't read file 74 at 0x4000000001fffff
fstat: can't read file 76 at 0x780000ffff
fstat: can't read file 77 at 0x200000001
fstat: can't read file 79 at 0x200007fffffffff
fstat: can't read file 80 at 0x4000000001fffff
fstat: can't read file 82 at 0x780000ffff
fstat: can't read file 83 at 0x200000000
fstat: can't read file 85 at 0x200007fffffffff
fstat: can't read file 86 at 0x4000000001fffff
fstat: can't read file 88 at 0x780000ffff
fstat: can't read file 89 at 0x200000000
fstat: can't read file 91 at 0x200007fffffffff
fstat: can't read file 92 at 0x4000000001fffff
fstat: can't read file 94 at 0x780000ffff
fstat: can't read file 95 at 0x9200000001
fstat: can't read file 97 at 0x200007fffffffff
fstat: can't read file 98 at 0x4000000001fffff
fstat: can't read file 100 at 0x780000ffff
fstat: can't read file 101 at 0x200000001
fstat: can't read file 103 at 0x200007fffffffff
fstat: can't read file 104 at 0x4000000001fffff
fstat: can't read file 106 at 0x780000ffff
fstat: can't read file 107 at 0x200000000
fstat: can't read file 109 at 0x200007fffffffff
fstat: can't read file 110 at 0x4000000001fffff
fstat: can't read file 112 at 0x780000ffff
fstat: can't read file 113 at 0x200000000
fstat: can't read file 115 at 0x200007fffffffff
fstat: can't read file 116 at 0x4000000001fffff
fstat: can't read file 118 at 0x780000ffff
fstat: can't read file 119 at 0x200000001
fstat: can't read file 121 at 0x200007fffffffff
fstat: can't read file 122 at 0x4000000001fffff
fstat: can't read file 124 at 0x780000ffff
fstat: can't read file 125 at 0x200000000
fstat: can't read file 131 at 0xcd163400000000
fstat: can't read file 133 at 0x200007fffffffff
fstat: can't read file 134 at 0x4000000001fffff
fstat: can't read file 136 at 0x780000ffff
fstat: can't read file 137 at 0x200000001
fstat: can't read file 139 at 0x200007fffffffff
fstat: can't read file 140 at 0x4000000001fffff
fstat: can't read file 142 at 0x780000ffff
fstat: can't read file 143 at 0x200000001
fstat: can't read file 145 at 0x200007fffffffff
fstat: can't read file 146 at 0x4000000001fffff
fstat: can't read file 148 at 0x780000ffff
fstat: can't read file 149 at 0xa00000001
fstat: can't read file 151 at 0x200007fffffffff
fstat: can't read file 152 at 0x4000000001fffff
fstat: can't read file 154 at 0x780000ffff
fstat: can't read file 155 at 0x600000001
fstat: can't read file 157 at 0x200007fffffffff
fstat: can't read file 158 at 0x4000000001fffff
fstat: can't read file 160 at 0x780000ffff
fstat: can't read file 161 at 0x200000001
fstat: can't read file 163 at 0x200007fffffffff
fstat: can't read file 164 at 0x4000000001fffff
fstat: can't read file 166 at 0x780000ffff
fstat: can't read file 167 at 0x200000001
fstat: can't read file 169 at 0x200007fffffffff
fstat: can't read file 170 at 0x4000000001fffff
fstat: can't read file 172 at 0x780000ffff
fstat: can't read file 173 at 0x200000001
fstat: can't read file 175 at 0x200007fffffffff
fstat: can't read file 176 at 0x4000000001fffff
fstat: can't read file 178 at 0x780000ffff
fstat: can't read file 179 at 0x200000001
fstat: can't read file 181 at 0x200007fffffffff
fstat: can't read file 182 at 0x4000000001fffff
fstat: can't read file 184 at 0x780000ffff
fstat: can't read file 185 at 0x200000001
fstat: can't read file 187 at 0x200007fffffffff
fstat: can't read file 188 at 0x4000000001fffff
fstat: can't read file 190 at 0x780000ffff
fstat: can't read file 191 at 0x200000001
fstat: can't read file 193 at 0x200007fffffffff
fstat: can't read file 194 at 0x4000000001fffff
fstat: can't read file 196 at 0x780000ffff
fstat: can't read file 197 at 0x200000001
fstat: can't read file 199 at 0x200007fffffffff
fstat: can't read file 200 at 0x4000000001fffff
fstat: can't read file 202 at 0x780000ffff
fstat: can't read file 203 at 0x200000001
fstat: can't read file 205 at 0x200007fffffffff
fstat: can't read file 206 at 0x4000000001fffff
fstat: can't read file 208 at 0x780000ffff
fstat: can't read file 209 at 0x200000001
fstat: can't read file 211 at 0x200007fffffffff
fstat: can't read file 212 at 0x4000000001fffff
fstat: can't read file 214 at 0x780000ffff
fstat: can't read file 215 at 0x200000001
fstat: can't read file 217 at 0x200007fffffffff
fstat: can't read file 218 at 0x4000000001fffff
fstat: can't read file 220 at 0x780000ffff
fstat: can't read file 221 at 0x200000001
fstat: can't read file 223 at 0x200007fffffffff
fstat: can't read file 224 at 0x4000000001fffff
fstat: can't read file 226 at 0x780000ffff
fstat: can't read file 227 at 0x200000001
fstat: can't read file 229 at 0x200007fffffffff
fstat: can't read file 230 at 0x4000000001fffff
fstat: can't read file 232 at 0x780000ffff
fstat: can't read file 233 at 0x200000001
fstat: can't read file 235 at 0x200007fffffffff
fstat: can't read file 236 at 0x4000000001fffff
fstat: can't read file 238 at 0x780000ffff
fstat: can't read file 239 at 0x200000001
fstat: can't read file 241 at 0x200007fffffffff
fstat: can't read file 242 at 0x4000000001fffff
fstat: can't read file 244 at 0x780000ffff
fstat: can't read file 245 at 0x200000001
fstat: can't read file 247 at 0x200007fffffffff
fstat: can't read file 248 at 0x4000000001fffff
fstat: can't read file 250 at 0x780000ffff
fstat: can't read file 251 at 0x200000001
fstat: can't read file 253 at 0x200007fffffffff
fstat: can't read file 254 at 0x4000000001fffff
fstat: can't read file 256 at 0x780000ffff
fstat: can't read file 257 at 0x200000001
fstat: can't read file 259 at 0x200007fffffffff
fstat: can't read file 260 at 0x4000000001fffff
fstat: can't read file 262 at 0x780000ffff
fstat: can't read file 263 at 0x200000001
fstat: can't read file 265 at 0x200007fffffffff
fstat: can't read file 266 at 0x4000000001fffff
fstat: can't read file 268 at 0x780000ffff
fstat: can't read file 269 at 0x200000001
fstat: can't read file 271 at 0x200007fffffffff
fstat: can't read file 272 at 0x4000000001fffff
fstat: can't read file 274 at 0x780000ffff
fstat: can't read file 275 at 0x200000001
fstat: can't read file 277 at 0x200007fffffffff
fstat: can't read file 278 at 0x4000000001fffff
fstat: can't read file 280 at 0x780000ffff
fstat: can't read file 281 at 0x200000001
fstat: can't read file 283 at 0x200007fffffffff
fstat: can't read file 284 at 0x4000000001fffff
fstat: can't read file 286 at 0x780000ffff
fstat: can't read file 287 at 0x200000001
fstat: can't read file 289 at 0x200007fffffffff
fstat: can't read file 290 at 0x4000000001fffff
fstat: can't read file 292 at 0x780000ffff
fstat: can't read file 293 at 0x200000001
fstat: can't read file 295 at 0x200007fffffffff
fstat: can't read file 296 at 0x4000000001fffff
fstat: can't read file 298 at 0x780000ffff
fstat: can't read file 299 at 0x200000001
fstat: can't read file 301 at 0x200007fffffffff
fstat: can't read file 302 at 0x4000000001fffff
fstat: can't read file 304 at 0x780000ffff
fstat: can't read file 305 at 0x200000001
fstat: can't read file 307 at 0x200007fffffffff
fstat: can't read file 308 at 0x4000000001fffff
fstat: can't read file 310 at 0x780000ffff
fstat: can't read file 311 at 0x200000001
fstat: can't read file 313 at 0x200007fffffffff
fstat: can't read file 314 at 0x4000000001fffff
fstat: can't read file 316 at 0x780000ffff
fstat: can't read file 317 at 0x200000001
fstat: can't read file 319 at 0x200007fffffffff
fstat: can't read file 320 at 0x4000000001fffff
fstat: can't read file 322 at 0x780000ffff
fstat: can't read file 323 at 0x200000001
fstat: can't read file 325 at 0x200007fffffffff
fstat: can't read file 326 at 0x4000000001fffff
fstat: can't read file 328 at 0x780000ffff
fstat: can't read file 329 at 0x200000001
fstat: can't read file 331 at 0x200007fffffffff
fstat: can't read file 332 at 0x4000000001fffff
fstat: can't read file 334 at 0x780000ffff
fstat: can't read file 335 at 0x200000001
fstat: can't read file 337 at 0x200007fffffffff
fstat: can't read file 338 at 0x4000000001fffff
fstat: can't read file 340 at 0x780000ffff
fstat: can't read file 341 at 0x200000001
fstat: can't read file 343 at 0x200007fffffffff
fstat: can't read file 344 at 0x4000000001fffff
fstat: can't read file 346 at 0x780000ffff
fstat: can't read file 347 at 0x200000001
fstat: can't read file 349 at 0x200007fffffffff
fstat: can't read file 350 at 0x4000000001fffff
fstat: can't read file 352 at 0x780000ffff
fstat: can't read file 353 at 0x200000001
fstat: can't read file 355 at 0x200007fffffffff
fstat: can't read file 356 at 0x4000000001fffff
fstat: can't read file 358 at 0x780000ffff
fstat: can't read file 359 at 0x200000001
fstat: can't read file 361 at 0x200007fffffffff
fstat: can't read file 362 at 0x4000000001fffff
fstat: can't read file 364 at 0x780000ffff
fstat: can't read file 365 at 0x200000001
fstat: can't read file 367 at 0x200007fffffffff
fstat: can't read file 368 at 0x4000000001fffff
fstat: can't read file 370 at 0x780000ffff
fstat: can't read file 371 at 0x200000001
fstat: can't read file 373 at 0x200007fffffffff
fstat: can't read file 374 at 0x4000000001fffff
fstat: can't read file 376 at 0x780000ffff
fstat: can't read file 377 at 0x200000001
fstat: can't read file 379 at 0x200007fffffffff
fstat: can't read file 380 at 0x4000000001fffff
fstat: can't read file 382 at 0x780000ffff
fstat: can't read file 383 at 0x200000001
fstat: can't read file 385 at 0x200007fffffffff
fstat: can't read file 386 at 0x4000000001fffff
fstat: can't read file 388 at 0x780000ffff
fstat: can't read file 389 at 0x200000001
fstat: can't read file 391 at 0x200007fffffffff
fstat: can't read file 392 at 0x4000000001fffff
fstat: can't read file 394 at 0x780000ffff
fstat: can't read file 395 at 0x200000001
fstat: can't read file 397 at 0x200007fffffffff
fstat: can't read file 398 at 0x4000000001fffff
fstat: can't read file 400 at 0x780000ffff
fstat: can't read file 401 at 0x200000001
fstat: can't read file 403 at 0x200007fffffffff
fstat: can't read file 404 at 0x4000000001fffff
fstat: can't read file 406 at 0x780000ffff
fstat: can't read file 407 at 0x200000001
fstat: can't read file 409 at 0x200007fffffffff
fstat: can't read file 410 at 0x4000000001fffff
fstat: can't read file 412 at 0x780000ffff
fstat: can't read file 413 at 0x200000001
fstat: can't read file 415 at 0x200007fffffffff
fstat: can't read file 416 at 0x4000000001fffff
fstat: can't read file 418 at 0x780000ffff
fstat: can't read file 419 at 0x200000001
fstat: can't read file 421 at 0x200007fffffffff
fstat: can't read file 422 at 0x4000000001fffff
fstat: can't read file 424 at 0x780000ffff
fstat: can't read file 425 at 0x200000001
fstat: can't read file 427 at 0x200007fffffffff
fstat: can't read file 428 at 0x4000000001fffff
fstat: can't read file 430 at 0x780000ffff
fstat: can't read file 431 at 0x200000001
fstat: can't read file 433 at 0x200007fffffffff
fstat: can't read file 434 at 0x4000000001fffff
fstat: can't read file 436 at 0x780000ffff
fstat: can't read file 437 at 0x200000001
fstat: can't read file 439 at 0x200007fffffffff
fstat: can't read file 440 at 0x4000000001fffff
fstat: can't read file 442 at 0x780000ffff
fstat: can't read file 443 at 0x200000001
fstat: can't read file 445 at 0x200007fffffffff
fstat: can't read file 446 at 0x4000000001fffff
fstat: can't read file 5 at 0x800000000
USER CMD PID FD MOUNT INUM MODE SZ|DV R/W
root getty 8799 root / 2 drwxr-xr-x 1024 r
root getty 8799 wd / 2 drwxr-xr-x 1024 r
root getty 8799 text /usr 25922735 -r-xr-xr-x 28360 r
root getty 8799 ctty /dev 65 crw------- ttyv7 rw
root getty 8799 0 /dev 65 crw------- ttyv7 rw
root getty 8798 root / 2 drwxr-xr-x 1024 r
root getty 8798 wd / 2 drwxr-xr-x 1024 r
root getty 8798 text /usr 25922735 -r-xr-xr-x 28360 r
root getty 8798 ctty /dev 64 crw------- ttyv6 rw
root getty 8798 0 /dev 64 crw------- ttyv6 rw
root getty 8797 root / 2 drwxr-xr-x 1024 r
root getty 8797 wd / 2 drwxr-xr-x 1024 r
root getty 8797 text /usr 25922735 -r-xr-xr-x 28360 r
root getty 8797 ctty /dev 63 crw------- ttyv5 rw
root getty 8797 0 /dev 63 crw------- ttyv5 rw
root getty 8796 root / 2 drwxr-xr-x 1024 r
root getty 8796 wd / 2 drwxr-xr-x 1024 r
root getty 8796 text /usr 25922735 -r-xr-xr-x 28360 r
root getty 8796 ctty /dev 62 crw------- ttyv4 rw
root getty 8796 0 /dev 62 crw------- ttyv4 rw
root getty 8795 root / 2 drwxr-xr-x 1024 r
root getty 8795 wd / 2 drwxr-xr-x 1024 r
root getty 8795 text /usr 25922735 -r-xr-xr-x 28360 r
root getty 8795 ctty /dev 61 crw------- ttyv3 rw
root getty 8795 0 /dev 61 crw------- ttyv3 rw
root getty 8794 root / 2 drwxr-xr-x 1024 r
root getty 8794 wd / 2 drwxr-xr-x 1024 r
root getty 8794 text /usr 25922735 -r-xr-xr-x 28360 r
root getty 8794 ctty /dev 60 crw------- ttyv2 rw
root getty 8794 0 /dev 60 crw------- ttyv2 rw
root getty 8793 root / 2 drwxr-xr-x 1024 r
root getty 8793 wd / 2 drwxr-xr-x 1024 r
root getty 8793 text /usr 25922735 -r-xr-xr-x 28360 r
root getty 8793 ctty /dev 59 crw------- ttyv1 rw
root getty 8793 0 /dev 59 crw------- ttyv1 rw
root getty 8792 root / 2 drwxr-xr-x 1024 r
root getty 8792 wd / 2 drwxr-xr-x 1024 r
root getty 8792 text /usr 25922735 -r-xr-xr-x 28360 r
root getty 8792 ctty /dev 58 crw------- ttyv0 rw
root getty 8792 0 /dev 58 crw------- ttyv0 rw
root cron 8746 root / 2 drwxr-xr-x 1024 r
root cron 8746 wd /var 28410624 drwxr-x--- 512 r
root cron 8746 text /usr 25200569 -r-xr-xr-x 41352 r
root cron 8746 0 /dev 9 crw-rw-rw- null rw
smmsp sendmail 8742 root / 2 drwxr-xr-x 1024 r
smmsp sendmail 8742 wd /var 13242246 drwxrwx--- 512 r
smmsp sendmail 8742 text /usr 25922903 -r-xr-sr-x 692520 r
smmsp sendmail 8742 0 /dev 9 crw-rw-rw- null r
root sendmail 8739 root / 2 drwxr-xr-x 1024 r
root sendmail 8739 wd /var 13242244 drwxr-xr-x 512 r
root sendmail 8739 text /usr 25922903 -r-xr-sr-x 692520 r
root sendmail 8739 0 /dev 9 crw-rw-rw- null r
root sshd 8736 root / 2 drwxr-xr-x 1024 r
root sshd 8736 wd / 2 drwxr-xr-x 1024 r
root sshd 8736 text /usr 25200639 -r-xr-xr-x 297792 r
root sshd 8736 0 /dev 9 crw-rw-rw- null rw
root ntpd 8695 root / 2 drwxr-xr-x 1024 r
root ntpd 8695 wd / 2 drwxr-xr-x 1024 r
root ntpd 8695 text /usr 25200561 -r-xr-xr-x 432544 r
root ntpd 8695 0 /dev 9 crw-rw-rw- null rw
root ntpd 8695 6 /dev 9 crw-rw-rw- null rw
root ntpd 8695 12 /dev 9 crw-rw-rw- null rw
root ntpd 8695 18* local dgram fffff80218f24690 <-> fffff8000b4aba50
root snmpd 8667 root / 2 drwxr-xr-x 1024 r
root snmpd 8667 wd / 2 drwxr-xr-x 1024 r
root snmpd 8667 text /usr 21850511 -rwxr-xr-x 29128 r
root snmpd 8667 0 /dev 9 crw-rw-rw- null rw
root snmpd 8667 6 /dev 9 crw-rw-rw- null rw
root snmpd 8667 12 /dev 9 crw-rw-rw- null rw
root mpd5 8490 root / 2 drwxr-xr-x 1024 r
root mpd5 8490 wd /usr 21830369 drwxr-xr-x 512 r
root mpd5 8490 text /usr 21830377 -rwxr-xr-x 2556555 r
root mpd5 8490 0 /dev 9 crw-rw-rw- null rw
root mpd5 8490 6 /dev 9 crw-rw-rw- null rw
root mpd5 8490 12 /dev 9 crw-rw-rw- null rw
root mpd5 8490 18* local dgram fffff8000b4ab960 <-> fffff8000b4aba50
root mpd5 8490 24 /var 2889219 -rw-r--r-- 5 rw
root mpd5 8490 30* netgraph dgram 2 fffff8000b4ce000
root mpd5 8490 36* netgraph dgram 1 fffff8000b4ce2b8
root mpd5 8490 42* pipe fffff8000b4175d0 <-> fffff8000b417730 0 rw
root mpd5 8490 48* pipe fffff8000b417730 <-> fffff8000b4175d0 0 rw
root mpd5 8490 54* netgraph dgram 2 fffff8000b4cdae0
root mpd5 8490 60* netgraph dgram 1 fffff8000b4cd828
root mpd5 8490 66* netgraph dgram 2 fffff8000b4cd570
root mpd5 8490 72* netgraph dgram 1 fffff8000b4cd2b8
root mpd5 8490 78* pipe fffff8000b47b000 <-> fffff8000b47b160 0 rw
root mpd5 8490 84* pipe fffff8000b47b160 <-> fffff8000b47b000 0 rw
root mpd5 8490 90* netgraph dgram 2 fffff8007e2112b8
root mpd5 8490 96* internet stream tcp fffff80218fad400
root mpd5 8490 102* pipe fffff80218f35000 <-> fffff80218f35160 0 rw
root mpd5 8490 108* pipe fffff80218f35160 <-> fffff80218f35000 0 rw
root mpd5 8490 114* internet stream tcp fffff80218fad000
root mpd5 8490 120* internet dgram udp fffff8000b546620
root mpd5 8490 132* pipe fffff8000b4165d0 <-> fffff8000b416730 0 rw
root mpd5 8490 138* pipe fffff8000b416730 <-> fffff8000b4165d0 0 rw
root mpd5 8490 144* netgraph dgram 2 fffff8000b5422b8
root mpd5 8490 150* netgraph dgram 1 fffff8000b542000
root mpd5 8490 156* netgraph dgram 2 fffff8000b536ae0
root mpd5 8490 162* netgraph dgram 1 fffff8000b536828
root mpd5 8490 168* netgraph dgram 2 fffff8000b536570
root mpd5 8490 174* netgraph dgram 1 fffff8000b44c000
root mpd5 8490 180* netgraph dgram 2 fffff8000b4d9ae0
root mpd5 8490 186* netgraph dgram 1 fffff8000b4d9828
root mpd5 8490 192* netgraph dgram 2 fffff8000b4d9570
root mpd5 8490 198* netgraph dgram 1 fffff8000b4d92b8
root mpd5 8490 204* netgraph dgram 2 fffff8000b4d9000
root mpd5 8490 210* netgraph dgram 1 fffff80146d36ae0
root mpd5 8490 216* netgraph dgram 2 fffff80146d36828
root mpd5 8490 222* netgraph dgram 1 fffff80146d36570
root mpd5 8490 228* netgraph dgram 2 fffff80146d362b8
root mpd5 8490 234* netgraph dgram 1 fffff80146d36000
root mpd5 8490 240* netgraph dgram 2 fffff8000b571ae0
root mpd5 8490 246* netgraph dgram 1 fffff8000b571828
root mpd5 8490 252* netgraph dgram 2 fffff80146d28828
root mpd5 8490 258* netgraph dgram 1 fffff80146d28570
root mpd5 8490 264* netgraph dgram 2 fffff80146d282b8
root mpd5 8490 270* netgraph dgram 1 fffff80146d28000
root mpd5 8490 276* netgraph dgram 2 fffff80146dd9ae0
root mpd5 8490 282* netgraph dgram 1 fffff80146dd9828
root mpd5 8490 288* netgraph dgram 2 fffff80146dd9570
root mpd5 8490 294* netgraph dgram 1 fffff80146dd92b8
root mpd5 8490 300* netgraph dgram 2 fffff80146dd9000
root mpd5 8490 306* netgraph dgram 1 fffff8000b44cae0
root mpd5 8490 312* netgraph dgram 2 fffff8000b44c828
root mpd5 8490 318* netgraph dgram 1 fffff8000b44c570
root mpd5 8490 324* netgraph dgram 2 fffff8000b44c2b8
root mpd5 8490 330* netgraph dgram 1 fffff80146e662b8
root mpd5 8490 336* netgraph dgram 2 fffff80146e66000
root mpd5 8490 342* netgraph dgram 1 fffff80146e64ae0
root mpd5 8490 348* netgraph dgram 2 fffff80146e64828
root mpd5 8490 354* netgraph dgram 1 fffff80146e64570
root mpd5 8490 360* netgraph dgram 2 fffff80146e642b8
root mpd5 8490 366* netgraph dgram 1 fffff80146e64000
root mpd5 8490 372* netgraph dgram 2 fffff80146e3fae0
root mpd5 8490 378* netgraph dgram 1 fffff80146e3f828
root mpd5 8490 384* netgraph dgram 2 fffff80146e3f570
root mpd5 8490 390* netgraph dgram 1 fffff80146e3f2b8
root mpd5 8490 396* netgraph dgram 2 fffff80146e3f000
root mpd5 8490 402* netgraph dgram 1 fffff80146d28ae0
root mpd5 8490 408* netgraph dgram 2 fffff80146e42ae0
root mpd5 8490 414* netgraph dgram 1 fffff80146e42828
root mpd5 8490 420* netgraph dgram 2 fffff80146e42570
root mpd5 8490 426* netgraph dgram 1 fffff80146e422b8
root mpd5 8490 432* netgraph dgram 2 fffff80146e42000
root mpd5 8490 438* netgraph dgram 1 fffff80146e63ae0
root mpd5 8490 444* netgraph dgram 2 fffff80146e63828
root syslogd 8315 root / 2 drwxr-xr-x 1024 r
root syslogd 8315 wd / 2 drwxr-xr-x 1024 r
root syslogd 8315 text /usr 25200460 -r-xr-xr-x 40352 r
root syslogd 8315 0 /dev 9 crw-rw-rw- null rw
root syslogd 8315 6 /dev 9 crw-rw-rw- null rw
root syslogd 8315 12 /dev 9 crw-rw-rw- null rw
root syslogd 8315 18 /var 2889248 -rw------- 4 w
root devd 7857 root / 2 drwxr-xr-x 1024 r
root devd 7857 wd / 2 drwxr-xr-x 1024 r
root devd 7857 text / 642135 -r-xr-xr-x 634824 r
root devd 7857 0 /dev 9 crw-rw-rw- null rw
root devd 7857 6 /dev 9 crw-rw-rw- null rw
quagga bgpd 6796 root / 2 drwxr-xr-x 1024 r
quagga bgpd 6796 wd / 2 drwxr-xr-x 1024 r
quagga bgpd 6796 text /usr 21848108 -rwxr-xr-x 935248 r
quagga bgpd 6796 0 /dev 9 crw-rw-rw- null rw
quagga bgpd 6796 6 /dev 9 crw-rw-rw- null rw
quagga bgpd 6796 12 /dev 9 crw-rw-rw- null rw
quagga zebra 6790 root / 2 drwxr-xr-x 1024 r
quagga zebra 6790 wd / 2 drwxr-xr-x 1024 r
quagga zebra 6790 text /usr 21848897 -rwxr-xr-x 194240 r
quagga zebra 6790 0 /dev 9 crw-rw-rw- null rw
quagga zebra 6790 6 /dev 9 crw-rw-rw- null rw
root init 1 root / 2 drwxr-xr-x 1024 r
root init 1 wd / 2 drwxr-xr-x 1024 r
root init 1 text / 642054 -r-xr-xr-x 981064 r
root kernel 0 root / 2 drwxr-xr-x 1024 r
root kernel 0 wd / 2 drwxr-xr-x 1024 r
dmesg
Fatal trap 18: integer divide fault while in kernel mode
cpuid = 0; apic id = 00
instruction pointer = 0x20:0xffffffff80785266
stack pointer = 0x28:0xfffffe0000283050
frame pointer = 0x28:0xfffffe00002830e0
code segment = base 0x0, limit 0xfffff, type 0x1b
= DPL 0, pres 1, long 1, def32 0, gran 1
processor eflags = interrupt enabled, resume, IOPL = 0
current process = 12 (irq286: igb3:que 0)
trap number = 18
panic: integer divide fault
cpuid = 0
Uptime: 5d21h31m53s
kernel config
options CONFIG_AUTOGENERATED
ident GENERIC
machine amd64
cpu HAMMER
makeoptions WITH_CTF=1
makeoptions DEBUG=-g
options RADIX_MPATH
options HZ=1000
options DEVICE_POLLING
options NETGRAPH_NETFLOW
options NETGRAPH_IPFW
options NETGRAPH_VJC
options NETGRAPH_UI
options NETGRAPH_TTY
options NETGRAPH_TEE
options NETGRAPH_RFC1490
options NETGRAPH_PPP
options NETGRAPH_ONE2MANY
options NETGRAPH_MPPC_ENCRYPTION
options NETGRAPH_LMI
options NETGRAPH_L2TP
options NETGRAPH_KSOCKET
options NETGRAPH_IFACE
options NETGRAPH_HOLE
options NETGRAPH_FRAME_RELAY
options NETGRAPH_ECHO
options NETGRAPH_BPF
options NETGRAPH_PPTPGRE
options NETGRAPH_PPPOE
options NETGRAPH_SOCKET
options NETGRAPH_ETHER
options NETGRAPH
options DUMMYNET
options IPDIVERT
options IPFIREWALL_VERBOSE_LIMIT=100
options IPFIREWALL
options XENHVM
options USB_DEBUG
options SC_PIXEL_MODE
options VESA
options AHD_REG_PRETTY_PRINT
options AHC_REG_PRETTY_PRINT
options ATA_STATIC_ID
options ACPI_DMAR
options SMP
options KDB_TRACE
options KDB
options INCLUDE_CONFIG_FILE
options DDB_CTF
options KDTRACE_HOOKS
options KDTRACE_FRAME
options MAC
options PROCDESC
options CAPABILITIES
options CAPABILITY_MODE
options AUDIT
options HWPMC_HOOKS
options KBD_INSTALL_CDEV
options PRINTF_BUFR_SIZE=128
options _KPOSIX_PRIORITY_SCHEDULING
options SYSVSEM
options SYSVMSG
options SYSVSHM
options STACK
options KTRACE
options SCSI_DELAY=5000
options COMPAT_FREEBSD7
options COMPAT_FREEBSD6
options COMPAT_FREEBSD5
options COMPAT_FREEBSD4
options COMPAT_FREEBSD32
options GEOM_LABEL
options GEOM_RAID
options GEOM_PART_GPT
options PSEUDOFS
options PROCFS
options CD9660
options MSDOSFS
options NFS_ROOT
options NFSLOCKD
options NFSD
options NFSCL
options MD_ROOT
options QUOTA
options UFS_GJOURNAL
options UFS_DIRHASH
options UFS_ACL
options SOFTUPDATES
options FFS
options SCTP
options TCP_OFFLOAD
options INET
options PREEMPTION
options SCHED_ULE
options NEW_PCIB
options GEOM_PART_MBR
options GEOM_PART_EBR_COMPAT
options GEOM_PART_BSD
device isa
device mem
device io
device uart_ns8250
device cpufreq
device acpi
device pci
device fdc
device ahci
device ata
device mvs
device siis
device ahc
device ahd
device esp
device hptiop
device isp
device mpt
device mps
device mpr
device sym
device trm
device adv
device adw
device aic
device bt
device isci
device scbus
device ch
device da
device sa
device cd
device pass
device ses
device amr
device arcmsr
device ciss
device dpt
device hptmv
device hptnr
device hptrr
device hpt27xx
device iir
device ips
device mly
device twa
device tws
device aac
device aacp
device aacraid
device ida
device mfi
device mlx
device mrsas
device twe
device atkbdc
device atkbd
device psm
device kbdmux
device vga
device splash
device sc
device vt
device vt_vga
device vt_efifb
device agp
device cbb
device pccard
device cardbus
device uart
device ppc
device ppbus
device lpt
device ppi
device puc
device em
device igb
device ixgbe
device miibus
device loop
device random
device padlock_rng
device rdrand_rng
device ether
device vlan
device tun
device md
device gif
device faith
device firmware
device bpf
device uhci
device ohci
device ehci
device xhci
device usb
device ukbd
device umass
device mmc
device mmcsd
device sdhci
device virtio
device virtio_pci
device vtnet
device virtio_blk
device virtio_scsi
device virtio_balloon
device hyperv
device xenpci
device vmx
device lagg
ddb capture buffer
ddb: ddb_capture: kvm_nlist
Поиски по форуму внятного ответа не дают, может кто то сталкивался и решил проблему?
Если потребуется дополнительная информация из дампа - пишите, спасибо за любую помощь.
Edited by nearia
cpu
hw.machine: amd64
hw.model: Intel(R) Xeon(R) CPU E5-2420 0 @ 1.90GHz
hw.ncpu: 6
hw.machine_arch: amd64
память
hw.physmem: 8535035904
loader.conf
net.link.lagg.0.use_flowid=0
sysctl.conf изменений не вносил
Топикстартер, а вы конфиг еще с 7.0 за собой таскаете или просто любите устаревшие/нонпродакшен опции? Соберите настоящий GENERIC для начала, без этих чудесных никому не нужных опций, а потом уже будем искать причины.
Может сможете привести пример?
поллинг - деприкейтед, не нужен вообще
radix_mpath - вообще не нужен трижды
вписывать руками остальную кучу опций давно нет необходимости, модулями есть все.
А если хотите знать более глубже, пожалуйста: сейчас идет активно переделка кода лукапа, и нерабочий до этого mpath более рабочим никто не сделал. Поллинг с момента выхода поддержки MSI-X никто не патчит и никто за ним не следит. Он давно уже не рабочий, блокировки в нем никто не правит, он даже в текущую модель-то не вписывается.
В общем собирайте нормальный генерик, а то не ясно вызваны ли трапы одной из устаревших функций или же это железное.
  • 2 weeks later...
Ядро пересобрано, результат пока такой :
kernel panic
instruction pointer = 0x20:0xffffffff81a4dc76
stack pointer = 0x28:0xfffffe00f63710e0
frame pointer = 0x28:0xfffffe00f6371170
current process = 12 (irq264: igb0:que 0)
trap number = 18
cpuid = 0
#0 0xffffffff8095e880 at kdb_backtrace+0x60
#1 0xffffffff809239a5 at panic+0x155
#2 0xffffffff80cfdbbf at trap_fatal+0x38f
#3 0xffffffff80cfd81c at trap+0x75c
#4 0xffffffff80ce3422 at calltrap+0x8
#5 0xffffffff81a4d45f at ng_bpf_rcvdata+0x8f
#6 0xffffffff81a1b0ca at ng_apply_item+0x21a
#7 0xffffffff81a1ad1a at ng_snd_item+0x38a
#8 0xffffffff81a1b0ca at ng_apply_item+0x21a
#9 0xffffffff81a1ad1a at ng_snd_item+0x38a
#10 0xffffffff81a1b0ca at ng_apply_item+0x21a
#11 0xffffffff81a1ad1a at ng_snd_item+0x38a
#12 0xffffffff81a3c1c8 at ng_ppp_comp_recv+0x148
#13 0xffffffff81a1b0ca at ng_apply_item+0x21a
#14 0xffffffff81a1ad1a at ng_snd_item+0x38a
#15 0xffffffff81a1b0ca at ng_apply_item+0x21a
#16 0xffffffff81a1ad1a at ng_snd_item+0x38a
#17 0xffffffff81a2fa6c at ng_pppoe_rcvdata_ether+0x27c
Uptime: 6d1h20m4s
kernel conf:
ident GENERIC
machine amd64
cpu HAMMER
options DUMMYNET
options IPDIVERT
options IPFIREWALL
options XENHVM
options USB_DEBUG
options ATH_ENABLE_11N
options AH_AR5416_INTERRUPT_MITIGATION
options AH_SUPPORT_AR5416
options IEEE80211_SUPPORT_MESH
options IEEE80211_AMPDU_AGE
options IEEE80211_DEBUG
options VESA
options ACPI_DMAR
options SMP
options KDB_TRACE
options KDB
options DDB_CTF
options MAC
options PROCDESC
options AUDIT
options HWPMC_HOOKS
options SYSVSEM
options SYSVMSG
options SYSVSHM
options STACK
options KTRACE
options GEOM_LABEL
options GEOM_RAID
options PSEUDOFS
options PROCFS
options CD9660
options MSDOSFS
options NFS_ROOT
options NFSLOCKD
options NFSD
options NFSCL
options MD_ROOT
options QUOTA
options UFS_DIRHASH
options UFS_ACL
options SOFTUPDATES
options FFS
options SCTP
options TCP_OFFLOAD
options INET
options PREEMPTION
options SCHED_ULE
options NEW_PCIB
device isa
device mem
device io
device uart_ns8250
device cpufreq
device acpi
device pci
device fdc
device ahci
device ata
device mvs
device siis
device ahc
device ahd
device esp
device hptiop
device isp
device mpt
device mps
device mpr
device sym
device trm
device adv
device adw
device aic
device bt
device isci
device scbus
device ch
device da
device sa
device cd
device pass
device ses
device amr
device arcmsr
device ciss
device dpt
device hptmv
device hptnr
device hptrr
device hpt27xx
device iir
device ips
device mly
device twa
device tws
device aac
device aacp
device aacraid
device ida
device mfi
device mlx
device mrsas
device twe
device atkbdc
device atkbd
device psm
device kbdmux
device vga
device splash
device sc
device vt
device vt_vga
device vt_efifb
device agp
device cbb
device pccard
device cardbus
device uart
device ppc
device ppbus
device lpt
device ppi
device puc
device bxe
device de
device em
device igb
device ixgbe
device ixl
device ixlv
device le
device ti
device txp
device vx
device miibus
device ae
device age
device alc
device ale
device bce
device bfe
device bge
device cas
device dc
device et
device fxp
device gem
device hme
device jme
device lge
device msk
device nfe
device nge
device pcn
device re
device rl
device sf
device sge
device sis
device sk
device ste
device stge
device tl
device tx
device vge
device vr
device wb
device xl
device cs
device ed
device ex
device ep
device fe
device sn
device xe
device wlan
device wlan_wep
device wlan_ccmp
device wlan_tkip
device wlan_amrr
device an
device ath
device ath_pci
device ath_hal
device ath_rate_sample
device ipw
device iwi
device iwn
device malo
device mwl
device ral
device wi
device wpi
device loop
device random
device padlock_rng
device rdrand_rng
device ether
device vlan
device tun
device md
device gif
device faith
device firmware
device bpf
device uhci
device ohci
device ehci
device xhci
device usb
device ukbd
device umass
device sound
device snd_cmi
device snd_csa
device snd_emu10kx
device snd_es137x
device snd_hda
device snd_ich
device snd_via8233
device mmc
device mmcsd
device sdhci
device virtio
device virtio_pci
device vtnet
device virtio_blk
device virtio_scsi
device hyperv
device xenpci
device vmx
device lagg
  • 2 weeks later...
Явным способом используется ng_bpf?
Пакетов не сортируем.
Вероятно надо все же поглядеть что вы делаете в netgraph.
# kldstat
Id Refs Address Size Name
1 32 0xffffffff80200000 1728a70 kernel
2 1 0xffffffff81a11000 357f ums.ko
3 1 0xffffffff81a15000 3821 ng_socket.ko
4 12 0xffffffff81a19000 b998 netgraph.ko
5 1 0xffffffff81a25000 2b99 ng_mppc.ko
6 1 0xffffffff81a28000 80d rc4.ko
7 1 0xffffffff81a29000 40a7 ng_ether.ko
8 1 0xffffffff81a2e000 4686 ng_pppoe.ko
9 1 0xffffffff81a33000 17d7 ng_tee.ko
10 1 0xffffffff81a35000 4052 ng_iface.ko
11 1 0xffffffff81a3a000 5817 ng_ppp.ko
12 1 0xffffffff81a40000 5f03 ng_netflow.ko
13 1 0xffffffff81a46000 4aaf ng_ksocket.ko
14 1 0xffffffff81a4b000 18b0 ng_tcpmss.ko
15 1 0xffffffff81a4d000 2952 ng_bpf.ko
16 1 0xffffffff81a50000 22b9 ng_car.ko
ng_bpf - поди где то деление на ноль или ещё что то недозволительное в арифметике.
Не подскажете как с этим бороться?
Edited by nearia
После выполнения команды сервер за 3 часа нарисовал файл с прямой линией, в ngctl.dot 240000 строк, есть ещё вывод ngctl list он не подойдёт?
На сервере более 1500 сессий PPPoe, graphviz вообще в состоянии такое нарисовать , или что я мог не правильно сделать?
С одной стороны я не очень понимаю зачем mpd линкует везде bpf, да еще с кучей хуков. Фильтрация?
С другой же 15 тысяч строк как-то не нормально, вы не находите? Где-то что-то протекло в нетграфе, вероятно.
Да, адреса поделены на внешние и локальные, другой какой то выборки нет.
Затрудняюсь ответить на этот вопрос , так как впервые с этим сталкиваюсь и не имею представления сколько будет "нормально" для такого количества соединений.
