Даже на 3.7 есть такие баги.
CSCth00248
SCE might reload during a policy apply operation. This was observed on rare occasions in Release 3.5.5 in SCE 2000 and SCE8000. This Could not be reproduced.
Workaround: None
CSCth82235
The SCE 8000 reboots occasionally without supplying a cause or reason in the log files.
SCE8000 might reboot without leaving any explanation in the logs
Symptom:
SCE8000 Reboots unexpectedly without leaving any explanations in either the
user-log or debug-log
Still, there's something in common for all these reboots which can be checked
by a TAC engineer through SCE support file analysis.
Conditions:
The problem is only applicable for SCE8000 and so far was only observed with
version 3.5.5.
Workaround:
None
There's some potential that the problem wouldn't happen with 3.6.0
(this is only based on the fact that all reported events where happening with
SCOS version 3.5.5)
Additional Information
The SCE development team has no way to investigate the root cause of these
reboots due to the following reasons:
1) There is no way to have a repeatable reproduction scenario of the problem
2) There are no stack traces written to the logs when the problem occurs.
Therefore, the development team also submitted additional defect to ensure
getting stack traces for such events in future versions, the defect ID for this
requirement is CSCth07363
in case where the problem will reoccur after the implementation of CSCth07363,
development team should have sufficient data to find the root cause and fix the
problem.
Не пробовали посмотреть, что шлёт SM перед ребутом? что выполняется?
