Konstantin Z
Пользователи
  • Публикации
    4
  • Зарегистрирован
  • Посещение
Все публикации пользователя Konstantin Z
  1. пробовали отключить alg вовсе. set secur alg disable commit вернее set secur alg h323 disable у меня на примере с DNS и RTSP хорошо помогло
  2. Есть вероятность, что самопроизвольные перезагрузки пофиксены. В 3.7.2 уже внесут исправления.
  3. Занимаемся с TACом с такой же проблемой. Появится, что новенькое отпишу.
  4. Даже на 3.7 есть такие баги. CSCth00248 SCE might reload during a policy apply operation. This was observed on rare occasions in Release 3.5.5 in SCE 2000 and SCE8000. This Could not be reproduced. Workaround: None CSCth82235 The SCE 8000 reboots occasionally without supplying a cause or reason in the log files. SCE8000 might reboot without leaving any explanation in the logs Symptom: SCE8000 Reboots unexpectedly without leaving any explanations in either the user-log or debug-log Still, there's something in common for all these reboots which can be checked by a TAC engineer through SCE support file analysis. Conditions: The problem is only applicable for SCE8000 and so far was only observed with version 3.5.5. Workaround: None There's some potential that the problem wouldn't happen with 3.6.0 (this is only based on the fact that all reported events where happening with SCOS version 3.5.5) Additional Information The SCE development team has no way to investigate the root cause of these reboots due to the following reasons: 1) There is no way to have a repeatable reproduction scenario of the problem 2) There are no stack traces written to the logs when the problem occurs. Therefore, the development team also submitted additional defect to ensure getting stack traces for such events in future versions, the defect ID for this requirement is CSCth07363 in case where the problem will reoccur after the implementation of CSCth07363, development team should have sufficient data to find the root cause and fix the problem. Не пробовали посмотреть, что шлёт SM перед ребутом? что выполняется?
